[Liblas-commits] r1118 - trunk/test/unit
liblas-commits at liblas.org
Thu Mar 19 20:35:48 EDT 2009
Author: mloskot
Date: Thu Mar 19 20:35:48 2009
New Revision: 1118
URL: http://liblas.org/changeset/1118
Fixed missing reset operation on reader when re-using it with iterators (#85).
trunk/test/unit/lasreader_iterator_test.cpp
Modified: trunk/test/unit/lasreader_iterator_test.cpp
--- trunk/test/unit/lasreader_iterator_test.cpp (original)
+++ trunk/test/unit/lasreader_iterator_test.cpp Thu Mar 19 20:35:48 2009
@@ -27,10 +27,10 @@
std::ifstream ifs_;
LASReader reader_;
- lasreader_iterator_data()
- : file10_(g_test_data_path + "//TO_core_last_clip.las"),
- ifs_(file10_.c_str(), std::ios::in | std::ios::binary),
- reader_(ifs_)
+ lasreader_iterator_data() :
+ file10_(g_test_data_path + "//TO_core_last_clip.las"),
+ ifs_(file10_.c_str(), std::ios::in | std::ios::binary),
+ reader_(ifs_)
@@ -205,11 +205,27 @@
lasreader_iterator::difference_type const d = std::distance(it, end);
ensure_equals(d, cnt);
+ // Test std::distance operation
+ template<>
+ template<>
+ void to::test<15>()
+ std::size_t a = std::distance(lasreader_iterator(reader_), lasreader_iterator());
+ // Reader state is set to "past-the-end-of-file"
+ // So, reset is needed
+ reader_.Reset();
+ std::size_t b = std::distance(lasreader_iterator(reader_), lasreader_iterator());
+ ensure_equals(a, b);
// Test std::advance operation
template<>
template<>
- void to::test<15>()
+ void to::test<16>()
lasreader_iterator it(reader_); // move to 1st point
@@ -223,7 +239,7 @@
// Test std::copy algorithm
template<>
template<>
- void to::test<16>()
+ void to::test<17>()
liblas::uint32_t const size = reader_.GetHeader().GetPointRecordsCount();
@@ -248,7 +264,7 @@
// Test std::count algorithm
template<>
template<>
- void to::test<17>()
+ void to::test<18>()
// Construct copy of 2nd point record from tested file
LASPoint pt;
@@ -274,22 +290,16 @@
// Test std::equal algorithm
template<>
template<>
- void to::test<18>()
+ void to::test<19>()
- // TODO - mloskot: Can not re-use the LASReader (object reader_) because libLAS does
- // not support reset operation yet. In order to reuse reader with mre than one iterator
- // we have to provide operation to reset reader (set internal pointer to beginning of LAS file, etc.).
- // So, here we reuse only file stream.
- //LASReader reader(ifs);
std::ifstream ifs(file10_.c_str(), std::ios::in | std::ios::binary);
+ LASReader reader(ifs);
// Copy LAS records to std::list based cache
typedef std::list<LASPoint> list_t;
typedef std::back_insert_iterator<list_t> inserter_t;
list_t cache;
- LASReader reader(ifs);
lasreader_iterator it(reader);
lasreader_iterator end;
ensure(it != end);
@@ -298,9 +308,11 @@
ensure_equals(cache.size(), reader.GetHeader().GetPointRecordsCount());
+ // Reset reader to the beginning of LAS file
+ reader.Reset();
// Compare LAS file with cache
ensure(it != end);
@@ -313,7 +325,7 @@
// Test std::find algorithm
template<>
template<>
- void to::test<19>()
+ void to::test<20>()
LASPoint pt;
@@ -340,7 +352,7 @@
// Test std::find_if algorithm
template<>
template<>
- void to::test<20>()
+ void to::test<21>()
@@ -355,7 +367,7 @@
// Test std::for_each algorithm
template<>
template<>
- void to::test<21>()
+ void to::test<22>()
@@ -374,4 +386,3 @@
ensure(lasbbox == bbox);
More information about the Liblas-commits
