[Liblas-commits] hg: Updated CMake configuration with WITH_GDAL,
WITH_GEOTIFF, WI...
liblas-commits at liblas.org
Sat Sep 26 21:18:56 EDT 2009
changeset ee7febfbdac6 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=ee7febfbdac6
summary: Updated CMake configuration with WITH_GDAL, WITH_GEOTIFF, WITH_ZLIB options and added zlib support. Significant refactoring and improvements to CMake macros.
diffstat:
CMakeLists.txt | 301 ++++++++++++++----------------------------
build/cmake/FindGDAL.cmake | 192 +++++++++++++--------------
build/cmake/FindGeoTIFF.cmake | 77 ++++++----
src/CMakeLists.txt | 142 +++++++++++---------
4 files changed, 313 insertions(+), 399 deletions(-)
diffs (truncated from 880 to 300 lines):
diff -r bba105eab4d9 -r ee7febfbdac6 CMakeLists.txt
--- a/CMakeLists.txt Sat Sep 26 16:55:56 2009 +0100
+++ b/CMakeLists.txt Sun Sep 27 02:18:46 2009 +0100
@@ -1,237 +1,134 @@
-# $Id$
+# Main CMake configuration file for libLAS
-# Top-level CMakeList.txt for libLAS
+# Author: Mateusz Loskot <mateusz at loskot.net>
# WARNING (mloskot): A PROTOTYPE - WORK IN PROGRESS - FEEL FREE TO IMPROVE
-PROJECT( libLAS )
+# libLAS general settings
+PROJECT(libLAS)
-SET( LIBLAS_LIB_NAME las )
-SET( LIBLAS_C_LIB_NAME las_c )
+# Name of C++ library
+SET(LIBLAS_LIB_NAME las)
+# Name of C library
+SET(LIBLAS_C_LIB_NAME las_c)
+# Choose package components
+SET(WITH_UTILITIES TRUE CACHE BOOL "Choose if libLAS utilities should be built")
+SET(WITH_TESTS FALSE CACHE BOOL "Choose if libLAS unit tests should be built")
# CMake settings
CMAKE_MINIMUM_REQUIRED( VERSION 2.4.0 )
-SET( CMAKE_COLOR_MAKEFILE ON )
+SET(CMAKE_COLOR_MAKEFILE ON)
# Path to additional CMake modules
SET(CMAKE_MODULE_PATH ${CMAKE_SOURCE_DIR}/build/cmake ${CMAKE_MODULE_PATH})
-# Building general settings
+# Build type settings
IF(NOT CMAKE_BUILD_TYPE)
- SET(CMAKE_BUILD_TYPE Debug CACHE STRING
- "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel."
- FORCE)
-ENDIF(NOT CMAKE_BUILD_TYPE)
+ SET(CMAKE_BUILD_TYPE Debug CACHE STRING
+ "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel"
+ FORCE)
+ENDIF()
+SET(BUILD_PEDANTIC TRUE CACHE BOOL "Choose compilation in pedantic or relaxed mode")
# Platform and compiler specific settings
-IF (WIN32)
- ADD_DEFINITIONS( /W4 )
+IF(WIN32)
+ IF (MSVC)
+ IF(BUILD_PEDANTIC)
+ SET(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
+ ENDIF()
- IF (MSVC)
IF (MSVC80)
- ADD_DEFINITIONS( /D_CRT_SECURE_NO_WARNINGS )
- ADD_DEFINITIONS( /D_CRT_NONSTDC_NO_WARNING )
- ENDIF (MSVC80)
- ENDIF (MSVC)
-ELSE (WIN32)
+ ADD_DEFINITIONS(-D_CRT_SECURE_NO_WARNINGS)
+ ADD_DEFINITIONS(-D_CRT_NONSTDC_NO_WARNING)
+ ENDIF()
+ ENDIF()
+ELSE()
+ IF(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
+ SET(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fPIC -Wall -Wno-long-long -ansi")
- IF (CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
- ADD_DEFINITIONS( -Wall -Wno-long-long -pedantic -ansi -fPIC )
+ SET(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -pedantic")
+ ENDIF()
+ IF (CMAKE_COMPILER_IS_GNUCXX)
+ SET(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++98")
+ ENDIF()
+ ENDIF()
+ENDIF(WIN32)
- IF (CMAKE_COMPILER_IS_GNUCXX)
- SET( CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++98" )
- ENDIF (CMAKE_COMPILER_IS_GNUCXX)
- ENDIF (CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
-ENDIF (WIN32)
# Search for dependencies
-FIND_PACKAGE(GDAL)
-IF (GDAL_FOUND)
- ADD_DEFINITIONS( -D HAVE_GDAL )
-ENDIF (GDAL_FOUND)
+# zlib support - optional, default=OFF
+SET(WITH_ZLIB FALSE CACHE BOOL "Choose if zlib support should be built")
-# GeoTIFF support (optional)
-FIND_PACKAGE(GeoTIFF)
-IF (GEOTIFF_FOUND)
- #TODO: Use to generate config.h
- #SET (HAVE_LIBGEOTIFF TRUE)
- ADD_DEFINITIONS( -D HAVE_LIBGEOTIFF )
-ENDIF (GEOTIFF_FOUND)
+IF(WITH_ZLIB)
+ FIND_PACKAGE(ZLIB)
+ IF(ZLIB_FOUND)
+ ADD_DEFINITIONS(-DHAVE_ZLIB)
+ ENDIF()
+ENDIF()
+# GDAL/OGR support - optional, default=OFF
+SET(WITH_GDAL FALSE CACHE BOOL "Choose if GDAL support should be built")
+IF(WITH_GDAL)
+ FIND_PACKAGE(GDAL 1.6.0)
+ IF (GDAL_FOUND)
+ ADD_DEFINITIONS(-DHAVE_GDAL)
+ ENDIF()
+ENDIF()
+# GeoTIFF support - optional, default=OFF
+SET(WITH_GEOTIFF FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
+IF(WITH_GEOTIFF)
+ FIND_PACKAGE(GeoTIFF 1.2.5)
+ IF(GEOTIFF_FOUND)
+ ADD_DEFINITIONS(-DHAVE_LIBGEOTIFF)
+ ENDIF()
+ENDIF()
+# Spatial Index support - optional, default=OFF
+# TODO
+# Oracle support - optional, default=OFF
+# TODO
+# Boost C++ Libraries support - optional, default=OFF
+# TODO
# List of directories to process
-SUBDIRS(
- include
- src
- apps
- test
+ADD_SUBDIRECTORY(src)
+IF(WITH_UTILITIES)
+ ADD_SUBDIRECTORY(apps)
+ENDIF()
+IF(WITH_TESTS)
+ ADD_SUBDIRECTORY(test)
+ENDIF()
-IF (XXX_FOUND)
+# Output configuration summary
-########## THE HUGE BLOCK BELOW IS TO LEARN CMAKE AND WILL BE REMOVED ###############
-# ------------------------- Begin Generic CMake Variable Logging ------------------
-MESSAGE( STATUS "=============== BEGIN TEST VARIABLES LOGGING OUTPUT =============" )
-# if you are building in-source, this is the same as CMAKE_SOURCE_DIR, otherwise
-# this is the top level directory of your build tree
-MESSAGE( STATUS "CMAKE_BINARY_DIR: " ${CMAKE_BINARY_DIR} )
-# if you are building in-source, this is the same as CMAKE_CURRENT_SOURCE_DIR, otherwise this
-# is the directory where the compiled or generated files from the current CMakeLists.txt will go to
-MESSAGE( STATUS "CMAKE_CURRENT_BINARY_DIR: " ${CMAKE_CURRENT_BINARY_DIR} )
-# this is the directory, from which cmake was started, i.e. the top level source directory
-MESSAGE( STATUS "CMAKE_SOURCE_DIR: " ${CMAKE_SOURCE_DIR} )
-# this is the directory where the currently processed CMakeLists.txt is located in
-MESSAGE( STATUS "CMAKE_CURRENT_SOURCE_DIR: " ${CMAKE_CURRENT_SOURCE_DIR} )
-# contains the full path to the top level directory of your build tree
-MESSAGE( STATUS "PROJECT_BINARY_DIR: " ${PROJECT_BINARY_DIR} )
-# contains the full path to the root of your project source directory,
-# i.e. to the nearest directory where CMakeLists.txt contains the PROJECT() command
-MESSAGE( STATUS "PROJECT_SOURCE_DIR: " ${PROJECT_SOURCE_DIR} )
-# set this variable to specify a common place where CMake should put all executable files
-# (instead of CMAKE_CURRENT_BINARY_DIR)
-MESSAGE( STATUS "EXECUTABLE_OUTPUT_PATH: " ${EXECUTABLE_OUTPUT_PATH} )
-# set this variable to specify a common place where CMake should put all libraries
-MESSAGE( STATUS "LIBRARY_OUTPUT_PATH: " ${LIBRARY_OUTPUT_PATH} )
-# tell CMake to search first in directories listed in CMAKE_MODULE_PATH
-# when you use FIND_PACKAGE() or INCLUDE()
-MESSAGE( STATUS "CMAKE_MODULE_PATH: " ${CMAKE_MODULE_PATH} )
-# this is the complete path of the cmake which runs currently (e.g. /usr/local/bin/cmake)
-MESSAGE( STATUS "CMAKE_COMMAND: " ${CMAKE_COMMAND} )
-# this is the CMake installation directory
-MESSAGE( STATUS "CMAKE_ROOT: " ${CMAKE_ROOT} )
-# this is the filename including the complete path of the file where this variable is used.
-MESSAGE( STATUS "CMAKE_CURRENT_LIST_FILE: " ${CMAKE_CURRENT_LIST_FILE} )
-# this is linenumber where the variable is used
-MESSAGE( STATUS "CMAKE_CURRENT_LIST_LINE: " ${CMAKE_CURRENT_LIST_LINE} )
-# this is used when searching for include files e.g. using the FIND_PATH() command.
-MESSAGE( STATUS "CMAKE_INCLUDE_PATH: " ${CMAKE_INCLUDE_PATH} )
-# this is used when searching for libraries e.g. using the FIND_LIBRARY() command.
-MESSAGE( STATUS "CMAKE_LIBRARY_PATH: " ${CMAKE_LIBRARY_PATH} )
-# the complete system name, e.g. "Linux-2.4.22", "FreeBSD-5.4-RELEASE" or "Windows 5.1"
-MESSAGE( STATUS "CMAKE_SYSTEM: " ${CMAKE_SYSTEM} )
-# the short system name, e.g. "Linux", "FreeBSD" or "Windows"
-MESSAGE( STATUS "CMAKE_SYSTEM_NAME: " ${CMAKE_SYSTEM_NAME} )
-# only the version part of CMAKE_SYSTEM
-MESSAGE( STATUS "CMAKE_SYSTEM_VERSION: " ${CMAKE_SYSTEM_VERSION} )
-# the processor name (e.g. "Intel(R) Pentium(R) M processor 2.00GHz")
-MESSAGE( STATUS "CMAKE_SYSTEM_PROCESSOR: " ${CMAKE_SYSTEM_PROCESSOR} )
-# is TRUE on all UNIX-like OS's, including Apple OS X and CygWin
-MESSAGE( STATUS "UNIX: " ${UNIX} )
-# is TRUE on Windows, including CygWin
-MESSAGE( STATUS "WIN32: " ${WIN32} )
-# is TRUE on Apple OS X
-MESSAGE( STATUS "APPLE: " ${APPLE} )
-# is TRUE when using the MinGW compiler in Windows
-MESSAGE( STATUS "MINGW: " ${MINGW} )
-# is TRUE on Windows when using the CygWin version of cmake
-MESSAGE( STATUS "CYGWIN: " ${CYGWIN} )
-# is TRUE on Windows when using a Borland compiler
-MESSAGE( STATUS "BORLAND: " ${BORLAND} )
-# Microsoft compiler
-MESSAGE( STATUS "MSVC: " ${MSVC} )
-MESSAGE( STATUS "MSVC_IDE: " ${MSVC_IDE} )
-MESSAGE( STATUS "MSVC60: " ${MSVC60} )
-MESSAGE( STATUS "MSVC70: " ${MSVC70} )
-MESSAGE( STATUS "MSVC71: " ${MSVC71} )
-MESSAGE( STATUS "MSVC80: " ${MSVC80} )
-MESSAGE( STATUS "CMAKE_COMPILER_2005: " ${CMAKE_COMPILER_2005} )
-# set this to true if you don't want to rebuild the object files if the rules have changed,
-# but not the actual source files or headers (e.g. if you changed the some compiler switches)
-MESSAGE( STATUS "CMAKE_SKIP_RULE_DEPENDENCY: " ${CMAKE_SKIP_RULE_DEPENDENCY} )
-# since CMake 2.1 the install rule depends on all, i.e. everything will be built before installing.
-# If you don't like this, set this one to true.
-MESSAGE( STATUS "CMAKE_SKIP_INSTALL_ALL_DEPENDENCY: " ${CMAKE_SKIP_INSTALL_ALL_DEPENDENCY} )
-# If set, runtime paths are not added when using shared libraries. Default it is set to OFF
-MESSAGE( STATUS "CMAKE_SKIP_RPATH: " ${CMAKE_SKIP_RPATH} )
-# set this to true if you are using makefiles and want to see the full compile and link
-# commands instead of only the shortened ones
-MESSAGE( STATUS "CMAKE_VERBOSE_MAKEFILE: " ${CMAKE_VERBOSE_MAKEFILE} )
-# this will cause CMake to not put in the rules that re-run CMake. This might be useful if
-# you want to use the generated build files on another machine.
More information about the Liblas-commits
