[Liblas-commits] r1272 - in trunk: apps include/liblas src
liblas-commits at liblas.org
Mon Jun 8 21:52:13 EDT 2009
Author: hobu
Date: Wed May 20 11:26:05 2009
New Revision: 1272
URL: http://liblas.org/changeset/1272
more refactoring, still not done
trunk/apps/lasindex.cpp
trunk/include/liblas/lasindex.hpp
trunk/src/lasindex.cpp
Modified: trunk/apps/lasindex.cpp
--- trunk/apps/lasindex.cpp (original)
+++ trunk/apps/lasindex.cpp Wed May 20 11:26:05 2009
@@ -143,7 +143,32 @@
std::cout << "Vec length" << ids->size() << std::endl;
delete idx;
+ LASDataStream* idxstrm = new LASDataStream(reader);
+ LASIndex* index = new LASIndex(*idxstrm, "MEMORY");
+ //doing it in memory
+ std::vector<liblas::uint32_t>* ids = 0;
+ try{
+// ids = idx->intersects(289815.12,4320979.06, 289818.01,4320982.59,46.83,170.65);
+// _zoom
+// ids = idx->intersects(630355.0,4834609.0,630395.0,4834641.0,0.0,200.0);
+// _clip
+// 630346.830000,4834500.000000,55.260000
+ ids = index->intersects(630262.300000,4834500.000000,630346.830000,4834500.000000,50.900000,55.260000);
+// ids = idx->intersects(630297.0,4834497.0,630302.0,4834501.0,0.0,200.0);
+ } catch (Tools::Exception& e) {
+ std::string s = e.what();
+ std::cout << "error querying index value" << s <<std::endl; exit(1);
// LASPoint* p
// liblas::uint32_t num_points = reader->GetHeader().GetPointRecordsCount();
// for (int i =0; i < num_points ; i++) {
Modified: trunk/include/liblas/lasindex.hpp
--- trunk/include/liblas/lasindex.hpp (original)
+++ trunk/include/liblas/lasindex.hpp Wed May 20 11:26:05 2009
@@ -115,7 +115,7 @@
uint32_t m_idxLeafCap;
uint32_t m_idxDimension;
double m_idxFillFactor;
- bool m_idxExternalExists;
+ bool m_idxExists;
uint16_t m_bufferCapacity;
@@ -124,7 +124,8 @@
void Init();
SpatialIndex::IStorageManager* CreateStorage(std::string& filename);
SpatialIndex::StorageManager::IBuffer* CreateIndexBuffer(SpatialIndex::IStorageManager& storage);
+ SpatialIndex::ISpatialIndex* CreateIndex(LASDataStream& strm);
+ SpatialIndex::ISpatialIndex* LoadIndex();
bool ExternalIndexExists(std::string& filename);
Modified: trunk/src/lasindex.cpp
--- trunk/src/lasindex.cpp (original)
+++ trunk/src/lasindex.cpp Wed May 20 11:26:05 2009
@@ -70,7 +70,7 @@
m_bufferCapacity = 10;
m_bufferWriteThrough = false;
- m_idxExternalExists = false;
+ m_idxExists = false;
LASIndex::LASIndex()
@@ -79,7 +79,55 @@
Init();
+SpatialIndex::ISpatialIndex* LASIndex::CreateIndex(LASDataStream& strm)
+ using namespace SpatialIndex;
+ ISpatialIndex* index = 0;
+ try{
+ index = RTree::createAndBulkLoadNewRTree( SpatialIndex::RTree::BLM_STR,
+ strm,
+ *m_buffer,
+ m_idxFillFactor,
+ m_idxCapacity,
+ m_idxLeafCap,
+ m_idxDimension,
+ SpatialIndex::RTree::RV_RSTAR,
+ m_idxId);
+ bool ret = index->isIndexValid();
+ if (ret == false)
+ throw std::runtime_error( "Spatial index error: index is not"
+ " valid after createAndBulkLoadNewRTree");
+ return index;
+ std::ostringstream os;
+ os << "Spatial Index Error: " << e.what();
+ throw std::runtime_error(os.str());
+SpatialIndex::ISpatialIndex* LASIndex::LoadIndex()
+ try{
+ index = RTree::loadRTree(*m_buffer,m_idxId);
+ if (ret == false)
+ " valid after loadRTree");
+ return index;
LASIndex::LASIndex(LASDataStream& strm, std::string& filename)
@@ -89,42 +137,15 @@
m_storage = CreateStorage(filename);
m_buffer = CreateIndexBuffer(*m_storage);
- if (m_idxType == eExternalIndex) {
- if (m_idxExternalExists == true) {
+ if (m_idxExists == true) {
std::cout << "loading existing index from LASDataStream " << std::endl;
- try{
- m_rtree = SpatialIndex::RTree::loadRTree(*m_buffer,m_idxId);
- } catch (Tools::Exception& e) {
- std::ostringstream os;
- os << "Spatial Index Error: " << e.what();
- throw std::runtime_error(os.str());
+ m_rtree = LoadIndex();
else
std::cout << "Creating new index from LASDataStream ... " << std::endl;
- try{
- m_rtree = RTree::createAndBulkLoadNewRTree( SpatialIndex::RTree::BLM_STR,
- strm,
- *m_buffer,
- m_idxFillFactor,
- m_idxCapacity,
- m_idxLeafCap,
- m_idxDimension,
- SpatialIndex::RTree::RV_RSTAR,
- m_idxId);
- bool ret = m_rtree->isIndexValid();
- if (ret == false)
- throw std::runtime_error( "Spatial index error: index is not"
- " valid after createAndBulkLoadNewRTree");
+ m_rtree = CreateIndex(strm);
- } // eExternalIndex
@@ -139,7 +160,7 @@
std::cout << "loading existing DiskStorage " << filename << std::endl;
try{
storage = loadDiskStorageManager(filename);
- m_idxExternalExists = true;
+ m_idxExists = true;
return storage;
@@ -150,7 +171,7 @@
try{
std::cout << "creating new DiskStorage " << filename << std::endl;
storage = createNewDiskStorageManager(filename, m_Pagesize);
return storage;
@@ -158,6 +179,19 @@
+ } else if (m_idxType == eMemoryIndex) {
+ try{
+ std::cout << "creating new DiskStorage " << filename << std::endl;
+ storage = createNewMemoryStorageManager();
+ return storage;
return storage;
@@ -186,15 +220,19 @@
os << filename << ".dat";
- if (m_idxExternalExists == true) return true;
+ // if we have already checked, we're done.
+ if (m_idxExists == true) return true;
std::string indexname = os.str();
+ // ret is -1 for no file existing and 0 for existing
int ret = stat(indexname.c_str(),&stats);
- std::cout << "indexname: " << indexname << " ret: " << ret << std::endl;
bool output = false;
if (ret == 0) output= true; else output =false;
return output;
LASIndex::LASIndex(std::string& filename)
@@ -204,31 +242,15 @@
- if (ExternalIndexExists(filename)) {
- std::cout << "loading existing index " << filename << std::endl;
- try{
- // m_storage = SpatialIndex::StorageManager::loadDiskStorageManager(filename);
- // m_buffer = SpatialIndex::StorageManager::createNewRandomEvictionsBuffer(*m_storage,
- // m_bufferCapacity,
- // m_bufferWriteThrough);
+ std::cout << "loading existing index from file " << std::endl;
- else{std::cout << "index name does not exist, failing" << std::endl;exit(1);}
- // else
- // std::cout << "Creating new index ... " << std::endl;
- // try{
- // m_storage = SpatialIndex::StorageManager::createNewDiskStorageManager(filename, 4096);
- // } catch (Tools::IllegalStateException& e) {
- // std::string s = e.what();
- // std::cout << "error creating index" << s <<std::endl; exit(1);
+ else
+ throw std::runtime_error("can't create index with only a filename, must have LASDatastream");
LASIndex::LASIndex(LASIndex const& other)
More information about the Liblas-commits
