[Liblas-commits] hg: fix up 4326 case to work like Dan's examples
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Oct 23 22:32:57 EDT 2009
changeset 5e54e79a89a7 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=5e54e79a89a7
summary: fix up 4326 case to work like Dan's examples
diffstat:
 apps/las2oci.cpp |  129 +++++++++++++++++++++++++++++++------------
 1 files changed, 93 insertions(+), 36 deletions(-)
diffs (230 lines):
diff -r e06f2ddbbb43 -r 5e54e79a89a7 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Fri Oct 23 15:58:31 2009 -0500
+++ b/apps/las2oci.cpp	Fri Oct 23 21:29:54 2009 -0500
@@ -306,31 +306,33 @@
     ostringstream s_gtype;
     ostringstream s_eleminfo;
     bool bUse3d = true;
+    bool bGeographic = true;
     if (srid == 0) {
         s_srid << "NULL";
         bUse3d = true;
         bUseSolidGeometry = true;
+    else if (srid == 4326) {
+        bUse3d = true;
+        bUseSolidGeometry = true;
+        bGeographic = true;
+        s_srid << "NULL";
     else {
         s_srid << srid;
         bUse3d = false;
-    if (srid == 4326) {
-        bUse3d = false;
-        bUseSolidGeometry = false;
-    } else {
         // If the user set an srid and set it to solid, we're still 3d
         if (bUseSolidGeometry == true)
             bUse3d = true;
     if (bUseSolidGeometry == true) {
         s_gtype << "3008";
         s_eleminfo << "(1,1007,3)";
     } else {
-        s_gtype << "2003";
+        s_gtype << "3003";
         s_eleminfo  << "(1,1003,3)";
@@ -338,22 +340,37 @@
     // std::cout << "use 3d?: " << bUse3d << " srid: " << s_srid.str() << std::endl;
     oss_geom.setf(std::ios_base::fixed, std::ios_base::floatfield);
     oss_geom.precision(precision);
-    oss_geom << "mdsys.sdo_geometry(" << s_gtype.str() << "," << s_srid.str() << ", null,";
-    oss_geom << "mdsys.sdo_elem_info_array" << s_eleminfo.str() << ",";
-    oss_geom << "mdsys.sdo_ordinate_array("<< b->getLow(0) <<","<<
+    oss_geom << "           mdsys.sdo_geometry("<<s_gtype.str() <<", "<<s_srid.str()<<", null,\n"
+"              mdsys.sdo_elem_info_array"<< s_eleminfo.str() <<",\n"
+"              mdsys.sdo_ordinate_array(\n";
+    oss_geom << b->getLow(0) <<","<<
                                             b->getLow(1) <<",";
-    if (bUse3d)
-        oss_geom <<                         b->getLow(2) <<",";
+    if (bUse3d) {
+        if (!bGeographic) {
+            oss_geom <<                         b->getLow(2) <<",";
+        } else {
+            oss_geom <<"0,";
     oss_geom <<                             b->getHigh(0) <<","<<
                                             b->getHigh(1);
-    if (bUse3d)
-        oss_geom                            <<","<< b->getHigh(2);
+    if (bUse3d) {
+            oss_geom                            <<","<< b->getHigh(2);
+        } else {
+            oss_geom <<",20000";
     oss_geom << "))";
-    oss << "INSERT INTO "<< tableName << "(OBJ_ID, BLK_ID, NUM_POINTS, BLK_EXTENT, POINTS) VALUES ( "
-                         << pc_id << "," << result.GetID() <<"," << num_points << ", " << oss_geom.str() <<", EMPTY_BLOB())";
+    oss << "INSERT INTO "<< tableName <<
+            "(OBJ_ID, BLK_ID, NUM_POINTS, BLK_EXTENT, POINTS, PCBLK_MIN_RES, PCBLK_MAX_RES, NUM_UNSORTED_POINTS, PT_SORT_DIM) VALUES ( "
+            << pc_id << "," << result.GetID() <<"," << num_points << ", "
+            << oss_geom.str() <<", EMPTY_BLOB(), 1, 1, 0, 1)";
     OWStatement* statement = 0;
     statement = connection->CreateStatement(oss.str().c_str());
@@ -427,6 +444,7 @@
     ostringstream s_srid;
     bool bUse3d = false;
+    bool bGeographic = false;
         bUse3d = true;
@@ -435,21 +453,36 @@
     if (srid == 0) {
         s_srid << "NULL";
         bUse3d = true;
+        s_srid << "NULL";
+        bUse3d = true;
     } else {
         s_srid << srid;
-        bUse3d = false;
+    oss <<  "INSERT INTO user_sdo_geom_metadata VALUES ('" << tableName <<
+        "','blk_extent', MDSYS.SDO_DIM_ARRAY(";
+    if (bGeographic == true) {
+        oss << "MDSYS.SDO_DIM_ELEMENT('X', -180, 180, .000000005),"
+               "MDSYS.SDO_DIM_ELEMENT('Y', -180, 180, .000000005)";
+    } else {
+        oss << "MDSYS.SDO_DIM_ELEMENT('X', "<< query->bounds.getLow(0) <<","<< query->bounds.getHigh(0)<<",0.05),"
+            "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05)";
-    oss <<  "INSERT INTO user_sdo_geom_metadata VALUES ('" << tableName <<
-            "','blk_extent', MDSYS.SDO_DIM_ARRAY("
-            "MDSYS.SDO_DIM_ELEMENT('X', "<< query->bounds.getLow(0) <<","<< query->bounds.getHigh(0)<<",0.05),"
-            "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05)";
+            // "MDSYS.SDO_DIM_ELEMENT('X', "<< query->bounds.getLow(0) <<","<< query->bounds.getHigh(0)<<",0.05),"
+            // "MDSYS.SDO_DIM_ELEMENT('Y', "<< query->bounds.getLow(1) <<","<< query->bounds.getHigh(1)<<",0.05)";
     if (bUse3d) {
-        oss << "," <<
-            "MDSYS.SDO_DIM_ELEMENT('Z', "<< query->bounds.getLow(2) <<","<< query->bounds.getHigh(2)<<",0.05)";
+        oss << ",";
+        if (bGeographic)
+            oss <<"MDSYS.SDO_DIM_ELEMENT('Z', "<< 0 <<","<< 200000<<",0.000000005)";
+        else
+            oss << "MDSYS.SDO_DIM_ELEMENT('Z', "<< query->bounds.getLow(2) <<","<< query->bounds.getHigh(2)<<",0.00000005)";
     oss << ")," << s_srid.str() << ")";
@@ -480,7 +513,7 @@
     if (srid == 4326) {
-        bUse3d = false;
+        bUse3d = true;
     oss << "CREATE INDEX "<< tableName <<"_cloud_idx on "<<tableName<<"(blk_extent) INDEXTYPE IS MDSYS.SPATIAL_INDEX";
@@ -583,27 +616,41 @@
     ostringstream s_geom;
+    bool bUse3d = true;
-    bool bUse3d = true;
     if (srid == 0) {
-        s_srid << "NULL";}
+        s_srid << "NULL";
+        bUse3d = true;
+        bUse3d = true;
+        bUseSolidGeometry = false;
+        s_srid << "NULL";
     else {
-            bUse3d = false;
         s_srid << srid;
+        bUse3d = false;
+        // If the user set an srid and set it to solid, we're still 3d
+        if (bUseSolidGeometry == true)
+            bUse3d = true;
         s_gtype << "3008";
     } else {
@@ -611,13 +658,23 @@
     s_geom << query->bounds.getLow(0) <<","<<
                                             query->bounds.getLow(1) <<",";
-    if (bUse3d)
-        s_geom <<                         query->bounds.getLow(2) <<",";
+    if (bUse3d) {
+            s_geom <<                         query->bounds.getLow(2) <<",";
+        } else {
+            s_geom <<"0,";
     s_geom <<                             query->bounds.getHigh(0) <<","<<
                                             query->bounds.getHigh(1);
-    if (bUse3d)
-        s_geom                            <<","<< query->bounds.getHigh(2);
+    if (bUse3d) {
+            s_geom                            <<","<< query->bounds.getHigh(2);
+        } else {
+            s_geom <<",20000";
     s_geom << "))";
More information about the Liblas-commits mailing list
