[Liblas-commits] hg: add detail/utility.cpp to hold the GeoTIFFPrint function
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Aug 24 10:45:35 EDT 2010
changeset bb542d024937 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=bb542d024937
summary: add detail/utility.cpp to hold the GeoTIFFPrint function
diffstat:
 include/liblas/detail/utility.hpp |  45 +++++++++++++-----------------
 src/CMakeLists.txt                |   5 ++-
 src/detail/utility.cpp            |  56 +++++++++++++++++++++++++++++++++++++++
 src/lasspatialreference.cpp       |   8 ++--
 4 files changed, 83 insertions(+), 31 deletions(-)
diffs (162 lines):
diff -r b08db92cda33 -r bb542d024937 include/liblas/detail/utility.hpp
--- a/include/liblas/detail/utility.hpp	Tue Aug 24 14:46:13 2010 +0100
+++ b/include/liblas/detail/utility.hpp	Tue Aug 24 09:45:20 2010 -0500
@@ -435,31 +435,26 @@
 #endif
 // Utility functor with accompanying to print GeoTIFF directory.
-struct geotiff_dir_printer
-    geotiff_dir_printer() {}
-    std::string output() const { return m_oss.str(); }
-    std::string::size_type size() const { return m_oss.str().size(); }
-    void operator()(char* data, void* aux)
-        if (0 != data)
-            m_oss << data;
-private:
-    std::ostringstream m_oss;
-extern "C" int GeoTiffPrintMethod(char* data, void* aux)
-    geotiff_dir_printer* printer = reinterpret_cast<geotiff_dir_printer*>(aux);
-    (*printer)(data, 0);
-    return static_cast<int>(printer->size());
+struct geotiff_dir_printer
+    geotiff_dir_printer() {}
+    std::string output() const { return m_oss.str(); }
+    std::string::size_type size() const { return m_oss.str().size(); }
+    void operator()(char* data, void* aux)
+        if (0 != data)
+            m_oss << data;
+private:
+    std::ostringstream m_oss;
+extern "C" int libLASGeoTIFFPrint(char* data, void* aux);
 }} // namespace liblas::detail
diff -r b08db92cda33 -r bb542d024937 src/CMakeLists.txt
--- a/src/CMakeLists.txt	Tue Aug 24 14:46:13 2010 +0100
+++ b/src/CMakeLists.txt	Tue Aug 24 09:45:20 2010 -0500
@@ -80,8 +80,9 @@
   lasvariablerecord.cpp
   laswriter.cpp)
-set(LIBLAS_DETAIL_CPP) # Currently empty
+set(LIBLAS_DETAIL_CPP
+  detail/utility.cpp)
 set(LIBLAS_DETAIL_INDEX_CPP
   detail/index/indexcell.cpp
   detail/index/indexoutput.cpp)
diff -r b08db92cda33 -r bb542d024937 src/detail/utility.cpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/src/detail/utility.cpp	Tue Aug 24 09:45:20 2010 -0500
@@ -0,0 +1,56 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  Generic utility code for libLAS
+ * Author:   Mateusz Loskot, mateusz at loskot.net
+ * Copyright (c) 2010, Mateusz Loskot
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#include <liblas/detail/utility.hpp>
+    liblas::detail::geotiff_dir_printer* printer = reinterpret_cast<liblas::detail::geotiff_dir_printer*>(aux);
+    (*printer)(data, 0);
+    return static_cast<int>(printer->size());
+namespace liblas { namespace detail {
+}} // namespace liblas::detail
diff -r b08db92cda33 -r bb542d024937 src/lasspatialreference.cpp
--- a/src/lasspatialreference.cpp	Tue Aug 24 14:46:13 2010 +0100
+++ b/src/lasspatialreference.cpp	Tue Aug 24 09:45:20 2010 -0500
@@ -562,7 +562,7 @@
 // if we have libgeotiff but not GDAL, we'll use the
 // simple method in libgeotiff
-#if defined(HAVE_LIBGEOTIFF) && !defined(HAVE_GDAL)
+#if defined(HAVE_LIBGEOTIFF) && !defined(HAVE_GDAL)
     GTIFDefn defn;
@@ -630,7 +630,7 @@
     int ret = 0;
     ret = GTIFSetFromProj4( m_gtiff, v.c_str());
@@ -671,8 +671,8 @@
     return std::string("");
 #else
-    detail::geotiff_dir_printer geotiff_printer;
-    GTIFPrint(m_gtiff, detail::GeoTiffPrintMethod, &geotiff_printer);
+    detail::geotiff_dir_printer geotiff_printer;
+    GTIFPrint(m_gtiff, detail::libLASGeoTIFFPrint, &geotiff_printer);
     return geotiff_printer.output();
 #endif
More information about the Liblas-commits mailing list
