[Liblas-commits] hg: Added a bunch of asserts to make it easier to
debug laswrite...
liblas-commits at liblas.org
Sat Oct 10 22:16:46 EDT 2009
changeset e638fd7bc2d8 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=e638fd7bc2d8
summary: Added a bunch of asserts to make it easier to debug laswrite problems with breaking file (lasreader reports EOF error)
diffstat:
include/liblas/detail/utility.hpp | 7 +++++++
src/detail/reader10.cpp | 1 +
src/lasreader.cpp | 1 -
test/unit/laswriter_test.cpp | 5 +++++
4 files changed, 13 insertions(+), 1 deletions(-)
diffs (93 lines):
diff -r af24c7e8c91c -r e638fd7bc2d8 include/liblas/detail/utility.hpp
--- a/include/liblas/detail/utility.hpp Sat Oct 10 02:30:57 2009 +0100
+++ b/include/liblas/detail/utility.hpp Sun Oct 11 03:16:37 2009 +0100
@@ -371,6 +371,8 @@
template <typename T>
inline void read_n(T& dest, std::istream& src, std::streamsize const& num)
+ assert(src);
// TODO: Review and redesign errors handling logic if necessary
if (!src)
throw std::runtime_error("detail::liblas::read_n input stream is not readable");
@@ -386,6 +388,8 @@
template <>
inline void read_n<PointRecord>(PointRecord& dest, std::istream& src, std::streamsize const& num)
+ assert(src);
if (!src)
@@ -408,6 +412,8 @@
template <>
inline void read_n<VLRHeader>(VLRHeader& dest, std::istream& src, std::streamsize const& num)
+ assert(src);
if (!src)
@@ -424,6 +430,7 @@
template <>
inline void read_n<std::string>(std::string& dest, std::istream& src, std::streamsize const& num)
+ assert(src);
assert(dest.max_size() >= static_cast<std::string::size_type>(num));
diff -r af24c7e8c91c -r e638fd7bc2d8 src/detail/reader10.cpp
--- a/src/detail/reader10.cpp Sat Oct 10 02:30:57 2009 +0100
+++ b/src/detail/reader10.cpp Sun Oct 11 03:16:37 2009 +0100
@@ -89,6 +89,7 @@
read_n(fsig, m_ifs, 4);
header.SetFileSignature(fsig);
// 2. Reserved
// This data must always contain Zeros.
read_n(n4, m_ifs, sizeof(n4));
diff -r af24c7e8c91c -r e638fd7bc2d8 src/lasreader.cpp
--- a/src/lasreader.cpp Sat Oct 10 02:30:57 2009 +0100
+++ b/src/lasreader.cpp Sun Oct 11 03:16:37 2009 +0100
@@ -58,7 +58,6 @@
m_pimpl(detail::ReaderFactory::Create(ifs)),
bCustomHeader(false)
Init();
diff -r af24c7e8c91c -r e638fd7bc2d8 test/unit/laswriter_test.cpp
--- a/test/unit/laswriter_test.cpp Sat Oct 10 02:30:57 2009 +0100
+++ b/test/unit/laswriter_test.cpp Sun Oct 11 03:16:37 2009 +0100
@@ -68,10 +68,13 @@
test_default_header(hdr_default);
+ exit(0);
// Read previously created LAS file and check its header block
std::ifstream ifs;
ifs.open(tmpfile_.c_str(), std::ios::in | std::ios::binary);
+ ensure(ifs.is_open());
liblas::LASReader reader(ifs);
ensure_equals<std::size_t>(reader.GetVersion(), liblas::eLASVersion12);
@@ -125,6 +128,7 @@
std::ifstream ifs;
liblas::LASPoint point; // reusable cache
@@ -215,6 +219,7 @@
std::ifstream ifs;
liblas::LASHeader const& header = reader.GetHeader();
More information about the Liblas-commits
