[Liblas-commits] r1270 - in trunk: apps include/liblas src
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jun 8 21:52:13 EDT 2009
Author: hobu
Date: Mon May 18 22:16:17 2009
New Revision: 1270
URL: http://liblas.org/changeset/1270
bulk index loading now works, need to refine
   trunk/apps/lasindex.cpp
   trunk/include/liblas/lasindex.hpp
   trunk/src/lasindex.cpp
Modified: trunk/apps/lasindex.cpp
--- trunk/apps/lasindex.cpp	(original)
+++ trunk/apps/lasindex.cpp	Mon May 18 22:16:17 2009
@@ -130,17 +130,20 @@
 //        ids = idx->intersects(630355.0,4834609.0,630395.0,4834641.0,0.0,200.0);
 // _clip
-       ids = idx->intersects(630297.0,4834497.0,630302.0,4834501.0,0.0,200.0);
+// 630346.830000,4834500.000000,55.260000
+        ids = idx->intersects(630262.300000,4834500.000000,630346.830000,4834500.000000,50.900000,55.260000);
+//       ids = idx->intersects(630297.0,4834497.0,630302.0,4834501.0,0.0,200.0);
-    } catch (Tools::IllegalArgumentException& e) {
+    } catch (Tools::Exception& e) {
         std::string s = e.what();
         std::cout << "error querying index value" << s <<std::endl; exit(1);
+    std::cout << "Vec length" << ids->size() << std::endl;
     delete idx;
-    std::cout << "Vec length" << ids->size() << std::endl;
     // LASPoint* p
     // liblas::uint32_t num_points = reader->GetHeader().GetPointRecordsCount();
     // for (int i =0; i < num_points ; i++) {
Modified: trunk/include/liblas/lasindex.hpp
--- trunk/include/liblas/lasindex.hpp	(original)
+++ trunk/include/liblas/lasindex.hpp	Mon May 18 22:16:17 2009
@@ -92,48 +92,19 @@
 class LASVisitor : public SpatialIndex::IVisitor
-public:
-    // size_t m_indexIO;
-    // size_t m_leafIO;
+private:
+    size_t m_indexIO;
+    size_t m_leafIO;
     std::vector<uint32_t>* m_vector;
 public:
-    LASVisitor(std::vector<uint32_t>* vect){m_vector = vect;}
-    void visitNode(const SpatialIndex::INode& n)
-        //         std::cout << "visitNode" << std::endl;
-        // if (n.isLeaf()) m_leafIO++;
-        // else m_indexIO++;
+    LASVisitor(std::vector<uint32_t>* vect);
-    void visitData(const SpatialIndex::IData& d)
-        SpatialIndex::IShape* pS;
-        d.getShape(&pS);
-            // do something.
-        delete pS;
-        // data should be an array of characters representing a Region as a string.
-        uint8_t* pData = 0;
-        size_t cLen = 0;
-        d.getData(cLen, &pData);
-        // do something.
-        //string s = reinterpret_cast<char*>(pData);
-        //cout << s << endl;
-        delete[] pData;
-        // std::cout << d.getIdentifier() << std::endl;
-        m_vector->push_back(d.getIdentifier());
-            // the ID of this data entry is an answer to the query. I will just print it to stdout.
-    void visitData(std::vector<const SpatialIndex::IData*>& v)
-        std::cout << v[0]->getIdentifier() << " " << v[1]->getIdentifier() << std::endl;
+    void visitNode(const SpatialIndex::INode& n);
+    void visitData(const SpatialIndex::IData& d);
+    void visitData(std::vector<const SpatialIndex::IData*>& v);
 class LASDataStream : public SpatialIndex::IDataStream
Modified: trunk/src/lasindex.cpp
--- trunk/src/lasindex.cpp	(original)
+++ trunk/src/lasindex.cpp	Mon May 18 22:16:17 2009
@@ -58,8 +58,8 @@
 LASIndex::LASIndex()
     std::cout << "Blank Index Constructor called!" << std::endl;
-    m_storage = createNewLASStorageManager();
-    Init();
+    // m_storage = createNewLASStorageManager();
+    // Init();
 LASIndex::LASIndex(LASDataStream& strm, std::string& filename)
@@ -73,14 +73,14 @@
     std::string indexname = os.str();
     int ret = stat(indexname.c_str(),&stats);
     if (!ret) {
-        std::cout << "loading existing index " << indexname << std::endl;
+        std::cout << "loading existing index from LASReader " << indexname << std::endl;
         try{
             m_storage = SpatialIndex::StorageManager::loadDiskStorageManager(filename);
-            Init();
-        } catch (Tools::Exception& e) {
+        } catch (Tools::IllegalStateException& e) {
             std::cout << "error loading index " << s <<std::endl; exit(1);
+        Init();
     else
@@ -107,7 +107,7 @@
        indexId);
         bool ret = m_rtree->isIndexValid();
         if (ret == false) std::cerr << "ERROR: Structure is invalid!" << std::endl;
+        std::cout << index() << std::endl;
             std::cout << "error creating index" << s <<std::endl; exit(1);
@@ -119,18 +119,20 @@
     uint16_t capacity = 10;
     bool writeThrough = false;
     m_buffer = SpatialIndex::StorageManager::createNewRandomEvictionsBuffer(*m_storage, capacity, writeThrough);
-    // R-Tree parameters
-    double fillFactor = 0.7;
-    uint32_t indexCapacity = 100;
-    uint32_t leafCapacity = 100;
-    uint32_t dimension = 3;
-    SpatialIndex::RTree::RTreeVariant variant = SpatialIndex::RTree::RV_RSTAR;
-    // create R-tree
+    // // R-Tree parameters
+    // double fillFactor = 0.7;
+    // uint32_t indexCapacity = 100;
+    // uint32_t leafCapacity = 100;
+    // uint32_t dimension = 3;
+    // SpatialIndex::RTree::RTreeVariant variant = SpatialIndex::RTree::RV_RSTAR;
+    // // create R-tree
     SpatialIndex::id_type indexId=1;
-    m_rtree = SpatialIndex::RTree::createNewRTree(*m_buffer, fillFactor, indexCapacity,
-                                   leafCapacity, dimension, variant, indexId);
+    m_rtree = SpatialIndex::RTree::loadRTree(*m_buffer,indexId);
+    std::cout << "index is valid? " << m_rtree->isIndexValid() << std::endl;
+    // m_rtree = SpatialIndex::RTree::createNewRTree(*m_buffer, fillFactor, indexCapacity,
+    //                                leafCapacity, dimension, variant, indexId);
@@ -155,16 +157,17 @@
-    else
-        std::cout << "Creating new index ... " << std::endl;
-        try{
-            m_storage = SpatialIndex::StorageManager::createNewDiskStorageManager(filename, 4096);
-        } catch (Tools::IllegalStateException& e) {
-            std::string s = e.what();
-            std::cout << "error creating index" << s <<std::endl; exit(1);
+    else{std::cout << "index name does not exist, failing" << std::endl;exit(1);}
+    // else
+    //     std::cout << "Creating new index ... " << std::endl;
+    //     try{
+    //         m_storage = SpatialIndex::StorageManager::createNewDiskStorageManager(filename, 4096);
+    //     } catch (Tools::IllegalStateException& e) {
+    //         std::string s = e.what();
+    //         std::cout << "error creating index" << s <<std::endl; exit(1);
     Init();
@@ -179,9 +182,12 @@
     std::cout << "~LASIndex called" << std::endl;
-    delete m_rtree;
-    delete m_buffer;
-    delete m_storage;
+    if (m_rtree != 0)
+        delete m_rtree;
+    if (m_buffer != 0)
+        delete m_buffer;
+    if (m_storage != 0)
+        delete m_storage;
@@ -207,11 +213,17 @@
     double min[3];
     double max[3];
-    min[0] = p.GetX(); min[1] = p.GetY(); min[2] = p.GetZ();
-    max[0] = p.GetX(); max[1] = p.GetY(); max[2] = p.GetZ();
+    min[0] = p.GetX();
+    min[1] = p.GetY();
+    min[2] = p.GetZ();
+    max[0] = p.GetX();
+    max[1] = p.GetY();
+    max[2] = p.GetZ();
     try{
-        index().insertData(0, 0, SpatialIndex::Region(min, max, 3), id);
+        m_rtree->insertData(0, 0, SpatialIndex::Region(min, max, 3), id);
         std::cout << "error inserting index value" << s <<std::endl; exit(1);
@@ -222,8 +234,13 @@
     double min[3];
     double max[3];
-    min[0] = minx; min[1] = miny; min[2] = minz;
-    max[0] = maxx; max[1] = maxy; max[2] = maxz;
+    min[0] = minx;
+    min[1] = miny;
+    min[2] = minz;
+    max[0] = maxx;
+    max[1] = maxy;
+    max[2] = maxz;
     std::cout.setf(std::ios_base::fixed);
@@ -233,9 +250,9 @@
     LASVisitor* visitor = new LASVisitor(vect);
     const SpatialIndex::Region *region = new SpatialIndex::Region(min, max, 3);
-    std::cout << *region << std::endl;
-    index().intersectsWithQuery(*region, *visitor);
-    std::cout << index() <<std::endl;
+    // std::cout << *region << std::endl;
+    m_rtree->intersectsWithQuery(*region, *visitor);
+    // std::cout << index() <<std::endl;
     return vect;
@@ -376,7 +393,7 @@
     SpatialIndex::Region r = SpatialIndex::Region(min, max, 3);
     m_pNext = new SpatialIndex::RTree::Data(0, 0, r, m_id);
-     std::cout << "Read point " << r <<  "Id: " << m_id << std::endl;
+     // std::cout << "Read point " << r <<  "Id: " << m_id << std::endl;
     return true;
@@ -417,4 +434,42 @@
     readPoint();
+LASVisitor::LASVisitor(std::vector<uint32_t>* vect){m_vector = vect;}
+void LASVisitor::visitNode(const SpatialIndex::INode& n)
+            std::cout << "visitNode" << std::endl;
+    if (n.isLeaf()) m_leafIO++;
+    else m_indexIO++;
+void LASVisitor::visitData(const SpatialIndex::IData& d)
+    SpatialIndex::IShape* pS;
+    d.getShape(&pS);
+    SpatialIndex::Region *r = new SpatialIndex::Region();
+    pS->getMBR(*r);
+    std::cout <<"found shape: " << *r << " dimension: " <<pS->getDimension() << std::endl;
+        // do something.
+    delete pS;
+    // data should be an array of characters representing a Region as a string.
+    uint8_t* pData = 0;
+    size_t cLen = 0;
+    d.getData(cLen, &pData);
+    // do something.
+    //string s = reinterpret_cast<char*>(pData);
+    //cout << s << endl;
+    delete[] pData;
+     // std::cout << "found: " <<d.getIdentifier() << std::endl;
+    m_vector->push_back(d.getIdentifier());
+        // the ID of this data entry is an answer to the query. I will just print it to stdout.
+void LASVisitor::visitData(std::vector<const SpatialIndex::IData*>& v)
+    std::cout << v[0]->getIdentifier() << " " << v[1]->getIdentifier() << std::endl;
 } // namespace liblas
\ No newline at end of file
More information about the Liblas-commits mailing list
