[Liblas-commits] hg: haven't updated in a while
liblas-commits at liblas.org
Tue Oct 6 10:06:34 EDT 2009
changeset 272621999bc0 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=272621999bc0
summary: haven't updated in a while
diffstat:
HOWTORELEASE.txt | 37 ++++++++++++++++++++++++-------------
1 files changed, 24 insertions(+), 13 deletions(-)
diffs (79 lines):
diff -r 218c025bd810 -r 272621999bc0 HOWTORELEASE.txt
--- a/HOWTORELEASE.txt Mon Oct 05 10:58:14 2009 -0500
+++ b/HOWTORELEASE.txt Tue Oct 06 09:04:02 2009 -0500
@@ -49,7 +49,15 @@
python setup.py bdist_wininst
python setup.py bdist_egg
- - Upload Python bindings to PyPI
+ - Upload source distribution to PyPI. Do this from OS X or Linux instead
+ of windows or otherwise the source distribution will be a busted zip file
+ because setuptools sucks.
+ python setup.py sdist upload
+ - Upload Python binary bindings to PyPI
@@ -60,10 +68,10 @@
c:\python24\python.exe setup.py bdist_wininst upload
c:\python24\python.exe setup.py bdist_egg upload
c:\python25\python.exe setup.py bdist_egg upload
+ c:\python26\python.exe setup.py bdist_egg upload
- - Create a zip file from the .\bin directory. This will contain the
- utilities and relevant DLLs. The Python bindings are packaged with their
- own copies of the DLLs. I usually call this file liblas$(VERSION).zip.
+ - Copy the liblas-1.3.1-win32.zip file to a Unix box so you can generate
+ the appropriate md5 for it in #5.
4) Make the source distribution
@@ -72,32 +80,35 @@
make dist
-5) Only bz2 files can be uploaded to trac, so gunzip the dist file and
- recompress it as bz2.
-6) Generate MD5 sums
+5) Generate MD5 sums
- md5 las-0.9.7.tar.bz2
- md5 liblas0.9.7.zip
+ md5 liblas-src-1.3.1.tar.bz2 > liblas-src-1.3.1.tar.bz2.md5
+ md5 liblas-src-1.3.1.tar.gz > liblas-src-1.3.1.tar.gz.md5
+ md5 liblas-1.3.1-win32.zip > liblas-1.3.1-win32.zip.md5
6) Create a new release page on http://liblas.org/wiki/Releases
7) Upload windows and source package as attachments to the new release page.
-8) Tag the release
+8) Tag the release. Use the ``-f`` switch if you are retagging because you
+ missed something.
- svn cp http://liblas.org/svn/trunk http://liblas.org/svn/tags/0.9.7
+ hg tag 1.3.1
9) Write the release notes. Place a copy of the release notes on the release
page you created as well as send an email to liblas-devel announcing the
new release.
10) Update Freshmeat: http://freshmeat.net
+11) Update liblas.org homepage
+12) Update ohloh liblas journal entry http://www.ohloh.net/p/liblas
$Id$
More information about the Liblas-commits
