[Liblas-commits] hg: Added FindGDAL macro (thanks to QGIS) to CMake builder. Now, ...
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Sep 25 19:14:26 EDT 2009
changeset ac99edd0005f in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=ac99edd0005f
summary: Added FindGDAL macro (thanks to QGIS) to CMake builder. Now, CMake can detect GDAL and GeoTIFF dependencies and build libLAS linking against these libraries.
diffstat:
 CMakeLists.txt                |   14 +--
 build/cmake/FindGDAL.cmake    |  153 ++++++++++++++++++++++++++++++++++++++
 build/cmake/FindGeoTIFF.cmake |    3 +
 src/CMakeLists.txt            |   12 +--
 test/unit/CMakeLists.txt      |    5 +-
 5 files changed, 169 insertions(+), 18 deletions(-)
diffs (256 lines):
diff -r b961d01e4905 -r ac99edd0005f CMakeLists.txt
--- a/CMakeLists.txt	Fri Sep 25 15:00:36 2009 -0500
+++ b/CMakeLists.txt	Sat Sep 26 00:14:15 2009 +0100
@@ -57,6 +57,11 @@
 # Search for dependencies
+FIND_PACKAGE(GDAL)
+IF (GDAL_FOUND)
+	ADD_DEFINITIONS( -D HAVE_GDAL )
+ENDIF (GDAL_FOUND)
 # GeoTIFF support (optional)
 FIND_PACKAGE(GeoTIFF)
 IF (GEOTIFF_FOUND)
@@ -65,15 +70,6 @@
 	ADD_DEFINITIONS( -D HAVE_LIBGEOTIFF )
 ENDIF (GEOTIFF_FOUND)
-# GDAL support (optional)
-FIND_PACKAGE(GDAL)
-IF (GDAL_FOUND)
-	#TODO: Use to generate config.h
-	#SET (HAVE_GDAL TRUE)
-	ADD_DEFINITIONS( -D HAVE_GDAL )
-ENDIF (GDAL_FOUND)
 # List of directories to process
diff -r b961d01e4905 -r ac99edd0005f build/cmake/FindGDAL.cmake
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/build/cmake/FindGDAL.cmake	Sat Sep 26 00:14:15 2009 +0100
@@ -0,0 +1,153 @@
+# $Id$
+# Macro to find GDAL library.
+# Once run this will define:
+# GDAL_FOUND       = system has GDAL lib
+# GDAL_LIBRARY     = full path to the library
+# GDAL_INCLUDE_DIR = where to find headers
+# Author of original: Magnus Homann (Quantum GIS)
+# Modifified by libLAS team.
+IF(WIN32)
+    IF (MINGW)
+        FIND_PATH(GDAL_INCLUDE_DIR gdal.h /usr/local/include /usr/include c:/msys/local/include)
+        FIND_LIBRARY(GDAL_LIBRARY NAMES gdal PATHS /usr/local/lib /usr/lib c:/msys/local/lib)
+    ENDIF (MINGW)
+    IF (MSVC)
+        SET (GDAL_INCLUDE_DIR
+            "$ENV{LIB_DIR}/include/gdal"
+            CACHE STRING INTERNAL
+        FIND_LIBRARY(GDAL_LIBRARY NAMES gdal gdal_i PATHS "$ENV{LIB_DIR}/lib" /usr/lib c:/msys/local/lib)
+        IF (GDAL_LIBRARY)
+            SET (GDAL_LIBRARY;odbc32;odbccp32 CACHE STRING INTERNAL)
+        ENDIF (GDAL_LIBRARY)
+    ENDIF (MSVC)
+ELSE(WIN32)
+    IF(UNIX)
+        # try to use framework on mac
+    IF (APPLE)
+        SET (GDAL_MAC_PATH /Library/Frameworks/GDAL.framework/unix/bin)
+    ENDIF (APPLE)
+    SET(GDAL_CONFIG_PREFER_PATH
+        "$ENV{GDAL_HOME}/bin" CACHE STRING "preferred path to GDAL (gdal-config)"
+    SET(GDAL_CONFIG_PREFER_FWTOOLS_PATH
+        "$ENV{FWTOOLS_HOME}/bin_safe" CACHE STRING "preferred path to GDAL (gdal-config) from FWTools"
+    FIND_PROGRAM(GDAL_CONFIG gdal-config
+        ${GDAL_CONFIG_PREFER_PATH}
+        ${GDAL_CONFIG_PREFER_FWTOOLS_PATH}
+        ${GDAL_MAC_PATH}
+        /usr/local/bin/
+        /usr/bin/
+    #MESSAGE("DBG GDAL_CONFIG ${GDAL_CONFIG}")
+    IF (GDAL_CONFIG)
+        # extract gdal version
+        EXEC_PROGRAM(${GDAL_CONFIG}
+            ARGS --version
+            OUTPUT_VARIABLE GDAL_VERSION
+        STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)\\.([0-9]+)" "\\1" GDAL_VERSION_MAJOR "${GDAL_VERSION}")
+        STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)\\.([0-9]+)" "\\2" GDAL_VERSION_MINOR "${GDAL_VERSION}")
+        #MESSAGE("DBG GDAL_VERSION ${GDAL_VERSION}")
+        #MESSAGE("DBG GDAL_VERSION_MAJOR ${GDAL_VERSION_MAJOR}")
+        #MESSAGE("DBG GDAL_VERSION_MINOR ${GDAL_VERSION_MINOR}")
+        # check for gdal version
+        # version 1.2.5 is known NOT to be supported (missing CPL_STDCALL macro)
+        # According to INSTALL, 1.4.0+ is required
+        IF (GDAL_VERSION_MAJOR LESS 1 OR GDAL_VERSION_MINOR LESS 4)
+            MESSAGE (FATAL_ERROR "GDAL version is too old (${GDAL_VERSION}). Use 1.4.0 or higher.")
+        ENDIF (GDAL_VERSION_MAJOR LESS 1 OR GDAL_VERSION_MINOR LESS 4)
+        # set INCLUDE_DIR to prefix+include
+        EXEC_PROGRAM(${GDAL_CONFIG} ARGS --prefix OUTPUT_VARIABLE GDAL_PREFIX)
+        #SET(GDAL_INCLUDE_DIR ${GDAL_PREFIX}/include CACHE STRING INTERNAL)
+            gdal.h
+            ${GDAL_PREFIX}/include/gdal
+            /usr/local/include
+            /usr/include
+        # extract link dirs for rpath
+        EXEC_PROGRAM(${GDAL_CONFIG} ARGS --libs OUTPUT_VARIABLE GDAL_CONFIG_LIBS )
+        # split off the link dirs (for rpath)
+        # use regular expression to match wildcard equivalent "-L*<endchar>"
+        # with <endchar> is a space or a semicolon
+        STRING(REGEX MATCHALL "[-][L]([^ ;])+"
+            GDAL_LINK_DIRECTORIES_WITH_PREFIX
+            "${GDAL_CONFIG_LIBS}"
+        # MESSAGE("DBG  GDAL_LINK_DIRECTORIES_WITH_PREFIX=${GDAL_LINK_DIRECTORIES_WITH_PREFIX}")
+        # remove prefix -L because we need the pure directory for LINK_DIRECTORIES
+        IF (GDAL_LINK_DIRECTORIES_WITH_PREFIX)
+            STRING(REGEX REPLACE "[-][L]" "" GDAL_LINK_DIRECTORIES ${GDAL_LINK_DIRECTORIES_WITH_PREFIX} )
+        ENDIF (GDAL_LINK_DIRECTORIES_WITH_PREFIX)
+        # split off the name
+        # use regular expression to match wildcard equivalent "-l*<endchar>"
+        STRING(REGEX MATCHALL "[-][l]([^ ;])+"
+            GDAL_LIB_NAME_WITH_PREFIX
+        #MESSAGE("DBG  GDAL_LIB_NAME_WITH_PREFIX=${GDAL_LIB_NAME_WITH_PREFIX}")
+        # remove prefix -l because we need the pure name
+        IF (GDAL_LIB_NAME_WITH_PREFIX)
+            STRING(REGEX REPLACE "[-][l]" "" GDAL_LIB_NAME ${GDAL_LIB_NAME_WITH_PREFIX} )
+        ENDIF (GDAL_LIB_NAME_WITH_PREFIX)
+        IF (APPLE)
+            SET(GDAL_LIBRARY ${GDAL_LINK_DIRECTORIES}/lib${GDAL_LIB_NAME}.dylib CACHE STRING INTERNAL)
+        ELSE (APPLE)
+            SET(GDAL_LIBRARY ${GDAL_LINK_DIRECTORIES}/lib${GDAL_LIB_NAME}.so CACHE STRING INTERNAL)
+        ENDIF (APPLE)
+    ELSE(GDAL_CONFIG)
+        MESSAGE("FindGDAL.cmake: gdal-config not found. Please set it manually. GDAL_CONFIG=${GDAL_CONFIG}")
+    ENDIF(GDAL_CONFIG)
+  ENDIF(UNIX)
+ENDIF(WIN32)
+IF (GDAL_INCLUDE_DIR AND GDAL_LIBRARY)
+    SET(GDAL_FOUND TRUE)
+ENDIF (GDAL_INCLUDE_DIR AND GDAL_LIBRARY)
+IF (GDAL_FOUND)
+    IF (NOT GDAL_FIND_QUIETLY)
+        MESSAGE(STATUS "Found GDAL: ${GDAL_LIBRARY}")
+    ENDIF (NOT GDAL_FIND_QUIETLY)
+ELSE (GDAL_FOUND)
+    MESSAGE(GDAL_INCLUDE_DIR=${GDAL_INCLUDE_DIR})
+    MESSAGE(GDAL_LIBRARY=${GDAL_LIBRARY})
+    MESSAGE(FATAL_ERROR "Could not find GDAL")
+ENDIF (GDAL_FOUND)
diff -r b961d01e4905 -r ac99edd0005f build/cmake/FindGeoTIFF.cmake
--- a/build/cmake/FindGeoTIFF.cmake	Fri Sep 25 15:00:36 2009 -0500
+++ b/build/cmake/FindGeoTIFF.cmake	Sat Sep 26 00:14:15 2009 +0100
@@ -1,3 +1,5 @@
+# $Id$
 # CMake module to search for GeoTIFF library
 # If it's found it sets GEOTIFF_FOUND to TRUE
@@ -12,6 +14,7 @@
 # and then again with no specified paths to search the default
 # locations. When an earlier FIND_* succeeds, subsequent FIND_*s
 # searching for the same item do nothing.
 FIND_PATH(GEOTIFF_INCLUDE_DIR geotiff.h
   "$ENV{LIB_DIR}/include"
   "$ENV{LIB_DIR}/include/geotiff"
diff -r b961d01e4905 -r ac99edd0005f src/CMakeLists.txt
--- a/src/CMakeLists.txt	Fri Sep 25 15:00:36 2009 -0500
+++ b/src/CMakeLists.txt	Sat Sep 26 00:14:15 2009 +0100
@@ -89,15 +89,10 @@
     ADD_DEFINITIONS( /Za )
 ENDIF (WIN32)
-# Configure GeoTIFF support (optional)
-IF (GEOTIFF_FOUND)
-    INCLUDE_DIRECTORIES( ${GEOTIFF_INCLUDE_DIR} )
-ELSE (GEOTIFF_FOUND)
-    SET(GEOTIFF_LIBRARY "")
-ENDIF (GEOTIFF_FOUND)
-    ../include
+    ../include
+    ${GDAL_INCLUDE_DIR}
+    ${GEOTIFF_INCLUDE_DIR}
 # Static library with libLAS C++ core
@@ -107,6 +102,7 @@
 ADD_LIBRARY( ${LIBLAS_C_LIB_NAME} SHARED ${LIBLAS_C_SOURCES} )
 TARGET_LINK_LIBRARIES( ${LIBLAS_C_LIB_NAME}
 	${LIBLAS_LIB_NAME}
+	${GDAL_LIBRARY}
 	${GEOTIFF_LIBRARY}
diff -r b961d01e4905 -r ac99edd0005f test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt	Fri Sep 25 15:00:36 2009 -0500
+++ b/test/unit/CMakeLists.txt	Sat Sep 26 00:14:15 2009 +0100
@@ -22,13 +22,16 @@
     ../../include
 ADD_EXECUTABLE( ${LIBLAS_TEST} ${LIBLAS_TEST_SRC} )
 TARGET_LINK_LIBRARIES( ${LIBLAS_TEST}
     ${LIBLAS_LIB_NAME}
-    ${GEOTIFF_LIBRARY}
+	${GDAL_LIBRARY}
+	${GEOTIFF_LIBRARY}
 # TODO: Needs to tweak the executable path
More information about the Liblas-commits mailing list
