[Liblas-commits] hg: segregate generic option handling into its own
files to be r...
liblas-commits at liblas.org
Thu Aug 12 12:11:08 EDT 2010
changeset a17bad855c63 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a17bad855c63
summary: segregate generic option handling into its own files to be reused in other contexts than las2las
diffstat:
apps/CMakeLists.txt | 6 +-
apps/las2las2.cpp | 569 +++------------------------------------------------
apps/laskernel.cpp | 561 +++++++++++++++++++++++++++++++++++++++++++++++++++
apps/laskernel.hpp | 82 +++++++
4 files changed, 680 insertions(+), 538 deletions(-)
diffs (truncated from 1323 to 300 lines):
diff -r d7975db2a1a1 -r a17bad855c63 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Wed Aug 11 13:32:14 2010 -0500
+++ b/apps/CMakeLists.txt Thu Aug 12 11:11:02 2010 -0500
@@ -88,7 +88,7 @@
endif()
if(LAS2LAS2)
- add_executable(${LAS2LAS2} las2las2.cpp)
+ add_executable(${LAS2LAS2} las2las2.cpp laskernel.cpp)
target_link_libraries(${LAS2LAS2} ${APPS_CPP_DEPENDENCIES} ${Boost_LIBRARIES})
endif()
@@ -128,8 +128,8 @@
# Build las2oci
if(LAS2OCI)
- add_executable(${LAS2OCI} las2oci.cpp oci_wrapper.cpp kdx_util.cpp oci_util.cpp)
- target_link_libraries(${LAS2OCI} ${APPS_CPP_DEPENDENCIES})
+ add_executable(${LAS2OCI} las2oci.cpp oci_wrapper.cpp kdx_util.cpp oci_util.cpp laskernel.cpp)
+ target_link_libraries(${LAS2OCI} ${APPS_CPP_DEPENDENCIES} ${Boost_LIBRARIES})
endif()
if (BIGFILE_TEST)
diff -r d7975db2a1a1 -r a17bad855c63 apps/las2las2.cpp
--- a/apps/las2las2.cpp Wed Aug 11 13:32:14 2010 -0500
+++ b/apps/las2las2.cpp Thu Aug 12 11:11:02 2010 -0500
@@ -10,17 +10,18 @@
#include <liblas/liblas.hpp>
+#include "laskernel.hpp"
-#include <fstream>
-#include <iostream>
-#include <sstream>
-#include <string>
-#include <vector>
-#include <string>
-#include <functional>
-#include <boost/program_options.hpp>
-#include <boost/tokenizer.hpp>
+// #include <fstream>
+// #include <iostream>
+// #include <sstream>
+// #include <string>
+// #include <vector>
+// #include <functional>
+// #include <boost/program_options.hpp>
+// #include <boost/tokenizer.hpp>
typedef boost::tokenizer<boost::char_separator<char> > tokenizer;
@@ -35,7 +36,7 @@
#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
#endif
-#define SEPARATORS ",|"
+// #define SEPARATORS ",|"
bool term_progress(std::ostream& os, double complete)
@@ -92,112 +93,6 @@
-bool IsDualRangeFilter(std::string parse_string)
-string::size_type dash = parse_string.find_first_of("-");
-if (dash != std::string::npos) {
- return true;
-return false;
-liblas::FilterI* MakeReturnFilter(std::string return_string, liblas::FilterI::FilterType ftype)
- boost::char_separator<char> sep(SEPARATORS);
- std::vector<uint16_t> returns;
- tokenizer tokens(return_string, sep);
- for (tokenizer::iterator t = tokens.begin(); t != tokens.end(); ++t) {
- returns.push_back(atoi((*t).c_str()));
- liblas::ReturnFilter* return_filter = new ReturnFilter(returns, false);
- return_filter->SetType(ftype);
- return return_filter;
-liblas::FilterI* MakeClassFilter(std::string class_string, liblas::FilterI::FilterType ftype)
- std::vector<uint8_t> classes;
- tokenizer tokens(class_string, sep);
- classes.push_back(atoi((*t).c_str()));
- liblas::ClassificationFilter* class_filter = new ClassificationFilter(classes);
- class_filter->SetType(ftype);
- return class_filter;
-liblas::FilterI* MakeBoundsFilter(std::string bounds_string, liblas::FilterI::FilterType ftype)
- std::vector<double> vbounds;
- tokenizer tokens(bounds_string, sep);
- liblas::Bounds<double> bounds;
- vbounds.push_back(atof((*t).c_str()));
- if (vbounds.size() == 4)
- bounds = liblas::Bounds<double>(vbounds[0],
- vbounds[1],
- vbounds[2],
- vbounds[3]);
- } else if (vbounds.size() == 6)
- vbounds[1],
- vbounds[2],
- vbounds[3],
- vbounds[4],
- vbounds[5]);
- } else {
- ostringstream oss;
- oss << "Bounds must be specified as a 4-tuple or "
- "6-tuple, not a "<< vbounds.size()<<"-tuple" << "\n";
- throw std::runtime_error(oss.str());
- liblas::BoundsFilter* bounds_filter = new BoundsFilter(bounds);
- bounds_filter->SetType(ftype);
- return bounds_filter;
-liblas::FilterI* MakeIntensityFilter(std::string intensities, liblas::FilterI::FilterType ftype)
- liblas::ContinuousValueFilter<uint16_t>::filter_func f = &liblas::Point::GetIntensity;
- liblas::ContinuousValueFilter<uint16_t>* intensity_filter = new liblas::ContinuousValueFilter<uint16_t>(f, intensities);
- intensity_filter->SetType(ftype);
- return intensity_filter;
-liblas::FilterI* MakeTimeFilter(std::string times, liblas::FilterI::FilterType ftype)
- liblas::ContinuousValueFilter<double>::filter_func f = &liblas::Point::GetTime;
- liblas::ContinuousValueFilter<double>* time_filter = new liblas::ContinuousValueFilter<double>(f, times);
- time_filter->SetType(ftype);
- return time_filter;
-liblas::FilterI* MakeScanAngleFilter(std::string intensities, liblas::FilterI::FilterType ftype)
- liblas::ContinuousValueFilter<int8_t>::filter_func f = &liblas::Point::GetScanAngleRank;
- liblas::ContinuousValueFilter<int8_t>* intensity_filter = new liblas::ContinuousValueFilter<int8_t>(f, intensities);
-liblas::FilterI* MakeColorFilter(liblas::Color const& low, liblas::Color const& high, liblas::FilterI::FilterType ftype)
- liblas::ColorFilter* filter = new liblas::ColorFilter(low, high);
- filter->SetType(ftype);
- return filter;
bool process( std::string const& input,
std::string const& output,
@@ -291,13 +186,13 @@
uint32_t split_size;
- uint32_t thin;
+ // uint32_t thin;
std::string input;
std::string output;
- bool last_return_only;
- bool first_return_only;
- bool valid_only;
+ // bool last_return_only;
+ // bool first_return_only;
+ // bool valid_only;
bool verbose = false;
std::vector<liblas::FilterI*> filters;
std::vector<liblas::TransformI*> transforms;
@@ -306,56 +201,39 @@
try {
- po::options_description desc("Allowed options");
+ po::options_description file_options("las2las2 options");
+ po::options_description filtering_options = GetFilteringOptions();
+ po::options_description transform_options = GetTransformationOptions() ;
po::positional_options_description p;
p.add("input", 1);
p.add("output", 1);
- desc.add_options()
+ file_options.add_options()
("help,h", "produce help message")
("split,s", po::value<uint32_t>(&split_size)->default_value(0), "Split file into multiple files with each being this size in MB or less. If this value is 0, no splitting is done")
("input,i", po::value< string >(), "input LAS file")
("output,o", po::value< string >(&output)->default_value("output.las"), "output LAS file")
- ("keep-classes,k", po::value< string >(), "A comma-separated list of classifications to keep:\n-k 2,4,12\n--keep-classes 2")
- ("drop-classes,d", po::value< string >(), "A comma-separated list of classifications to drop:\n-d 1,7,8\n--drop-classes 2")
- ("extent,e", po::value< string >(), "Extent window that points must fall within to keep.\nUse a comma-separated list, for example, \n -e minx, miny, maxx, maxy\n or \n -e minx, miny, maxx, maxy, minz, maxz")
- ("thin,t", po::value<uint32_t>(&thin)->default_value(0), "Simple decimation-style thinning.\nThin the file by removing every t'th point from the file.")
- ("last_return_only", po::value<bool>(&last_return_only)->zero_tokens(), "Keep last returns (cannot be used with --first_return_only)")
- ("first_return_only", po::value<bool>(&first_return_only)->zero_tokens(), "Keep first returns (cannot be used with --last_return_only")
- ("keep-returns", po::value< string >(), "A comma-separated list of return numbers to keep in the output file: \n--keep-returns 1,2,3")
- ("drop-returns", po::value< string >(), "Return numbers to drop.\nUse a comma-separated list, for example, --drop-returns 2,3,4,5")
- ("valid_only", po::value<bool>(&valid_only)->zero_tokens(), "Keep only valid points")
- ("keep-intensity", po::value< string >(), "Range in which to keep intensity.\nThe following expression types are supported: \n--keep-intensity 0-100 \n--keep-intensity <200 \n--keep-intensity >400 \n--keep-intensity >=200")
- ("drop-intensity", po::value< string >(), "Range in which to drop intensity.\nThe following expression types are supported: \n--drop-intensity <200 \n--drop-intensity >400 \n--drop-intensity >=200")
- ("keep-time", po::value< string >(), "Range in which to keep time.\nThe following expression types are supported: \n--keep-time 413665.2336-414092.8462 \n--keep-time <414094.8462 \n--keep-time >413665.2336 \n--keep-time >=413665.2336")
- ("drop-time", po::value< string >(), "Range in which to drop time.\nThe following expression types are supported: \n--drop-time <413666.2336 \n--drop-time >413665.2336 \n--drop-time >=413665.2336")
- ("keep-scan-angle", po::value< string >(), "Range in which to keep scan angle.\nThe following expression types are supported: \n--keep-scan-angle 0-100 \n--keep-scan-angle <100\n--keep-scan-angle <=100")
- ("drop-scan-angle", po::value< string >(), "Range in which to drop scan angle.\nThe following expression types are supported: \n--drop-scan-angle <30 \n--drop-scan-angle >100 \n--drop-scan-angle >=100")
- ("keep-color", po::value< string >(), "Range in which to keep colors.\nDefine colors as two 3-tuples (R,G,B-R,G,B): \n--keep-color '0,0,0-125,125,125'")
- ("drop-color", po::value< string >(), "Range in which to drop colors.\nDefine colors as two 3-tuples (R,G,B-R,G,B): \n--drop-color '255,255,255-65536,65536,65536'")
+ ("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Verbose message output")
- ("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Verbose message output")
- ("a_srs", po::value< string >(), "Coordinate system to assign to input LAS file")
- ("t_srs", po::value< string >(), "Coordinate system to reproject output LAS file to. Use --a_srs or verify that your input LAS file has a coordinate system according to lasinfo")
- ("offset", po::value< string >(), "A comma-separated list of offsets to set on the output file: \n--offset 0,0,0 \n--offset min,min,min\n ")
- ("scale", po::value< string >(), "A comma-separated list of scales to set on the output file: \n--scale 0.1,0.1,0.00001\n ")
- ("format,f", po::value< string >(), "Set the LAS format of the new file (only 1.0-1.2 supported at this time): \n--format 1.2\n-f 1.1")
- po::variables_map vm;
+ po::variables_map vm;
+ po::options_description options;
+ options.add(file_options).add(transform_options).add(filtering_options);
po::store(po::command_line_parser(argc, argv).
- options(desc).positional(p).run(), vm);
+ options(options).positional(p).run(), vm);
po::notify(vm);
if (vm.count("help"))
- std::cout << desc << "\n";
+ std::cout << file_options<<transform_options<<filtering_options<<"\n";
return 1;
if (vm.count("input"))
@@ -371,381 +249,15 @@
liblas::Reader reader(ifs);
header = reader.GetHeader();
} else {
- std::cerr << "Input LAS file not specified!\n" << desc << "\n";
+ std::cerr << "Input LAS file not specified!\n";
return 1;
- if (vm.count("keep-classes"))
- std::string classes = vm["keep-classes"].as< string >();
- if (verbose)
- std::cout << "Keeping classes with the values: " << classes << std::endl;
- liblas::FilterI* class_filter = MakeClassFilter( classes,
- liblas::FilterI::eInclusion);
- filters.push_back(class_filter);
- if (vm.count("drop-classes"))
- std::string classes = vm["drop-classes"].as< string >();
- if (verbose)
- std::cout << "Dropping classes with the values: " << classes << std::endl;
- liblas::FilterI::eExclusion);
- if (vm.count("keep-returns"))
- std::string returns = vm["keep-returns"].as< string >();
More information about the Liblas-commits
