[Liblas-commits] r1102 - trunk/test/unit
liblas-commits at liblas.org
Mon Mar 16 10:57:13 EDT 2009
Author: hobu
Date: Mon Mar 16 10:57:12 2009
New Revision: 1102
URL: http://liblas.org/changeset/1102
making mloskot proud by adding to the tests
Added:
trunk/test/unit/lassrs_test.cpp
- copied, changed from r1101, /trunk/test/unit/lasheader_test.cpp
trunk/test/unit/Makefile.am
trunk/test/unit/common.cpp
trunk/test/unit/laspoint_test.cpp
Modified: trunk/test/unit/Makefile.am
--- trunk/test/unit/Makefile.am (original)
+++ trunk/test/unit/Makefile.am Mon Mar 16 10:57:12 2009
@@ -25,9 +25,11 @@
laserror_test.cpp \
lasfile_test.cpp \
lasheader_test.cpp \
+ lassrs_test.cpp \
laspoint_test.cpp \
lasreader_iterator_test.cpp \
lasreader_test.cpp \
lasrecordheader_test.cpp \
laswriter_test.cpp \
liblas_test_suite.cpp
\ No newline at end of file
Modified: trunk/test/unit/common.cpp
--- trunk/test/unit/common.cpp (original)
+++ trunk/test/unit/common.cpp Mon Mar 16 10:57:12 2009
@@ -110,6 +110,13 @@
ensure_equals("wrong defualt time",
p.GetTime(), double(0));
+ ensure_equals("invalid default red color",
+ p.GetColor().GetRed(), 0);
+ ensure_equals("invalid default green color",
+ p.GetColor().GetGreen(), 0);
+ ensure_equals("invalid default blue color",
+ p.GetColor().GetBlue(), 0);
ensure("invalid defualt point record", p.IsValid());
Modified: trunk/test/unit/lasheader_test.cpp
--- trunk/test/unit/lasheader_test.cpp (original)
+++ trunk/test/unit/lasheader_test.cpp Mon Mar 16 10:57:12 2009
@@ -6,6 +6,7 @@
// http://www.opensource.org/licenses/bsd-license.php)
#include <liblas/lasheader.hpp>
+#include <liblas/lassrs.hpp>
#include <liblas/cstdint.hpp>
#include <liblas/guid.hpp>
#include <tut/tut.hpp>
@@ -281,5 +282,17 @@
+ // Test GetSRS
+ template<>
+ template<>
+ void to::test<12>()
+ liblas::LASHeader h;
+ liblas::LASSRS srs = h.GetSRS();
+ ensure_equals(srs.GetProj4(), "");
+ ensure_equals(srs.GetWKT(), "");
Modified: trunk/test/unit/laspoint_test.cpp
--- trunk/test/unit/laspoint_test.cpp (original)
+++ trunk/test/unit/laspoint_test.cpp Mon Mar 16 10:57:12 2009
@@ -6,6 +6,7 @@
#include <liblas/laspoint.hpp>
+#include <liblas/lascolor.hpp>
#include <liblas/exception.hpp>
#include <bitset>
@@ -366,5 +367,48 @@
ensure_not(p.IsValid());
+ // Test Get/SetColor
+ template<>
+ template<>
+ void to::test<16>()
+ m_default.GetColor().GetRed(), 0);
+ m_default.GetColor().GetGreen(), 0);
+ m_default.GetColor().GetBlue(), 0);
+ liblas::LASColor color;
+ color.SetRed(211);
+ color.SetGreen(211);
+ color.SetBlue(211);
+ m_default.SetColor(color);
+ ensure_equals("invalid set red color",
+ m_default.GetColor().GetRed(), 211);
+ ensure_equals("invalid set green color",
+ m_default.GetColor().GetGreen(), 211);
+ ensure_equals("invalid set blue color",
+ m_default.GetColor().GetBlue(), 211);
+ liblas::LASPoint p = m_default;
+ ensure_equals("invalid copied red color",
+ p.GetColor().GetRed(), 211);
+ ensure_equals("invalid copied green color",
+ p.GetColor().GetGreen(), 211);
+ ensure_equals("invalid copied blue color",
+ p.GetColor().GetBlue(), 211);
Copied: trunk/test/unit/lassrs_test.cpp (from r1101, /trunk/test/unit/lasheader_test.cpp)
--- /trunk/test/unit/lasheader_test.cpp (original)
+++ trunk/test/unit/lassrs_test.cpp Mon Mar 16 10:57:12 2009
@@ -5,7 +5,7 @@
// (See accompanying file LICENSE.txt or copy at
-#include <liblas/lasheader.hpp>
@@ -15,271 +15,272 @@
namespace tut
- struct lasheader_data
+ struct lassrs_data
- liblas::LASHeader m_default;
+ liblas::LASSRS m_default;
- typedef test_group<lasheader_data> tg;
+ typedef test_group<lassrs_data> tg;
typedef tg::object to;
- tg test_group_lasheader("liblas::LASHeader");
+ tg test_group_lassrs("liblas::LASSRS");
// Test default constructor
template<>
template<>
void to::test<1>()
- test_default_header(m_default);
+ ensure_equals(m_default.GetProj4(), "");
+ ensure_equals(m_default.GetWKT(), "");
- // Test copy constructor
- template<>
- template<>
- void to::test<2>()
- using liblas::LASHeader;
- LASHeader copy_of_default(m_default);
- test_default_header(copy_of_default);
- std::string sig("LASF and garbage");
- LASHeader h1;
- h1.SetFileSignature(sig);
- ensure_not(h1.GetFileSignature() == sig);
- ensure_equals(h1.GetFileSignature().size(), 4);
- ensure_equals(h1.GetFileSignature(), LASHeader::FileSignature);
- LASHeader h2(h1);
- ensure_not(h2.GetFileSignature() == sig);
- ensure_equals(h2.GetFileSignature().size(), 4);
- ensure_equals(h2.GetFileSignature(), LASHeader::FileSignature);
- // Test assignment operator
- template<>
- template<>
- void to::test<3>()
- LASHeader copy_of_default;
- copy_of_default = m_default;
- // Test Get/SetFileSignature
- template<>
- template<>
- void to::test<4>()
- LASHeader h1;
- LASHeader h2;
- h2 = h1;
- // Test Get/SetFileSourceId
- template<>
- template<>
- void to::test<5>()
- using liblas::uint16_t;
- uint16_t const id1 = 1;
- uint16_t const id2 = 65535;
- uint16_t const overflowed = 0;
- LASHeader h1;
- h1.SetFileSourceId(id1);
- ensure_equals(h1.GetFileSourceId(), id1);
- h1.SetFileSourceId(id2);
- ensure_equals(h1.GetFileSourceId(), id2);
-#ifdef _MSC_VER
-# pragma warning(push)
-# pragma warning(disable: 4305) // truncation from 'int' to 'liblas::uint16_t'
-# pragma warning(disable: 4309) // conditional expression is constant.
-#endif
- // Unsigned overflow
- // Likely compiler warning: truncation from int to liblas::uint16_t
- h1.SetFileSourceId(id2 + 1);
- ensure_equals(h1.GetFileSourceId(), overflowed);
-#ifdef _MSC_VER
-#endif
- // Test GetReserved
- template<>
- template<>
- void to::test<6>()
- liblas::LASHeader h;
- ensure_equals(h.GetReserved(), 0);
- // Test Set/GetProjectId
- template<>
- template<>
- void to::test<7>()
- std::string strid("030B4A82-1B7C-11CF-9D53-00AA003C9CB6");
- liblas::guid id(strid.c_str());
- h.SetProjectId(id);
- ensure_not(h.GetProjectId().is_null());
- ensure_equals(h.GetProjectId(), id);
- // Test handling minor/major version
- template<>
- template<>
- void to::test<8>()
- h.SetVersionMajor(1);
- h.SetVersionMinor(0);
- ensure_equals(h.GetVersionMajor(), 1);
- ensure_equals(h.GetVersionMinor(), 0);
- h.SetVersionMinor(1);
- ensure_equals(h.GetVersionMinor(), 1);
- try
- h.SetVersionMajor(2);
- ensure("std::out_of_range not thrown", false);
- catch (std::out_of_range const& e)
- ensure(e.what(), true);
- try
- h.SetVersionMinor(3);
- // Test Get/SetSystemId
- template<>
- template<>
- void to::test<9>()
- std::string sysid1("Short Sys Id"); // 12 bytes
- std::string::size_type const len1 = sysid1.size();
- std::string sysid2("Long System Identifier - XXX YYY"); // 32 bytes
- std::string::size_type const len2 = sysid2.size();
- LASHeader h;
- h.SetSystemId(sysid1);
- ensure_equals(h.GetSystemId(), sysid1);
- ensure_equals(h.GetSystemId().size(), len1);
- ensure_equals(h.GetSystemId(true).size(), 32);
- h.SetSystemId(sysid2);
- ensure_equals(h.GetSystemId(), sysid2);
- ensure_equals(h.GetSystemId().size(), len2);
- // Test Get/SetSoftwareId
- template<>
- template<>
- void to::test<10>()
- std::string softid1("Short Soft Id"); // 13 bytes
- std::string::size_type const len1 = softid1.size();
- std::string softid2("Long Software Identifier - XX YY"); // 32 bytes
- std::string::size_type const len2 = softid2.size();
- LASHeader h;
- h.SetSoftwareId(softid1);
- ensure_equals(h.GetSoftwareId(), softid1);
- ensure_equals(h.GetSoftwareId().size(), len1);
- ensure_equals(h.GetSoftwareId(true).size(), 32);
- h.SetSoftwareId(softid2);
- ensure_equals(h.GetSoftwareId(), softid2);
- ensure_equals(h.GetSoftwareId().size(), len2);
- // Test GetPointRecordsByReturnCount
- template<>
- template<>
- void to::test<11>()
- ensure_equals(h.GetPointRecordsByReturnCount().size(), 5);
- h.SetPointRecordsByReturnCount(0, 100);
- ensure_equals(h.GetPointRecordsByReturnCount().at(0), 100);
- h.SetPointRecordsByReturnCount(1, 101);
- ensure_equals(h.GetPointRecordsByReturnCount().at(1), 101);
- h.SetPointRecordsByReturnCount(2, 102);
- ensure_equals(h.GetPointRecordsByReturnCount().at(2), 102);
- h.SetPointRecordsByReturnCount(3, 103);
- ensure_equals(h.GetPointRecordsByReturnCount().at(3), 103);
- h.SetPointRecordsByReturnCount(4, 104);
- ensure_equals(h.GetPointRecordsByReturnCount().at(4), 104);
- try
- // 5 is out of range
- h.SetPointRecordsByReturnCount(5, 500);
+// // Test copy constructor
+// template<>
+// template<>
+// void to::test<2>()
+// using liblas::LASSRS;
+// LASSRS copy_of_default(m_default);
+// test_default_header(copy_of_default);
+// std::string sig("LASF and garbage");
+// LASHeader h1;
+// h1.SetFileSignature(sig);
+// ensure_not(h1.GetFileSignature() == sig);
+// ensure_equals(h1.GetFileSignature().size(), 4);
+// ensure_equals(h1.GetFileSignature(), LASHeader::FileSignature);
+// LASHeader h2(h1);
+// ensure_not(h2.GetFileSignature() == sig);
+// ensure_equals(h2.GetFileSignature().size(), 4);
+// ensure_equals(h2.GetFileSignature(), LASHeader::FileSignature);
+// // Test assignment operator
+// template<>
+// template<>
+// void to::test<3>()
+// using liblas::LASHeader;
+// LASHeader copy_of_default;
+// copy_of_default = m_default;
+// // Test Get/SetFileSignature
+// template<>
+// template<>
+// void to::test<4>()
+// LASHeader h1;
+// LASHeader h2;
+// h2 = h1;
+// // Test Get/SetFileSourceId
+// template<>
+// template<>
+// void to::test<5>()
+// using liblas::uint16_t;
+// uint16_t const id1 = 1;
+// uint16_t const id2 = 65535;
+// uint16_t const overflowed = 0;
+// LASHeader h1;
+// h1.SetFileSourceId(id1);
+// ensure_equals(h1.GetFileSourceId(), id1);
+// h1.SetFileSourceId(id2);
+// ensure_equals(h1.GetFileSourceId(), id2);
+// #ifdef _MSC_VER
+// # pragma warning(push)
+// # pragma warning(disable: 4305) // truncation from 'int' to 'liblas::uint16_t'
+// # pragma warning(disable: 4309) // conditional expression is constant.
+// #endif
+// // Unsigned overflow
+// // Likely compiler warning: truncation from int to liblas::uint16_t
+// h1.SetFileSourceId(id2 + 1);
+// ensure_equals(h1.GetFileSourceId(), overflowed);
+// #ifdef _MSC_VER
+// #endif
+// // Test GetReserved
+// template<>
+// template<>
+// void to::test<6>()
+// liblas::LASHeader h;
+// ensure_equals(h.GetReserved(), 0);
+// // Test Set/GetProjectId
+// template<>
+// template<>
+// void to::test<7>()
+// std::string strid("030B4A82-1B7C-11CF-9D53-00AA003C9CB6");
+// liblas::guid id(strid.c_str());
+// h.SetProjectId(id);
+// ensure_not(h.GetProjectId().is_null());
+// ensure_equals(h.GetProjectId(), id);
+// // Test handling minor/major version
+// template<>
+// template<>
+// void to::test<8>()
+// h.SetVersionMajor(1);
+// h.SetVersionMinor(0);
+// ensure_equals(h.GetVersionMajor(), 1);
+// ensure_equals(h.GetVersionMinor(), 0);
+// h.SetVersionMinor(1);
+// ensure_equals(h.GetVersionMinor(), 1);
+// try
+// h.SetVersionMajor(2);
+// ensure("std::out_of_range not thrown", false);
+// catch (std::out_of_range const& e)
+// ensure(e.what(), true);
+// try
+// h.SetVersionMinor(3);
+// // Test Get/SetSystemId
+// template<>
+// template<>
+// void to::test<9>()
+// std::string sysid1("Short Sys Id"); // 12 bytes
+// std::string::size_type const len1 = sysid1.size();
+// std::string sysid2("Long System Identifier - XXX YYY"); // 32 bytes
+// std::string::size_type const len2 = sysid2.size();
+// LASHeader h;
+// h.SetSystemId(sysid1);
+// ensure_equals(h.GetSystemId(), sysid1);
+// ensure_equals(h.GetSystemId().size(), len1);
+// ensure_equals(h.GetSystemId(true).size(), 32);
+// h.SetSystemId(sysid2);
+// ensure_equals(h.GetSystemId(), sysid2);
+// ensure_equals(h.GetSystemId().size(), len2);
+// // Test Get/SetSoftwareId
+// template<>
+// template<>
+// void to::test<10>()
+// std::string softid1("Short Soft Id"); // 13 bytes
+// std::string::size_type const len1 = softid1.size();
+// std::string softid2("Long Software Identifier - XX YY"); // 32 bytes
+// std::string::size_type const len2 = softid2.size();
+// LASHeader h;
+// h.SetSoftwareId(softid1);
+// ensure_equals(h.GetSoftwareId(), softid1);
+// ensure_equals(h.GetSoftwareId().size(), len1);
+// ensure_equals(h.GetSoftwareId(true).size(), 32);
+// h.SetSoftwareId(softid2);
+// ensure_equals(h.GetSoftwareId(), softid2);
+// ensure_equals(h.GetSoftwareId().size(), len2);
+// // Test GetPointRecordsByReturnCount
+// template<>
+// template<>
+// void to::test<11>()
+// ensure_equals(h.GetPointRecordsByReturnCount().size(), 5);
+// h.SetPointRecordsByReturnCount(0, 100);
+// ensure_equals(h.GetPointRecordsByReturnCount().at(0), 100);
+// h.SetPointRecordsByReturnCount(1, 101);
+// ensure_equals(h.GetPointRecordsByReturnCount().at(1), 101);
+// h.SetPointRecordsByReturnCount(2, 102);
+// ensure_equals(h.GetPointRecordsByReturnCount().at(2), 102);
+// h.SetPointRecordsByReturnCount(3, 103);
+// ensure_equals(h.GetPointRecordsByReturnCount().at(3), 103);
+// h.SetPointRecordsByReturnCount(4, 104);
+// ensure_equals(h.GetPointRecordsByReturnCount().at(4), 104);
+// try
+// // 5 is out of range
+// h.SetPointRecordsByReturnCount(5, 500);
More information about the Liblas-commits
