[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Wed Sep 30 11:50:41 EDT 2009
changeset 75dd1030c673 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=75dd1030c673
summary: add the example script to grab classes out of a file
changeset 9cde96b45e48 in /home/www/liblas.org/hg
details: http://hg.liblas.org/main/hg?cmd=changeset;node=9cde96b45e48
summary: ignore some python stuff
diffstat:
.hgignore | 5 ++-
python/examples/grab_classes.py | 62 +++++++++++++++++++++++++++++++
2 files changed, 66 insertions(+), 1 deletions(-)
diffs (80 lines):
diff -r 42d56ee70cea -r 9cde96b45e48 .hgignore
--- a/.hgignore Wed Sep 30 00:29:37 2009 +0100
+++ b/.hgignore Wed Sep 30 10:50:34 2009 -0500
@@ -32,4 +32,7 @@
Makefile.in
build.hobu
test/data/*.dat
-test/data/*.idx
\ No newline at end of file
+test/data/*.idx
+python/build/*
+python/dist/*
+python/libLAS.egg-info/*
diff -r 42d56ee70cea -r 9cde96b45e48 python/examples/grab_classes.py
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/python/examples/grab_classes.py Wed Sep 30 10:50:34 2009 -0500
@@ -0,0 +1,62 @@
+from liblas import file
+from liblas import point
+import sys
+import getopt
+def extract_classifications(infile, outfile, classifications):
+ inp = file.File(infile, mode='r')
+ header = inp.header
+ output = file.File(outfile, mode='w', header=header)
+ cnt = 0
+ for p in inp:
+ cls = p.classification
+ if int(cls) in classifications:
+ output.write(p)
+ cnt += 1 # keep a new count
+ inp.close()
+ output.close()
+ del inp
+ del output
+ # overwrite our header with our point count
+ header.point_records_count = cnt
+ output = file.File(outfile, mode='w+', header=header)
+ output.close()
+ del output
+ print 'wrote %d points' % cnt
+def usage():
+ print "grab_classes.py"
+ print "\n"
+ print "--input input.las - Input file name"
+ print "--output output.las - Output file name"
+ print "--classifications 0,1,2,11 - The classifications to keep "
+ sys.exit(2)
+def main():
+ infile = None
+ outfile = None
+ classifications = None
+ try:
+ opts, args = getopt.getopt(sys.argv[1:],
+ "i:o:c:",
+ ["input=","output=","classifications="])
+ except getopt.GetoptError, err:
+ print str(err)
+ usage()
+ sys.exit(2)
+ for o, a in opts:
+ print o, a
+ if o in ["-i", "--input"]:
+ infile = a
+ if o in ["-o", "--output"]:
+ outfile = a
+ if o in ["-c", "--classifications"]:
+ try:
+ classifications = [int(i) for i in a.split(',')]
+ except:
+ classifications = int(a)
+ if not infile or not outfile:
+ usage()
+ print 'Input: ', infile
+ print 'Output: ', outfile
+ print 'Classifications to fetch: ', classifications
+ extract_classifications(infile, outfile, classifications)
+if __name__ == "__main__":
+ main()
More information about the Liblas-commits
