[Liblas-commits] hg: use 4327 for the default srid and identify the
index type as 3d
liblas-commits at liblas.org
Tue Oct 13 22:28:33 EDT 2009
changeset 487723ab179f in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=487723ab179f
summary: use 4327 for the default srid and identify the index type as 3d
diffstat:
apps/las2oci.cpp | 10 +++++-----
1 files changed, 5 insertions(+), 5 deletions(-)
diffs (48 lines):
diff -r 5d1ceaf7f036 -r 487723ab179f apps/las2oci.cpp
--- a/apps/las2oci.cpp Tue Oct 13 15:18:05 2009 -0500
+++ b/apps/las2oci.cpp Tue Oct 13 21:25:48 2009 -0500
@@ -391,7 +391,7 @@
// MDSYS.SDO_DIM_ARRAY(
// MDSYS.SDO_DIM_ELEMENT('X', 630250.000000, 630500.000000, 0.05),
// MDSYS.SDO_DIM_ELEMENT('Y', 4834500, 4834750, 0.05)),
-// 8307)
+// 4327)
oss << "INSERT INTO user_sdo_geom_metadata VALUES ('" << tableName <<
"','blk_extent', MDSYS.SDO_DIM_ARRAY("
@@ -412,7 +412,7 @@
ostringstream oss;
OWStatement* statement = 0;
- oss << "CREATE INDEX "<< tableName <<"_cloud_idx on "<<tableName<<"(blk_extent) INDEXTYPE IS MDSYS.SPATIAL_INDEX" ;
+ oss << "CREATE INDEX "<< tableName <<"_cloud_idx on "<<tableName<<"(blk_extent) INDEXTYPE IS MDSYS.SPATIAL_INDEX PARAMETERS('sdo_indx_dims=3')" ;
statement = Run(connection, oss);
if (statement != 0) delete statement; else return false;
oss.str("");
@@ -527,7 +527,7 @@
fprintf(stderr,"las2oci -i output.las lidar/lidar at oraclemachine/instance \n"
"--block-table-name hobu_blocks --base-table-name hobu_base\n"
- "--cloud-column-name PC --srid 8307 -d\n");
+ "--cloud-column-name PC --srid 4327 -d\n");
@@ -553,7 +553,7 @@
-// select sdo_pc_pkg.to_geometry(a.points, a.num_points, 3, 8307) from NACHES_BAREEARTH_BLOCK1 a where a.obj_id= 8907
+// select sdo_pc_pkg.to_geometry(a.points, a.num_points, 3, 4327) from NACHES_BAREEARTH_BLOCK1 a where a.obj_id= 8907
int main(int argc, char* argv[])
@@ -570,7 +570,7 @@
bool bDropTable = false;
liblas::uint32_t nCapacity = 10000;
double dFillFactor = 0.99;
- int srid = 8307;
+ int srid = 4327;
for (int i = 1; i < argc; i++)
More information about the Liblas-commits
