[Liblas-commits] r1149 - trunk
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 25 22:59:49 EDT 2009
Author: hobu
Date: Wed Mar 25 22:59:49 2009
New Revision: 1149
URL: http://liblas.org/changeset/1149
update in preparation for 1.2.0 release
   trunk/README
Modified: trunk/README
--- trunk/README	(original)
+++ trunk/README	Wed Mar 25 22:59:49 2009
@@ -1,17 +1,15 @@
-libLAS - LAS 1.0/1.1 ASPRS LiDAR data translation toolset
+libLAS - LAS 1.0/1.1/1.2 ASPRS LiDAR data translation toolset
-libLAS is a C/C++ library for reading and writing ASPRS LAS version 1.0 and 1.1
-data.  LAS-formatted data is heavily used in `LiDAR`_ processing operations, and
-the LAS format is a sequential binary format used to store data from sensors
-and as intermediate processing storage by some applications.
+libLAS is a C/C++ library for reading and writing ASPRS LAS versions 1.0, 1.1 and 1.2
+data.  The LAS format is a sequential binary format used to store data from sensors
+and as intermediate processing storage by some `LiDAR`_-related applications.
 libLAS is available under the terms of the `BSD License`_. It builds on work
 by `Martin Isenburg and Jonathan Shewchuk`_ of the  University of North
-Carolina in their `LAStools`_ project.  libLAS' base C++ library that reads
-and writes LAS 1.0/1.1 data was replaced with new development, and Martin's
-tools were ported to use this new code.
+Carolina in their `LAStools`_ project by replacing the base C++ library
+with new development and porting Martin's tools this new code.
 libLAS' initial development was supported by the `IGSB`_ of the Iowa DNR
 for use in its state-wide `LIDAR`_ project.
@@ -20,7 +18,7 @@
 Download
-The 1.0.0 version of libLAS can be downloaded from http://liblas.org/wiki/1.0.0
+The 1.2.0 version of libLAS can be downloaded from http://liblas.org/wiki/1.2.0
 Older releases may be obtained from http://liblas.org/wiki/Releases
@@ -54,6 +52,7 @@
 * `FOSS4G 2008`_ presentation that provides a basic overview of the design and philosophy of libLAS
+* `ASPRS Workshop Demo`_ by Jason Woolard of NOAA describing how to use libLAS with Python
 * `Tutorials`_ - tutorials on using libLAS from C++, Python and .NET/Mono languages
 * `LAS C API`_- doxygen docs that describe the libLAS C API
 * `dotnetLibLAS API`_ - docs for the .NET API
@@ -91,7 +90,7 @@
 libLAS is open source software.  You can embed it in your own applications
 (and even resell it) as long as you follow the crediting restriction of the BSD
-license.
+license.  See `License`_ for more detail.
 Multiple APIs
@@ -101,8 +100,10 @@
 Spatial Reference System Support
-Linked against the latest version of `libgeotiff`_, you can set and get the spatial reference
+Linked against a 1.2.5+ version of `libgeotiff`_, you can set and get the spatial reference
 systems of LAS files using simple `proj.4`_ coordinate system definitions.
+Alternatively, with libLAS 1.2, you can link against `GDAL`_ to be able to
+manipulate spatial references using WKT.
 Simple Variable Length Record Abstraction
@@ -216,3 +217,4 @@
 .. _`OSGeo4W`: http://wiki.osgeo.org/wiki/OSGeo_Win32_Installer
 .. _`dotnetLibLAS API`: http://liblas.org/wiki/dotnetapi
 .. _`FOSS4G 2008`: http://liblas.org/raw-attachment/wiki/WikiStart/liblas_foss4g_2008.pdf
+.. _`ASPRS Workshop Demo`: http://liblas.org/raw-attachment/wiki/WikiStart/ASPRS-Workshop-NOAA-Demo.pdf
\ No newline at end of file
More information about the Liblas-commits mailing list
