[Liblas-commits] r1271 - in trunk: include/liblas src
liblas-commits at liblas.org
Mon Jun 8 21:52:13 EDT 2009
Author: hobu
Date: Tue May 19 16:24:50 2009
New Revision: 1271
URL: http://liblas.org/changeset/1271
more refactoring, still not close to done though
trunk/include/liblas/lasindex.hpp
trunk/src/lasindex.cpp
Modified: trunk/include/liblas/lasindex.hpp
--- trunk/include/liblas/lasindex.hpp (original)
+++ trunk/include/liblas/lasindex.hpp Tue May 19 16:24:50 2009
@@ -62,6 +62,12 @@
public:
+ enum IndexType
+ eMemoryIndex = 1, ///< A transient memory index that will go away
+ eVLRIndex = 2, ///< An index that will store its data in VLR records
+ eExternalIndex = 3 ///< An index that will store its data in files alongside the .las file (.las.dat & .las.idx)
LASIndex();
LASIndex(LASDataStream& strm, std::string& filename);
@@ -76,18 +82,50 @@
/// Comparison operator.
bool operator==(const LASIndex& other) const;
- SpatialIndex::ISpatialIndex& index() {return *m_rtree;}
void insert(LASPoint& p, int64_t id);
std::vector<uint32_t>* intersects(double minx, double miny, double maxx, double maxy, double minz, double maxz);
+ /// Sets the page size for the index when stored externally
+ /// \param v - page value. Defaults to 4096.
+ void SetPageSize(uint32_t v) { m_Pagesize = v; }
+ /// Get index page size for indexes that are stored externally
+ /// \return index page size.
+ uint32_t GetPageSize() { return m_Pagesize; }
+ /// Sets the index type
+ /// \param v - index type.
+ void SetIndexType(IndexType v) { m_idxType = v; }
+ /// Gets the index type
+ /// \return index type.
+ IndexType GetIndexType() { return m_idxType; }
private:
SpatialIndex::IStorageManager* m_storage;
SpatialIndex::StorageManager::IBuffer* m_buffer;
SpatialIndex::ISpatialIndex* m_rtree;
- std::string m_indexname;
+ uint32_t m_Pagesize;
+ IndexType m_idxType;
+ SpatialIndex::id_type m_idxId;
+ uint32_t m_idxCapacity;
+ uint32_t m_idxLeafCap;
+ uint32_t m_idxDimension;
+ double m_idxFillFactor;
+ bool m_idxExternalExists;
+ uint16_t m_bufferCapacity;
+ bool m_bufferWriteThrough;
void Init();
+ SpatialIndex::IStorageManager* CreateStorage(std::string& filename);
+ SpatialIndex::StorageManager::IBuffer* CreateIndexBuffer(SpatialIndex::IStorageManager& storage);
+ bool ExternalIndexExists(std::string& filename);
class LASVisitor : public SpatialIndex::IVisitor
Modified: trunk/src/lasindex.cpp
--- trunk/src/lasindex.cpp (original)
+++ trunk/src/lasindex.cpp Tue May 19 16:24:50 2009
@@ -54,107 +54,168 @@
namespace liblas
+void LASIndex::Init()
+ m_Pagesize = 4096;
+ m_idxType = eExternalIndex;
+ m_idxId = 1;
+ m_idxCapacity = 100;
+ m_idxLeafCap = 100;
+ m_idxDimension = 3;
+ m_idxFillFactor = 0.7;
+ m_bufferCapacity = 10;
+ m_bufferWriteThrough = false;
+ m_idxExternalExists = false;
LASIndex::LASIndex()
std::cout << "Blank Index Constructor called!" << std::endl;
- // m_storage = createNewLASStorageManager();
- // Init();
+ Init();
LASIndex::LASIndex(LASDataStream& strm, std::string& filename)
+ using namespace SpatialIndex;
+ Init();
+ m_storage = CreateStorage(filename);
+ m_buffer = CreateIndexBuffer(*m_storage);
- struct stat stats;
- std::ostringstream os;
- os << filename << ".dat";
- std::cout << "LASDataStream index name: " << os.str() << std::endl;
- std::string indexname = os.str();
- int ret = stat(indexname.c_str(),&stats);
- if (!ret) {
- std::cout << "loading existing index from LASReader " << indexname << std::endl;
+ if (m_idxType == eExternalIndex) {
+ if (m_idxExternalExists == true) {
+ std::cout << "loading existing index from LASDataStream " << std::endl;
try{
- m_storage = SpatialIndex::StorageManager::loadDiskStorageManager(filename);
- } catch (Tools::IllegalStateException& e) {
- std::string s = e.what();
- std::cout << "error loading index " << s <<std::endl; exit(1);
+ m_rtree = SpatialIndex::RTree::loadRTree(*m_buffer,m_idxId);
+ } catch (Tools::Exception& e) {
+ std::ostringstream os;
+ os << "Spatial Index Error: " << e.what();
+ throw std::runtime_error(os.str());
- Init();
else
- std::cout << "Creating new index from LASReader stream ... " << std::endl;
+ std::cout << "Creating new index from LASDataStream ... " << std::endl;
try{
- m_storage = SpatialIndex::StorageManager::createNewDiskStorageManager(filename, 4096);
- uint16_t capacity = 10;
- bool writeThrough = false;
- // R-Tree parameters
- double fillFactor = 0.7;
- uint32_t indexCapacity = 100;
- uint32_t leafCapacity = 100;
- uint32_t dimension = 3;
- SpatialIndex::id_type indexId=1;
- m_buffer = SpatialIndex::StorageManager::createNewRandomEvictionsBuffer(*m_storage, capacity, writeThrough);
- m_rtree = SpatialIndex::RTree::createAndBulkLoadNewRTree( SpatialIndex::RTree::BLM_STR,
- strm,
- *m_buffer,
- fillFactor,
- indexCapacity,
- leafCapacity,
- dimension,
- SpatialIndex::RTree::RV_RSTAR,
- indexId);
+ m_rtree = RTree::createAndBulkLoadNewRTree( SpatialIndex::RTree::BLM_STR,
+ strm,
+ *m_buffer,
+ m_idxFillFactor,
+ m_idxCapacity,
+ m_idxLeafCap,
+ m_idxDimension,
+ SpatialIndex::RTree::RV_RSTAR,
+ m_idxId);
bool ret = m_rtree->isIndexValid();
- if (ret == false) std::cerr << "ERROR: Structure is invalid!" << std::endl;
- std::cout << index() << std::endl;
+ if (ret == false)
+ throw std::runtime_error( "Spatial index error: index is not"
+ " valid after createAndBulkLoadNewRTree");
- std::cout << "error creating index" << s <<std::endl; exit(1);
+ } // eExternalIndex
-void LASIndex::Init()
- // // R-Tree parameters
- // double fillFactor = 0.7;
- // uint32_t indexCapacity = 100;
- // uint32_t leafCapacity = 100;
- // uint32_t dimension = 3;
- // SpatialIndex::RTree::RTreeVariant variant = SpatialIndex::RTree::RV_RSTAR;
- // // create R-tree
- m_rtree = SpatialIndex::RTree::loadRTree(*m_buffer,indexId);
- std::cout << "index is valid? " << m_rtree->isIndexValid() << std::endl;
- // m_rtree = SpatialIndex::RTree::createNewRTree(*m_buffer, fillFactor, indexCapacity,
- // leafCapacity, dimension, variant, indexId);
+SpatialIndex::IStorageManager* LASIndex::CreateStorage(std::string& filename)
+ using namespace SpatialIndex::StorageManager;
+ SpatialIndex::IStorageManager* storage = 0;
+ if (ExternalIndexExists(filename) && !filename.empty()) {
+ std::cout << "loading existing DiskStorage " << filename << std::endl;
+ try{
+ storage = loadDiskStorageManager(filename);
+ m_idxExternalExists = true;
+ return storage;
+ } else if (!filename.empty()){
+ try{
+ std::cout << "creating new DiskStorage " << filename << std::endl;
+ storage = createNewDiskStorageManager(filename, m_Pagesize);
+ return storage;
+ return storage;
+SpatialIndex::StorageManager::IBuffer* LASIndex::CreateIndexBuffer(SpatialIndex::IStorageManager& storage)
+ IBuffer* buffer = 0;
+ try{
+ if ( m_storage == 0 ) throw std::runtime_error("Storage was invalid to create index buffer");
+ buffer = createNewRandomEvictionsBuffer(storage,
+ m_bufferCapacity,
+ m_bufferWriteThrough);
+ return buffer;
-LASIndex::LASIndex(std::string& filename)
+bool LASIndex::ExternalIndexExists(std::string& filename)
- // FIXME: This is not C, no need for struct.
- // FIXME: stat is very weak name! There tons of structs in various C libs (ie. struct stat; in Windows C lib)
struct stat stats;
- std::cout << "index name: " << os.str() << std::endl;
+ if (m_idxExternalExists == true) return true;
- if (!ret) {
- std::cout << "loading existing index " << indexname << std::endl;
+ std::cout << "indexname: " << indexname << " ret: " << ret << std::endl;
+ bool output = false;
+ if (ret == 0) output= true; else output =false;
+ return output;
+LASIndex::LASIndex(std::string& filename)
+ Init();
+ if (ExternalIndexExists(filename)) {
+ std::cout << "loading existing index " << filename << std::endl;
try{
+ // m_storage = SpatialIndex::StorageManager::loadDiskStorageManager(filename);
+ // m_buffer = SpatialIndex::StorageManager::createNewRandomEvictionsBuffer(*m_storage,
+ // m_bufferCapacity,
+ // m_bufferWriteThrough);
else{std::cout << "index name does not exist, failing" << std::endl;exit(1);}
@@ -168,8 +229,6 @@
// std::cout << "error creating index" << s <<std::endl; exit(1);
- Init();
LASIndex::LASIndex(LASIndex const& other)
More information about the Liblas-commits
