[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Oct 7 17:47:12 EDT 2009
changeset 88471ec2904e in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=88471ec2904e
summary: be more explicit for operator precedence
changeset c0caf67671c3 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=c0caf67671c3
summary: reinstate the check for extra 1.0-style pad bytes around the end of the header.  some people are writing them but not accounting for them in the dataoffset (qtmodeler)
diffstat:
 include/liblas/detail/reader.hpp |   2 +-
 src/detail/reader.cpp            |  29 ++++++++++++++++++++++++++++-
 src/detail/reader10.cpp          |  13 +++++++++++++
 src/detail/reader11.cpp          |  17 ++++++++++++++++-
 src/detail/reader12.cpp          |  13 +++++++++++++
 src/laspoint.cpp                 |   6 +++---
 6 files changed, 74 insertions(+), 6 deletions(-)
diffs (159 lines):
diff -r fdcd26af0c5a -r c0caf67671c3 include/liblas/detail/reader.hpp
--- a/include/liblas/detail/reader.hpp	Wed Oct 07 14:41:07 2009 -0500
+++ b/include/liblas/detail/reader.hpp	Wed Oct 07 16:44:33 2009 -0500
@@ -93,7 +93,7 @@
     void FillPoint(PointRecord& record, LASPoint& point, const LASHeader& header);
     void Project(LASPoint& point);
+    bool HasPointDataSignature();
 private:
     // Blocked copying operations, declared but not defined.
diff -r fdcd26af0c5a -r c0caf67671c3 src/detail/reader.cpp
--- a/src/detail/reader.cpp	Wed Oct 07 14:41:07 2009 -0500
+++ b/src/detail/reader.cpp	Wed Oct 07 16:44:33 2009 -0500
@@ -113,7 +113,6 @@
         point.SetY(y);
         point.SetZ(z);
     } else {
         point.SetX(record.x);
         point.SetY(record.y);
@@ -276,6 +275,33 @@
 #endif
+bool Reader::HasPointDataSignature()
+    uint8_t const sgn1 = 0xCC;
+    uint8_t const sgn2 = 0xDD;
+    uint8_t pad1 = 0x0;
+    uint8_t pad2 = 0x0;
+    std::streamsize const current_pos = m_ifs.tellg();
+    detail::read_n(pad1, m_ifs, sizeof(uint8_t));
+    detail::read_n(pad2, m_ifs, sizeof(uint8_t));
+    LIBLAS_SWAP_BYTES(pad1);
+    LIBLAS_SWAP_BYTES(pad2);
+    // Put the stream back where we found it
+    m_ifs.seekg(current_pos, std::ios::beg);
+    // FIXME: we have to worry about swapping issues
+    // but some people write the pad bytes backwards
+    // anyway.  Let's check both ways.
+    bool found = false;
+    if (sgn1 == pad2 && sgn2 == pad1) found = true;
+    if (sgn1 == pad1 && sgn2 == pad2) found = true;
+    return found;
 Reader* ReaderFactory::Create(std::istream& ifs)
     if (!ifs)
@@ -319,4 +345,5 @@
     p = 0;
 }} // namespace liblas::detail
diff -r fdcd26af0c5a -r c0caf67671c3 src/detail/reader10.cpp
--- a/src/detail/reader10.cpp	Wed Oct 07 14:41:07 2009 -0500
+++ b/src/detail/reader10.cpp	Wed Oct 07 16:44:33 2009 -0500
@@ -213,6 +213,19 @@
     header.SetMax(x1, y1, z1);
     header.SetMin(x2, y2, z2);
+    // We're going to check the two bytes off the end of the header to
+    // see if they're pad bytes anyway.  Some softwares, notably older QTModeler,
+    // write 1.0-style pad bytes off the end of their files but state that the
+    // offset is actually 2 bytes back.  We need to set the dataoffset
+    // appropriately in those cases anyway.
+    m_ifs.seekg(header.GetDataOffset());
+    bool has_pad = HasPointDataSignature();
+    if (has_pad) {
+        m_ifs.seekg(current_pos + 2);
+        header.SetDataOffset(header.GetDataOffset() + 2);
     Reset(header);
     return true;
diff -r fdcd26af0c5a -r c0caf67671c3 src/detail/reader11.cpp
--- a/src/detail/reader11.cpp	Wed Oct 07 14:41:07 2009 -0500
+++ b/src/detail/reader11.cpp	Wed Oct 07 16:44:33 2009 -0500
@@ -214,7 +214,20 @@
+    if (has_pad) {
     Reset(header);
     return true;
@@ -250,6 +263,8 @@
         Reader::FillPoint(record, point, header);
         point.SetCoordinates(header, point.GetX(), point.GetY(), point.GetZ());
+        // printf("ReadNextPoint: %d %d %d\n%.3f %.3f %.3f\n", record.x, record.y, record.z, point.GetX(), point.GetY(), point.GetZ());
         if (header.GetDataFormatId() == LASHeader::ePointFormat1)
diff -r fdcd26af0c5a -r c0caf67671c3 src/detail/reader12.cpp
--- a/src/detail/reader12.cpp	Wed Oct 07 14:41:07 2009 -0500
+++ b/src/detail/reader12.cpp	Wed Oct 07 16:44:33 2009 -0500
@@ -217,6 +217,19 @@
+    if (has_pad) {
     Reset(header);
     return true;
diff -r fdcd26af0c5a -r c0caf67671c3 src/laspoint.cpp
--- a/src/laspoint.cpp	Wed Oct 07 14:41:07 2009 -0500
+++ b/src/laspoint.cpp	Wed Oct 07 16:44:33 2009 -0500
@@ -94,9 +94,9 @@
 void LASPoint::SetCoordinates(LASHeader const& header, double x, double y, double z)
-    double const cx = x * header.GetScaleX() + header.GetOffsetX();
-    double const cy = y * header.GetScaleY() + header.GetOffsetY();
-    double const cz = z * header.GetScaleZ() + header.GetOffsetZ();
+    double const cx = (x * header.GetScaleX()) + header.GetOffsetX();
+    double const cy = (y * header.GetScaleY()) + header.GetOffsetY();
+    double const cz = (z * header.GetScaleZ()) + header.GetOffsetZ();
     SetCoordinates(cx, cy, cz);
More information about the Liblas-commits mailing list
