[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Aug 11 12:23:13 EDT 2010
changeset 44971e6e7e13 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=44971e6e7e13
summary: update lasblock to user boost::program_options, update chipper to use liblas::Bounds<double> instead of individual methods
changeset 244af56577e7 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=244af56577e7
summary: copy/paste typo
diffstat:
 apps/CMakeLists.txt        |    2 +-
 apps/chipper.cpp           |   26 ++++--
 apps/chipper.hpp           |   27 +++---
 apps/las2las2.cpp          |    2 +-
 apps/lasblock.cpp          |  173 +++++++++++++++++++++++++-------------------
 doc/utilities/lasblock.txt |   22 +++++-
 6 files changed, 154 insertions(+), 98 deletions(-)
diffs (truncated from 370 to 300 lines):
diff -r 92878748f048 -r 244af56577e7 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Tue Aug 10 15:53:44 2010 -0500
+++ b/apps/CMakeLists.txt	Wed Aug 11 11:23:05 2010 -0500
@@ -117,7 +117,7 @@
 if(LASBLOCK)
     set(LASBLOCK_SRC lasblock.cpp chipper.cpp chipper.hpp)
     add_executable(${LASBLOCK} ${LASBLOCK_SRC})
-    target_link_libraries(${LASBLOCK} ${APPS_CPP_DEPENDENCIES})
+    target_link_libraries(${LASBLOCK} ${APPS_CPP_DEPENDENCIES} ${Boost_LIBRARIES})
 endif()
 # Build las2ogr
diff -r 92878748f048 -r 244af56577e7 apps/chipper.cpp
--- a/apps/chipper.cpp	Tue Aug 10 15:53:44 2010 -0500
+++ b/apps/chipper.cpp	Wed Aug 11 11:23:05 2010 -0500
@@ -285,17 +285,25 @@
     Block b;
     b.m_list_p = &wide;
-    if (wide.m_dir == DIR_X) {
-        b.m_xmin = wide[widemin].m_pos;
-        b.m_xmax = wide[widemax].m_pos;
-        b.m_ymin = narrow[narrowmin].m_pos;
-        b.m_ymax = narrow[narrowmax].m_pos;
+    if (wide.m_dir == DIR_X) {
+        // minx, miny, maxx, maxy
+        liblas::Bounds<double> bnd(wide[widemin].m_pos, narrow[narrowmin].m_pos, wide[widemax].m_pos,  narrow[narrowmax].m_pos);
+        b.SetBounds(bnd);
+        // b.m_xmin = wide[widemin].m_pos;
+        // b.m_xmax = wide[widemax].m_pos;
+        // b.m_ymin = narrow[narrowmin].m_pos;
+        // b.m_ymax = narrow[narrowmax].m_pos;
     else {
-        b.m_xmin = narrow[narrowmin].m_pos;
-        b.m_xmax = narrow[narrowmax].m_pos;
-        b.m_ymin = wide[widemin].m_pos;
-        b.m_ymax = wide[widemax].m_pos;
+        liblas::Bounds<double> bnd(narrow[narrowmin].m_pos, wide[widemin].m_pos, narrow[narrowmax].m_pos, wide[widemax].m_pos);
+        b.SetBounds(bnd);
+        // b.m_xmin = narrow[narrowmin].m_pos;
+        // b.m_xmax = narrow[narrowmax].m_pos;
+        // b.m_ymin = wide[widemin].m_pos;
+        // b.m_ymax = wide[widemax].m_pos;
     b.m_left = widemin;
     b.m_right = widemax;
diff -r 92878748f048 -r 244af56577e7 apps/chipper.hpp
--- a/apps/chipper.hpp	Tue Aug 10 15:53:44 2010 -0500
+++ b/apps/chipper.hpp	Wed Aug 11 11:23:05 2010 -0500
@@ -69,21 +69,24 @@
     RefList *m_list_p;
     boost::uint32_t m_left;
     boost::uint32_t m_right;
-    double m_xmin;
-    double m_ymin;
-    double m_xmax;
-    double m_ymax;
+    liblas::Bounds<double> m_bounds;
+    // double m_xmin;
+    // double m_ymin;
+    // double m_xmax;
+    // double m_ymax;
 public:
     std::vector<boost::uint32_t> GetIDs() const;
-    double GetXmin() const
-        { return m_xmin; }
-    double GetYmin() const
-        { return m_ymin; }
-    double GetXmax() const
-        { return m_xmax; }
-    double GetYmax() const
-        { return m_ymax; }
+    liblas::Bounds<double> const& GetBounds() const {return m_bounds;}
+    void SetBounds(liblas::Bounds<double> const& bounds) {m_bounds = bounds;}
+    // double GetXmin() const
+    //     { return m_xmin; }
+    // double GetYmin() const
+    //     { return m_ymin; }
+    // double GetXmax() const
+    //     { return m_xmax; }
+    // double GetYmax() const
+    //     { return m_ymax; }
 class Chipper
diff -r 92878748f048 -r 244af56577e7 apps/las2las2.cpp
--- a/apps/las2las2.cpp	Tue Aug 10 15:53:44 2010 -0500
+++ b/apps/las2las2.cpp	Wed Aug 11 11:23:05 2010 -0500
@@ -316,7 +316,7 @@
             ("drop-intensity", po::value< string >(), "Range in which to drop intensity.\nThe following expression types are supported:  \n--drop-intensity <200 \n--drop-intensity >400 \n--drop-intensity >=200")
             ("keep-time", po::value< string >(), "Range in which to keep time.\nThe following expression types are supported:  \n--keep-time 413665.2336-414092.8462 \n--keep-time <414094.8462 \n--keep-time >413665.2336 \n--keep-time >=413665.2336")
             ("drop-time", po::value< string >(), "Range in which to drop time.\nThe following expression types are supported:  \n--drop-time <413666.2336 \n--drop-time >413665.2336 \n--drop-time >=413665.2336")
-            ("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Keep only valid points")
+            ("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Verbose message output")
             ("a_srs", po::value< string >(), "Coordinate system to assign to input LAS file")
             ("t_srs", po::value< string >(), "Coordinate system to reproject output LAS file to.  Use --a_srs or verify that your input LAS file has a coordinate system according to lasinfo")
             ("offset", po::value< string >(), "A comma-separated list of offsets to set on the output file: \n--offset 0,0,0 \n--offset  min,min,min\n ")
diff -r 92878748f048 -r 244af56577e7 apps/lasblock.cpp
--- a/apps/lasblock.cpp	Tue Aug 10 15:53:44 2010 -0500
+++ b/apps/lasblock.cpp	Wed Aug 11 11:23:05 2010 -0500
@@ -21,17 +21,42 @@
 #define compare_no_case(a,b,n)  strncasecmp( (a), (b), (n) )
 #endif
+#include <boost/program_options.hpp>
-void usage() {
-    std::cout << "----------------------------------------------------------\n";
-    std::cout << "    lasblock (version ) usage:\n";
-    std::cout << " lasblock filename.las -c 1000 \n";
-    std::cout << "--capacity: (-c)  capacity of the blocks\n";
+namespace po = boost::program_options;
+bool term_progress(std::ostream& os, double complete)
+    static int lastTick = -1;
+    int tick = static_cast<int>(complete * 40.0);
+    tick = std::min(40, std::max(0, tick));
+    // Have we started a new progress run?
+    if (tick < lastTick && lastTick >= 39)
+        lastTick = -1;
+    if (tick <= lastTick)
+        return true;
+    while (tick > lastTick)
+        lastTick++;
+        if (lastTick % 4 == 0)
+            os << (lastTick / 4) * 10;
+        else
+            os << ".";
+    if( tick == 40 )
+        os << " - done.\n";
+    else
+        os.flush();
+    return true;
 using namespace liblas;
@@ -40,87 +65,82 @@
     std::string input;
     std::string output;
-    long capacity = 10000;
+    long capacity = 3000;
+    long precision = 8;
+    bool verbose = false;
+    po::options_description desc("Allowed lasblock options");
+    po::positional_options_description p;
+    p.add("input", 1);
+    p.add("output", 1);
+    desc.add_options()
+        ("help,h", "Produce this help message")
+        ("capacity,c", po::value<long>(&capacity)->default_value(3000), "Number of points to nominally put into each block (note that this number will not be exact)")
+        ("precision,p", po::value<long>(&precision)->default_value(8), "Number of decimal points to write for each bbox")
+        ("input,i", po::value< std::string >(), "input LAS file")
+        ("output,o", po::value< std::string >(&output)->default_value(""), "The output .kdx file (defaults to input filename + .kdx)")
-    for (int i = 1; i < argc; i++)
+    po::variables_map vm;
+    po::store(po::command_line_parser(argc, argv).
+      options(desc).positional(p).run(), vm);
+    po::notify(vm);
+    if (vm.count("help"))
-        if (    std::strcmp(argv[i],"-h") == 0 ||
-                std::strcmp(argv[i],"--help") == 0
+        std::cout << desc << "\n";
+        return 1;
+    if (vm.count("input"))
+        input = vm["input"].as< std::string >();
+        std::ifstream ifs;
+        if (!liblas::Open(ifs, input.c_str()))
-            usage();
-            exit(0);
+            std::cerr << "Cannot open file '" << input << "'for read.  Exiting...";
+            return 1;
-        else if (   std::strcmp(argv[i],"--input") == 0  ||
-                    std::strcmp(argv[i],"-input") == 0   ||
-                    std::strcmp(argv[i],"-i") == 0       ||
-                    std::strcmp(argv[i],"-in") == 0
-            i++;
-            input = std::string(argv[i]);
-        else if (   strcmp(argv[i],"--output") == 0  ||
-                    strcmp(argv[i],"--out") == 0     ||
-                    strcmp(argv[i],"-out") == 0     ||
-                    strcmp(argv[i],"-o") == 0
-            i++;
-            output = std::string(argv[i]) + ".kdx";
-        else if (   std::strcmp(argv[i],"--capacity") == 0  ||
-                    std::strcmp(argv[i],"-cap") == 0     ||
-                    std::strcmp(argv[i],"-c") == 0
-            i++;
-            capacity = atoi(argv[i]);
-        else if (input.empty())
-        else if (output.empty())
-            output = std::string(input) + ".kdx";
-        else
-            usage();
-            exit(1);
-    if (input.empty()) {
-        usage();
-        exit(-1);
     if (output.empty())
-    std::ifstream in(input.c_str());
+    std::ifstream in;
+    if (!liblas::Open(in, input.c_str()))
+        std::cerr << "Cannot open " << input << "for read.  Exiting...";
+        return 1;
     std::ofstream out(output.c_str());
     liblas::Reader reader( in );
     liblas::chipper::Chipper c(&reader, capacity);
+    if (verbose)
+        std::cout << "Blocking " << input<< " to " << output <<std::endl;
     c.Chip();
-    std::cout << "Blocking " << input<< " to " << output <<std::endl;
     boost::uint32_t num_blocks = c.GetBlockCount();
-    std::cout << "Block count: " << num_blocks << std::endl;
+    if (verbose)
+        std::cout << "Writing " << num_blocks << " blocks to " << output << std::endl;
+    boost::uint32_t prog = 0;
     for ( boost::uint32_t i = 0; i < num_blocks; ++i )
         const liblas::chipper::Block& b = c.GetBlock(i);
@@ -128,18 +148,23 @@
More information about the Liblas-commits mailing list
