[Liblas-commits] hg: default to 4326 for 2d geodedic case,
use 2d geometry for PC...
liblas-commits at liblas.org
Fri Oct 23 15:15:45 EDT 2009
changeset 5355055d225d in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=5355055d225d
summary: default to 4326 for 2d geodedic case, use 2d geometry for PC creation if we're 2d
diffstat:
apps/las2oci.cpp | 47 ++++++++++++++++++++++++++++++++---------------
1 files changed, 32 insertions(+), 15 deletions(-)
diffs (109 lines):
diff -r 6ead09c2f4b9 -r 5355055d225d apps/las2oci.cpp
--- a/apps/las2oci.cpp Fri Oct 23 12:16:35 2009 -0500
+++ b/apps/las2oci.cpp Fri Oct 23 14:12:47 2009 -0500
@@ -317,7 +317,7 @@
bUse3d = false;
- if (srid == 4327) {
+ if (srid == 4326) {
bUse3d = false;
bUseSolidGeometry = false;
} else {
@@ -439,7 +439,7 @@
s_srid << srid;
bUse3d = false;
oss << "INSERT INTO user_sdo_geom_metadata VALUES ('" << tableName <<
@@ -479,7 +479,7 @@
bUse3d = true;
bUse3d = false;
@@ -582,10 +582,15 @@
ostringstream s_srid;
ostringstream s_gtype;
ostringstream s_eleminfo;
+ ostringstream s_geom;
+ bool bUse3d = true;
if (srid == 0) {
s_srid << "NULL";}
else {
+ bUse3d = false;
s_srid << srid;
if (bUseSolidGeometry == true) {
@@ -599,6 +604,25 @@
+ s_geom << " mdsys.sdo_geometry("<<s_gtype.str() <<", "<<s_srid.str()<<", null,\n"
+" mdsys.sdo_elem_info_array"<< s_eleminfo.str() <<",\n"
+" mdsys.sdo_ordinate_array(\n";
+ s_geom << query->bounds.getLow(0) <<","<<
+ query->bounds.getLow(1) <<",";
+ if (bUse3d)
+ s_geom << query->bounds.getLow(2) <<",";
+ s_geom << query->bounds.getHigh(0) <<","<<
+ query->bounds.getHigh(1);
+ if (bUse3d)
+ s_geom <<","<< query->bounds.getHigh(2);
+ s_geom << "))";
oss << "declare\n"
" pc_id NUMBER := :1;\n"
" pc sdo_pc;\n"
@@ -610,15 +634,8 @@
" '"<< cloudColumnName_u<<"', -- Column name of the SDO_POINT_CLOUD object\n"
" '"<<blkTableName_u<<"', -- Table to store blocks of the point cloud\n"
" 'blk_capacity="<<blk_capacity<<"', -- max # of points per block\n"
-" mdsys.sdo_geometry("<<s_gtype.str() <<", "<<s_srid.str()<<", null,\n"
-" mdsys.sdo_elem_info_array"<< s_eleminfo.str() <<",\n"
-" mdsys.sdo_ordinate_array(\n"
-<< query->bounds.getLow(0) << ","
-<< query->bounds.getLow(1) << ","
-<< query->bounds.getLow(2) << ","
-<< query->bounds.getHigh(0) << ","
-<< query->bounds.getHigh(1) << ","
-<< query->bounds.getHigh(2) << ")), -- Extent\n"
+<< s_geom.str() <<
+", -- Extent\n"
" 0.5, -- Tolerance for point cloud\n"
" "<<nDimension<<", -- Total number of dimensions\n"
" null);\n"
@@ -668,7 +685,7 @@
fprintf(stderr,"las2oci -i output.las lidar/lidar at oraclemachine/instance \n"
"--block-table-name hobu_blocks --base-table-name hobu_base\n"
- "--cloud-column-name PC --srid 4327 -d\n");
+ "--cloud-column-name PC --srid 4326 -d\n");
@@ -694,7 +711,7 @@
-// select sdo_pc_pkg.to_geometry(a.points, a.num_points, 3, 4327) from NACHES_BAREEARTH_BLOCK1 a where a.obj_id= 8907
+// select sdo_pc_pkg.to_geometry(a.points, a.num_points, 3, 4326) from NACHES_BAREEARTH_BLOCK1 a where a.obj_id= 8907
int main(int argc, char* argv[])
More information about the Liblas-commits
