[Liblas-commits] r1154 - in trunk/doc: . man static writers
liblas-commits at liblas.org
Mon Mar 30 12:28:14 EDT 2009
Author: hobu
Date: Mon Mar 30 12:28:09 2009
New Revision: 1154
URL: http://liblas.org/changeset/1154
remake the docs section in preparation for sphinx. doxygen stuff untouched
Added:
trunk/doc/Makefile
trunk/doc/conf.py
trunk/doc/index.txt
trunk/doc/make.bat
trunk/doc/static/
Removed:
trunk/doc/Makefile.am
trunk/doc/man/
trunk/doc/rst2man.py
trunk/doc/writers/
trunk/doc/ (props changed)
Added: trunk/doc/Makefile
--- (empty file)
+++ trunk/doc/Makefile Mon Mar 30 12:28:09 2009
@@ -0,0 +1,91 @@
+# Makefile for Sphinx documentation
+# You can set these variables from the command line.
+SPHINXOPTS =
+SPHINXBUILD = sphinx-build
+PAPER =
+# Internal variables.
+PAPEROPT_a4 = -D latex_paper_size=a4
+PAPEROPT_letter = -D latex_paper_size=letter
+ALLSPHINXOPTS = -d build/doctrees $(PAPEROPT_$(PAPER)) $(SPHINXOPTS) .
+.PHONY: html help clean html dirhtml pickle json htmlhelp qthelp latex changes linkcheck doctest
+html:
+ $(SPHINXBUILD) -b html $(ALLSPHINXOPTS) build/html
+ @echo
+ @echo "Build finished. The HTML pages are in build/html."
+help:
+ @echo "Please use \`make <target>' where <target> is one of"
+ @echo " html to make standalone HTML files"
+ @echo " dirhtml to make HTML files named index.html in directories"
+ @echo " pickle to make pickle files"
+ @echo " json to make JSON files"
+ @echo " htmlhelp to make HTML files and a HTML help project"
+ @echo " qthelp to make HTML files and a qthelp project"
+ @echo " latex to make LaTeX files, you can set PAPER=a4 or PAPER=letter"
+ @echo " changes to make an overview of all changed/added/deprecated items"
+ @echo " linkcheck to check all external links for integrity"
+ @echo " doctest to run all doctests embedded in the documentation (if enabled)"
+clean:
+ -rm -rf build/*
+dirhtml:
+ $(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) build/dirhtml
+ @echo
+ @echo "Build finished. The HTML pages are in build/dirhtml."
+pickle:
+ $(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) build/pickle
+ @echo
+ @echo "Build finished; now you can process the pickle files."
+json:
+ $(SPHINXBUILD) -b json $(ALLSPHINXOPTS) build/json
+ @echo
+ @echo "Build finished; now you can process the JSON files."
+htmlhelp:
+ $(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) build/htmlhelp
+ @echo
+ @echo "Build finished; now you can run HTML Help Workshop with the" \
+ ".hhp project file in build/htmlhelp."
+qthelp:
+ $(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) build/qthelp
+ @echo
+ @echo "Build finished; now you can run "qcollectiongenerator" with the" \
+ ".qhcp project file in build/qthelp, like this:"
+ @echo "# qcollectiongenerator build/qthelp/libLAS.qhcp"
+ @echo "To view the help file:"
+ @echo "# assistant -collectionFile build/qthelp/libLAS.qhc"
+latex:
+ $(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) build/latex
+ @echo
+ @echo "Build finished; the LaTeX files are in build/latex."
+ @echo "Run \`make all-pdf' or \`make all-ps' in that directory to" \
+ "run these through (pdf)latex."
+changes:
+ $(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) build/changes
+ @echo
+ @echo "The overview file is in build/changes."
+linkcheck:
+ $(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) build/linkcheck
+ @echo
+ @echo "Link check complete; look for any errors in the above output " \
+ "or in build/linkcheck/output.txt."
+doctest:
+ $(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) build/doctest
+ @echo "Testing of doctests in the sources finished, look at the " \
+ "results in build/doctest/output.txt."
+doxygen:
+ cd api; doxygen doxygen.conf
Added: trunk/doc/conf.py
--- (empty file)
+++ trunk/doc/conf.py Mon Mar 30 12:28:09 2009
@@ -0,0 +1,198 @@
+# -*- coding: utf-8 -*-
+# libLAS documentation build configuration file, created by
+# sphinx-quickstart on Mon Mar 30 11:04:44 2009.
+# This file is execfile()d with the current directory set to its containing dir.
+# Note that not all possible configuration values are present in this
+# autogenerated file.
+# All configuration values have a default; values that are commented out
+# serve to show the default.
+import sys, os
+# If extensions (or modules to document with autodoc) are in another directory,
+# add these directories to sys.path here. If the directory is relative to the
+# documentation root, use os.path.abspath to make it absolute, like shown here.
+#sys.path.append(os.path.abspath('.'))
+# -- General configuration -----------------------------------------------------
+# Add any Sphinx extension module names here, as strings. They can be extensions
+# coming with Sphinx (named 'sphinx.ext.*') or your custom ones.
+extensions = ['sphinx.ext.autodoc', 'sphinx.ext.doctest', 'sphinx.ext.intersphinx', 'sphinx.ext.todo', 'sphinx.ext.ifconfig']
+# Add any paths that contain templates here, relative to this directory.
+templates_path = ['templates']
+# The suffix of source filenames.
+source_suffix = '.txt'
+# The encoding of source files.
+#source_encoding = 'utf-8'
+# The master toctree document.
+master_doc = 'index'
+# General information about the project.
+project = u'libLAS'
+copyright = u'2009, Howard Butler'
+# The version info for the project you're documenting, acts as replacement for
+# |version| and |release|, also used in various other places throughout the
+# built documents.
+# The short X.Y version.
+version = '1.3.0'
+# The full version, including alpha/beta/rc tags.
+release = '1.3.0'
+# The language for content autogenerated by Sphinx. Refer to documentation
+# for a list of supported languages.
+#language = None
+# There are two options for replacing |today|: either, you set today to some
+# non-false value, then it is used:
+#today = ''
+# Else, today_fmt is used as the format for a strftime call.
+#today_fmt = '%B %d, %Y'
+# List of documents that shouldn't be included in the build.
+#unused_docs = []
+# List of directories, relative to source directory, that shouldn't be searched
+# for source files.
+exclude_trees = ['build']
+# The reST default role (used for this markup: `text`) to use for all documents.
+#default_role = None
+# If true, '()' will be appended to :func: etc. cross-reference text.
+#add_function_parentheses = True
+# If true, the current module name will be prepended to all description
+# unit titles (such as .. function::).
+#add_module_names = True
+# If true, sectionauthor and moduleauthor directives will be shown in the
+# output. They are ignored by default.
+#show_authors = False
+# The name of the Pygments (syntax highlighting) style to use.
+pygments_style = 'sphinx'
+# A list of ignored prefixes for module index sorting.
+#modindex_common_prefix = []
+# -- Options for HTML output ---------------------------------------------------
+# The theme to use for HTML and HTML Help pages. Major themes that come with
+# Sphinx are currently 'default' and 'sphinxdoc'.
+html_theme = 'default'
+# Theme options are theme-specific and customize the look and feel of a theme
+# further. For a list of options available for each theme, see the
+# documentation.
+#html_theme_options = {}
+# Add any paths that contain custom themes here, relative to this directory.
+#html_theme_path = []
+# The name for this set of Sphinx documents. If None, it defaults to
+# "<project> v<release> documentation".
+#html_title = None
+# A shorter title for the navigation bar. Default is the same as html_title.
+#html_short_title = None
+# The name of an image file (relative to this directory) to place at the top
+# of the sidebar.
+#html_logo = None
+# The name of an image file (within the static path) to use as favicon of the
+# docs. This file should be a Windows icon file (.ico) being 16x16 or 32x32
+# pixels large.
+#html_favicon = None
+# Add any paths that contain custom static files (such as style sheets) here,
+# relative to this directory. They are copied after the builtin static files,
+# so a file named "default.css" will overwrite the builtin "default.css".
+html_static_path = ['static']
+# If not '', a 'Last updated on:' timestamp is inserted at every page bottom,
+# using the given strftime format.
+#html_last_updated_fmt = '%b %d, %Y'
+# If true, SmartyPants will be used to convert quotes and dashes to
+# typographically correct entities.
+#html_use_smartypants = True
+# Custom sidebar templates, maps document names to template names.
+#html_sidebars = {}
+# Additional templates that should be rendered to pages, maps page names to
+# template names.
+#html_additional_pages = {}
+# If false, no module index is generated.
+#html_use_modindex = True
+# If false, no index is generated.
+#html_use_index = True
+# If true, the index is split into individual pages for each letter.
+#html_split_index = False
+# If true, links to the reST sources are added to the pages.
+#html_show_sourcelink = True
+# If true, an OpenSearch description file will be output, and all pages will
+# contain a <link> tag referring to it. The value of this option must be the
+# base URL from which the finished HTML is served.
+#html_use_opensearch = ''
+# If nonempty, this is the file name suffix for HTML files (e.g. ".xhtml").
+#html_file_suffix = ''
+# Output file base name for HTML help builder.
+htmlhelp_basename = 'libLASdoc'
+# -- Options for LaTeX output --------------------------------------------------
+# The paper size ('letter' or 'a4').
+#latex_paper_size = 'letter'
+# The font size ('10pt', '11pt' or '12pt').
+#latex_font_size = '10pt'
+# Grouping the document tree into LaTeX files. List of tuples
+# (source start file, target name, title, author, documentclass [howto/manual]).
+latex_documents = [
+ ('index', 'libLAS.tex', u'libLAS Documentation',
+ u'Howard Butler', 'manual'),
+# The name of an image file (relative to this directory) to place at the top of
+# the title page.
+#latex_logo = None
+# For "manual" documents, if this is true, then toplevel headings are parts,
+# not chapters.
+#latex_use_parts = False
+# Additional stuff for the LaTeX preamble.
+#latex_preamble = ''
+# Documents to append as an appendix to all manuals.
+#latex_appendices = []
+#latex_use_modindex = True
+# Example configuration for intersphinx: refer to the Python standard library.
+intersphinx_mapping = {'http://docs.python.org/': None}
Added: trunk/doc/index.txt
--- (empty file)
+++ trunk/doc/index.txt Mon Mar 30 12:28:09 2009
@@ -0,0 +1,22 @@
+.. libLAS documentation master file, created by
+ sphinx-quickstart on Mon Mar 30 11:04:44 2009.
+ You can adapt this file completely to your liking, but it should at least
+ contain the root `toctree` directive.
+Welcome to libLAS's documentation!
+Contents:
+.. toctree::
+ :maxdepth: 2
+ lasinfo
+Indices and tables
+* :ref:`genindex`
+* :ref:`modindex`
+* :ref:`search`
Added: trunk/doc/make.bat
--- (empty file)
+++ trunk/doc/make.bat Mon Mar 30 12:28:09 2009
@@ -0,0 +1,112 @@
+ at ECHO OFF
+REM Command file for Sphinx documentation
+set SPHINXBUILD=sphinx-build
+set ALLSPHINXOPTS=-d build/doctrees %SPHINXOPTS% .
+if NOT "%PAPER%" == "" (
+ set ALLSPHINXOPTS=-D latex_paper_size=%PAPER% %ALLSPHINXOPTS%
+if "%1" == "" goto help
+if "%1" == "help" (
+ :help
+ echo.Please use `make ^<target^>` where ^<target^> is one of
+ echo. html to make standalone HTML files
+ echo. dirhtml to make HTML files named index.html in directories
+ echo. pickle to make pickle files
+ echo. json to make JSON files
+ echo. htmlhelp to make HTML files and a HTML help project
+ echo. qthelp to make HTML files and a qthelp project
+ echo. latex to make LaTeX files, you can set PAPER=a4 or PAPER=letter
+ echo. changes to make an overview over all changed/added/deprecated items
+ echo. linkcheck to check all external links for integrity
+ echo. doctest to run all doctests embedded in the documentation if enabled
+ goto end
+if "%1" == "clean" (
+ for /d %%i in (build\*) do rmdir /q /s %%i
+ del /q /s build\*
+ goto end
+if "%1" == "html" (
+ %SPHINXBUILD% -b html %ALLSPHINXOPTS% build/html
+ echo.
+ echo.Build finished. The HTML pages are in build/html.
+ goto end
+if "%1" == "dirhtml" (
+ %SPHINXBUILD% -b dirhtml %ALLSPHINXOPTS% build/dirhtml
+ echo.
+ echo.Build finished. The HTML pages are in build/dirhtml.
+ goto end
+if "%1" == "pickle" (
+ %SPHINXBUILD% -b pickle %ALLSPHINXOPTS% build/pickle
+ echo.
+ echo.Build finished; now you can process the pickle files.
+ goto end
+if "%1" == "json" (
+ %SPHINXBUILD% -b json %ALLSPHINXOPTS% build/json
+ echo.
+ echo.Build finished; now you can process the JSON files.
+ goto end
+if "%1" == "htmlhelp" (
+ %SPHINXBUILD% -b htmlhelp %ALLSPHINXOPTS% build/htmlhelp
+ echo.
+ echo.Build finished; now you can run HTML Help Workshop with the ^
+.hhp project file in build/htmlhelp.
+ goto end
+if "%1" == "qthelp" (
+ %SPHINXBUILD% -b qthelp %ALLSPHINXOPTS% build/qthelp
+ echo.
+ echo.Build finished; now you can run "qcollectiongenerator" with the ^
+.qhcp project file in build/qthelp, like this:
+ echo.^> qcollectiongenerator build\qthelp\libLAS.qhcp
+ echo.To view the help file:
+ echo.^> assistant -collectionFile build\qthelp\libLAS.ghc
+ goto end
+if "%1" == "latex" (
+ %SPHINXBUILD% -b latex %ALLSPHINXOPTS% build/latex
+ echo.
+ echo.Build finished; the LaTeX files are in build/latex.
+ goto end
+if "%1" == "changes" (
+ %SPHINXBUILD% -b changes %ALLSPHINXOPTS% build/changes
+ echo.
+ echo.The overview file is in build/changes.
+ goto end
+if "%1" == "linkcheck" (
+ %SPHINXBUILD% -b linkcheck %ALLSPHINXOPTS% build/linkcheck
+ echo.
+ echo.Link check complete; look for any errors in the above output ^
+or in build/linkcheck/output.txt.
+ goto end
+if "%1" == "doctest" (
+ %SPHINXBUILD% -b doctest %ALLSPHINXOPTS% build/doctest
+ echo.
+ echo.Testing of doctests in the sources finished, look at the ^
+results in build/doctest/output.txt.
+ goto end
+:end
More information about the Liblas-commits
