[Liblas-commits] hg: make liblas::Bounds n-dimensional
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Aug 3 10:13:46 EDT 2010
changeset 06239bc11752 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=06239bc11752
summary: make liblas::Bounds n-dimensional
diffstat:
 include/liblas/lasbounds.hpp |  15 ++++----
 src/lasbounds.cpp            |  75 ++++++++++++++++++++++++++++++++-----------
 2 files changed, 63 insertions(+), 27 deletions(-)
diffs (204 lines):
diff -r 39362a321c31 -r 06239bc11752 include/liblas/lasbounds.hpp
--- a/include/liblas/lasbounds.hpp	Tue Aug 03 00:59:05 2010 +0100
+++ b/include/liblas/lasbounds.hpp	Tue Aug 03 09:13:39 2010 -0500
@@ -43,8 +43,8 @@
 #define LIBLAS_LASBOUNDS_HPP_INCLUDED
 #include <liblas/detail/fwd.hpp>
-// boost
-#include <boost/array.hpp>
+#include <vector>
 namespace liblas {
@@ -52,12 +52,13 @@
 public:
-    typedef boost::array<double, 3> Array;
+    typedef std::vector<double> Vector;
     Bounds();
     Bounds(double minx, double miny, double maxx, double maxy, double minz, double maxz);
     Bounds(double minx, double miny, double maxx, double maxy);
     Bounds(const Point& min, const Point& max);
+    Bounds( std::vector<double> const& low, std::vector<double> const& high);
     Bounds(Bounds const& other);
     Bounds& operator=(Bounds const& rhs);
@@ -82,12 +83,12 @@
     bool equal(Bounds const& other) const;
-    bool intersects2d(Bounds const& other) const;
-    bool intersects3d(Bounds const& other) const;
+    bool intersects(Bounds const& other) const;
+    uint32_t dimension() const;
 private:
-    Array mins;
-    Array maxs;
+    Vector mins;
+    Vector maxs;
     void verify();
diff -r 39362a321c31 -r 06239bc11752 src/lasbounds.cpp
--- a/src/lasbounds.cpp	Tue Aug 03 00:59:05 2010 +0100
+++ b/src/lasbounds.cpp	Tue Aug 03 09:13:39 2010 -0500
@@ -41,15 +41,18 @@
 #include <liblas/lasbounds.hpp>
 #include <liblas/laspoint.hpp>
+#include <liblas/detail/utility.hpp>
 // boost
 #include <boost/cstdint.hpp>
 #include <boost/concept_check.hpp>
 // std
 #include <cmath>
 #include <limits>
 #include <string>
 #include <sstream>
+#include <vector>
 using namespace boost;
@@ -57,8 +60,8 @@
 Bounds::Bounds()
-    mins.assign(0);
-    maxs.assign(0);
+    mins.resize(0);
+    maxs.resize(0);
 Bounds::Bounds( double minx,
@@ -68,6 +71,9 @@
                 double minz,
                 double maxz)
+    mins.resize(3);
+    maxs.resize(3);
     mins[0] = minx;
     mins[1] = miny;
     mins[2] = minz;
@@ -82,6 +88,9 @@
 Bounds::Bounds( const Point& min, const Point& max)
+    mins.resize(3);
+    maxs.resize(3);
     mins[0] = min.GetX();
     mins[1] = min.GetY();
     mins[2] = min.GetZ();
@@ -100,12 +109,12 @@
                 double maxx,
                 double maxy)
+    mins.resize(2);
+    maxs.resize(2);
     mins[0] = minx;
     mins[1] = miny;
-    mins[2] = 0;
     maxs[0] = maxx;
     maxs[1] = maxy;
-    maxs[2] = 0;
 #ifdef DEBUG
     verify();
@@ -113,6 +122,24 @@
+Bounds::Bounds( std::vector<double> const& low, std::vector<double> const& high)
+    if (low.size() != high.size() ) {
+        std::ostringstream msg;
+        msg << "Bounds dimensions are not equal.  Low bounds dimensions are " << low.size()
+            << " and the high bounds are " << high.size();
+        throw std::runtime_error(msg.str());
+    mins.resize(low.size());
+    mins = low;
+    maxs = high;
+#ifdef DEBUG
+    verify();
+#endif
 Bounds::Bounds(Bounds const& other)
     : mins(other.mins)
     , maxs(other.maxs)
@@ -129,9 +156,13 @@
     return *this;
+uint32_t Bounds::dimension() const
+    return mins.size();
 void Bounds::verify()
-    for (uint32_t d = 0; d < 3; ++d)
+    for (uint32_t d = 0; d < dimension(); ++d)
         if (min(d) > max(d) )
@@ -151,9 +182,10 @@
 bool Bounds::equal(Bounds const& other) const
-    // FIXME: direct comparison of float-point values may give wrong result --mloskot
-    for (Array::size_type i = 0; i < 3; i++) {
-        if (!(min(i) == other.min(i)) && !(max(i) == other.max(i)))
+    for (Vector::size_type i = 0; i < dimension(); i++) {
+        if    (!(detail::compare_distance(min(i), other.min(i)))
+            && !(detail::compare_distance(max(i), other.max(i))))
             return false;
@@ -161,20 +193,23 @@
     return true;
-bool Bounds::intersects2d(Bounds const& other) const
+bool Bounds::intersects(Bounds const& other) const
+    if (other.dimension() != dimension())
+        msg << "Bounds dimensions are not equal.  Comparison dimension is " << other.dimension()
+            << " and this dimension is " << dimension();
-    return (other.min(0) < max(0) && other.min(0) > min(0) && other.min(1) < max(1) && other.min(1) > max(1))
-        || (other.max(0) < max(0) && other.max(0) > min(0) && other.min(1) < max(1) && other.min(1) > max(1))
-        || (other.min(0) < max(0) && other.min(0) > min(0) && other.max(1) < max(1) && other.max(1) > max(1))
-        || (other.max(0) < max(0) && other.max(0) > min(0) && other.max(1) < max(1) && other.max(1) > max(1));
+    for (uint32_t i = 0; i < dimension(); i++){
+        if (min(i) > other.max(i) || max(i) < other.min(i)) return false;
+    return true;
-bool Bounds::intersects3d(Bounds const& other) const
-    boost::ignore_unused_variable_warning(other);
-    // not implemented
-    throw    std::runtime_error("not implemented");
 } // namespace liblas
More information about the Liblas-commits mailing list
