[Liblas-commits] hg: --debug switch, enable processing
liblas-commits at liblas.org
Sat Aug 14 21:46:17 EDT 2010
changeset 8ea8aeee6173 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8ea8aeee6173
summary: --debug switch, enable processing
diffstat:
apps/las2oci.cpp | 680 ++++++++++++++++++++----------------------------------
1 files changed, 254 insertions(+), 426 deletions(-)
diffs (truncated from 815 to 300 lines):
diff -r 68ff6da9dfc4 -r 8ea8aeee6173 apps/las2oci.cpp
--- a/apps/las2oci.cpp Sat Aug 14 14:49:33 2010 -0500
+++ b/apps/las2oci.cpp Sat Aug 14 20:46:07 2010 -0500
@@ -625,6 +625,7 @@
("input,i", po::value< string >(), "input LAS file")
("connection,c", po::value< string >(), "OCI connection string")
("verbose,v", po::value<bool>()->zero_tokens(), "Verbose message output")
+ ("debug", po::value<bool>()->zero_tokens(), "Enable debugging")
("base-table-name", po::value< string >()->default_value("HOBU"), "The table name in which to put the point cloud object. This table must have a column of type SDO_PC, with the name to be specified with --cloud-column-name")
("block-table-name", po::value< string >(), "The table name in which to put the block data. This table must be of type SDO_PC.BLK_TABLE. This table will be created using the filename of the input LAS file if not specified. Use -d to delete the table if it already exists.")
("cloud-column-name", po::value< string >()->default_value("CLOUD"), "The column name that contains the point cloud object in the base table")
@@ -647,7 +648,6 @@
po::options_description hidden_options("hidden options");
hidden_options.add_options()
- ("help,h", "produce help message")
("xmin", po::value< double >(), "global-extent minx value")
("ymin", po::value< double >(), "global-extent miny value")
("zmin", po::value< double >(), "global-extent minz value")
@@ -656,7 +656,23 @@
("zmax", po::value< double >(), "global-extent maxz value")
-return file_options.add(hidden_options);
+return file_options;
+po::options_description GetHiddenOptions()
+ po::options_description hidden_options("hidden options");
+hidden_options.add_options()
+ ("xmin", po::value< double >(), "global-extent minx value")
+ ("ymin", po::value< double >(), "global-extent miny value")
+ ("zmin", po::value< double >(), "global-extent minz value")
+ ("xmax", po::value< double >(), "global-extent maxx value")
+ ("ymax", po::value< double >(), "global-extent maxy value")
+ ("zmax", po::value< double >(), "global-extent maxz value")
+return hidden_options;
// select sdo_pc_pkg.to_geometry(a.points, a.num_points, 3, 4326) from NACHES_BAREEARTH_BLOCK1 a where a.obj_id= 8907
int main(int argc, char* argv[])
@@ -685,6 +701,7 @@
bool bUse3d = false;
bool bInsertHeaderBlob = false;
uint32_t nCapacity = 10000;
int srid = 0;
@@ -698,6 +715,7 @@
bool verbose = false;
+ bool debug = false;
std::vector<liblas::FilterI*> filters;
std::vector<liblas::TransformI*> transforms;
@@ -709,6 +727,7 @@
po::options_description file_options = GetFileOptions();
po::options_description filtering_options = GetFilteringOptions();
po::options_description transform_options = GetTransformationOptions() ;
+ po::options_description hidden_options = GetHiddenOptions();
po::positional_options_description p;
p.add("input", 1);
p.add("connection", 1);
@@ -718,7 +737,7 @@
po::variables_map vm;
po::options_description options;
- options.add(file_options).add(transform_options).add(filtering_options);
+ options.add(file_options).add(transform_options).add(filtering_options).add(hidden_options);
po::store(po::command_line_parser(argc, argv).
options(options).positional(p).run(), vm);
@@ -726,15 +745,26 @@
if (vm.count("help"))
- std::cout << GetInvocationHeader()<<file_options;//<<transform_options<<filtering_options<<"\n";
- return 1;
+ std::cout << GetInvocationHeader()<<file_options<<transform_options<<filtering_options<<"\n";
+ return 0;
if (vm.count("verbose"))
verbose = vm["verbose"].as< bool >();
+ if (vm.count("debug"))
+ debug = vm["debug"].as< bool >();
+ verbose = true; // implies verbose too
+ const char* gdal_debug = getenv("CPL_DEBUG");
+ if (gdal_debug == 0)
+ char d[20] = "CPL_DEBUG=ON";
+ putenv(d);
if (vm.count("input"))
input = vm["input"].as< string >();
@@ -808,14 +838,14 @@
aux_columns = vm["aux-columns"].as< string >();
if (verbose)
- std::cout << "Setting aux-columns to:" << aux_columns << std::endl;
+ std::cout << "Setting aux-columns to: " << aux_columns << std::endl;
if (vm.count("aux-values"))
aux_values = vm["aux-values"].as< string >();
if (verbose)
- std::cout << "Setting aux-values to:" << aux_columns << std::endl;
+ std::cout << "Setting aux-values to: " << aux_values << std::endl;
@@ -830,7 +860,7 @@
precision = vm["precision"].as< uint32_t >();
if (verbose)
- std::cout << "Setting precision to:" << precision << std::endl;
+ std::cout << "Setting precision to: " << precision << std::endl;
@@ -944,48 +974,257 @@
double xmin = vm["xmin"].as< double >();
global_extent.min(0, xmin);
if (verbose)
- std::cout << "Setting xmin to:" << xmin << std::endl;
+ std::cout << "Setting xmin to: " << xmin << std::endl;
if (vm.count("ymin"))
double ymin = vm["ymin"].as< double >();
global_extent.min(1, ymin);
if (verbose)
- std::cout << "Setting ymin to:" << ymin << std::endl;
+ std::cout << "Setting ymin to: " << ymin << std::endl;
if (vm.count("zmin"))
double zmin = vm["zmin"].as< double >();
global_extent.min(2, zmin);
if (verbose)
- std::cout << "Setting zmin to:" << zmin << std::endl;
+ std::cout << "Setting zmin to: " << zmin << std::endl;
if (vm.count("xmax"))
double xmax = vm["xmax"].as< double >();
global_extent.max(0, xmax);
if (verbose)
- std::cout << "Setting xmax to:" << xmax << std::endl;
+ std::cout << "Setting xmax to: " << xmax << std::endl;
if (vm.count("ymax"))
double ymax = vm["ymax"].as< double >();
global_extent.max(1, ymax);
if (verbose)
- std::cout << "Setting ymax to:" << ymax << std::endl;
+ std::cout << "Setting ymax to: " << ymax << std::endl;
if (vm.count("zmax"))
double zmax = vm["zmax"].as< double >();
global_extent.max(2, zmax);
if (verbose)
- std::cout << "Setting zmax to:" << zmax << std::endl;
+ std::cout << "Setting zmax to: " << zmax << std::endl;
filters = GetFilters(vm, verbose);
// Transforms alter our header as well. Setting scales, offsets, etc.
transforms = GetTransforms(vm, verbose, header);
+ if (connection.empty() || input.empty()) {
+ if (input.empty())
+ std::cerr << "Input .las file not specified!" << std::endl;
+ if (connection.empty())
+ std::cerr << "Oracle connection string empty!" << std::endl;
+ return 1;
+ if (block_table_name.size() == 0) {
+ // change filename foo.las -> foo for an appropriate
+ // block tablename for oracle... must be less than 30 characters
+ // and no extraneous characters.
+ string::size_type dot_pos = input.find_first_of(".");
+ block_table_name = input.substr(0,dot_pos);
+ } else {
+ block_table_name = block_table_name;
+ string::size_type slash_pos = connection.find("/",0);
+ username = connection.substr(0,slash_pos);
+ string::size_type at_pos = connection.find("@",slash_pos);
+ // std::cout <<"slash_pos: " << slash_pos << " at_pos: " << at_pos<<std::endl;
+ password = connection.substr(slash_pos+1, at_pos-slash_pos-1);
+ instance = connection.substr(at_pos+1);
+ std::cout << "Connecting with username: " << username << " password: "<< password<< " instance: " << instance << std::endl;
+ std::cout << "Base table name " << base_table_name << " cloud column: " << point_cloud_name <<" block table: " << block_table_name << std::endl;
+ // OCI_SUCCESS_WITH_INFO error, which according to google relates to
+ // a warning related to expired or expiring passwords needs to be
+ // handled in the oracle wrapper.
+ // Create the index before connecting to Oracle. That way we don't heartbeat
+ // the server while we're cruising through the file(s).
+ // OS X RAMDISK configuration
+ // http://www.macosxhints.com/article.php?story=20090222092827145
+ // Obj_id is serial for each row in the block table
+ // blk_id is the index leaf node id (this is currently being written incorrectly)
+ OWConnection* con = new OWConnection(username.c_str(),password.c_str(),instance.c_str());
+ if (con->Succeeded()) {
+ std::cout <<"Oracle connection succeded" << std::endl;
+ } else {
+ std::cout <<"Oracle connection failed" << std::endl; exit(1);
+ // std::istream* istrm;
+ // try {
+ // istrm = OpenInput(input, false);
+ // } catch (std::exception const& e)
+ // std::cout << e.what() << std::endl;
+ // std::cout << "exiting..." << std::endl;
+ // exit(-1);
+ con->StartTransaction();
+ if (bDropTable) {
+ std::cout << "dropping existing tables..." << std::endl;
+ WipeBlockTable(con, block_table_name, base_table_name, point_cloud_name);
+ if (!pre_sql.empty()) {
+ std::cout << "running pre-sql ..." << std::endl;
+ ostringstream oss;
+ oss << pre_sql;
+ OWStatement* statement = 0;
+ statement = RunSQL(con, oss);
+ if (statement != 0) {
+ delete statement;
+ else {
+ std::cout << "pre-sql execution failed.." << std::endl;
+ return false;
+ oss.str("");
+ if (!BlockTableExists(con, block_table_name.c_str()))
+ CreateBlockTable(con, block_table_name);
+ else {
+ bUseExistingBlockTable = true;
+ std::cout << "Using existing block table ... " << std::endl;
+ KDXIndexSummary* query = 0;
+ if (!KDTreeIndexExists(input)) {
+ std::cout << "KDTree .kdx file does not exist for file, unable to proceed" << std::endl;
+ exit(1);
+ } else {
+ std::cout << "Using kdtree ... " << std::endl;
+ std::ostringstream os;
+ os << input << ".kdx" ;
+ std::istream* kdx = OpenInput(os.str(), false);
+ query = new KDXIndexSummary(*kdx);
+ ResultsVector& results = query->GetResults();
+ ResultsVector::iterator i;
+ std::istream* istrm2;
+ istrm2 = OpenInput(input, false);
+ liblas::Reader* reader2 = new liblas::Reader(*istrm2);
More information about the Liblas-commits
