[Liblas-commits] hg: Do not import external namespaces within
liblas namespace.
liblas-commits at liblas.org
Mon Aug 2 12:05:17 EDT 2010
changeset a34577812df9 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a34577812df9
summary: Do not import external namespaces within liblas namespace.
diffstat:
apps/chipper.cpp | 23 +++++++++--------------
src/detail/reader/header.cpp | 5 +++--
src/detail/reader/point.cpp | 4 ++--
src/detail/writer/base.cpp | 4 +---
src/detail/writer/header.cpp | 8 ++++----
src/detail/writer/point.cpp | 4 ++--
src/lasbounds.cpp | 4 +++-
src/lasclassification.cpp | 4 ++--
test/unit/common.cpp | 4 ++--
9 files changed, 28 insertions(+), 32 deletions(-)
diffs (198 lines):
diff -r 812f38ad95f0 -r a34577812df9 apps/chipper.cpp
--- a/apps/chipper.cpp Sun Aug 01 02:12:30 2010 +0100
+++ b/apps/chipper.cpp Mon Aug 02 17:09:01 2010 +0100
@@ -38,10 +38,14 @@
* OF SUCH DAMAGE.
+#include "chipper.hpp"
+// boost
+#include <boost/cstdint.hpp>
+// std
+#include <cmath>
-#include "chipper.hpp"
-#include <cmath>
+using namespace boost;
+using namespace std;
The objective is to split the region into non-overlapping blocks, each
@@ -73,14 +77,7 @@
be stored.
-namespace liblas
-using namespace std;
-using namespace boost;
-namespace chipper
+namespace liblas { namespace chipper {
vector<uint32_t> Block::GetIDs() const
@@ -305,6 +302,4 @@
m_blocks.push_back(b);
-} // namespace chipper
-} // namespace liblas
+}} // namespace liblas::chipper
diff -r 812f38ad95f0 -r a34577812df9 src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp Sun Aug 01 02:12:30 2010 +0100
+++ b/src/detail/reader/header.cpp Mon Aug 02 17:09:01 2010 +0100
@@ -44,13 +44,14 @@
#include <liblas/lasheader.hpp>
#include <liblas/lasvariablerecord.hpp>
// boost
#include <boost/concept_check.hpp>
namespace liblas { namespace detail { namespace reader {
Header::Header(std::istream& ifs)
: m_ifs(ifs)
, m_header(new liblas::Header())
diff -r 812f38ad95f0 -r a34577812df9 src/detail/reader/point.cpp
--- a/src/detail/reader/point.cpp Sun Aug 01 02:12:30 2010 +0100
+++ b/src/detail/reader/point.cpp Mon Aug 02 17:09:01 2010 +0100
@@ -50,11 +50,11 @@
#include <cstring>
#include <sstream>
-namespace liblas { namespace detail { namespace reader {
+namespace liblas { namespace detail { namespace reader {
Point::Point(std::istream& ifs, HeaderPtr header)
: m_ifs(ifs)
, m_header(header)
diff -r 812f38ad95f0 -r a34577812df9 src/detail/writer/base.cpp
--- a/src/detail/writer/base.cpp Sun Aug 01 02:12:30 2010 +0100
+++ b/src/detail/writer/base.cpp Mon Aug 02 17:09:01 2010 +0100
@@ -47,9 +47,7 @@
-WriterBase::WriterBase(std::ostream& ofs, uint32_t& count)
+WriterBase::WriterBase(std::ostream& ofs, boost::uint32_t& count)
: m_pointCount(count)
, m_ofs(ofs)
diff -r 812f38ad95f0 -r a34577812df9 src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp Sun Aug 01 02:12:30 2010 +0100
+++ b/src/detail/writer/header.cpp Mon Aug 02 17:09:01 2010 +0100
@@ -58,13 +58,13 @@
#include <string>
#include <vector>
-namespace liblas { namespace detail { namespace writer {
-Header::Header(std::ostream& ofs, uint32_t& count, liblas::Header const& header) :
- Base(ofs, count)
+namespace liblas { namespace detail { namespace writer {
+Header::Header(std::ostream& ofs, uint32_t& count, liblas::Header const& header)
+ : Base(ofs, count)
m_header = header;
diff -r 812f38ad95f0 -r a34577812df9 src/detail/writer/point.cpp
--- a/src/detail/writer/point.cpp Sun Aug 01 02:12:30 2010 +0100
+++ b/src/detail/writer/point.cpp Mon Aug 02 17:09:01 2010 +0100
@@ -51,10 +51,10 @@
#include <cmath>
#include <sstream>
Point::Point(std::ostream& ofs, uint32_t& count, const liblas::Header& header)
: Base(ofs, count)
, m_ofs(ofs)
diff -r 812f38ad95f0 -r a34577812df9 src/lasbounds.cpp
--- a/src/lasbounds.cpp Sun Aug 01 02:12:30 2010 +0100
+++ b/src/lasbounds.cpp Mon Aug 02 17:09:01 2010 +0100
@@ -42,6 +42,7 @@
#include <liblas/lasbounds.hpp>
#include <liblas/laspoint.hpp>
// boost
#include <boost/array.hpp>
// std
@@ -50,6 +51,8 @@
#include <string>
#include <sstream>
namespace liblas {
Bounds::Bounds()
@@ -128,7 +131,6 @@
void Bounds::verify()
for (uint32_t d = 0; d < 3; ++d)
if (min(d) > max(d) )
diff -r 812f38ad95f0 -r a34577812df9 src/lasclassification.cpp
--- a/src/lasclassification.cpp Sun Aug 01 02:12:30 2010 +0100
+++ b/src/lasclassification.cpp Mon Aug 02 17:09:01 2010 +0100
@@ -47,6 +47,8 @@
#include <cstddef>
#include <string>
namespace {
static std::string g_class_names[] =
@@ -89,8 +91,6 @@
namespace liblas {
std::size_t const Classification::class_table_size = detail::static_array_size(g_class_names);
std::string Classification::GetClassName() const
diff -r 812f38ad95f0 -r a34577812df9 test/unit/common.cpp
--- a/test/unit/common.cpp Sun Aug 01 02:12:30 2010 +0100
+++ b/test/unit/common.cpp Mon Aug 02 17:09:01 2010 +0100
@@ -14,10 +14,10 @@
// std
#include <string>
namespace tut {
void test_default_header(liblas::Header const& h)
using liblas::Header;
More information about the Liblas-commits
