[Liblas-commits] r1260 - in trunk: include/liblas src
liblas-commits at liblas.org liblas-commits at liblas.org
Fri May 8 18:20:50 EDT 2009
Author: mloskot
Date: Fri May  8 18:20:50 2009
New Revision: 1260
URL: http://liblas.org/changeset/1260
Missing std headers, const qualifiers and some FIXME notes in lasindex.{h|cpp}.
   trunk/include/liblas/lasindex.hpp
   trunk/src/lasindex.cpp
Modified: trunk/include/liblas/lasindex.hpp
--- trunk/include/liblas/lasindex.hpp	(original)
+++ trunk/include/liblas/lasindex.hpp	Fri May  8 18:20:50 2009
@@ -66,7 +66,7 @@
     LASIndex();
-    LASIndex(std::string& filename);
+    LASIndex(std::string const& filename);
     /// Copy constructor.
     LASIndex(LASIndex const& other);
     ~LASIndex();
@@ -89,8 +89,6 @@
     std::string m_indexname;
     void Init();
 class LASVisitor : public SpatialIndex::IVisitor
Modified: trunk/src/lasindex.cpp
--- trunk/src/lasindex.cpp	(original)
+++ trunk/src/lasindex.cpp	Fri May  8 18:20:50 2009
@@ -43,7 +43,11 @@
 #include <liblas/cstdint.hpp>
 #include <liblas/guid.hpp>
+#include <cstddef>
+#include <iostream>
+#include <sstream>
+#include <string>
+#include <vector>
 namespace liblas
@@ -76,8 +80,10 @@
-LASIndex::LASIndex(std::string& filename)
+LASIndex::LASIndex(std::string const& filename)
+    // FIXME: This is not C, no need for struct.
+    // FIXME: stat is very weak name! There tons of structs in various C libs (ie. struct stat; in Windows C lib)
     struct stat stats;
     std::ostringstream os;
     os << filename << ".dat";
@@ -107,13 +113,13 @@
     Init();
 LASIndex::LASIndex(LASIndex const& other)
     std::cout << "Index copy called" << std::endl;
 LASIndex::~LASIndex()
     std::cout << "~LASIndex called" << std::endl;
@@ -204,7 +210,7 @@
 	for (std::vector<Entry*>::iterator it = m_buffer.begin(); it != m_buffer.end(); it++) delete *it;
-void LASStorageManager::loadByteArray(const id_type id, size_t& len, uint8_t** data)
+void LASStorageManager::loadByteArray(const id_type id, std::size_t& len, uint8_t** data)
 	Entry* e;
 	try
@@ -223,7 +229,7 @@
 	memcpy(*data, e->m_pData, len);
-void LASStorageManager::storeByteArray(id_type& id, const size_t len, const uint8_t* const data)
+void LASStorageManager::storeByteArray(id_type& id, const std::size_t len, const uint8_t* const data)
 	if (id == NewPage)
More information about the Liblas-commits mailing list
