[Liblas-commits] hg: lots of typos thanks to search/replace
liblas-commits at liblas.org
Mon Aug 23 14:08:04 EDT 2010
changeset 1ea0e479343a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1ea0e479343a
summary: lots of typos thanks to search/replace
diffstat:
src/lasindex.cpp | 688 +++++++++++++++++++++++++++---------------------------
1 files changed, 344 insertions(+), 344 deletions(-)
diffs (truncated from 1097 to 300 lines):
diff -r 06ba842fc49e -r 1ea0e479343a src/lasindex.cpp
--- a/src/lasindex.cpp Mon Aug 23 12:01:11 2010 -0600
+++ b/src/lasindex.cpp Mon Aug 23 13:07:55 2010 -0500
@@ -156,19 +156,19 @@
m_pointheader = m_reader->GetHeader();
} // else
boost::uint32_t initialVLRs = m_idxheader.GetRecordsCount();
- for (boost::uint32_t i = 0; i < initialVLRs; ++i)
- VariableRecord const& vlr = m_idxheader.GetVLR(i);
- // a combination of "liblas" and 42 denotes that this is a liblas spatial index id
- if (std::string(vlr.GetUserId(false)) == std::string("liblas"))
- if (vlr.GetRecordId() == 42)
- LoadIndexVLR(vlr);
- IndexFound = true;
- break;
+ for (boost::uint32_t i = 0; i < initialVLRs; ++i)
+ VariableRecord const& vlr = m_idxheader.GetVLR(i);
+ // a combination of "liblas" and 42 denotes that this is a liblas spatial index id
+ if (std::string(vlr.GetUserId(false)) == std::string("liblas"))
+ if (vlr.GetRecordId() == 42)
+ LoadIndexVLR(vlr);
+ IndexFound = true;
+ break;
if (IndexFound)
@@ -208,26 +208,26 @@
void Index::ClearOldIndex(void)
- boost::uint32_t TempDataVLR_ID = GetDataVLR_ID();
- // 42 is index ID
- // sets DataVLR_ID to value in index header
- m_idxheader.DeleteVLR(i);
- } // if
- else if (vlr.GetRecordId() == GetDataVLR_ID())
- } // else if
- } // if
+ boost::uint32_t TempDataVLR_ID = GetDataVLR_ID();
+ // 42 is index ID
+ // sets DataVLR_ID to value in index header
+ m_idxheader.DeleteVLR(i);
+ } // if
+ else if (vlr.GetRecordId() == GetDataVLR_ID())
+ } // else if
+ } // if
} // for
// restore Data VLR ID
@@ -260,17 +260,17 @@
m_filterResult.resize(0);
if (m_reader)
- for (boost::uint32_t i = 0; i < m_idxheader.GetRecordsCount(); ++i)
- boost::uint16_t RecordID = vlr.GetRecordId();
- if (RecordID == 42)
- if (! LoadIndexVLR(vlr))
- break;
+ for (boost::uint32_t i = 0; i < m_idxheader.GetRecordsCount(); ++i)
+ boost::uint16_t RecordID = vlr.GetRecordId();
+ if (RecordID == 42)
+ if (! LoadIndexVLR(vlr))
+ break;
// Beyond the first record would be more VLR's with the actual index data
// some cells will fall completely inside, some outside and some straddling the filter bounds
SetCellFilterBounds(ParamSrc);
@@ -280,14 +280,14 @@
fprintf(m_debugger, "Index bounds do not intersect filter bounds.\n");
break;
} // if
- } // if 42
- else if (RecordID == m_DataVLR_ID)
- // some of our data is in this record
- if (! FilterOneVLR(vlr, i, ParamSrc))
- break;
- } // else if ID matches ID stored in index header
+ } // if 42
+ else if (RecordID == m_DataVLR_ID)
+ // some of our data is in this record
+ if (! FilterOneVLR(vlr, i, ParamSrc))
+ break;
+ } // else if ID matches ID stored in index header
} // m_reader
return (m_filterResult);
@@ -355,9 +355,9 @@
try {
//boost::uint16_t VLRIndexRecLen = vlr.GetRecordLength();
- // GetData returns a vector of boost::uint8_t
- // std::vector<uint8_t>
- // read the first record of our index data
+ // GetData returns a vector of boost::uint8_t
+ // std::vector<uint8_t>
+ // read the first record of our index data
IndexVLRData const& VLRIndexData = vlr.GetData();
// parse the index header data
ReadVLRData_n(VersionMajor, VLRIndexData, ReadPos);
@@ -422,15 +422,15 @@
} // Index::LoadIndexVLR
-bool Index::FilterOneVLR(VariableRecord const& vlr, boost::uint32_t& i, IndexData const& ParamSrc)
+bool Index::FilterOneVLR(VariableRecord const& vlr, boost::uint32_t& i, IndexData const& ParamSrc)
boost::uint16_t ReadPos = 0;
boost::uint32_t MinCellX, MinCellY, MaxCellX, MaxCellY, DataRecordSize = 0;
- IndexVLRData CompositeData;
- try {
- IndexVLRData const& VLRIndexRecordData = vlr.GetData();
+ IndexVLRData CompositeData;
+ try {
+ IndexVLRData const& VLRIndexRecordData = vlr.GetData();
CompositeData.resize(VLRIndexRecLen);
ReadVLRDataNoInc_str((char *)&CompositeData[0], VLRIndexRecordData, VLRIndexRecLen, 0);
@@ -452,8 +452,8 @@
while (UnreadData)
++i;
- VariableRecord const& vlr2 = m_idxheader.GetVLR(i);
- IndexVLRData const& TempData = vlr2.GetData();
+ VariableRecord const& vlr2 = m_idxheader.GetVLR(i);
+ IndexVLRData const& TempData = vlr2.GetData();
boost::uint16_t TempRecLen = vlr2.GetRecordLength();
ReadVLRDataNoInc_str((char *)&CompositeData[ReadData], TempData, TempRecLen, 0);
ReadData += TempRecLen;
@@ -464,12 +464,12 @@
UnreadData = 0;
} // while
} // if
- if (VLRInteresting(MinCellX, MinCellY, MaxCellX, MaxCellY, ParamSrc))
- // translate the data for this VLR
- while (ReadPos + sizeof (boost::uint32_t) < DataRecordSize)
+ if (VLRInteresting(MinCellX, MinCellY, MaxCellX, MaxCellY, ParamSrc))
+ // translate the data for this VLR
+ while (ReadPos + sizeof (boost::uint32_t) < DataRecordSize)
// current cell, x, y
boost::uint32_t x, y, PtRecords, SubCellsXY, SubCellsZ;
ReadVLRData_n(x, CompositeData, ReadPos);
@@ -484,10 +484,10 @@
ReadVLRData_n(PtRecords, CompositeData, ReadPos);
ReadVLRData_n(SubCellsXY, CompositeData, ReadPos);
ReadVLRData_n(SubCellsZ, CompositeData, ReadPos);
- // read the data stored in Z cells, if any
- for (boost::uint32_t SubCellZ = 0; SubCellZ < SubCellsZ; ++SubCellZ)
+ // read the data stored in Z cells, if any
+ for (boost::uint32_t SubCellZ = 0; SubCellZ < SubCellsZ; ++SubCellZ)
boost::uint32_t ZCellID;
ReadVLRData_n(ZCellID, CompositeData, ReadPos);
// number of point records in subcell
@@ -511,10 +511,10 @@
} // for
} // if
} // for
- } // for
- // read the data stored in XY quadtree cells
- for (boost::uint32_t SubCellXY = 0; SubCellXY < SubCellsXY; ++SubCellXY)
+ } // for
+ // read the data stored in XY quadtree cells
+ for (boost::uint32_t SubCellXY = 0; SubCellXY < SubCellsXY; ++SubCellXY)
boost::uint32_t SubCellID;
ReadVLRData_n(SubCellID, CompositeData, ReadPos);
@@ -522,7 +522,7 @@
ReadVLRData_n(SubCellNumRecords, CompositeData, ReadPos);
for (uint32_t SubCellPt = 0; SubCellPt < SubCellNumRecords; ++SubCellPt)
- boost::uint32_T PointID, LastPointID = static_cast<boost::uint32_T>(~0);
+ boost::uint32_t PointID, LastPointID = static_cast<boost::uint32_t>(~0);
bool LastPtRead = 0;
ReadVLRData_n(PointID, CompositeData, ReadPos);
assert(PointID < m_pointRecordsCount);
@@ -530,7 +530,7 @@
ReadVLRData_n(ConsecutivePts, CompositeData, ReadPos);
if (TestPointsInThisCell && SubCellInteresting(SubCellID, x, y, ParamSrc))
- for (boost::uint32_T PtCt = 0; PtCt < ConsecutivePts; ++PointID, ++PtCt)
+ for (boost::uint32_t PtCt = 0; PtCt < ConsecutivePts; ++PointID, ++PtCt)
if (FilterOnePoint(x, y, 0, PointID, LastPointID, LastPtRead, ParamSrc))
m_filterResult.push_back(PointID);
@@ -538,13 +538,13 @@
} // for
} // if
} // for
- } // for
- // read data in unsubdivided cells
+ } // for
+ // read data in unsubdivided cells
if (! (SubCellsZ || SubCellsXY))
- for (boost::uint32_T CurPt = 0; CurPt < PtRecords; ++CurPt)
+ for (boost::uint32_t CurPt = 0; CurPt < PtRecords; ++CurPt)
@@ -552,7 +552,7 @@
if (TestPointsInThisCell)
@@ -561,9 +561,9 @@
} // if
} // for
} // if
- } // while
- } // if
- } // try
+ } // while
+ } // if
+ } // try
catch (std::bad_alloc) {
return (false);
} // catch
@@ -571,51 +571,51 @@
return (false);
} // catch
return true;
-} // Index::FilterOneVLR
+} // Index::FilterOneVLR
-bool Index::VLRInteresting(boost::int32_t MinCellX, boost::int32_t MinCellY, boost::int32_t MaxCellX, boost::int32_t MaxCellY, IndexData const& ParamSrc)
More information about the Liblas-commits
