[Liblas-commits] hg: ExtraData support complete
liblas-commits at liblas.org
Mon Apr 12 15:02:05 EDT 2010
changeset 4c7a8a986f66 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4c7a8a986f66
summary: ExtraData support complete
diffstat:
include/liblas/capi/liblas.h | 3 ++
include/liblas/lasformat.hpp | 2 +
python/liblas/core.py | 4 ++
python/liblas/format.py | 8 +++++-
python/liblas/point.py | 2 +-
python/tests/File.txt | 59 ++++++++++++++++++++++++++++++++++++++++++++
python/tests/Format.txt | 5 ++-
src/detail/reader/point.cpp | 26 ++++++++++--------
src/detail/writer/point.cpp | 30 ++++++++++++++++++++--
src/las_c_api.cpp | 9 ++++++
src/lasformat.cpp | 5 +++
11 files changed, 135 insertions(+), 18 deletions(-)
diffs (274 lines):
diff -r 726c6e34ca1c -r 4c7a8a986f66 include/liblas/capi/liblas.h
--- a/include/liblas/capi/liblas.h Mon Apr 12 08:59:26 2010 -0500
+++ b/include/liblas/capi/liblas.h Mon Apr 12 13:56:09 2010 -0500
@@ -1179,6 +1179,9 @@
LAS_DLL LASError LASPointFormat_SetTime( LASPointFormatH hFormat, uint8_t bTime);
LAS_DLL uint16_t LASPointFormat_GetByteSize( LASPointFormatH hFormat);
LAS_DLL LASError LASPointFormat_SetByteSize( LASPointFormatH hFormat, uint16_t size);
+LAS_DLL uint16_t LASPointFormat_GetBaseByteSize( LASPointFormatH hFormat);
+LAS_DLL LASError LASPointFormat_SetBaseByteSize( LASPointFormatH hFormat, uint16_t size);
LAS_DLL LASPointFormatH LASHeader_GetPointFormat( LASHeaderH hHeader );
LAS_DLL LASError LASHeader_SetPointFormat( LASHeaderH hHeader, LASPointFormatH hFormat);
diff -r 726c6e34ca1c -r 4c7a8a986f66 include/liblas/lasformat.hpp
--- a/include/liblas/lasformat.hpp Mon Apr 12 08:59:26 2010 -0500
+++ b/include/liblas/lasformat.hpp Mon Apr 12 13:56:09 2010 -0500
@@ -76,6 +76,8 @@
/// Set value of the red image channel
void SetByteSize(uint16_t const& value);
+ /// Get the base size (only accounting for Time, Color, etc )
+ uint16_t GetBaseByteSize() const;
uint8_t GetVersionMajor() const;
void SetVersionMajor(uint8_t const& value);
diff -r 726c6e34ca1c -r 4c7a8a986f66 python/liblas/core.py
--- a/python/liblas/core.py Mon Apr 12 08:59:26 2010 -0500
+++ b/python/liblas/core.py Mon Apr 12 13:56:09 2010 -0500
@@ -708,6 +708,10 @@
las.LASPointFormat_SetByteSize.argtypes = [ctypes.c_void_p, ctypes.c_ushort]
las.LASPointFormat_SetByteSize.errcheck = check_return
+las.LASPointFormat_GetBaseByteSize.restype = ctypes.c_ushort
+las.LASPointFormat_GetBaseByteSize.argtypes = [ctypes.c_void_p]
+las.LASPointFormat_GetBaseByteSize.errcheck = check_value
las.LASPointFormat_HasColor.restype = ctypes.c_uint8
las.LASPointFormat_HasColor.argtypes = [ctypes.c_void_p]
las.LASPointFormat_HasColor.errcheck = check_value
diff -r 726c6e34ca1c -r 4c7a8a986f66 python/liblas/format.py
--- a/python/liblas/format.py Mon Apr 12 08:59:26 2010 -0500
+++ b/python/liblas/format.py Mon Apr 12 13:56:09 2010 -0500
@@ -109,8 +109,14 @@
return core.las.LASPointFormat_SetByteSize(self.handle, int(value))
doc = """Size in bytes of the format. """
- size = property(get_size, set_size)
+ size = property(get_size, set_size, None, doc)
+ def get_base_size(self):
+ return core.las.LASPointFormat_GetBaseByteSize(self.handle)
+ doc = """Base size in bytes of the format. (only accounting for time, color, etc.)"""
+ base_size = property(get_base_size, None, None, doc)
def get_color(self):
return bool(core.las.LASPointFormat_HasColor(self.handle))
diff -r 726c6e34ca1c -r 4c7a8a986f66 python/liblas/point.py
--- a/python/liblas/point.py Mon Apr 12 08:59:26 2010 -0500
+++ b/python/liblas/point.py Mon Apr 12 13:56:09 2010 -0500
@@ -423,7 +423,7 @@
for i in range(l.contents.value):
s[i] = d2.contents[i]
p_d = ctypes.cast(d, ctypes.POINTER(ctypes.c_char_p))
- core.las.LASString_Free(p_d)
+ # core.las.LASString_Free(p_d)
return s
diff -r 726c6e34ca1c -r 4c7a8a986f66 python/tests/File.txt
--- a/python/tests/File.txt Mon Apr 12 08:59:26 2010 -0500
+++ b/python/tests/File.txt Mon Apr 12 13:56:09 2010 -0500
@@ -250,7 +250,65 @@
630323.57
630320.95
630280.89
+The following tests writing out point data that are larger in size than
+the base point format, allowing you to store extra data.
+ >>> f6 = file.File('../test/data/TO_core_last_clip.las')
+ >>> p2 = f6.read(6)
+ >>> p2.x, p2.y, p2.z
+ (630320.95999999996, 4834500.0, 55.009999999999998)
+ >>> h6 = f6.header
+ >>> f = h6.format
+ >>> f.time = True
+ >>> f.color = True
+ >>> f.size = 52
+ >>> h6.format = f
+ >>> h6.data_record_length
+ 52
+f.size - f.base_size will be 16 bytes of space (h6.data_record_length - 34 bytes for point format 3)
+>>> import ctypes
+ >>> d = (ctypes.c_ubyte * (f.size - f.base_size))()
+ >>> d[10]
+ 0
+ >>> d[0] = 13
+ >>> d2 = (ctypes.c_ubyte * 6)()
+ >>> d2[0] = 11
+ >>> f7 = file.File('junk5.las',mode='w', header=h6)
+ >>> i = 0
+ >>> for p in points:
+ ... if i == 0:
+ ... p.data = d
+ ... if i == 1:
+ ... p.data = d2
+ ... i = i + 1
+ ... f7.write(p)
+ >>> f7.close()
+ >>> del f7
+ >>> f8 = file.File('junk5.las')
+ >>> f8.header.data_record_length
+ 52
+ >>> p = f8[0].data[0]
+ >>> p
+ 13
+ >>> p = f8[0].data[15]
+ >>> p
+ 0
+ >>> p = f8[1].data[0]
+ >>> p
+ 11
>>> import os
>>> os.remove('junk.las')
>>> os.remove('junk2.las')
@@ -272,3 +330,4 @@
diff -r 726c6e34ca1c -r 4c7a8a986f66 python/tests/Format.txt
--- a/python/tests/Format.txt Mon Apr 12 08:59:26 2010 -0500
+++ b/python/tests/Format.txt Mon Apr 12 13:56:09 2010 -0500
@@ -62,4 +62,7 @@
>>> h.format = f
>>> h.data_record_length
- 40
\ No newline at end of file
+ 40
+ >>> f.base_size
+ 20
diff -r 726c6e34ca1c -r 4c7a8a986f66 src/detail/reader/point.cpp
--- a/src/detail/reader/point.cpp Mon Apr 12 08:59:26 2010 -0500
+++ b/src/detail/reader/point.cpp Mon Apr 12 13:56:09 2010 -0500
@@ -140,16 +140,8 @@
- if (bytesread != m_format.GetByteSize()) {
- std::ostringstream msg;
- msg << "The number of bytes that were read ("<< bytesread <<") does not "
- "match the number of bytes the point's format "
- "says it should have (" <<
- m_format.GetByteSize() << ")";
- throw std::runtime_error(msg.str());
- if (m_format.GetByteSize() != m_header.GetDataRecordLength())
+ if (m_format.GetBaseByteSize() != m_format.GetByteSize())
std::size_t bytesleft = m_header.GetDataRecordLength() - bytesread;
@@ -160,8 +152,18 @@
m_point.SetExtraData(data);
- // off_type const pos(static_cast<off_type>(m_header.GetDataRecordLength() - bytesread));
- // m_ifs.seekg(pos, std::ios::cur);
+ bytesread = bytesread + bytesleft;
+ if (bytesread != m_format.GetByteSize()) {
+ std::ostringstream msg;
+ msg << "The number of bytes that were read ("<< bytesread <<") does not "
+ "match the number of bytes the point's format "
+ "says it should have (" <<
+ m_format.GetByteSize() << ")";
+ throw std::runtime_error(msg.str());
diff -r 726c6e34ca1c -r 4c7a8a986f66 src/detail/writer/point.cpp
--- a/src/detail/writer/point.cpp Mon Apr 12 08:59:26 2010 -0500
+++ b/src/detail/writer/point.cpp Mon Apr 12 13:56:09 2010 -0500
@@ -145,10 +145,34 @@
// write in our extra data that the user set on the
// point up to the header's specified DataRecordLength
- if (m_format.GetByteSize() != m_header.GetDataRecordLength()) {
+ if (m_format.GetByteSize() != m_format.GetBaseByteSize()) {
std::vector<uint8_t> const& data = point.GetExtraData();
- std::streamsize const size = static_cast<std::streamsize>(m_header.GetDataRecordLength() - data.size());
- detail::write_n(GetStream(), data.front(), size);
+ uint16_t size = m_format.GetByteSize() - m_format.GetBaseByteSize();
+ if (data.size() == 0) {
+ char* blanks = new char[size];
+ for (int i=0; i < size; ++i) {
+ blanks[i] = '\0';
+ detail::write_n(GetStream(), blanks, static_cast<std::streamsize>(size));
+ delete [] blanks;
+ } else if (data.size() != size){
+ int16_t difference = size - data.size();
+ if (difference < 0) {
+ throw std::runtime_error("Format's base size is larger than it's size. This should not happen!");
+ char* blanks = new char[difference];
+ blanks[i] = '\0';
+ detail::write_n(GetStream(), data.front(), data.size());
+ detail::write_n(GetStream(), blanks, static_cast<std::streamsize>(difference));
+ delete [] blanks;
+ } else {
+ detail::write_n(GetStream(), data.front(), static_cast<std::streamsize>(size));
diff -r 726c6e34ca1c -r 4c7a8a986f66 src/las_c_api.cpp
--- a/src/las_c_api.cpp Mon Apr 12 08:59:26 2010 -0500
+++ b/src/las_c_api.cpp Mon Apr 12 13:56:09 2010 -0500
@@ -2201,6 +2201,15 @@
+LAS_DLL liblas::uint16_t LASPointFormat_GetBaseByteSize( LASPointFormatH hFormat)
+ VALIDATE_LAS_POINTER1(hFormat, "LASPointFormat_GetBaseByteSize", 0);
+ liblas::PointFormat* format = ((liblas::PointFormat*) hFormat);
+ return format->GetBaseByteSize();
LAS_DLL void LASPointFormat_Destroy(LASPointFormatH hFormat) {
VALIDATE_LAS_POINTER0(hFormat, "LASPointFormat_Destroy");
delete (liblas::PointFormat*) hFormat;
diff -r 726c6e34ca1c -r 4c7a8a986f66 src/lasformat.cpp
--- a/src/lasformat.cpp Mon Apr 12 08:59:26 2010 -0500
+++ b/src/lasformat.cpp Mon Apr 12 13:56:09 2010 -0500
@@ -212,4 +212,9 @@
updatesize();
+uint16_t PointFormat::GetBaseByteSize() const
+ return m_base_size;
} // namespace liblas
More information about the Liblas-commits
