[Liblas-commits] r1159 - trunk/doc
liblas-commits at liblas.org
Mon Mar 30 14:18:19 EDT 2009
Author: hobu
Date: Mon Mar 30 14:18:18 2009
New Revision: 1159
URL: http://liblas.org/changeset/1159
doc updates
trunk/doc/index.txt
trunk/doc/las2las.txt
trunk/doc/las2ogr.txt
trunk/doc/las2txt.txt
trunk/doc/lasdiff.txt
trunk/doc/lasinfo.txt
trunk/doc/lasmerge.txt
trunk/doc/txt2las.txt
Modified: trunk/doc/index.txt
--- trunk/doc/index.txt (original)
+++ trunk/doc/index.txt Mon Mar 30 14:18:18 2009
@@ -9,9 +9,16 @@
Contents:
.. toctree::
- :maxdepth: 2
+ :maxdepth: 1
lasinfo
+ las2las
+ las2txt
+ lasmerge
+ lasdiff
+ las2ogr
+ txt2las
Indices and tables
Modified: trunk/doc/las2las.txt
--- trunk/doc/las2las.txt (original)
+++ trunk/doc/las2las.txt Mon Mar 30 14:18:18 2009
@@ -1,5 +1,7 @@
+.. _las2las:
- las2las: converts from binary LAS to binary LAS
+ las2las
:Author: Martin Isenburg
@@ -9,8 +11,6 @@
:Revision: $Revision$
:Date: $Date$
-.. sectnum::
.. contents::
:depth: 3
:backlinks: top
@@ -18,11 +18,11 @@
Description
-`las2las` reads and writes LiDAR data in the ASPRS LAS 1.0 and 1.1 formats while
+:ref:`las2las` reads and writes LiDAR data in the ASPRS LAS 1.0 and 1.1 formats while
modifying its contents. While `lasinfo` can do a few simple operations like
updating header information, more drastic changes, like removing points or
-altering values, will require `las2las`. `las2las` is expected to be used for
-modifying single files at a time, and all `las2las` operations require multiple
+altering values, will require :ref:`las2las`. :ref:`las2las` is expected to be used for
+modifying single files at a time, and all :ref:`las2las` operations require multiple
read passes through the points. Some examples of operations `las2las` can be
used for include:
@@ -37,7 +37,7 @@
* changing the format from LAS 1.0 to 1.1 or vice versa
* eliminating points of a given classification (--eliminate class 2)
-`las2las` is a port of Martin Isenburg's `las2las` utility from `LASTools`_
+:ref:`las2las` is a port of Martin Isenburg's :ref:`las2las` utility from `LASTools`_
to the libLAS library. For the most part, it is unchanged from Martin's
utility except for a few differences:
Modified: trunk/doc/las2ogr.txt
--- trunk/doc/las2ogr.txt (original)
+++ trunk/doc/las2ogr.txt Mon Mar 30 14:18:18 2009
@@ -1,5 +1,7 @@
+.. _las2ogr:
- las2ogr: converts from binary LAS to one of OGR formats
+ las2ogr
:Author: Mateusz Loskot
@@ -7,8 +9,6 @@
:Date: $Date$
-.. sectnum::
.. contents::
:depth: 3
:backlinks: top
Modified: trunk/doc/las2txt.txt
--- trunk/doc/las2txt.txt (original)
+++ trunk/doc/las2txt.txt Mon Mar 30 14:18:18 2009
@@ -1,20 +1,96 @@
- las2txt: converts from binary LAS to a standard ASCII format
+.. _las2txt:
+ las2txt
:Contact: isenburg at cs.unc.edu
+:Author: Howard Butler
+:Contact: hobu.inc at gmail.com
:Date: $Date$
-.. sectnum::
.. contents::
:depth: 3
:backlinks: top
+Description
+:ref:`las2txt` allows you to output ASRPS LAS files into ASCII text.
+Usage
+ C:\lastools\bin>las2txt -h
+ usage:
+ las2txt lidar.las
+ las2txt -parse xyziar lidar.las lidar.txt
+ las2txt -i lidar.las -o lidar.laz -parse xyz
+ las2txt -parse xyzt -verbose lidar.las
+ las2txt -parse xyz lidar.las.gz
+ las2txt -h
+The '-parse txyz' flag specifies how to format each each line of the ASCII
+file. For example, 'txyzia' means that the first number of each line should
+be the gpstime, the next three numbers should be the x, y, and z coordinate,
+the next number should be the intensity and the next number should be the
+scan angle.
+Supported entries
+* a - scan angle
+* i - intensity,
+* n - number of returns for given pulse
+* r - number of this return
+* c - classification
+* u - user data
+* p - point source ID
+* e - edge of flight line flag
+* d - direction of scan flag
+* R - red channel of RGB color
+* G - green channel of RGB color
+* B - blue channel of RGB color
+* M - vertex index number
+Separators
+The '-sep space' flag specifies what separator to use. The default is a
+space. The following list is valid for separator characters (case sensitive):
+* tab
+* comma
+* colon
+* hyphen
+* dot
+* semicolon
+Header Separators
+The '-header pound' flag results in the header information being printed at
+the beginning of the ASCII file in form of a comment that starts with the
+special character '#'. Other possible special characters include (case sensitive):
+* percent
+* dollar
+* semicolon
+* comma
+* star
+* colon
+* semicolon
+Examples
Simple conversion to text file
@@ -22,10 +98,10 @@
converts LAS file to ASCII and places the x, y, and z coordinate
of each point at the 1st, 2nd, and 3rd entry of each line. the
-entries are seperated by a space.
+entries are separated by a space.
Specifying a separator
@@ -36,8 +112,8 @@
and the number of the return as the 5th entry of each line. the
entries are separated by a komma.
-Altering the header separtor
+Altering the header separator
@@ -45,12 +121,12 @@
at the 1st, 2nd, and 3rd entry, the intensity at the 4th and the
-scan angle as the 5th entry of each line. the entries are separated
+scan angle as the 5th entry of each line. The entries are separated
by a semicolon. at the beginning of the file we print the header
information as a comment starting with a '#' symbol.
Altering the coordinate order
@@ -61,51 +137,3 @@
the user data as the 5th entry of each line. the entries are
separated by a semicolon. at the beginning of the file we print
the header information as a comment starting with a '%' symbol.
-Usage
- C:\lastools\bin>las2txt -h
- usage:
- las2txt lidar.las
- las2txt -parse xyziar lidar.las lidar.txt
- las2txt -i lidar.las -o lidar.laz -parse xyz
- las2txt -parse xyzt -verbose lidar.las
- las2txt -parse xyz lidar.las.gz
- las2txt -h
-The '-parse txyz' flag specifies how to format each each line of the ASCII
-file. For example, 'txyzia' means that the first number of each line should
-be the gpstime, the next three numbers should be the x, y, and z coordinate,
-the next number should be the intensity and the next number should be the
-scan angle.
-Supported entries
- * a - scan angle
- * i - intensity,
- * n - number of returns for given pulse
- * r - number of this return
- * c - classification
- * u - user data
- * p - point source ID
- * e - edge of flight line flag
- * d - direction of scan flag
-Separators
-The '-sep space' flag specifies what separator to use. The default is a
-space but 'tab', 'komma', 'colon', 'hyphen', 'dot', or 'semicolon'
-are other possibilities.
-Header Separators
-The '-header pound' flag results in the header information being printed at
-the beginning of the ASCII file in form of a comment that starts with the
-special character '#'. Also possible are 'percent', 'dollar', 'semicolon',
-'komma', 'star', 'colon', or 'semicolon' as that special character.
Modified: trunk/doc/lasdiff.txt
--- trunk/doc/lasdiff.txt (original)
+++ trunk/doc/lasdiff.txt Mon Mar 30 14:18:18 2009
@@ -1,5 +1,5 @@
- lasdiff: comparison of LAS files
+ lasdiff
@@ -7,8 +7,6 @@
:Date: $Date$
-.. sectnum::
.. contents::
:depth: 3
:backlinks: top
Modified: trunk/doc/lasinfo.txt
--- trunk/doc/lasinfo.txt (original)
+++ trunk/doc/lasinfo.txt Mon Mar 30 14:18:18 2009
@@ -1,5 +1,5 @@
- lasinfo: a utility for inspecting LAS files
+ lasinfo
@@ -9,8 +9,6 @@
:Date: $Date$
-.. sectnum::
.. contents::
:depth: 3
:backlinks: top
Modified: trunk/doc/lasmerge.txt
--- trunk/doc/lasmerge.txt (original)
+++ trunk/doc/lasmerge.txt Mon Mar 30 14:18:18 2009
@@ -7,8 +7,6 @@
:Date: $Date$
-.. sectnum::
.. contents::
:depth: 3
:backlinks: top
Modified: trunk/doc/txt2las.txt
--- trunk/doc/txt2las.txt (original)
+++ trunk/doc/txt2las.txt Mon Mar 30 14:18:18 2009
@@ -1,5 +1,6 @@
+.. _txt2las
- las2txt: converts from standard ASCII to LAS
+ txt2las
@@ -7,8 +8,6 @@
:Date: $Date$
-.. sectnum::
.. contents::
:depth: 3
:backlinks: top
More information about the Liblas-commits
