[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Aug 26 12:56:36 EDT 2010
changeset 7f1e141f7926 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7f1e141f7926
summary: add some docs to filter types
changeset 7cad188b96bc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7cad188b96bc
summary: some more docs for new public methods
diffstat:
 include/liblas/lasfilter.hpp |  112 ++++++++++++++++++++++++------------------
 include/liblas/lasheader.hpp |   15 +++++-
 2 files changed, 79 insertions(+), 48 deletions(-)
diffs (206 lines):
diff -r 76397c8a28d0 -r 7cad188b96bc include/liblas/lasfilter.hpp
--- a/include/liblas/lasfilter.hpp	Thu Aug 26 11:02:34 2010 -0500
+++ b/include/liblas/lasfilter.hpp	Thu Aug 26 11:56:29 2010 -0500
@@ -87,6 +87,8 @@
     FilterType m_type;
+/// A filter for keeping or rejecting points that fall within a
+/// specified bounds.
 class BoundsFilter: public FilterI
 public:
@@ -106,7 +108,7 @@
     BoundsFilter& operator=(BoundsFilter const& rhs);
+/// A filter for keeping or rejecting a list of classification ids
 class ClassificationFilter: public FilterI
 public:
@@ -124,11 +126,12 @@
     ClassificationFilter& operator=(ClassificationFilter const& rhs);
+/// A filter simple decimation
 class ThinFilter: public liblas::FilterI
 public:
+    /// Default constructor.  Keep every thin'th point.
     ThinFilter(boost::uint32_t thin);
     bool filter(const liblas::Point& point);
@@ -143,6 +146,7 @@
+/// A filter for keeping or rejecting a list of return ids.
 class ReturnFilter: public FilterI
 public:
@@ -176,64 +180,78 @@
+/// A templated class that allows you
+/// to create complex filters using functions that are callable
+/// from the liblas::Point class.  See laskernel.cpp for examples
+/// how to use it for filtering intensity and time values.
 template <typename T>
 class ContinuousValueFilter: public FilterI
-    // A ContinuousValueFilter is a templated class that allows you
-    // to create complexe filters using functions that are callable
-    // from the liblas::Point class.  See las2las2 for examples
-    // how to use it for filtering intensity and time values.
-    // To use this we must take in a filtering function that returns
-    // us a value from the point, and a binary_predicate comparator
-    // (ie, std::less, std::greater, std::equal_to, etc).
-    // Example:
-    // GetIntensity returns a uint16_t, so we use that for our template
-    // value.  This filter would keep all points with intensities that are
-    // less than 100.
-    // liblas::ContinuousValueFilter<uint16_t>::compare_func c = std::less<uint16_t>();
-    // liblas::ContinuousValueFilter<uint16_t>::filter_func f = &liblas::Point::GetIntensity;
-    // liblas::ContinuousValueFilter<uint16_t>* intensity_filter = new liblas::ContinuousValueFilter<uint16_t>(f, 100, c);
-    // intensity_filter->SetType(liblas::FilterI::eInclusion);
-    // In addition to explicitly setting your comparator function, you can
-    // also use the constructor that takes in a simple expression string
-    // and constructs the basic comparators.  See the source code or las2las2
-    // help output for the forms that are supported.  This may be
-    // improved in the future.
-    // std::string intensities("<100")
-    // liblas::ContinuousValueFilter<uint16_t>* intensity_filter = new liblas::ContinuousValueFilter<uint16_t>(f, intensities);
 public:
     typedef boost::function<T (const Point*)> filter_func;
     typedef boost::function<bool(T, T)> compare_func;
+    /// Construct the filter with a filter_func, a comparison value,
+    /// and a compare_func.  To use this we must take in a filtering function that returns
+    ///  us a value from the point, and a binary_predicate comparator
+    /// (ie, std::less, std::greater, std::equal_to, etc).
+    /// \param f - The function to compare with from the liblas::Point.  It
+    /// must be one of the functions that returns an integer type or double type
+    /// \param value - The value to use for one-way comparison
+    /// \param c - the std::binary_predicate to use for comparison
+    /// To use this we must take in a filtering function that returns
+    /// Example:
+    /// GetIntensity returns a uint16_t, so we use that for our template
+    /// value.  This filter would keep all points with intensities that are
+    /// less than 100.
+    /// liblas::ContinuousValueFilter<uint16_t>::compare_func c = std::less<uint16_t>();
+    /// liblas::ContinuousValueFilter<uint16_t>::filter_func f = &liblas::Point::GetIntensity;
+    /// liblas::ContinuousValueFilter<uint16_t>* intensity_filter = new liblas::ContinuousValueFilter<uint16_t>(f, 100, c);
+    /// intensity_filter->SetType(liblas::FilterI::eInclusion);
     ContinuousValueFilter(filter_func f, T value, compare_func c) :
         liblas::FilterI(eInclusion), f(f), c(c),value(value)
+    /// Construct the filter with a filter_func and a simple
+    /// expression.
+    /// \param filter_string - A string to use for the filter.  Supports taking
+    /// in a simple expression and turning it into
+    /// a comparator we can use.  We support dead simple stuff:
+    /// >200
+    /// ==150
+    /// >=32
+    /// <=150
+    /// <100
+    /// We don't strip whitespace, and we don't support complex
+    /// comparisons (ie, two function  10<x<300)
+    /// In addition to explicitly setting your comparator function, you can
+    /// also use the constructor that takes in a simple expression string
+    /// and constructs the basic comparators.  See the source code or las2las2
+    /// help output for the forms that are supported.  This may be
+    /// improved in the future.
+    /// std::string intensities("<100")
+    /// liblas::ContinuousValueFilter<uint16_t>* intensity_filter = new liblas::ContinuousValueFilter<uint16_t>(f, intensities);
     ContinuousValueFilter(filter_func f, std::string const& filter_string) :
-        // Support taking in a simple expression and turning it into
-        // a comparator we can use.  We support dead simple stuff:
-        // >200
-        // ==150
-        // >=32
-        // <=150
-        // <100
-        // We don't strip whitespace, and we don't support complex
-        // comparisons (ie, two function  10<x<300)
         compare_func compare;
         bool gt = HasPredicate(filter_string, ">");
@@ -341,7 +359,7 @@
+/// A filter for color ranges
 class ColorFilter: public FilterI
 public:
diff -r 76397c8a28d0 -r 7cad188b96bc include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp	Thu Aug 26 11:02:34 2010 -0500
+++ b/include/liblas/lasheader.hpp	Thu Aug 26 11:56:29 2010 -0500
@@ -325,13 +325,26 @@
     /// Set the georeference
     void SetSRS(SpatialReference& srs);
+    /// Returns the schema.
+    Schema GetSchema() const;
-    Schema GetSchema() const;
+    /// Sets the schema
     void SetSchema(const Schema& format);
+    /// Return the liblas::Bounds.  This is a
+    /// combination of the GetMax and GetMin
+    /// (or GetMinX, GetMaxY, etc) data.
     const Bounds<double>& GetExtent() const;
+    /// Set the liblas::Bounds.  This is a
+    /// (or GetMinX, GetMaxY, etc) data, and it is equivalent to setting
+    /// all of these values.
     void SetExtent(Bounds<double> const& extent);
+    /// Returns a property_tree that contains
+    /// all of the header data in a structured format.
     liblas::property_tree::ptree GetPTree() const;
 private:
More information about the Liblas-commits mailing list
