[Liblas-commits] r1139 - trunk
liblas-commits at liblas.org
Wed Mar 25 05:56:16 EDT 2009
Author: mloskot
Date: Wed Mar 25 05:56:15 2009
New Revision: 1139
URL: http://liblas.org/changeset/1139
Fixed LF to CRLF in nmake.opt.
trunk/nmake.opt
Modified: trunk/nmake.opt
--- trunk/nmake.opt (original)
+++ trunk/nmake.opt Wed Mar 25 05:56:15 2009
@@ -1,104 +1,104 @@
-# $Id$
-# nmake.opt - main configuration file for NMAKE makefiles
-# Set BUILD_DEBUG balue to YES if you want to make debug build
-# and to prepare not optimized binaries.
-BUILD_DEBUG = NO
-# libLAS package settings
-LAS_LIB = liblas.lib
-LAS_DLL = liblas1.dll
-LAS_LIB_DLL = liblas_i.lib
-# only used for filenames of packages
-PACKAGE_VERSION = 1.2.0b3
-INCLUDES = -I$(LAS_ROOT)/include -I$(LAS_ROOT)/include/liblas/capi
-# GeoTIFF Support
-# Uncomment the folling line to build GeoTIFF support for reading and
-# writing LAS files with Coordinate Systems information.
-# comment out GEOTIFF_HOME if you are building against a GDAL source tree
-GEOTIFF_HOME=C:\osgeo4w
-!IFDEF GEOTIFF_HOME
-GEOTIFF_LIB = $(GEOTIFF_HOME)\lib\geotiff_i.lib
-GEOTIFF_INCLUDE = -I$(GEOTIFF_HOME)\include
-INCLUDES = $(INCLUDES) $(GEOTIFF_INCLUDE)
-!ENDIF
-# GDAL/OGR Support
-# Uncomment the folling line to build OGR support for
-# the las2ogr command
-#GDAL_HOME=C:\osgeo4w
-#USE_GDAL_SOURCE_TREE=YES
-#GDAL_HOME=C:\cvs\buildkit\gdal
-!IFDEF GDAL_HOME
-GDAL_LIB = $(GDAL_HOME)\lib\gdal_i.lib
-GDAL_INCLUDE = -I$(GDAL_HOME)\include
-!IF "$(USE_GDAL_SOURCE_TREE)" == "YES"
-GDAL_LIB = $(GDAL_HOME)\gdal_i.lib
-GDAL_INCLUDE = -I$(GDAL_HOME)\port -I$(GDAL_HOME)\frmts\gtiff\libgeotiff -I$(GDAL_HOME)\frmts\gtiff\libtiff -I$(GDAL_HOME)\ogr -I$(GDAL_HOME)\gcore
-GEOTIFF_INCLUDE = -I$(GEOTIFF_HOME)\frmts\gtiff\libgeotiff
-!ENDIF
-INCLUDES = $(INCLUDES) $(GDAL_INCLUDE)
-!ENDIF
-# End of GeoTIFF Support
-LAS_HOME=C:\cvs\liblas\trunk
-BINDIR=$(LAS_HOME)\bin
-OSGEO4W_DIR = $(LAS_HOME)\osgeo4w
-PYDLL_DIR = $(LAS_HOME)\python
-# Compilation flags for Release and Debug modes
-!IF "$(BUILD_DEBUG)" == "YES"
-OPTFLAGS= /nologo /MDd /EHsc /Z7 /W4 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /DDEBUG /D_DEBUG /Fd$(LAS_ROOT)\las.pdb
-LAS_LIB = liblas_d.lib
-LAS_DLL = liblas_d1.dll
-LAS_LIB_DLL = libl1as_i.lib
-!ELSE
-# You may need to remove /GR if you are statically linking libLAS
-OPTFLAGS=/nologo /MD /EHsc /Ox /GR /W3 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /DNDEBUG
-!ENDIF
-CFLAGS= $(OPTFLAGS) $(INCLUDES)
-CFLAGS = $(CFLAGS) /DHAVE_LIBGEOTIFF=1
-!ENDIF
-!IFDEF GDAL_HOME
-CFLAGS = $(CFLAGS) /DHAVE_GDAL=1
-!ENDIF
-!ENDIF
-# End of compilation flags settings
-# Compiler executable
-CC = cl.exe
-# Linker executable
-# - Dynamic-Linked Libraries
-# $(LINK) /dll
-# - Static Libraries (use of lib.exe wrapper is not portable, see VC++ Toolkit 2003)
-# $(LINK) /lib
-LINK = link.exe
-.c.obj:
- $(CC) $(CFLAGS) /c $*.c /Fo$*.obj
-.cpp.obj:
- $(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
+# $Id$
+# nmake.opt - main configuration file for NMAKE makefiles
+# Set BUILD_DEBUG balue to YES if you want to make debug build
+# and to prepare not optimized binaries.
+BUILD_DEBUG = NO
+# libLAS package settings
+LAS_LIB = liblas.lib
+LAS_DLL = liblas1.dll
+LAS_LIB_DLL = liblas_i.lib
+# only used for filenames of packages
+PACKAGE_VERSION = 1.2.0b3
+INCLUDES = -I$(LAS_ROOT)/include -I$(LAS_ROOT)/include/liblas/capi
+# GeoTIFF Support
+# Uncomment the folling line to build GeoTIFF support for reading and
+# writing LAS files with Coordinate Systems information.
+# comment out GEOTIFF_HOME if you are building against a GDAL source tree
+GEOTIFF_HOME=C:\osgeo4w
+!IFDEF GEOTIFF_HOME
+GEOTIFF_LIB = $(GEOTIFF_HOME)\lib\geotiff_i.lib
+GEOTIFF_INCLUDE = -I$(GEOTIFF_HOME)\include
+INCLUDES = $(INCLUDES) $(GEOTIFF_INCLUDE)
+!ENDIF
+# GDAL/OGR Support
+# Uncomment the folling line to build OGR support for
+# the las2ogr command
+#GDAL_HOME=C:\osgeo4w
+#USE_GDAL_SOURCE_TREE=YES
+#GDAL_HOME=C:\cvs\buildkit\gdal
+!IFDEF GDAL_HOME
+GDAL_LIB = $(GDAL_HOME)\lib\gdal_i.lib
+GDAL_INCLUDE = -I$(GDAL_HOME)\include
+!IF "$(USE_GDAL_SOURCE_TREE)" == "YES"
+GDAL_LIB = $(GDAL_HOME)\gdal_i.lib
+GDAL_INCLUDE = -I$(GDAL_HOME)\port -I$(GDAL_HOME)\frmts\gtiff\libgeotiff -I$(GDAL_HOME)\frmts\gtiff\libtiff -I$(GDAL_HOME)\ogr -I$(GDAL_HOME)\gcore
+GEOTIFF_INCLUDE = -I$(GEOTIFF_HOME)\frmts\gtiff\libgeotiff
+!ENDIF
+INCLUDES = $(INCLUDES) $(GDAL_INCLUDE)
+!ENDIF
+# End of GeoTIFF Support
+LAS_HOME=C:\cvs\liblas\trunk
+BINDIR=$(LAS_HOME)\bin
+OSGEO4W_DIR = $(LAS_HOME)\osgeo4w
+PYDLL_DIR = $(LAS_HOME)\python
+# Compilation flags for Release and Debug modes
+!IF "$(BUILD_DEBUG)" == "YES"
+OPTFLAGS= /nologo /MDd /EHsc /Z7 /W4 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /DDEBUG /D_DEBUG /Fd$(LAS_ROOT)\las.pdb
+LAS_LIB = liblas_d.lib
+LAS_DLL = liblas_d1.dll
+LAS_LIB_DLL = libl1as_i.lib
+!ELSE
+# You may need to remove /GR if you are statically linking libLAS
+OPTFLAGS=/nologo /MD /EHsc /Ox /GR /W3 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /D_SCL_SECURE_NO_DEPRECATE /DNDEBUG
+!ENDIF
+CFLAGS= $(OPTFLAGS) $(INCLUDES)
+CFLAGS = $(CFLAGS) /DHAVE_LIBGEOTIFF=1
+!ENDIF
+!IFDEF GDAL_HOME
+CFLAGS = $(CFLAGS) /DHAVE_GDAL=1
+!ENDIF
+!ENDIF
+# End of compilation flags settings
+# Compiler executable
+CC = cl.exe
+# Linker executable
+# - Dynamic-Linked Libraries
+# $(LINK) /dll
+# - Static Libraries (use of lib.exe wrapper is not portable, see VC++ Toolkit 2003)
+# $(LINK) /lib
+LINK = link.exe
+.c.obj:
+ $(CC) $(CFLAGS) /c $*.c /Fo$*.obj
+.cpp.obj:
+ $(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
More information about the Liblas-commits
