[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Oct 26 13:30:13 EDT 2009
changeset 5bfa8fedf282 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=5bfa8fedf282
summary: smarten up reprojection, use header's SRS if it is there and we haven't set one with -s_srs
changeset f21138c20a3a in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=f21138c20a3a
summary: add support for #153, a --thin option
diffstat:
 apps/las2las.c |  75 +++++++++++++++++++++++++++++++------
 1 files changed, 63 insertions(+), 12 deletions(-)
diffs (161 lines):
diff -r e9158c0af165 -r f21138c20a3a apps/las2las.c
--- a/apps/las2las.c	Sat Oct 24 22:01:06 2009 -0500
+++ b/apps/las2las.c	Mon Oct 26 12:26:56 2009 -0500
@@ -147,7 +147,11 @@
     int eliminated_intensity = 0;
     int eliminated_class = 0;
     int eliminated_first_only = 0;
-    int eliminated_last_only = 0;
+    int eliminated_last_only = 0;
+    int thinned = 0;
+    int bThin = FALSE;
+    int nThin = 0;
     double xyz_scale[3] = {0.0, 0.0, 0.0};
     double xyz_offset[3] = {0.0, 0.0, 0.0};
@@ -156,6 +160,7 @@
     LASPointSummary* summary = NULL;
+    char* in_wkt = NULL;
     int ret = 0;
     for (i = 1; i < argc; i++) {
@@ -317,7 +322,8 @@
         else if (   strcmp(argv[i],"--t_srs") == 0  ||
-                    strcmp(argv[i],"-t_srs") == 0
+                    strcmp(argv[i],"-t_srs") == 0    ||
+                    strcmp(argv[i],"-t") == 0
             ++i;
@@ -381,6 +387,15 @@
             do_pad_header = TRUE;
             header_pad = atoi(argv[i]);
+        else if (   strcmp(argv[i],"--thin") == 0  ||
+                    strcmp(argv[i],"-y") == 0
+            i++;
+            bThin = TRUE;
+            nThin = atoi(argv[i]);
+            printf("nThin %d\n");
         else if (file_name_in == NULL && file_name_out == NULL)
             file_name_in = argv[i];
@@ -435,9 +450,15 @@
         exit(1);
+    i = 0;
     while (p)
+        if (bThin && ((i % nThin) != 0)) {
+            thinned++;
+            i++;
+            p = LASReader_GetNextPoint(reader);
+            continue;
         if (last_only && LASPoint_GetReturnNumber(p) != LASPoint_GetNumberOfReturns(p))
             eliminated_last_only++;
@@ -572,7 +593,7 @@
+        i++;
     if (eliminated_first_only)
@@ -604,6 +625,11 @@
         "eliminated based on intensity: %d\n",
         eliminated_intensity);
+    if (bThin)
+        fprintf(stderr,
+        "thinned: %d\n",
+        thinned);
     LASReader_Destroy(reader);
     LASHeader_Destroy(header);
@@ -794,6 +820,12 @@
                 "Setting new coordinate system to %s", proj4_text);
             free(proj4_text);
+        /* keep around the header's SRS if we don't have on set by the user */
+        if (in_srs == NULL) {
+            in_srs = LASHeader_GetSRS(surviving_header);
         LASHeader_SetSRS(surviving_header, out_srs);
@@ -815,16 +847,27 @@
         exit(1);
-    if (in_srs != NULL) {
-        LASWriter_SetInputSRS(writer, in_srs);
+    if (do_reprojection) {
+        if (in_srs != NULL) {
+            char* in_wkt = LASSRS_GetWKT(in_srs);
+            if (strlen(in_wkt) == 0) {
+                free(in_wkt);
+                LASError_Print("Input SRS is empty, please specify with -s_srs");
+                exit(1);
+            free(in_wkt);
+            LASWriter_SetInputSRS(writer, in_srs);
+        } else {
-    if (out_srs != NULL) {
-        if (verbose) {
-            fprintf(stderr,
-                "Setting LASWriter_SetOutputSRS to %s", LASSRS_GetProj4(out_srs));
+        if (out_srs != NULL) {
+            if (verbose) {
+                fprintf(stderr,
+                    "Setting LASWriter_SetOutputSRS to %s", LASSRS_GetProj4(out_srs));
+            LASWriter_SetOutputSRS(writer, out_srs);
-        LASWriter_SetOutputSRS(writer, out_srs);
@@ -865,8 +908,15 @@
         exit(1);
+    i = 0;
     while (p) {
+            i++;
+            continue;
         if (skip_invalid && !LASPoint_IsValid(p)) {
             continue;
@@ -919,6 +969,7 @@
         LASWriter_WritePoint(writer,p);
+        i++;
     LASWriter_Destroy(writer);
More information about the Liblas-commits mailing list
