[Liblas-commits] hg: build/cmake: Fixed test if ENV{OSGEO4W_ROOT}
is defined in C...
liblas-commits at liblas.org
Mon Oct 19 17:15:40 EDT 2009
changeset 86bdc137f776 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=86bdc137f776
summary: build/cmake: Fixed test if ENV{OSGEO4W_ROOT} is defined in CMake macros.
diffstat:
build/cmake/FindGDAL.cmake | 2 +-
build/cmake/FindGeoTIFF.cmake | 2 +-
build/cmake/FindSpatialIndex.cmake | 2 +-
3 files changed, 3 insertions(+), 3 deletions(-)
diffs (36 lines):
diff -r 2f33d0723e98 -r 86bdc137f776 build/cmake/FindGDAL.cmake
--- a/build/cmake/FindGDAL.cmake Mon Oct 19 22:00:35 2009 +0100
+++ b/build/cmake/FindGDAL.cmake Mon Oct 19 22:15:30 2009 +0100
@@ -21,7 +21,7 @@
IF(WIN32)
SET(OSGEO4W_IMPORT_LIBRARY gdal_i)
- IF($ENV{OSGEO4W_ROOT})
+ IF(DEFINED ENV{OSGEO4W_ROOT})
SET(OSGEO4W_ROOT_DIR $ENV{OSGEO4W_ROOT})
MESSAGE(STATUS "Trying OSGeo4W using environment variable OSGEO4W_ROOT=$ENV{OSGEO4W_ROOT}")
ELSE()
diff -r 2f33d0723e98 -r 86bdc137f776 build/cmake/FindGeoTIFF.cmake
--- a/build/cmake/FindGeoTIFF.cmake Mon Oct 19 22:00:35 2009 +0100
+++ b/build/cmake/FindGeoTIFF.cmake Mon Oct 19 22:15:30 2009 +0100
@@ -27,7 +27,7 @@
IF(WIN32)
SET(OSGEO4W_IMPORT_LIBRARY geotiff_i)
ELSE()
diff -r 2f33d0723e98 -r 86bdc137f776 build/cmake/FindSpatialIndex.cmake
--- a/build/cmake/FindSpatialIndex.cmake Mon Oct 19 22:00:35 2009 +0100
+++ b/build/cmake/FindSpatialIndex.cmake Mon Oct 19 22:15:30 2009 +0100
@@ -22,7 +22,7 @@
IF(WIN32)
SET(OSGEO4W_IMPORT_LIBRARY spatialindex_i)
ELSE()
More information about the Liblas-commits
