[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Aug 18 10:11:45 EDT 2010
changeset df07406b52de in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=df07406b52de
summary: Fixed case of Boost CMake macros. Incorrect case led to not adding Boost include path to include directories.
changeset c70a97b6ec33 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c70a97b6ec33
summary: Missing boost:: qualifiers specified for integer types.
changeset 3ef3932dd20a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=3ef3932dd20a
summary: mege
diffstat:
 CMakeLists.txt                              |    4 +-
 include/liblas/detail/index/indexcell.hpp   |    2 +-
 include/liblas/detail/index/indexoutput.hpp |   53 +-
 include/liblas/lasfilter.hpp                |    6 +-
 include/liblas/lasindex.hpp                 |  137 +++-
 src/CMakeLists.txt                          |    1 +
 src/detail/index/indexoutput.cpp            |  415 +++++++--------
 src/lasfilter.cpp                           |    2 +
 src/lasindex.cpp                            |  731 +++++++++++++++++----------
 9 files changed, 822 insertions(+), 529 deletions(-)
diffs (truncated from 2090 to 300 lines):
diff -r 5de82dbc68a8 -r 3ef3932dd20a CMakeLists.txt
--- a/CMakeLists.txt	Tue Aug 17 22:17:47 2010 +0100
+++ b/CMakeLists.txt	Wed Aug 18 15:15:24 2010 +0100
@@ -120,9 +120,9 @@
 # Boost C++ Libraries support - required
 message(STATUS "Searching for Boost 1.38+ - done")
-find_package(Boost 1.38 REQUIRED program_options)
+find_package(Boost 1.38 COMPONENTS program_options REQUIRED)
-if(Boost_FOUND AND Boost_program_options_FOUND)
+if(Boost_FOUND AND Boost_PROGRAM_OPTIONS_FOUND)
   include_directories(${Boost_INCLUDE_DIRS})
 endif()
diff -r 5de82dbc68a8 -r 3ef3932dd20a include/liblas/detail/index/indexcell.hpp
--- a/include/liblas/detail/index/indexcell.hpp	Tue Aug 17 22:17:47 2010 +0100
+++ b/include/liblas/detail/index/indexcell.hpp	Wed Aug 18 15:15:24 2010 +0100
@@ -43,7 +43,7 @@
 #ifndef LIBLAS_DETAIL_INDEXCELL_HPP_INCLUDED
 #define LIBLAS_DETAIL_INDEXCELL_HPP_INCLUDED
-#include <boost/cstdint.hpp>
 #include <map>
 namespace liblas { namespace detail {
diff -r 5de82dbc68a8 -r 3ef3932dd20a include/liblas/detail/index/indexoutput.hpp
--- a/include/liblas/detail/index/indexoutput.hpp	Tue Aug 17 22:17:47 2010 +0100
+++ b/include/liblas/detail/index/indexoutput.hpp	Wed Aug 18 15:15:24 2010 +0100
@@ -43,7 +43,6 @@
 #ifndef LIBLAS_DETAIL_INDEXOUTPUT_HPP_INCLUDED
 #define LIBLAS_DETAIL_INDEXOUTPUT_HPP_INCLUDED
 #include <liblas/lasindex.hpp>
 #include <liblas/detail/index/indexcell.hpp>
@@ -59,8 +58,8 @@
 	liblas::Index *m_index;
 	liblas::VariableRecord m_indexVLRHeaderRecord, m_indexVLRCellRecord;
 	IndexVLRData m_indexVLRHeaderData, m_indexVLRCellPointData, m_indexVLRTempData;
-	uint32_t m_VLRCommonDataSize, m_VLRDataSizeLocation, m_FirstCellLocation, m_LastCellLocation, m_DataRecordSize,
-		m_TempWritePos;
+	uint32_t m_VLRCommonDataSize, m_VLRDataSizeLocation, m_FirstCellLocation, m_LastCellLocation;
+	uint32_t  m_DataRecordSize, m_TempWritePos;
 	bool m_FirstCellInVLR, m_SomeDataReadyToWrite;
 protected:
@@ -71,6 +70,54 @@
+template <typename T, typename Q>
+inline void WriteVLRData_n(IndexVLRData& dest, T src, Q& pos)
+    // Fix little-endian
+    LIBLAS_SWAP_BYTES_N(&src, sizeof(T));
+    // error if writing past array end
+    if (static_cast<size_t>(pos) + sizeof(T) > dest.size())
+		throw std::out_of_range("liblas::detail::WriteVLRData_n: array index out of range");
+	// copy sizeof(T) bytes to destination
+    memcpy(&dest[pos], &src, sizeof(T));
+    // increment the write position to end of written data
+    pos += sizeof(T);
+inline void WriteVLRDataNoInc_n(IndexVLRData& dest, T src, Q const& pos)
+		throw std::out_of_range("liblas::detail::WriteVLRDataNoInc_n: array index out of range");
+inline void WriteVLRData_str(IndexVLRData& dest, char * const src, T const srclen, Q& pos)
+ 	// copy srclen bytes to destination
+	memcpy(&dest[pos], src, srclen);
+    if (static_cast<size_t>(pos) + static_cast<size_t>(srclen) > dest.size())
+		throw std::out_of_range("liblas::detail::WriteVLRData_str: array index out of range");
+    pos += srclen;
+inline void WriteVLRDataNoInc_str(IndexVLRData& dest, char * const src, T const srclen, Q pos)
+		throw std::out_of_range("liblas::detail::WriteVLRDataNoInc_str: array index out of range");
 }} // namespace liblas::detail
 #endif // LIBLAS_DETAIL_INDEXOUTPUT_HPP_INCLUDED
diff -r 5de82dbc68a8 -r 3ef3932dd20a include/liblas/lasfilter.hpp
--- a/include/liblas/lasfilter.hpp	Tue Aug 17 22:17:47 2010 +0100
+++ b/include/liblas/lasfilter.hpp	Wed Aug 18 15:15:24 2010 +0100
@@ -128,7 +128,7 @@
 public:
-    ThinFilter(uint32_t thin);
+    ThinFilter(boost::uint32_t thin);
     bool filter(const liblas::Point& point);
@@ -137,8 +137,8 @@
     ThinFilter(ThinFilter const& other);
     ThinFilter& operator=(ThinFilter const& rhs);
-    uint32_t thin_amount;
-    uint32_t thin_count;
+    boost::uint32_t thin_amount;
+    boost::uint32_t thin_count;
diff -r 5de82dbc68a8 -r 3ef3932dd20a include/liblas/lasindex.hpp
--- a/include/liblas/lasindex.hpp	Tue Aug 17 22:17:47 2010 +0100
+++ b/include/liblas/lasindex.hpp	Wed Aug 18 15:15:24 2010 +0100
@@ -42,9 +42,10 @@
 #ifndef LIBLAS_LASINDEX_HPP_INCLUDED
 #define LIBLAS_LASINDEX_HPP_INCLUDED
 #include <liblas/lasreader.hpp>
 #include <liblas/lasheader.hpp>
+#include <liblas/lasbounds.hpp>
 #include <liblas/lasvariablerecord.hpp>
@@ -73,10 +74,10 @@
 public:
 	Index();
-	Index(liblas::Reader *reader, std::ostream *ofs = 0, const char *tmpfilenme = 0, const char *outfilenme = 0, const char *indexauthor = 0,
+	Index(liblas::Reader *reader, std::ostream *ofs = 0, const char *tmpfilenme = 0, const char *indexauthor = 0,
 		const char *indexcomment = 0, const char *indexdate = 0,
 		double zbinht = 0.0, uint32_t maxmem = LIBLAS_INDEX_MAXMEMDEFAULT, int debugoutputlevel = 0, FILE *debugger = 0);
-    Index(std::istream *ifs, std::ostream *ofs = 0, const char *tmpfilenme = 0, const char *outfilenme = 0, const char *indexauthor = 0,
+    Index(std::istream *ifs, std::ostream *ofs = 0, const char *tmpfilenme = 0, const char *indexauthor = 0,
     Index(IndexData const& ParamSrc);
@@ -91,8 +92,11 @@
 private:
 	Reader *m_reader;
-	Header m_header;
-	bool m_indexBuilt, m_tempFileStarted, m_readerCreated, m_readOnly, m_forceNewIndex;
+	Reader *m_idxreader;
+	Header m_pointheader;
+	Header m_idxheader;
+	Bounds<double> m_bounds;
+	bool m_indexBuilt, m_tempFileStarted, m_readerCreated, m_readOnly, m_writestandaloneindex, m_forceNewIndex;
 	int m_debugOutputLevel;
     uint32_t m_pointRecordsCount, m_maxMemoryUsage, m_cellsX, m_cellsY, m_cellsZ, m_totalCells,
 		m_tempFileWrittenBytes, m_DataVLR_ID;
@@ -100,11 +104,10 @@
 		m_LowZCellCompletelyIn, m_HighZCellCompletelyIn;
     int32_t m_LowXBorderCell, m_HighXBorderCell, m_LowYBorderCell, m_HighYBorderCell,
 		m_LowZBorderCell, m_HighZBorderCell;
-    double m_minX, m_maxX, m_minY, m_maxY, m_minZ, m_maxZ, m_scaleX, m_scaleY, m_scaleZ,
-		m_offsetX, m_offsetY, m_offsetZ, m_rangeX, m_rangeY, m_rangeZ, m_cellSizeZ, m_cellSizeX, m_cellSizeY;
-	double m_filterMinXCell, m_filterMaxXCell, m_filterMinYCell, m_filterMaxYCell, m_filterMinZCell, m_filterMaxZCell;
+    double m_rangeX, m_rangeY, m_rangeZ, m_cellSizeZ, m_cellSizeX, m_cellSizeY;
+	double m_filterMinXCell, m_filterMaxXCell, m_filterMinYCell, m_filterMaxYCell, m_filterMinZCell, m_filterMaxZCell,
+		m_LowXBorderPartCell, m_HighXBorderPartCell, m_LowYBorderPartCell, m_HighYBorderPartCell;
 	std::string m_tempFileName;
-	std::string m_outFileName;
 	std::string m_indexAuthor;
 	std::string m_indexComment;
 	std::string m_indexDate;
@@ -120,6 +123,11 @@
 	bool LoadIndexVLR(VariableRecord const& vlr);
 	void SetCellFilterBounds(IndexData const& ParamSrc);
 	bool FilterOneVLR(VariableRecord const& vlr, uint32_t& i, IndexData const& ParamSrc);
+	bool VLRInteresting(int32_t MinCellX, int32_t MinCellY, int32_t MaxCellX, int32_t MaxCellY,
+		IndexData const& ParamSrc);
+	bool CellInteresting(int32_t x, int32_t y, IndexData const& ParamSrc);
+	bool SubCellInteresting(int32_t SubCellID, int32_t XCellID, int32_t YCellID, IndexData const& ParamSrc);
+	bool ZCellInteresting(int32_t ZCellID, IndexData const& ParamSrc);
 	bool FilterOnePoint(int32_t x, int32_t y, int32_t z, int32_t PointID, int32_t LastPointID, bool &LastPtRead,
 	bool IdentifyCell(Point const& CurPt, uint32_t& CurCellX, uint32_t& CurCellY) const;
@@ -132,8 +140,6 @@
 	void CloseTempFile(void);
 	bool SaveIndexInLASFile(void);
 	bool SaveIndexInStandAloneFile(void);
-	FILE *OpenOutputFile(void);
-	void CloseOutputFile(void);
 	bool FileError(const char *Reporter);
 	bool OutputFileError(const char *Reporter) const;
 	bool DebugOutputError(const char *Reporter) const;
@@ -141,6 +147,7 @@
 	bool PointBoundsError(const char *Reporter) const;
 	bool MemoryError(const char *Reporter) const;
 	bool InitError(const char *Reporter) const;
+	bool InputBoundsError(const char *Reporter) const;
 	// debugging
 	bool OutputCellStats(IndexCellDataBlock& CellBlock)  const;
@@ -150,12 +157,13 @@
     bool IndexFailed(void)  const {return (! m_indexBuilt);};
     bool IndexReady(void)  const {return (m_indexBuilt);};
     const std::vector<uint32_t>& Filter(IndexData const& ParamSrc);
-	double GetMinX(void) const	{return m_minX;};
-	double GetMaxX(void) const	{return m_maxX;};
-	double GetMinY(void) const	{return m_minY;};
-	double GetMaxY(void) const	{return m_maxY;};
-	double GetMinZ(void) const	{return m_minZ;};
-	double GetMaxZ(void) const	{return m_maxZ;};
+	double GetMinX(void) const	{return m_bounds.min(0);};
+	double GetMaxX(void) const	{return m_bounds.max(0);};
+	double GetMinY(void) const	{return m_bounds.min(1);};
+	double GetMaxY(void) const	{return m_bounds.max(1);};
+	double GetMinZ(void) const	{return m_bounds.min(2);};
+	double GetMaxZ(void) const	{return m_bounds.max(2);};
+	Bounds<double> const& GetBounds(void) const	{return m_bounds;};
 	uint32_t GetPointRecordsCount(void) const	{return m_pointRecordsCount;};
 	uint32_t GetCellsX(void) const	{return m_cellsX;};
 	uint32_t GetCellsY(void) const	{return m_cellsY;};
@@ -164,13 +172,15 @@
 	double GetCellSizeZ(void) const	{return m_cellSizeZ;};
 	FILE *GetDebugger(void) const	{return m_debugger;};
 	bool GetReadOnly(void) const	{return m_readOnly;};
+	bool GetStandaloneIndex(void) const	{return m_writestandaloneindex;};
 	bool GetForceNewIndex(void) const	{return m_forceNewIndex;};
 	uint32_t GetMaxMemoryUsage(void) const	{return m_maxMemoryUsage;};
-	Header *GetHeader(void) {return &m_header;};
+	Header *GetPointHeader(void) {return &m_pointheader;};
+	Header *GetIndexHeader(void) {return &m_idxheader;};
 	Reader *GetReader(void) const {return m_reader;};
+	Reader *GetIndexReader(void) const {return m_idxreader;};
 	int GetDebugOutputLevel(void) const {return m_debugOutputLevel;};
 	const char *GetTempFileName(void) const {return m_tempFileName.c_str();};
-	const char *GetOutFileName(void) const {return m_outFileName.c_str();};
 	const char *GetIndexAuthorStr(void)  const;
 	const char *GetIndexCommentStr(void)  const;
 	const char *GetIndexDateStr(void)  const;
@@ -178,15 +188,15 @@
 	void SetIndexAuthorStr(const char *ias)	{m_indexAuthor = ias;};
 	void SetIndexCommentStr(const char *ics)	{m_indexComment = ics;};
 	void SetIndexDateStr(const char *ids)	{m_indexDate = ids;};
-	void SetMinX(double minX)	{m_minX = minX;};
-	void SetMaxX(double maxX)	{m_maxX = maxX;};
-	void SetMinY(double minY)	{m_minY = minY;};
-	void SetMaxY(double maxY)	{m_maxY = maxY;};
-	void SetMinZ(double minZ)	{m_minZ = minZ;};
-	void SetMaxZ(double maxZ)	{m_maxZ = maxZ;};
-	void CalcRangeX(void)	{m_rangeX = m_maxX - m_minX;};
-	void CalcRangeY(void)	{m_rangeY = m_maxY - m_minY;};
-	void CalcRangeZ(void)	{m_rangeZ = m_maxZ - m_minZ;};
+	void SetMinX(double minX)	{m_bounds.min(0, minX);};
+	void SetMaxX(double maxX)	{m_bounds.max(0, maxX);};
+	void SetMinY(double minY)	{m_bounds.min(1, minY);};
+	void SetMaxY(double maxY)	{m_bounds.max(1, maxY);};
+	void SetMinZ(double minZ)	{m_bounds.min(2, minZ);};
+	void SetMaxZ(double maxZ)	{m_bounds.max(2, maxZ);};
+	void CalcRangeX(void)	{m_rangeX = m_bounds.max(0) - m_bounds.min(0);};
+	void CalcRangeY(void)	{m_rangeY = m_bounds.max(1) - m_bounds.min(1);};
+	void CalcRangeZ(void)	{m_rangeZ = m_bounds.max(2) - m_bounds.min(2);};
 	void SetPointRecordsCount(uint32_t prc)	{m_pointRecordsCount = prc;};
 	void SetCellsX(uint32_t cellsX)	{m_cellsX = cellsX;};
 	void SetCellsY(uint32_t cellsY)	{m_cellsY = cellsY;};
@@ -200,10 +210,12 @@
 public:
 	IndexData(void);
  	IndexData(Index const& index);
-	bool SetInitialValues(std::istream *ifs = 0, Reader *reader = 0, std::ostream *ofs = 0, const char *tmpfilenme = 0, const char *outfilenme = 0, const char *indexauthor = 0,
+	bool SetInitialValues(std::istream *ifs = 0, Reader *reader = 0, std::ostream *ofs = 0, Reader *idxreader = 0, const char *tmpfilenme = 0, const char *indexauthor = 0,
 		const char *indexcomment = 0, const char *indexdate = 0, double zbinht = 0.0,
-		uint32_t maxmem = LIBLAS_INDEX_MAXMEMDEFAULT, int debugoutputlevel = 0, bool readonly = 0, bool forcenewindex = 0, FILE *debugger = 0);
+		uint32_t maxmem = LIBLAS_INDEX_MAXMEMDEFAULT, int debugoutputlevel = 0, bool readonly = 0, bool writestandaloneindex = 0,
+		bool forcenewindex = 0, FILE *debugger = 0);
 	bool SetFilterValues(double LowFilterX, double HighFilterX, double LowFilterY, double HighFilterY, double LowFilterZ, double HighFilterZ);
+	bool SetFilterValues(Bounds<double> const& src);
     // Blocked copying operations, declared but not defined.
     /// Copy constructor.
@@ -213,41 +225,47 @@
 private:
 	void SetValues(void);
+	bool CalcFilterEnablers(void);
 protected:
 	Reader *m_reader;
More information about the Liblas-commits mailing list
