[Liblas-commits] hg: [cmake] Added check for ST_Create function in
GeoTIFF librar...
liblas-commits at liblas.org
Mon Sep 28 19:00:15 EDT 2009
changeset 246d96e3395a in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=246d96e3395a
summary: [cmake] Added check for ST_Create function in GeoTIFF library (Ticket #52)
diffstat:
CMakeLists.txt | 14 ++++++++++++--
1 files changed, 12 insertions(+), 2 deletions(-)
diffs (24 lines):
diff -r 00a83380e688 -r 246d96e3395a CMakeLists.txt
--- a/CMakeLists.txt Mon Sep 28 18:08:49 2009 +0100
+++ b/CMakeLists.txt Tue Sep 29 00:00:06 2009 +0100
@@ -99,8 +99,18 @@
FIND_PACKAGE(GeoTIFF 1.2.5)
IF(GEOTIFF_FOUND)
- INCLUDE_DIRECTORIES(${GEOTIFF_INCLUDE_DIR})
- ADD_DEFINITIONS(-DHAVE_LIBGEOTIFF=1)
+ INCLUDE(CheckFunctionExists)
+ SET(CMAKE_REQUIRED_LIBRARIES ${GEOTIFF_LIBRARY})
+ CHECK_FUNCTION_EXISTS(ST_Create HAVE_ST_CREATE)
+ IF(NOT HAVE_ST_CREATE)
+ SET(GEOTIFF_FOUND) # Reset to NOT found for GeoTIFF
+ MESSAGE(FATAL_ERROR "GeoTIFF support requires libgeotiff 1.2.5 or newer.")
+ ELSE()
+ INCLUDE_DIRECTORIES(${GEOTIFF_INCLUDE_DIR})
+ ADD_DEFINITIONS(-DHAVE_LIBGEOTIFF=1)
+ ENDIF()
ENDIF()
ENDIF()
More information about the Liblas-commits
