[Liblas-commits] hg: cache and use PointFormat to determine what to
write in deta...
liblas-commits at liblas.org
Thu Apr 8 12:11:33 EDT 2010
changeset 62a51c68d6a5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=62a51c68d6a5
summary: cache and use PointFormat to determine what to write in detail::writer::Point
diffstat:
include/liblas/detail/writer/point.hpp | 1 +
src/detail/writer/point.cpp | 78 +++++++++++++++++----------------
2 files changed, 42 insertions(+), 37 deletions(-)
diffs (130 lines):
diff -r 8f77899df915 -r 62a51c68d6a5 include/liblas/detail/writer/point.hpp
--- a/include/liblas/detail/writer/point.hpp Thu Apr 08 09:00:40 2010 -0500
+++ b/include/liblas/detail/writer/point.hpp Thu Apr 08 11:05:26 2010 -0500
@@ -101,6 +101,7 @@
PointRecord m_record;
+ PointFormat m_format;
void project();
void setup();
void fill();
diff -r 8f77899df915 -r 62a51c68d6a5 src/detail/writer/point.cpp
--- a/src/detail/writer/point.cpp Thu Apr 08 09:00:40 2010 -0500
+++ b/src/detail/writer/point.cpp Thu Apr 08 11:05:26 2010 -0500
@@ -62,7 +62,8 @@
m_ofs(ofs),
m_header(header),
m_point(liblas::Point()),
- m_transform(0)
+ m_transform(0),
+ m_format(header.GetPointFormat())
setup();
@@ -70,8 +71,13 @@
Point::Point( std::ostream& ofs,
liblas::uint32_t& count,
const liblas::Header& header,
- OGRCoordinateTransformationH transform) : Base(ofs, count),
- m_ofs(ofs), m_header(header), m_point(liblas::Point()), m_transform(transform)
+ OGRCoordinateTransformationH transform) :
+ Base(ofs, count),
+ m_ofs(ofs),
+ m_header(header),
+ m_point(liblas::Point()),
+ m_transform(transform),
setup();
@@ -91,49 +97,47 @@
uint16_t green = 0;
liblas::Color color;
- // std::size_t byteswritten(0);
+ std::size_t byteswritten(0);
m_point = point;
fill();
detail::write_n(m_ofs, m_record, sizeof(m_record));
- // byteswritten += sizeof(PointRecord);
+ byteswritten += sizeof(PointRecord);
- if (m_header.GetDataFormatId() == liblas::ePointFormat1)
+ if (m_format.HasTime())
t = point.GetTime();
detail::write_n(m_ofs, t, sizeof(double));
+ byteswritten += sizeof(double);
+ if (m_format.HasColor())
+ color = point.GetColor();
+ red = color.GetRed();
+ green = color.GetGreen();
+ blue = color.GetBlue();
+ detail::write_n(m_ofs, red, sizeof(uint16_t));
+ detail::write_n(m_ofs, green, sizeof(uint16_t));
+ detail::write_n(m_ofs, blue, sizeof(uint16_t));
+ byteswritten += 3 * sizeof(uint16_t);
+ } else {
- // byteswritten += sizeof(double);
- else if (m_header.GetDataFormatId() == liblas::ePointFormat2)
- color = point.GetColor();
- red = color.GetRed();
- green = color.GetGreen();
- blue = color.GetBlue();
- detail::write_n(m_ofs, red, sizeof(uint16_t));
- detail::write_n(m_ofs, green, sizeof(uint16_t));
- detail::write_n(m_ofs, blue, sizeof(uint16_t));
- // byteswritten += 3 * sizeof(uint16_t);
- else if (m_header.GetDataFormatId() == liblas::ePointFormat3)
- t = point.GetTime();
- detail::write_n(m_ofs, t, sizeof(double));
liblas::uint32_t& count = GetPointCount();
count++;
@@ -141,7 +145,7 @@
// write in our extra data that the user set on the
// point up to the header's specified DataRecordLength
- if (m_header.GetPointFormat().GetByteSize() != m_header.GetDataRecordLength()) {
+ if (m_format.GetByteSize() != m_header.GetDataRecordLength()) {
std::vector<uint8_t> const& data = point.GetExtraData();
std::streamsize const size = static_cast<std::streamsize>(m_header.GetDataRecordLength() - data.size());
detail::write_n(GetStream(), data.front(), size);
More information about the Liblas-commits
