[Liblas-commits] hg: 5 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Aug 17 10:56:09 EDT 2010
changeset f446e613f2b0 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f446e613f2b0
summary: that was never gonna work :)
changeset 3a4f16c6c9a3 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=3a4f16c6c9a3
summary: add prototypes for cached reader with custom header -- we need a factory here.
changeset 634ec5a66e26 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=634ec5a66e26
summary: use custom header when we read the file to pick up any modified elements from the transformations
changeset 829f90d9231e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=829f90d9231e
summary: reproject the bounds of the header if we're doing reprojection transformations as well
changeset 0ed40975a132 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0ed40975a132
summary: add some docs to las2oci
diffstat:
 apps/las2oci.cpp             |    8 +-
 apps/laskernel.cpp           |    4 +
 doc/utilities/las2oci.txt    |  181 ++++++++++++++++++++++++++++++++++++++++++-
 include/liblas/lasbounds.hpp |    4 +-
 include/liblas/lasreader.hpp |    2 +-
 src/lasreader.cpp            |   19 ++++-
 6 files changed, 207 insertions(+), 11 deletions(-)
diffs (truncated from 306 to 300 lines):
diff -r 99023a42b7b9 -r 0ed40975a132 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Tue Aug 17 09:15:25 2010 -0500
+++ b/apps/las2oci.cpp	Tue Aug 17 09:55:57 2010 -0500
@@ -1023,7 +1023,7 @@
             bool bCachedReader = vm["cached"].as< bool >();
             if (verbose)
                 std::cout << "Caching entire file... " << std::endl;
         filters = GetFilters(vm, verbose);
@@ -1122,9 +1122,9 @@
         liblas::Reader* reader2 = 0;
         if (bCachedReader)
-            reader2 = new liblas::Reader(*istrm2,0);
+            reader2 = new liblas::Reader(*istrm2,0, header);
         else
-            reader2 = new liblas::Reader(*istrm2);
+            reader2 = new liblas::Reader(*istrm2, header);
         reader2->SetFilters(&filters);
         reader2->SetTransforms(&transforms);
@@ -1139,7 +1139,7 @@
             std::ostringstream os;
             os << input << ".kdx" ;
             if (verbose)
-                std::cout << "Using existing "<<os<<" chip file ... " << std::endl;
+                std::cout << "Using existing "<<os.str()<<" chip file ... " << std::endl;
             std::istream* kdx = OpenInput(os.str(), false);
diff -r 99023a42b7b9 -r 0ed40975a132 apps/laskernel.cpp
--- a/apps/laskernel.cpp	Tue Aug 17 09:15:25 2010 -0500
+++ b/apps/laskernel.cpp	Tue Aug 17 09:55:57 2010 -0500
@@ -457,6 +457,10 @@
         // made the transformation, and this SRS will be used to
         // write the new file(s)
         header.SetSRS(out_ref);
+        liblas::Bounds<double> b = header.GetExtent();
+        b.project(in_ref, out_ref);
+        header.SetExtent(b);
         liblas::TransformI* srs_transform = new liblas::ReprojectionTransform(in_ref, out_ref);
         transforms.push_back(srs_transform);
diff -r 99023a42b7b9 -r 0ed40975a132 doc/utilities/las2oci.txt
--- a/doc/utilities/las2oci.txt	Tue Aug 17 09:15:25 2010 -0500
+++ b/doc/utilities/las2oci.txt	Tue Aug 17 09:55:57 2010 -0500
@@ -17,10 +17,185 @@
 :ref:`las2oci` allows a user to load LAS 1.0-1.2 data into `Oracle Point Cloud`_
-tables within Oracle 11gR2+.  All optional components are necessary to be
-compiled with libLAS for this code to work, as spatial indexing and GDAL are
-required.  See :ref:`optional_libraries` for details on obtaining the
+tables within Oracle 11gR2+.  GDAL and OCI must be compiled with libLAS for
+las2oci to work properly.  See :ref:`optional_libraries` for details on obtaining the
 necessary components if you are building for yourself.
+Usage
+:ref:`las2oci` is a command-line utility that allows you to ingest a
+.las file into Oracle.
+        las2oci (libLAS 1.6.0 with GeoTIFF 1.3.0 GDAL 1.8dev)
+    las2oci options:
+      -h [ --help ]                    produce help message
+      -i [ --input ] arg               input LAS file
+      -c [ --connection ] arg          OCI connection string
+      -v [ --verbose ]                 Verbose message output
+      --debug                          Enable debug messages (SQL calls)
+      --base-table-name arg (=HOBU)    The table name in which to put the point
+                                       cloud object.  This table must have a column
+                                       of type SDO_PC, with the name to be
+                                       specified with --cloud-column-name
+      --block-table-name arg           The table name in which to put the block
+                                       data.  This table must be of type
+                                       SDO_PC.BLK_TABLE.  This table will be
+                                       created using the filename of the input LAS
+                                       file if not specified.  Use -d to delete the
+                                       table if it already exists.
+      --cloud-column-name arg (=CLOUD) The column name that contains the point
+                                       cloud object in the base table
+      --header-blob-column arg         Blob column name in the base table in which
+                                       to optionally insert the contents of the
+                                       input file's header.
+      -d [ --overwrite ]               Drop block table before inserting data.
+      --block-capacity arg (=3000)     Maximum number of points to be inserted into
+                                       each block
+      -p [ --precision ] arg (=8)      Number of decimal points to write into SQL
+                                       for point coordinate data.  Used in
+                                       user_sdo_geom_metadata entry and defining
+                                       the PC_EXTENT for the point cloud object.
+      -s [ --srid ] arg                Oracle numerical SRID value to use to define
+                                       point cloud.
+      --pre-sql arg                    Quoted SQL or filename location of PL/SQL to
+                                       run before executing the point cloud
+                                       creation process.
+      --pre-block-sql arg              Quoted SQL or filename location of PL/SQL to
+                                       run before executing the insertion of block
+                                       data.
+      --post-sql arg                   Quoted SQL or filename location of PL/SQL to
+                                       run after inserting block data.
+      --base-table-aux-columns arg     Quoted, comma-separated list of columns to
+                                       add to the SQL that gets executed as part of
+                                       the point cloud insertion into the
+                                       base-table-name
+      --base-table-aux-values arg      Quoted, comma-separated list of values to
+                                       base-table-name
+      --solid                          Define the point cloud's PC_EXTENT geometry
+                                       gtype as (1,1007,3) instead of the normal
+                                       (1,1003,3), and use gtype 3008/2008 vs
+                                       3003/2003 for BLK_EXTENT geometry values.
+      --3d                             Use Z values for insertion of all extent
+                                       (PC_EXTENT, BLK_EXTENT,
+                                       USER_SDO_GEOM_METADATA) entries
+      --global-extent arg              Extent window to define for the PC_EXTENT.
+                                       Use a comma-separated list, for example,
+                                         --global-extent minx, miny, maxx, maxy
+                                         or
+                                         --global-extent minx, miny, minz, maxx,
+                                       maxy, maxz
+      --cached                         Cache the entire file on the first read
+    Transformation options:
+      --a_srs arg           Coordinate system to assign to input LAS file
+      --t_srs arg           Coordinate system to reproject output LAS file to.  Use
+                            --a_srs or verify that your input LAS file has a
+                            coordinate system according to lasinfo
+      --offset arg          A comma-separated list of offsets to set on the output
+                            file:
+                            --offset 0,0,0
+                            --offset  min,min,min
+      --scale arg           A comma-separated list of scales to set on the output
+                            file:
+                            --scale 0.1,0.1,0.00001
+      -f [ --format ] arg   Set the LAS format of the new file (only 1.0-1.2
+                            supported at this time):
+                            --format 1.2
+                            -f 1.1
+      --pad-header arg      Add extra bytes to the existing header
+    Filtering options:
+      -e [ --extent ] arg    Extent window that points must fall within to keep.
+                               -e minx, miny, maxx, maxy
+                               or
+                               -e minx, miny, minz, maxx, maxy, maxz
+      -t [ --thin ] arg (=0) Simple decimation-style thinning.
+                             Thin the file by removing every t'th point from the
+                             file.
+      --last_return_only     Keep last returns (cannot be used with
+                             --first_return_only)
+      --first_return_only    Keep first returns (cannot be used with
+      --keep-returns arg     A comma-separated list of return numbers to keep in
+                             the output file:
+                             --keep-returns 1,2,3
+      --drop-returns arg     Return numbers to drop.
+                             --drop-returns 2,3,4,5
+      --valid_only           Keep only valid points
+      --keep-classes arg     A comma-separated list of classifications to keep:
+                             --keep-classes 2,4,12
+                             --keep-classes 2
+      --drop-classes arg     A comma-separated list of classifications to drop:
+                             --drop-classes 1,7,8
+                             --drop-classes 2
+      --keep-intensity arg   Range in which to keep intensity.
+                             The following expression types are supported:
+                             --keep-intensity 0-100
+                             --keep-intensity <200
+                             --keep-intensity >400
+                             --keep-intensity >=200
+      --drop-intensity arg   Range in which to drop intensity.
+                             --drop-intensity <200
+                             --drop-intensity >400
+                             --drop-intensity >=200
+      --keep-time arg        Range in which to keep time.
+                             --keep-time 413665.2336-414092.8462
+                             --keep-time <414094.8462
+                             --keep-time >413665.2336
+                             --keep-time >=413665.2336
+      --drop-time arg        Range in which to drop time.
+                             --drop-time <413666.2336
+                             --drop-time >413665.2336
+                             --drop-time >=413665.2336
+      --keep-scan-angle arg  Range in which to keep scan angle.
+                             --keep-scan-angle 0-100
+                             --keep-scan-angle <100
+                             --keep-scan-angle <=100
+      --drop-scan-angle arg  Range in which to drop scan angle.
+                             --drop-scan-angle <30
+                             --drop-scan-angle >100
+                             --drop-scan-angle >=100
+      --keep-color arg       Range in which to keep colors.
+                             Define colors as two 3-tuples (R,G,B-R,G,B):
+                             --keep-color '0,0,0-125,125,125'
+      --drop-color arg       Range in which to drop colors.
+                             --drop-color '255,255,255-65536,65536,65536'
+    $ las2oci   --input input.las \
+                --connection lidar/lidar at oracle/crrel \
+                --pre-sql "CREATE TABLE HOBU (id number, CLOUD SDO_PC, DESCRIPTION VARCHAR2(20), HEADER BLOB)"
+                --post-sql "CREATE INDEX HOBU_ID_IDX on hobu(id)" \
+                --base-table-aux-columns "description" \
+                --base-table-aux-values "'Some text'" \
+                --global-extent -180.0,-90.0,180.0,90.0 \
+                --header-blob-column HEADER \
+                --base-table-name HOBU \
+                --cloud-column-name CLOUD \
+                --block-table-name OUTPUT
 .. _`Oracle Point Cloud`: http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_pc_pkg_ref.htm
diff -r 99023a42b7b9 -r 0ed40975a132 include/liblas/lasbounds.hpp
--- a/include/liblas/lasbounds.hpp	Tue Aug 17 09:15:25 2010 -0500
+++ b/include/liblas/lasbounds.hpp	Tue Aug 17 09:55:57 2010 -0500
@@ -203,13 +203,13 @@
 liblas::Point min() {
     liblas::Point p;
-    p.SetCoordinates(mins(0), mins(1), mins(2));
+    p.SetCoordinates(min(0), min(1), min(2));
     return p;
 liblas::Point max() {
     liblas::Point p;
-    p.SetCoordinates(max(0), max(1), maxs(2));
+    p.SetCoordinates(max(0), max(1), max(2));
     return p;
diff -r 99023a42b7b9 -r 0ed40975a132 include/liblas/lasreader.hpp
--- a/include/liblas/lasreader.hpp	Tue Aug 17 09:15:25 2010 -0500
+++ b/include/liblas/lasreader.hpp	Tue Aug 17 09:55:57 2010 -0500
@@ -69,7 +69,7 @@
     /// @excepion std::runtime_error - on failure state of the input stream.
     Reader(std::istream& ifs);
     Reader(std::istream& ifs, uint32_t cache_size);
+    Reader(std::istream& ifs, uint32_t cache_size, Header& header);
     Reader(ReaderI* reader);
diff -r 99023a42b7b9 -r 0ed40975a132 src/lasreader.cpp
--- a/src/lasreader.cpp	Tue Aug 17 09:15:25 2010 -0500
+++ b/src/lasreader.cpp	Tue Aug 17 09:55:57 2010 -0500
@@ -71,7 +71,7 @@
 Reader::Reader(std::istream& ifs, uint32_t cache_size) :
-    m_pimpl(new detail::CachedReaderImpl(ifs,cache_size)),
+    m_pimpl(new detail::CachedReaderImpl(ifs, cache_size)),
     m_header(HeaderPtr()),
     m_point(0),
     m_empty_point(new Point()),
@@ -82,6 +82,23 @@
     Init();
+Reader::Reader(std::istream& ifs, uint32_t cache_size, Header& header) :
+    m_header(HeaderPtr( )),
+    m_point(0),
+    m_empty_point(new Point()),
+    bCustomHeader(true),
+    m_filters(0),
+    m_transforms(0),
+    m_reprojection_transform(TransformPtr())
+    // if we have a custom header, create a slot for it and then copy
+    // the header we were given
+    m_header = HeaderPtr(new Header(header));
More information about the Liblas-commits mailing list
