[Liblas-commits] r1262 - trunk/python/examples
liblas-commits at liblas.org
Tue May 12 12:43:04 EDT 2009
Author: hobu
Date: Tue May 12 12:43:04 2009
New Revision: 1262
URL: http://liblas.org/changeset/1262
add OCI example
Added:
trunk/python/examples/
trunk/python/examples/oci_pc.py
Added: trunk/python/examples/oci_pc.py
--- (empty file)
+++ trunk/python/examples/oci_pc.py Tue May 12 12:43:04 2009
@@ -0,0 +1,74 @@
+import liblas
+import cx_Oracle
+import cx_Oracle as oci
+con = oci.Connection('lidar/lidar at ubuntu.hobu.biz/crrel.local')
+cur = con.cursor()
+def run (operations):
+ import copy
+ ops = copy.copy(operations)
+ for op in ops:
+ try:
+ print op
+ cur.execute(op)
+ except cx_Oracle.DatabaseError, e:
+ print e
+def insert_lidar(filename):
+ reader = liblas.file.File(filename)
+ i= 0
+ commit_frequency = 10000
+ sql = """INSERT INTO LIDAR_DATA (ID, GEOMETRY)
+ VALUES (:id,
+ MDSYS.SDO_GEOMETRY(3001, NULL, MDSYS.SDO_POINT_TYPE(:x,:y,:z), NULL, NULL))"""
+ rows = []
+ for p in reader:
+ # sql = "INSERT INTO LIDAR_DATA (ID, GEOMETRY) VALUES (%d,SDO_UTIL.FROM_WKTGEOMETRY('POINT(%.6f %.6f %.6f)'))" % (i, p.x,p.y,p.z)
+ # sql = "INSERT INTO LIDAR_DATA (ID, GEOMETRY) VALUES (%d, MDSYS.SDO_GEOMETRY(2001, NULL, MDSYS.SDO_POINT_TYPE(%.6f,%.6f,%.6f), NULL, NULL))" % (i,p.x,p.y,p.z)
+ # sql = "INSERT INTO LIDAR_DATA (ID, GEOMETRY) VALUES (%d, MDSYS.SDO_POINT_TYPE(6,8,10))"%i
+ row = { 'x':p.x,
+ 'y':p.y,
+ 'z':p.z,
+ 'id':i}
+ rows.append(row)
+ if i %commit_frequency == 0:
+ cur.executemany(sql, rows)
+ con.commit()
+ rows = []
+ print 'commit'
+ i+=1
+ cur.executemany(sql,rows)
+ con.commit()
+cleanup = [ "DELETE FROM BASE",
+ "DROP TABLE BASE",
+ "DROP TABLE BLKTAB",
+ "DROP TABLE INPTAB",
+ "DROP TABLE LIDAR_DATA",
+ "DELETE FROM USER_SDO_GEOM_METADATA WHERE TABLE_NAME='BASE'",
+ "DROP TABLE RESTST",
+run(cleanup)
+creation = [ 'CREATE TABLE LIDAR_DATA (ID NUMBER, GEOMETRY SDO_GEOMETRY)',
+run(creation)
+filename = '/Users/hobu/svn/liblas/trunk/test/data/TO_core_last_zoom.las'
+insert_lidar(filename)
More information about the Liblas-commits
