[Liblas-commits] hg: clean up strdup warnings by using LASCopyString
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Aug 26 15:39:53 EDT 2010
changeset 30d7b8e1bb8f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=30d7b8e1bb8f
summary: clean up strdup warnings by using LASCopyString
diffstat:
 apps/las2txt.c  |  2 +-
 apps/lasmerge.c |  2 +-
 apps/txt2las.c  |  6 ++++--
 3 files changed, 6 insertions(+), 4 deletions(-)
diffs (54 lines):
diff -r a9c19590b2aa -r 30d7b8e1bb8f apps/las2txt.c
--- a/apps/las2txt.c	Thu Aug 26 14:30:54 2010 -0500
+++ b/apps/las2txt.c	Thu Aug 26 13:39:36 2010 -0600
@@ -316,7 +316,7 @@
             len = (int)strlen(file_name_in);
-            file_name_out = strdup(file_name_in);
+            file_name_out = LASCopyString(file_name_in);
             if (file_name_out[len-3] == '.' && file_name_out[len-2] == 'g' && file_name_out[len-1] == 'z')
                 len = len - 4;
diff -r a9c19590b2aa -r 30d7b8e1bb8f apps/lasmerge.c
--- a/apps/lasmerge.c	Thu Aug 26 14:30:54 2010 -0500
+++ b/apps/lasmerge.c	Thu Aug 26 13:39:36 2010 -0600
@@ -233,7 +233,7 @@
                         alloced_file_name_in *= 2;
                         file_names_in = (char**)realloc(file_names_in,sizeof(char*)*alloced_file_name_in);
-                    file_names_in[num_file_name_in] = strdup(line);
+                    file_names_in[num_file_name_in] = LASCopyString(line);
                     i = (int)strlen(file_names_in[num_file_name_in]) - 1;
                     while ( i &&
                             file_names_in[num_file_name_in][i] != 's' &&
diff -r a9c19590b2aa -r 30d7b8e1bb8f apps/txt2las.c
--- a/apps/txt2las.c	Thu Aug 26 14:30:54 2010 -0500
+++ b/apps/txt2las.c	Thu Aug 26 13:39:36 2010 -0600
@@ -20,6 +20,8 @@
 #define LAS_FORMAT_11 1
 #define LAS_FORMAT_12 2
 void usage()
@@ -536,7 +538,7 @@
     if (file_name_out == NULL && file_name_in != NULL)
         int len = (int)strlen(file_name_in);
         while (len > 0 && file_name_out[len] != '.')
@@ -567,7 +569,7 @@
     /* create a cheaper parse string that only looks for 'x' 'y' 'z' and 'r' */
-    parse_less = strdup(parse_string);
+    parse_less = LASCopyString(parse_string);
     for (i = 0; i < (int)strlen(parse_string); i++)
         if (parse_less[i] != 'x' &&
More information about the Liblas-commits mailing list
