[Liblas-commits] r1147 - trunk
liblas-commits at liblas.org
Wed Mar 25 22:45:43 EDT 2009
Author: hobu
Date: Wed Mar 25 22:45:43 2009
New Revision: 1147
URL: http://liblas.org/changeset/1147
add an auto-generated ChangeLog using svn2cl xslt transformation http://ch.tudelft.nl/~arthur/svn2cl/
trunk/ChangeLog
Modified: trunk/ChangeLog
--- trunk/ChangeLog (original)
+++ trunk/ChangeLog Wed Mar 25 22:45:43 2009
@@ -0,0 +1,1100 @@
+2009-03-25 16:58 hobu
+ * trunk/nmake.opt: tweak some comments
+2009-03-25 16:52 hobu
+ * trunk/configure.ac: name our dist target to liblas-src and ensure
+ that the .bz2 file is made with 'make dist'
+2009-03-25 11:22 mloskot
+ * trunk: Updated svn:ignore property.
+2009-03-25 11:21 mloskot
+ * trunk/build/msvc90, trunk/build/msvc90/las2las,
+ trunk/build/msvc90/las2txt, trunk/build/msvc90/lasdiff,
+ trunk/build/msvc90/lasinfo, trunk/build/msvc90/lasmerge,
+ trunk/build/msvc90/liblas_c_dll, trunk/build/msvc90/liblas_lib,
+ trunk/build/msvc90/liblas_test, trunk/build/msvc90/txt2las: Updated
+ svn:ignore property.
+2009-03-25 11:14 mloskot
+ * trunk/apps/makefile.vc, trunk/nmake.opt: nmake.opt: Added support of
+ EXT_NMAKE_OPT for building libLAS with NMAKE (Ticket #117).
+ Improved detection of GDAL_HOME and GEOTIFF_HOME - check if
+ directories exist. Added auto-magical determination of version of
+ Visual C++ compiler based on NMAKE version (see WARNING in
+ NMAKE).
+2009-03-25 09:56 mloskot
+ * trunk/nmake.opt: Fixed LF to CRLF in nmake.opt.
+2009-03-25 09:43 mloskot
+ * trunk/src: Updated svn:ignore property for src.
+2009-03-23 09:47 mloskot
+ * trunk/build/msvc90/liblas_lib/liblas_lib.vcproj: build/msvc90:
+ updated project files after renaming classes LASSRS and LASVLR."
+2009-03-22 20:13 hobu
+ * trunk/include/liblas/lascolor.hpp, trunk/src/lascolor.cpp: fix #116,
+ LASColor has no == operation
+2009-03-22 20:12 hobu
+ * trunk/include/liblas/capi/liblas.h, trunk/src/las_c_api.cpp: Fix
+ #115, add Get/SetPointSourceId to C API
+2009-03-20 21:16 mloskot
+ * trunk/src/makefile.vc: Renamed class LASVLR to LASVariableRecord in
+ src/makefile.vc (Ticket #114).
+2009-03-20 20:59 mloskot
+ * trunk/src/Makefile.am: Renamed class LASVLR to LASVariableRecord in
+ src/Makefile.am (Ticket 14). The C API has not been touched.
+2009-03-20 20:55 mloskot
+ * trunk/build/msvc80/liblas_dll/liblas_dll.vcproj,
+ trunk/build/msvc80/liblas_lib/liblas_lib.vcproj,
+ trunk/build/msvc80/liblas_test/liblas_test.vcproj,
+ trunk/build/msvc90/liblas_dll/liblas_dll.vcproj,
+ trunk/build/msvc90/liblas_lib/liblas_lib.vcproj,
+ trunk/build/msvc90/liblas_test/liblas_test.vcproj,
+ trunk/include/Makefile.am, trunk/include/liblas/lasheader.hpp,
+ trunk/include/liblas/lasreader.hpp,
+ trunk/include/liblas/lasrecordheader.hpp,
+ trunk/include/liblas/lasspatialreference.hpp,
+ trunk/include/liblas/lasvariablerecord.hpp, trunk/src/CMakeLists.txt,
+ trunk/src/detail/reader.cpp, trunk/src/detail/reader10.cpp,
+ trunk/src/detail/reader11.cpp, trunk/src/detail/reader12.cpp,
+ trunk/src/detail/writer.cpp, trunk/src/las_c_api.cpp,
+ trunk/src/lasheader.cpp, trunk/src/lasrecordheader.cpp,
+ trunk/src/lasspatialreference.cpp, trunk/src/lasvariablerecord.cpp,
+ trunk/test/unit/CMakeLists.txt, trunk/test/unit/Makefile.am,
+ trunk/test/unit/lasrecordheader_test.cpp,
+ trunk/test/unit/lasvariablerecord_test.cpp: Renamed class LASVLR to
+ LASVariableRecord (Ticket #114). The C API has not been touched.
+2009-03-20 20:42 mloskot
+ * trunk/test/unit/Makefile.am: Renamed class LASSRS to
+ LASSpatialReference in test/unit/Makefile.am (Ticket #113).
+2009-03-20 20:35 mloskot
+ * trunk/build/msvc80/liblas_lib/liblas_lib.vcproj,
+ trunk/include/Makefile.am, trunk/include/liblas/detail/fwd.hpp,
+ trunk/include/liblas/detail/reader.hpp,
+ trunk/include/liblas/detail/writer.hpp,
+ trunk/include/liblas/lasheader.hpp,
+ trunk/include/liblas/lassrs.hpp, trunk/include/liblas/laswriter.hpp,
+ trunk/src/CMakeLists.txt, trunk/src/Makefile.am,
+ trunk/src/detail/reader.cpp, trunk/src/detail/writer.cpp,
+ trunk/src/las_c_api.cpp, trunk/src/lasheader.cpp,
+ trunk/src/lasreader.cpp, trunk/src/lasspatialreference.cpp,
+ trunk/src/lassrs.cpp, trunk/src/laswriter.cpp, trunk/src/makefile.vc,
+ trunk/test/unit/lasheader_test.cpp,
+ trunk/test/unit/lasspatialreference_test.cpp,
+ trunk/test/unit/lassrs_test.cpp: Renamed class LASSRS to
+ LASSpatialReference (Ticket #113). The C API has not been
+ touched.
+2009-03-20 18:02 hobu
+ * trunk/configure.ac, trunk/include/liblas/capi/las_version.h,
+ trunk/nmake.opt, trunk/python/setup.py: increment versions in prep
+ for 1.2.0b3
+2009-03-20 17:19 hobu
+ * trunk/python/tests/Header.txt: try to fix date test again
+2009-03-20 16:59 hobu
+ * trunk/python/tests/SRS.txt, trunk/python/tests/VLR.txt: Guards for
+ when we have no HAVE_LIBGEOTIFF
+ * trunk/python/tests/File.txt: Make sure that void functions return
+ None for ctype or we'll get unexpected jtrunk back
+2009-03-20 16:57 hobu
+ * trunk/python/liblas/core.py: Make sure that void functions return
+2009-03-20 16:50 hobu
+ * trunk/python/liblas/core.py: don't know where LASReader_Destroy
+ went
+2009-03-20 16:25 hobu
+ * trunk/src/las_c_api.cpp: We use #ifdef _WIN32 instead of #ifdef
+ WIN32 for strncasecmp
+2009-03-20 01:31 mloskot
+ * trunk/include/liblas/detail/reader.hpp,
+ trunk/include/liblas/lasreader.hpp, trunk/src/detail/reader.cpp,
+ trunk/src/detail/reader10.cpp, trunk/src/detail/reader11.cpp,
+ trunk/src/detail/reader12.cpp, trunk/src/lasreader.cpp: Fixed
+ weakness of MakePIMPL by reverting changes applied as r984 and
+ bringing m_pimpl back to constness. There is no need to re-create
+ internal reader object and reassign it to m_pimpl, because reader
+ state can be correctly reset by simple call of LASReader::Init.
+ This fix is also related to Ticket #85. All 87 test cases pass.
+2009-03-20 01:27 mloskot
+ * trunk/test/unit/lasreader_iterator_test.cpp: Fixed LF.
+2009-03-20 00:45 mloskot
+ trunk/build/msvc80/liblas_test/liblas_test.vcproj: Updated
+ build/msvc80 adding new files. Use $(SolutionDir) macro in unit
+ test runner, instead of relative path.
+2009-03-20 00:44 mloskot
+ * trunk/test/unit/liblas_test_suite.cpp: Cleanup
+2009-03-20 00:35 mloskot
+ * trunk/test/unit/lasreader_iterator_test.cpp: Fixed missing reset
+ operation on reader when re-using it with iterators (#85).
+2009-03-20 00:31 mloskot
+ * trunk/src/lasreader.cpp: Fixed but with incompletely re-initialized
+ LASReader after reset. The MakePIMPL idea is weak.
+2009-03-19 22:34 hobu
+ * trunk/python/liblas/core.py, trunk/python/tests/File.txt: beef up
+ test for _Destroy being called twice
+2009-03-19 22:11 hobu
+ * trunk/src/las_c_api.cpp: strncasecmp doesn't exist on windows
+2009-03-19 18:16 hobu
+ * trunk/src/las_c_api.cpp: fix #112, rename VALIDATE_POINTER0 and
+ VALIDATE_POINTER1
+2009-03-19 04:20 hobu
+ * trunk/include/liblas/lasheader.hpp, trunk/python/liblas/file.py,
+ trunk/python/tests/File.txt, trunk/src/las_c_api.cpp,
+ trunk/src/lasheader.cpp: stop tracking open readers/writers in
+ order to allow multiple readers to operate on a file #111
+2009-03-18 03:40 hobu
+ * trunk/include/liblas/detail/writer.hpp: dummy struct for when we
+ don't have GDAL
+2009-03-17 17:30 hobu
+ * trunk/apps/las2txt.c: fix #109, las2txt doesn't output RGB
+2009-03-17 17:24 hobu
+ * trunk/include/liblas/capi/liblas.h, trunk/src/las_c_api.cpp: fix
+ #110, LASSRS VLR methods for C API
+2009-03-17 17:19 hobu
+ * trunk/python/liblas/core.py, trunk/python/liblas/srs.py,
+ trunk/python/tests/SRS.txt: Add VLR methods to srs object
+2009-03-17 17:12 hobu
+ * trunk/src/detail/writer.cpp: oops #108
+2009-03-17 16:58 hobu
+ trunk/include/liblas/detail/writer.hpp, trunk/python/tests/SRS.txt,
+ trunk/src/detail/reader.cpp, trunk/src/detail/writer.cpp: Fix #108,
+ LASWriter::SetSRS and LASReader::SetSRS don't work
+2009-03-17 16:56 hobu
+ * trunk/python/liblas/file.py: clean up __del__ a bit when core is
+ already deleted
+2009-03-17 16:55 hobu
+ * trunk/python/liblas/point.py: complete #106, add descale/scale
+ convenience methods to liblas.point
+2009-03-17 04:15 hobu
+ * trunk/src/lassrs.cpp: clean up a bit
+2009-03-17 04:05 hobu
+ trunk/include/liblas/detail/reader.hpp, trunk/python/liblas/core.py,
+ trunk/python/liblas/file.py, trunk/python/tests/SRS.txt,
+ trunk/src/detail/reader.cpp, trunk/src/las_c_api.cpp,
+ trunk/src/lassrs.cpp: start fixing LASReader/LASWriter SetSRS
+ methods
+2009-03-16 14:57 hobu
+ * trunk/test/unit/Makefile.am, trunk/test/unit/common.cpp,
+ trunk/test/unit/laspoint_test.cpp, trunk/test/unit/lassrs_test.cpp:
+ making mloskot proud by adding to the tests
+2009-03-13 17:35 hobu
+ trunk/nmake.opt, trunk/python/setup.py: increment versions to 1.2.0b2
+ in preparation for release
+2009-03-13 17:34 hobu
+ * trunk/apps/makefile.vc: link GEOTIFF_LIB to everything because we
+ do GTIFPrint when available now.
+2009-03-13 04:35 hobu
+ * trunk/configure.ac: try again on r1098
+2009-03-13 04:30 hobu
+ * trunk/configure.ac: try again on r1097
+2009-03-13 04:04 hobu
+ * trunk/configure.ac: don't overwrite GEOTIFF_INC in the GDAL source
+ tree case with the wrong stuff
+2009-03-12 19:53 hobu
+ * trunk/apps/las2las.c: default to writing 1.2 files for las2las, can
+ be overriden with --format
+ * trunk/apps/txt2las.c: clean up logic for RGB parsing, support
+ setting the format
+2009-03-12 19:40 hobu
+ * trunk/apps/txt2las.c: support setting RGB colors in txt2las #103
+2009-03-12 17:40 hobu
+ * trunk/src/laspoint.cpp: fix #104, copy the LASColor in copy and
+ assignment constructors of LASPoint
+2009-03-12 02:34 hobu
+ * trunk/configure.ac: attempt to fix #100 by pulling in libtiff's
+ header location
+2009-03-10 20:17 hobu
+ * trunk/apps/lascommon.c, trunk/include/liblas/lassrs.hpp,
+ trunk/src/las_c_api.cpp, trunk/src/lassrs.cpp: there is no such thing
+ as a TIFF*, clean up cases for when we don't have libgeotiff
+2009-03-09 18:07 hobu
+ * trunk/include/liblas/capi/liblas.h, trunk/include/liblas/lassrs.hpp,
+ trunk/src/las_c_api.cpp, trunk/src/lassrs.cpp: fix #102, add
+ LASSRS::SetGTIFF
+2009-03-08 20:11 hobu
+ * trunk/src/las_c_api.cpp: make sure to only free things that exist
+2009-03-08 20:10 hobu
+ #101, LASString_Free
+2009-03-08 20:05 hobu
+ * trunk/include/liblas/capi/liblas.h: oops, missing LASSRS_Destroy
+2009-03-08 14:37 hobu
+ * trunk/apps/lascommon.c: silence const warning
+2009-03-08 13:34 hobu
+ * trunk/apps/lascommon.c: const qualifier for GTIF*
+2009-03-07 19:24 hobu
+ * trunk/src/lassrs.cpp, trunk/test/data/1.0_0.las,
+ trunk/test/data/1.0_1.las, trunk/test/data/1.1_0.las,
+ trunk/test/data/1.1_1.las, trunk/test/data/1.2_0.las,
+ trunk/test/data/1.2_1.las, trunk/test/data/1.2_2.las,
+ trunk/test/data/1.2_3.las: oops we were dumb with ASCII records
+2009-03-07 18:43 hobu
+ * trunk/apps/lascommon.c: use GTIFPrint if we can to print geotiff
+ info
+2009-03-07 18:39 hobu
+ * trunk/src/lassrs.cpp: return an empty string if we have nothing
+2009-03-04 19:36 hobu
+ * trunk/test/data/make_data.py: add number_of_points parameter
+2009-02-26 02:13 hobu
+ preparation for 1.2.0b1
+2009-02-26 02:10 hobu
+ * trunk/include/Makefile.am: add 1.2-related headers to dist target
+2009-02-26 00:53 mloskot
+ * trunk/include/liblas/detail/reader12.hpp,
+ trunk/include/liblas/detail/writer12.hpp,
+ trunk/include/liblas/lascolor.hpp, trunk/src/detail/reader12.cpp,
+ trunk/src/detail/writer12.cpp: Little refactoring and cleanup, no
+ fixes applied.
+2009-02-26 00:36 mloskot
+ * trunk/include/liblas/lascolor.hpp, trunk/src/lascolor.cpp: Fixed LAS
+ version and copyright notice and updated doxygen doc in
+ lascolor.{hpp|cpp}
+2009-02-26 00:24 mloskot
+ trunk/src/detail/reader12.cpp, trunk/src/detail/writer12.cpp: Fixed
+ LAS version and copyright notice in {reader12|writer12}.{hpp|cpp}
+2009-02-25 23:57 mloskot
+ * trunk/src/detail/reader.cpp, trunk/src/detail/writer.cpp,
+ trunk/src/lassrs.cpp: Use Zero as nullptr value instead of
+ 'almost-deprecated' NULL macro.
+2009-02-25 23:51 mloskot
+ * trunk/include/liblas/lassrs.hpp, trunk/src/lassrs.cpp: Little
+ refactoring of LASRSR class.
+2009-02-25 13:02 mloskot
+ * trunk/build/msvc90/liblas_lib/liblas_lib.vcproj,
+ trunk/src/lasheader.cpp, trunk/src/lassrs.cpp: * Updated project
+ files for Visual C++ 2008.
+ * Cleaned up some warnings.
+2009-02-25 05:41 hobu
+ * trunk/src/lassrs.cpp: Fix #98, LASSRS not compiling without geotiff
+ or GDAL
+2009-02-25 05:34 hobu
+ * trunk/nmake.opt: support building against a GDAL source tree
+2009-02-25 05:33 hobu
+ * trunk/src/detail/writer.cpp, trunk/src/lassrs.cpp: clean up some
+ warnings, add a FIXME for projecting while writing PointRecord,
+ which needs to be descaled
+2009-02-24 04:33 hobu
+ * trunk/makefile.vc, trunk/src/makefile.vc: w00t! windows building.
+2009-02-23 23:52 hobu
+ * trunk/configure.ac: support building against a GDAL source tree
+2009-02-23 20:04 hobu
+ * trunk/configure.ac: add configure logic to use gdal source tree --
+ not quite done yet
+2009-02-21 03:11 hobu
+ * trunk/include/liblas/lassrs.hpp, trunk/python/tests/Header.txt,
+ trunk/python/tests/SRS.txt, trunk/src/las_c_api.cpp,
+ trunk/src/lasheader.cpp, trunk/src/lassrs.cpp: make ResetVLRs
+ private, clean up SetGeoreference
+ * trunk/test/data/1.0_0.las, trunk/test/data/1.0_1.las,
+ trunk/test/data/1.1_0.las, trunk/test/data/1.1_1.las,
+ trunk/test/data/1.2_0.las, trunk/test/data/1.2_1.las,
+ trunk/test/data/1.2_2.las, trunk/test/data/1.2_3.las,
+ trunk/test/data/make_data.py: latest version of test data with srs
+ and guids
+2009-02-21 03:06 hobu
+ * trunk/test/data/make_data.py: use a srs object now that
+ header.proj4 is gone
+2009-02-21 02:52 hobu
+ * trunk/python/liblas/header.py, trunk/python/tests/File.txt,
+ trunk/python/tests/Header.txt, trunk/python/tests/VLR.txt: fix up
+ tests
+2009-02-20 22:54 hobu
+ * trunk/src/lassrs.cpp: oops, we're broken right now
+2009-02-20 22:44 hobu
+ * trunk/apps/lascommon.c, trunk/include/liblas/capi/liblas.h,
+ trunk/include/liblas/lasheader.hpp, trunk/python/liblas/core.py,
+ trunk/python/liblas/header.py, trunk/python/tests/Header.txt,
+ trunk/src/lasheader.cpp: remove LASHeader::[G|S]etProj4 #97
+2009-02-20 22:36 hobu
+ * trunk/python/tests/Header.txt, trunk/python/tests/VLR.txt: update
+ python tests to reflect current oprations
+2009-02-20 21:49 hobu
+ * trunk/include/liblas/capi/liblas.h, trunk/include/liblas/liblas.hpp,
+ trunk/python/liblas/__init__.py, trunk/python/liblas/core.py,
+ trunk/python/tests/VLR.txt, trunk/src/las_c_api.cpp: add the ability
+ to check for HAVE_GDAL and HAVE_LIBGEOTIFF at runtime
+2009-02-20 19:42 hobu
+ * trunk/src/lassrs.cpp: we should fetch the m_gtiff on Set* methods
+ to create it
+2009-02-20 19:14 hobu
+ trunk/include/liblas/laswriter.hpp, trunk/src/detail/reader.cpp,
+ trunk/src/detail/writer.cpp, trunk/src/lasreader.cpp,
+ trunk/src/laswriter.cpp: add the ability to have Reader/Writer
+ project on the way out #93
+2009-02-20 05:43 hobu
+ * trunk/include/liblas/capi/liblas.h, trunk/python/liblas/__init__.py,
+ trunk/python/liblas/core.py, trunk/python/liblas/header.py,
+ trunk/python/liblas/srs.py, trunk/python/tests/Header.txt,
+ trunk/python/tests/SRS.txt, trunk/src/las_c_api.cpp: start on Python
+ API for SRS
+2009-02-20 04:19 hobu
+ trunk/src/las_c_api.cpp, trunk/src/lassrs.cpp: C API for LASSRS
+2009-02-19 19:34 hobu
+ * trunk/include/liblas/lassrs.hpp, trunk/src/Makefile.am,
+ trunk/src/gt_wkt_srs.cpp, trunk/src/lassrs.cpp: move the GDAL code
+ into its own file so it can easily be swapped in and out
+2009-02-19 19:20 hobu
+ trunk/test/data/make_data.py: use correct SRS description and
+ points for the test data
+2009-02-19 19:08 hobu
+ * trunk/apps/lascommon.c: don't leak a LASColorH
+2009-02-19 19:04 hobu
+2009-02-19 19:02 hobu
+ * trunk/src/lassrs.cpp: don't leak, better error checking
+2009-02-19 05:27 hobu
+ trunk/test/data/make_data.py: make files more rigorous
+2009-02-19 04:17 hobu
+ * trunk/src/lasheader.cpp, trunk/src/lassrs.cpp,
+ trunk/test/data/1.0_0.las, trunk/test/data/1.0_1.las,
+ trunk/test/data/1.2_2.las, trunk/test/data/1.2_3.las: fix up SRS
+ handling of ASCII keys. libgeotiff's simple keys stuff was at
+ fault
+2009-02-18 15:29 hobu
+ * trunk/src/detail/reader.cpp, trunk/src/lasheader.cpp,
+ trunk/src/lassrs.cpp, trunk/test/data/1.0_0.las,
+ trunk/test/data/1.2_3.las, trunk/test/data/make_data.py: a bunch of
+ debugging lint to fix not supporting geotiff ASCII records
+2009-02-17 22:35 hobu
+ trunk/test/data/make_data.py: add test data array
+2009-02-17 21:00 hobu
+ * trunk/python/tests/Header.txt: update test for 1.2 being default
+ * trunk/src/lassrs.cpp: support libgeotiff-only setting of proj4
+2009-02-17 20:26 hobu
+ * trunk/configure.ac: apply Doug's patch for #66
+2009-02-17 19:19 hobu
+ * trunk/include/liblas/lassrs.hpp, trunk/src/lassrs.cpp: allow building
+ without libgeotiff or GDAL
+2009-02-17 18:55 hobu
+ * trunk/test/unit/common.cpp, trunk/test/unit/laswriter_test.cpp:
+ update tests to reflect that 1.2 is now the default version
+2009-02-17 18:48 hobu
+ * trunk/test/data/make_data.py: add make_data script
+2009-02-17 17:57 hobu
+ * trunk/include/liblas/lassrs.hpp: docs for LASSRS
+2009-02-17 17:56 hobu
+ * trunk/src/lassrs.cpp: remember to clear the vlrs when doing a Reset
+2009-02-17 07:02 hobu
+ * trunk/python/liblas/color.py, trunk/python/liblas/header.py,
+ trunk/src/lasheader.cpp: default to using 1.2 for LASHeader and fix
+ SetVersionMinor interaction with the data offset that likely
+ prevented us from ever correctly writing 1.0 data
+2009-02-17 05:21 hobu
+ * trunk/include/liblas/lassrs.hpp: don't include private geotiff
+ stuff
+2009-02-17 04:49 hobu
+ * trunk/CMakeLists.txt, trunk/src/CMakeLists.txt: update cmake a bit.
+ We need to be able to set GDAL though
+2009-02-17 04:13 hobu
+ * trunk/python/tests/VLR.txt, trunk/src/detail/reader.cpp,
+ trunk/src/lasheader.cpp, trunk/src/lassrs.cpp: fix up so tests can
+ pass
+2009-02-17 02:51 hobu
+ * trunk/test/unit/Makefile.am: add geotiff and gdal info to test
+ automake stuff
+2009-02-17 02:40 hobu
+ * trunk/configure.ac: fix #96, check for ST_Create in libgeotiff
+ instead of XTIFFClientOpen
+2009-02-17 02:33 hobu
+ * trunk/include/Makefile.am: fix #95, nobase option for include files
+2009-02-17 02:32 hobu
+ which is where we will be at the next release
+2009-02-16 20:34 hobu
+ * trunk/include/liblas/lassrs.hpp, trunk/src/lasheader.cpp,
+ trunk/src/lassrs.cpp: oh, it seems to work now :)
+2009-02-16 18:50 hobu
+ * trunk/include/liblas/lasheader.hpp, trunk/include/liblas/lassrs.hpp,
+ trunk/src/lasheader.cpp, trunk/src/lassrs.cpp: more updates to
+ LASSRS. Still broken, but improving :)
+2009-02-16 05:40 hobu
+ * trunk/include/liblas/detail/utility.hpp,
+ trunk/include/liblas/lassrs.hpp, trunk/src/detail/reader.cpp,
+ trunk/src/lassrs.cpp: some improvement on srs stuff
+2009-02-16 04:19 hobu
+ trunk/include/liblas/lasheader.hpp, trunk/include/liblas/lassrs.hpp,
+ trunk/src/detail/reader.cpp, trunk/src/lasheader.cpp,
+ trunk/src/lassrs.cpp: more SRS stuff, quite broken right now unless
+ you link GDAL in
+2009-02-14 03:07 hobu
+ * trunk/Makefile.am, trunk/apps/Makefile.am, trunk/include/Makefile.am,
+ trunk/include/liblas/lassrs.hpp: more LASSRS stuff
+2009-02-14 02:47 hobu
+ * trunk/src/lassrs.cpp: more LASSRS stuff, pull in GDAL's code
+2009-02-13 03:12 hobu
+ * trunk/include/liblas/detail/fwd.hpp,
+ trunk/src/Makefile.am, trunk/src/lassrs.cpp: LASSRS skeleton
+2009-02-12 04:23 hobu
+ * trunk/src/Makefile.am: GDAL define support for src/
+2009-02-11 19:31 hobu
+ trunk/include/liblas/detail/reader10.hpp,
+ trunk/include/liblas/detail/reader11.hpp,
+ trunk/include/liblas/detail/reader12.hpp,
+ trunk/include/liblas/detail/writer10.hpp,
+ trunk/include/liblas/detail/writer11.hpp,
+ trunk/src/detail/writer.cpp, trunk/src/detail/writer10.cpp,
+ trunk/src/detail/writer11.cpp, trunk/src/detail/writer12.cpp:
+ reorganize reader and writer Impl to put redundant VLR-related
+ operations in the Reader:: and Writer:: abstract classes instead
+ of each Impl
+2009-02-11 19:18 hobu
+ * trunk/apps/lascommon.c, trunk/include/liblas/capi/liblas.h: report
+ min/max colors as part of a summary
+2009-02-11 15:55 hobu
+ trunk/include/liblas/detail/writer.hpp, trunk/src/detail/reader.cpp,
+ trunk/src/detail/reader12.cpp: remove redundant GetStream and move
+ istream into abstract Reader:: class
+2009-02-11 15:49 hobu
+ * trunk/include/liblas/detail/writer.hpp,
+ trunk/src/detail/writer11.cpp, trunk/src/detail/writer12.cpp: remove
+ redundant GetStream and move ostream into abstract Writer:: class
+2009-02-11 04:34 hobu
+ * trunk/apps/las2las.c: allow las2las to write 1.2 format
+2009-02-11 04:33 hobu
+ * trunk/src/detail/writer.cpp, trunk/src/detail/writer12.cpp,
+ trunk/src/laswriter.cpp: actually support writing 1.2 now that
+ coding is done
+2009-02-11 04:24 hobu
+ * trunk/include/liblas/detail/writer.hpp, trunk/src/detail/writer.cpp,
+ trunk/src/detail/writer10.cpp, trunk/src/detail/writer11.cpp,
+ trunk/src/detail/writer12.cpp: we have to descale the points as we
+ write them
+2009-02-11 03:56 hobu
+ trunk/src/detail/reader12.cpp, trunk/src/detail/writer.cpp,
+ trunk/src/detail/writer12.cpp, trunk/src/laswriter.cpp: 1.2 LASWriter
+ support
+2009-02-10 20:46 hobu
+ * trunk/include/liblas/capi/liblas.h, trunk/python/liblas/color.py,
+ trunk/python/liblas/core.py, trunk/python/liblas/point.py,
+ trunk/python/tests/Point.txt, trunk/src/las_c_api.cpp: color
+ implementation for C API and Python API
+2009-02-10 20:15 hobu
+ trunk/include/liblas/detail/utility.hpp,
+ trunk/include/liblas/lascolor.hpp, trunk/include/liblas/laspoint.hpp,
+ trunk/include/liblas/lasreader.hpp, trunk/src/Makefile.am,
+ trunk/src/detail/reader12.cpp, trunk/src/lascolor.cpp,
+ trunk/src/laspoint.cpp: rework to use public LASColor class, 1.2
+ reading now works
+2009-02-10 16:26 hobu
+ * trunk/src/detail/reader10.cpp, trunk/src/detail/reader12.cpp,
+ trunk/src/lasreader.cpp: clean up commented out code
+2009-02-10 15:54 hobu
+ * trunk/include/liblas/detail/reader.hpp: make FillPoint protected
+ instead of public
+2009-02-10 03:34 hobu
+ trunk/include/liblas/laspoint.hpp,
+ trunk/include/liblas/lasreader.hpp, trunk/python/tests/File.txt,
+ trunk/src/laspoint.cpp, trunk/src/lasreader.cpp: reorganize
+ LASReader. Tests (cppUnit and Python) all still pass
+2009-02-09 01:47 hobu
+ trunk/include/liblas/lasheader.hpp, trunk/include/liblas/liblas.hpp,
+ trunk/src/Makefile.am, trunk/src/detail/reader.cpp,
+ trunk/src/detail/writer12.cpp, trunk/src/lasheader.cpp,
+ trunk/src/laspoint.cpp, trunk/src/lasreader.cpp: start in on 1.2 read
+ support. Tests pass, but 1.2 reading is not working yet
+2009-02-06 03:01 hobu
+ * trunk/python/liblas/__init__.py, trunk/python/liblas/core.py: re-fix
+ #89 liblas.version
+2009-02-05 02:59 hobu
+ * trunk/include/liblas/laspoint.hpp: add Red, Green, and Blue to
+ LASPoint for 1.2 support #91
+2009-02-05 02:48 hobu
+ trunk/test/unit/lasheader_test.cpp: increment max VersionMinor to 2
+ for 1.2 support #91
+2009-02-05 02:43 hobu
+ * trunk/include/liblas/lasheader.hpp: increment the point formats and
+ point sizes for LAS 1.2 #91
+2009-02-04 03:31 hobu
+ * trunk/README: add a link to the 1.2 specification
+2009-02-04 03:26 hobu
+ * trunk/build/xcode, trunk/build/xcode/xcode.xcodeproj/hobu.mode1v3,
+ trunk/build/xcode/xcode.xcodeproj/hobu.pbxuser,
+ trunk/build/xcode/xcode.xcodeproj/project.pbxproj: xcode projects
+2009-02-03 16:08 mloskot
+ * trunk/include/liblas/laspoint.hpp,
+ trunk/include/liblas/lasreader.hpp: * Documented libLAS-specific
+ elements of LASPoint class (no need to repeat LAS specification).
+2009-02-03 15:40 mloskot
+ * trunk/build/msvc90/liblas.sln, trunk/include/liblas/laspoint.hpp,
+ trunk/src/detail/reader11.cpp, trunk/test/unit/laswriter_test.cpp: *
+ Updated LASWriter test with checks of get/set methods for Point
+ Source ID attribute.
+ * Removed unused <iostream> from laspoint.hpp.
+ * Include missing <iostream> in reader11.cpp, std::cerr object is
+ used.
+ * build/msvc90 project updated.
+2009-02-03 15:21 hobu
+ * trunk/include/liblas/lasreader.hpp, trunk/src/lasreader.cpp: fix up
+ creation of a local m_pimpl that was masking the LASReader's
+2009-02-03 14:59 mloskot
+ trunk/include/liblas/laspoint.hpp, trunk/src/laspoint.cpp,
+ trunk/src/lasreader.cpp, trunk/src/laswriter.cpp,
+ trunk/test/unit/common.cpp: Fixed #87 - implemented support for
+ reading/writing "Point Source ID" - attribute of point record
+ defined in LAS 1.0.
+ The new LASPoint accessors operating on Point Source ID play dual
+ role, for LAS 1.0 they get/set User Bit Field but for LAS 1.1 -
+ Point Source ID.
+2009-02-03 14:50 mloskot
+ * trunk/test/sample/utility.hpp: Added print_point() function to
+ sample/utility.hpp header.
+2009-02-03 14:48 mloskot
+ * trunk/build/msvc90: Updated svn:ignore property for build/msvc90.
+2009-02-03 05:32 hobu
+ * trunk/include/liblas/lasreader.hpp, trunk/src/lasreader.cpp: an
+ attempt at a Reset() and IsEOF() functions #85
+2009-01-01 02:56 hobu
+ * trunk/build/xcode, trunk/build/xcode/xcode.xcodeproj,
+ trunk/build/xcode/xcode.xcodeproj/hobu.mode1v3,
+ trunk/build/xcode/xcode.xcodeproj/project.pbxproj: add xcode
+ project
+2008-12-31 04:50 hobu
+ * trunk/apps: ignore liblas-config
+2008-12-26 05:39 hobu
+ * trunk/apps/las2txt.c: add index parse option to las2txt #86
+2008-12-26 05:31 hobu
+ * trunk/test/unit/lasreader_iterator_test.cpp: fix test to use
+ qualified type names
+2008-12-26 05:21 hobu
+ trunk/python/setup.py: bump minor version so we're now 1.1 in trtrunk
+ * trunk/nmake.opt: change to *nix line ending mode
+2008-12-26 05:16 hobu
+ * trunk/apps/Makefile.am, trunk/apps/liblas-config.in,
+ trunk/configure.ac: add a liblas-config script #88
+2008-12-26 04:00 hobu
+ * trunk/python/liblas/core.py: no lint
+2008-12-26 03:59 hobu
+ * trunk/python/liblas/core.py: make sure to free heap allocated
+ strings that were given to us by the C API
+2008-12-25 05:38 hobu
+ * trunk/python/liblas/core.py: fix #89, broken liblas.version
+2008-12-15 15:12 mloskot
+ * trunk/src/detail/reader10.cpp, trunk/src/detail/reader11.cpp: Unified
+ type of count value passed to ST_SetKey/ST_GetKey of libgeotiff
+ API
+2008-12-10 16:05 mloskot
+ * trunk/build/msvc90, trunk/build/msvc90/clean.bat,
+ trunk/build/msvc90/las2las,
+ trunk/build/msvc90/las2las/las2las.vcproj,
+ trunk/build/msvc90/las2ogr,
+ trunk/build/msvc90/las2ogr/las2ogr.vcproj,
+ trunk/build/msvc90/las2ogr/las2ogr.vsprops,
+ trunk/build/msvc90/las2txt/las2txt.vcproj,
+ trunk/build/msvc90/lasdiff,
+ trunk/build/msvc90/lasdiff/lasdiff.vcproj,
+ trunk/build/msvc90/lasinfo/lasinfo.vcproj,
+ trunk/build/msvc90/lasmerge,
+ trunk/build/msvc90/lasmerge/lasmerge.vcproj,
+ trunk/build/msvc90/liblas.sln, trunk/build/msvc90/liblas.vsprops,
+ trunk/build/msvc90/liblas_c_dll/liblas_c_dll.vcproj,
+ trunk/build/msvc90/liblas_dll,
+ trunk/build/msvc90/liblas_lib,
+ trunk/build/msvc90/txt2las,
+ trunk/build/msvc90/txt2las/txt2las.vcproj: Added solution &
+ projects for Visual Studio 9.0
+2008-11-13 22:02 hobu
+ * trunk/README: dummy
+2008-11-13 21:59 hobu
+2008-11-13 21:58 hobu
+2008-11-13 21:50 hobu
+ * trunk/README: point to new maillist
+2008-11-09 12:41 mloskot
+ lasreader_iterator_test.cpp: refactored to remove redundant code
+ and reuse common test group data.
+2008-11-06 16:18 mloskot
+ * trunk/test/unit/common.hpp,
+ trunk/test/unit/lasreader_iterator_test.cpp:
+ lasreader_iterator_test.cpp: added test cases for number of
+ standard algorithms: copy, count, equal, find, find_if, for_each.
+2008-11-06 15:51 mloskot
+ * trunk/test/unit/common.hpp: test/unit/common.hpp: Added is_xy
+ predicated and bbox_calculator functor, both used in unit tests.
+2008-11-06 15:48 mloskot
+ * trunk/src/laspoint.cpp: liblas::LASPoint: fixed incorrect
+ logical-or where logical-and is expected (Ticket #84).
+2008-11-06 15:42 mloskot
+ * trunk/include/liblas/detail/utility.hpp: liblas::detail::Point:
+ improved equal-to operation for Point<T> class.
+2008-11-05 20:41 mloskot
+ * trunk/build/msvc80/liblas_test/liblas_test.vcproj: Updated Visual
+ C++ project file liblas_test.vcproj.
+2008-11-05 20:38 mloskot
+ * trunk/test/unit/CMakeLists.txt, trunk/test/unit/Makefile.am,
+ trunk/test/unit/lasreader_iterator_test.cpp: Added unit test of
+ liblas::lasreader_iterator class.
+2008-11-05 20:33 mloskot
+ * trunk/test/unit/common.cpp, trunk/test/unit/common.hpp,
+ trunk/test/unit/lasreader_test.cpp: Move common test routines from
+ lasreader_test.cpp to common.hpp|.cpp
+2008-11-05 19:17 mloskot
+ * trunk/README: REAME: reordered utilities
+2008-10-30 08:35 mloskot
+ trunk/include/liblas/laswriter.hpp, trunk/src/lasreader.cpp,
+ trunk/src/laswriter.cpp: Expose TODO entries in .c and .cpp files
+ from doxygen comments in headers, to not to forget about them.
+2008-10-29 11:15 mloskot
+ * trunk/doc/las2ogr.txt: doc/las2ogr.txt: Updated svn:mine-type,
+ svn:eol-style and svn:keywords.
+2008-10-29 11:12 mloskot
+ * trunk/doc/las2ogr.txt: Set svn:keywords on las2ogr.txt
+2008-10-29 11:09 mloskot
+ * trunk/README, trunk/doc/las2ogr.txt: Added doc/las2ogr.txt file.
+ Linked las2ogr.txt from main README.
+2008-10-29 10:54 mloskot
+ * trunk/apps/makefile.vc: apps/makefile.vc: remove .ilk and .pdb
+ files from clean target.
+2008-10-14 02:18 hobu
+ * trunk/python/liblas/point.py, trunk/python/tests/File.txt,
+ trunk/python/tests/Header.txt, trunk/python/tests/Point.txt: more
+ fixups related to #83.. ensure we use GMT and fix microseconds
+ overflow
More information about the Liblas-commits
