[Liblas-commits] hg: support setting the block table name too
liblas-commits at liblas.org
Thu Oct 8 22:47:30 EDT 2009
changeset 6c6b2300ac38 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=6c6b2300ac38
summary: support setting the block table name too
diffstat:
apps/las2oci.cpp | 44 ++++++++++++++++++++++++++++++++++++++------
1 files changed, 38 insertions(+), 6 deletions(-)
diffs (98 lines):
diff -r 62b4f0cbfe30 -r 6c6b2300ac38 apps/las2oci.cpp
--- a/apps/las2oci.cpp Thu Oct 08 12:08:42 2009 -0500
+++ b/apps/las2oci.cpp Thu Oct 08 21:44:39 2009 -0500
@@ -20,6 +20,8 @@
#include <algorithm>
#include <cctype>
+#include <sys/stat.h>
#ifdef HAVE_SPATIALINDEX
#include <spatialindex/SpatialIndex.h>
#endif
@@ -474,6 +476,23 @@
void usage() {}
+bool ExternalIndexExists(std::string& filename)
+ struct stat stats;
+ std::ostringstream os;
+ os << filename << ".dat";
+ std::string indexname = os.str();
+ // ret is -1 for no file existing and 0 for existing
+ int ret = stat(indexname.c_str(),&stats);
+ bool output = false;
+ if (ret == 0) output= true; else output =false;
+ return output;
// select sdo_pc_pkg.to_geometry(a.points, a.num_points, 3, 8307) from NACHES_BAREEARTH_BLOCK1 a where a.obj_id= 8907
int main(int argc, char* argv[])
@@ -483,10 +502,10 @@
std::string username;
std::string password;
std::string instance;
- std::string block_table_name;
std::string point_cloud_name("CLOUD");
std::string base_table_name("HOBU");
+ std::string block_table_name("");
bool bDropTable = false;
liblas::uint32_t nCapacity = 10000;
double dFillFactor = 0.99;
@@ -556,6 +575,14 @@
i++;
base_table_name = std::string(argv[i]);
+ else if ( strcmp(argv[i],"--block-table-name") == 0 ||
+ strcmp(argv[i],"-bk") == 0
+ i++;
+ printf("have bk");
+ block_table_name = std::string(argv[i]);
else if (input.empty())
input = std::string(argv[i]);
@@ -571,7 +598,13 @@
+ string table_name ;
+ if (block_table_name.size() == 0) {
+ string::size_type dot_pos = input.find_first_of(".");
+ table_name = input.substr(0,dot_pos);
+ } else {
+ table_name = block_table_name;
string::size_type slash_pos = connection.find("/",0);
username = connection.substr(0,slash_pos);
string::size_type at_pos = connection.find("@",slash_pos);
@@ -580,7 +613,7 @@
instance = connection.substr(at_pos+1);
std::cout << "Connecting with username: " << username << " password: "<< password<< " instance: " << instance << std::endl;
- std::cout << "Base table name " << base_table_name << " cloud column: " << point_cloud_name << std::endl;
+ std::cout << "Base table name " << base_table_name << " cloud column: " << point_cloud_name <<" block table: " << block_table_name << std::endl;
if (bDropTable) std::cout << "dropping existing tables..." << std::endl;
// OCI_SUCCESS_WITH_INFO error, which according to google relates to
// a warning related to expired or expiring passwords needs to be
@@ -619,8 +652,7 @@
// and no extraneous characters.
// We need an option for the user to specify the blk tablename
- string::size_type dot_pos = input.find_first_of(".");
- string table_name = input.substr(0,dot_pos);
if (bDropTable) DeleteTable(con, table_name.c_str(), base_table_name.c_str(), point_cloud_name.c_str());
CreateTable(con, table_name.c_str());
More information about the Liblas-commits
