[Liblas-commits] r1266 - in trunk: apps include/liblas src
liblas-commits at liblas.org
Fri May 15 12:27:41 EDT 2009
Author: hobu
Date: Fri May 15 12:27:40 2009
New Revision: 1266
URL: http://liblas.org/changeset/1266
indexing does not belong in the reader
trunk/apps/lasindex.cpp
trunk/include/liblas/lasreader.hpp
trunk/src/lasreader.cpp
Modified: trunk/apps/lasindex.cpp
--- trunk/apps/lasindex.cpp (original)
+++ trunk/apps/lasindex.cpp Fri May 15 12:27:40 2009
@@ -105,43 +105,43 @@
usage();
exit(-1);
- std::cout << "input: " << input<< " output: " <<output<<std::endl;
- std::istream* istrm = OpenInput(input);
- LASReader* reader = new LASReader(*istrm);
- reader->Index(input);
- LASHeader header = reader->GetHeader();
- std::cout << "number of points: " << header.GetPointRecordsCount() << std::endl;
- for (int i=0; i< header.GetPointRecordsCount(); i++) {
- try{
- bool read = reader->ReadPointAt(i);
- LASPoint p = reader->GetPoint();
- } catch (Tools::IllegalStateException& e) {
- std::string s = e.what();
- std::cout << "error creating index" << s <<std::endl; exit(1);
- std::cout.precision(2);
- std::cout.setf(std::ios_base::fixed);
- // std::cout << "x: " << p.GetX() << " y: " << p.GetY() << std::endl;
- LASIndex* idx = reader->GetIndex();
- std::vector<liblas::uint32_t>* ids = 0;
- try{
- ids = idx->intersects(289815.12,4320979.06, 289818.01,4320982.59,46.83,170.65);
- } catch (Tools::IllegalArgumentException& e) {
- std::cout << "error querying index value" << s <<std::endl; exit(1);
- std::cout << "Vec length" << ids->size() << std::endl;
- delete reader;
- delete istrm;
+ // std::cout << "input: " << input<< " output: " <<output<<std::endl;
+ // std::istream* istrm = OpenInput(input);
+ // LASReader* reader = new LASReader(*istrm);
+ // reader->Index(input);
+ // LASHeader header = reader->GetHeader();
+ // std::cout << "number of points: " << header.GetPointRecordsCount() << std::endl;
+ // for (int i=0; i< header.GetPointRecordsCount(); i++) {
+ // try{
+ // bool read = reader->ReadPointAt(i);
+ // LASPoint p = reader->GetPoint();
+ // } catch (Tools::IllegalStateException& e) {
+ // std::string s = e.what();
+ // std::cout << "error creating index" << s <<std::endl; exit(1);
+ // std::cout.precision(2);
+ // std::cout.setf(std::ios_base::fixed);
+ // // std::cout << "x: " << p.GetX() << " y: " << p.GetY() << std::endl;
+ // LASIndex* idx = reader->GetIndex();
+ // std::vector<liblas::uint32_t>* ids = 0;
+ // try{
+ // ids = idx->intersects(289815.12,4320979.06, 289818.01,4320982.59,46.83,170.65);
+ // } catch (Tools::IllegalArgumentException& e) {
+ // std::cout << "error querying index value" << s <<std::endl; exit(1);
+ // std::cout << "Vec length" << ids->size() << std::endl;
+ // delete reader;
+ // delete istrm;
Modified: trunk/include/liblas/lasreader.hpp
--- trunk/include/liblas/lasreader.hpp (original)
+++ trunk/include/liblas/lasreader.hpp Fri May 15 12:27:40 2009
@@ -49,10 +49,6 @@
#include <liblas/lasspatialreference.hpp>
#include <liblas/detail/fwd.hpp>
-#ifdef HAVE_SPATIALINDEX
-#include <liblas/lasindex.hpp>
-#endif
// std
#include <iosfwd>
#include <string>
@@ -92,10 +88,6 @@
void Index(std::string& filename);
void Index();
- LASIndex* GetIndex();
-#endif
private:
// Blocked copying operations, declared but not defined.
@@ -109,13 +101,6 @@
LASPoint m_point;
std::vector<LASVariableRecord> m_vlrs;
- bool m_doindex;
- LASIndex* m_index;
-#else
- typedef void* LASIndex;
-#endif
} // namespace liblas
Modified: trunk/src/lasreader.cpp
--- trunk/src/lasreader.cpp (original)
+++ trunk/src/lasreader.cpp Fri May 15 12:27:40 2009
@@ -55,12 +55,9 @@
LASReader::LASReader(std::istream& ifs) :
- m_pimpl(detail::ReaderFactory::Create(ifs)),
- m_doindex(false)
+ m_pimpl(detail::ReaderFactory::Create(ifs))
- m_index = 0;
-#endif
Init();
@@ -68,9 +65,6 @@
// empty, but required so we can implement PIMPL using
// std::auto_ptr with incomplete type (Reader).
- if (m_index != 0) delete m_index;
-#endif
std::size_t LASReader::GetVersion() const
@@ -97,10 +91,6 @@
bool LASReader::ReadPointAt(std::size_t n)
bool ret = m_pimpl->ReadPointAt(n, m_point, m_header);
- if (m_doindex) m_index->insert(m_point, n);
-#endif
return ret;
@@ -156,28 +146,5 @@
return true;
-void LASReader::Index()
- m_doindex = true;
- m_index = new LASIndex();
-#endif
-void LASReader::Index(std::string& filename)
- m_doindex = true;
- m_index = new LASIndex(filename);
-#endif
-LASIndex* LASReader::GetIndex()
- return m_index;
-#endif
More information about the Liblas-commits
