[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Thu Aug 26 16:38:04 EDT 2010
changeset 28d5309e4a92 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=28d5309e4a92
summary: fix ups so las2oci compiles on windows
changeset d9076e050572 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d9076e050572
summary: merge
diffstat:
CMakeLists.txt | 13 -------------
apps/CMakeLists.txt | 3 +--
apps/kdx_util.cpp | 34 +++++++++++++++++-----------------
apps/kdx_util.hpp | 12 ++++++------
apps/las2oci.cpp | 26 +++++++++++++-------------
apps/las2oci.hpp | 5 +++--
apps/oci_util.hpp | 2 ++
src/CMakeLists.txt | 3 +--
8 files changed, 43 insertions(+), 55 deletions(-)
diffs (truncated from 339 to 300 lines):
diff -r ebaaaf3dc720 -r d9076e050572 CMakeLists.txt
--- a/CMakeLists.txt Thu Aug 26 14:28:05 2010 -0600
+++ b/CMakeLists.txt Thu Aug 26 14:37:47 2010 -0600
@@ -136,19 +136,6 @@
mark_as_advanced(CLEAR Boost_LIBRARY_DIRS)
link_directories(${Boost_LIBRARY_DIRS})
-# libxml2 support - optional, default=ON
-set(WITH_LIBXML2 FALSE CACHE BOOL "Choose if libxml2 support should be built ")
-if(WITH_LIBXML2)
- find_package(LibXml2)
- mark_as_advanced(CLEAR LIBXML2_INCLUDE_DIR)
- mark_as_advanced(CLEAR LIBXML2_LIBRARIES)
- if(LIBXML2_FOUND)
- include_directories(${LIBXML2_INCLUDE_DIR})
- add_definitions(-DHAVE_LIBXML2=1)
- endif()
-endif()
# GeoTIFF support - optional, default=OFF
set(WITH_GEOTIFF FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
diff -r ebaaaf3dc720 -r d9076e050572 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Thu Aug 26 14:28:05 2010 -0600
+++ b/apps/CMakeLists.txt Thu Aug 26 14:37:47 2010 -0600
@@ -66,8 +66,7 @@
${TIFF_LIBRARY}
${GEOTIFF_LIBRARY}
${GDAL_LIBRARY}
- ${SPATIALINDEX_LIBRARY}
- ${LIBXML2_LIBRARIES})
+ ${SPATIALINDEX_LIBRARY})
diff -r ebaaaf3dc720 -r d9076e050572 apps/kdx_util.cpp
--- a/apps/kdx_util.cpp Thu Aug 26 14:28:05 2010 -0600
+++ b/apps/kdx_util.cpp Thu Aug 26 14:37:47 2010 -0600
@@ -19,7 +19,7 @@
const liblas::chipper::Block& b = c.GetBlock(i);
- std::vector<uint32_t> ids = b.GetIDs();
+ std::vector<boost::uint32_t> ids = b.GetIDs();
liblas::Bounds<double> const& bnd = b.GetBounds();
if (first) {
mins[0] = bnd.min(0);
@@ -35,7 +35,7 @@
maxs[0] = std::max(maxs[0], bnd.max(0));
maxs[1] = std::max(maxs[1], bnd.max(1));
- IndexResult result(static_cast<uint32_t>(i));
+ IndexResult result(static_cast<boost::uint32_t>(i));
result.SetIDs(ids);
result.SetBounds(bnd);
m_results.push_back(result);
@@ -86,7 +86,7 @@
liblas::Bounds<double> b(low[0], low[1], high[0],high[1]);
- IndexResult result(static_cast<uint32_t>(id));
+ IndexResult result(static_cast<boost::uint32_t>(id));
result.SetIDs(ids);
result.SetBounds(b);
@@ -97,7 +97,7 @@
bool GetPointData( liblas::Point const& p,
// bool bTime,
- std::vector<uint8_t>& point_data)
+ std::vector<boost::uint8_t>& point_data)
// This function returns an array of bytes describing the
// x,y,z and optionally time values for the point.
@@ -109,9 +109,9 @@
double z = p.GetZ();
// double t = p.GetTime();
- uint8_t* x_b = reinterpret_cast<uint8_t*>(&x);
- uint8_t* y_b = reinterpret_cast<uint8_t*>(&y);
- uint8_t* z_b = reinterpret_cast<uint8_t*>(&z);
+ boost::uint8_t* x_b = reinterpret_cast<boost::uint8_t*>(&x);
+ boost::uint8_t* y_b = reinterpret_cast<boost::uint8_t*>(&y);
+ boost::uint8_t* z_b = reinterpret_cast<boost::uint8_t*>(&z);
// liblas::uint8_t* t_b = reinterpret_cast<liblas::uint8_t*>(&t);
@@ -149,7 +149,7 @@
return true;
-void IndexResult::GetData(liblas::Reader* reader, std::vector<uint8_t>& data)
+void IndexResult::GetData(liblas::Reader* reader, std::vector<boost::uint8_t>& data)
IDVector const& ids = GetIDs();
@@ -162,15 +162,15 @@
data.clear();
IDVector::const_iterator i;
- std::vector<uint8_t>::iterator pi;
+ std::vector<boost::uint8_t>::iterator pi;
- uint32_t block_id = GetID();
+ boost::uint32_t block_id = GetID();
- std::vector<uint8_t> point_data;
+ std::vector<boost::uint8_t> point_data;
for (i=ids.begin(); i!=ids.end(); ++i)
- uint32_t id = *i;
+ boost::uint32_t id = *i;
bool doRead = reader->ReadPointAt(id);
if (doRead) {
@@ -182,21 +182,21 @@
bool gotdata = GetPointData(p, point_data);
if (!gotdata) { throw std::runtime_error("Unable to fetch Point Data"); exit(1);}
- std::vector<uint8_t>::const_iterator d;
+ std::vector<boost::uint8_t>::const_iterator d;
for (d = point_data.begin(); d!=point_data.end(); ++d) {
data.push_back(*d);
- uint8_t* id_b = reinterpret_cast<uint8_t*>(&id);
- uint8_t* block_b = reinterpret_cast<uint8_t*>(&block_id);
+ boost::uint8_t* id_b = reinterpret_cast<boost::uint8_t*>(&id);
+ boost::uint8_t* block_b = reinterpret_cast<boost::uint8_t*>(&block_id);
// 4-byte big-endian integer for the BLK_ID value
- for (int i = sizeof(uint32_t) - 1; i >= 0; i--) {
+ for (int i = sizeof(boost::uint32_t) - 1; i >= 0; i--) {
data.push_back(block_b[i]);
// 4-byte big-endian integer for the PT_ID value
data.push_back(id_b[i]);
diff -r ebaaaf3dc720 -r d9076e050572 apps/kdx_util.hpp
--- a/apps/kdx_util.hpp Thu Aug 26 14:28:05 2010 -0600
+++ b/apps/kdx_util.hpp Thu Aug 26 14:37:47 2010 -0600
@@ -14,22 +14,22 @@
-typedef std::vector<uint32_t> IDVector;
+typedef std::vector<boost::uint32_t> IDVector;
typedef boost::shared_ptr< IDVector > IDVectorPtr;
class IndexResult
public:
- IndexResult(uint32_t id) : bounds(), m_id(id) {}
+ IndexResult(boost::uint32_t id) : bounds(), m_id(id) {}
IDVector const& GetIDs() const { return ids; }
void SetIDs(IDVector& v) {ids = v;}
const liblas::Bounds<double> GetBounds() const { return bounds; }
void SetBounds(const liblas::Bounds<double> b) {bounds = b;}
- uint32_t GetID() const {return m_id;}
- void SetID(uint32_t v) {m_id = v;}
+ boost::uint32_t GetID() const {return m_id;}
+ void SetID(boost::uint32_t v) {m_id = v;}
- void GetData(liblas::Reader* reader, std::vector<uint8_t>& data);
+ void GetData(liblas::Reader* reader, std::vector<boost::uint8_t>& data);
private:
@@ -41,7 +41,7 @@
IDVector ids;
liblas::Bounds<double> bounds;
- uint32_t m_id;
+ boost::uint32_t m_id;
diff -r ebaaaf3dc720 -r d9076e050572 apps/las2oci.cpp
--- a/apps/las2oci.cpp Thu Aug 26 14:28:05 2010 -0600
+++ b/apps/las2oci.cpp Thu Aug 26 14:37:47 2010 -0600
@@ -180,7 +180,7 @@
IDVector const& ids = result.GetIDs();
// const SpatialIndex::Region* b = result.GetBounds();
- uint32_t num_points = ids.size();
+ boost::uint32_t num_points = ids.size();
// EnableTracing(connection);
@@ -223,7 +223,7 @@
// :4
statement->Define( locator, 1 );
- std::vector<uint8_t> data;
+ std::vector<boost::uint8_t> data;
result.GetData(reader, data);
// std::vector<liblas::uint8_t> data;
@@ -426,7 +426,7 @@
bool bUse3d,
bool bInsertHeaderBlob,
std::string const& header_blob_column,
- std::vector<uint8_t> const& header_data)
+ std::vector<boost::uint8_t> const& header_data)
ostringstream oss;
@@ -610,10 +610,10 @@
fprintf(stderr,"----------------------------------------------------------\n");
-std::vector<uint8_t> GetHeaderData(std::string const& filename, uint32_t offset)
+std::vector<boost::uint8_t> GetHeaderData(std::string const& filename, boost::uint32_t offset)
std::istream* in = OpenInput(filename, false);
- std::vector<uint8_t> data(offset);
+ std::vector<boost::uint8_t> data(offset);
liblas::detail::read_n(data.front(), *in, offset);
delete in;
return data;
@@ -636,9 +636,9 @@
("cloud-column-name", po::value< string >()->default_value("CLOUD"), "The column name that contains the point cloud object in the base table")
("header-blob-column", po::value< string >(), "Blob column name in the base table in which to optionally insert the contents of the input file's header.")
("overwrite,d", po::value<bool>()->zero_tokens(), "Drop block table before inserting data.")
- ("block-capacity", po::value<uint32_t>()->default_value(3000), "Maximum number of points to be inserted into each block")
- ("precision,p", po::value<uint32_t>()->default_value(8), "Number of decimal points to write into SQL for point coordinate data. Used in user_sdo_geom_metadata entry and defining the PC_EXTENT for the point cloud object.")
- ("srid,s", po::value<uint32_t>(), "Oracle numerical SRID value to use to define point cloud.")
+ ("block-capacity", po::value<boost::uint32_t>()->default_value(3000), "Maximum number of points to be inserted into each block")
+ ("precision,p", po::value<boost::uint32_t>()->default_value(8), "Number of decimal points to write into SQL for point coordinate data. Used in user_sdo_geom_metadata entry and defining the PC_EXTENT for the point cloud object.")
+ ("srid,s", po::value<boost::uint32_t>(), "Oracle numerical SRID value to use to define point cloud.")
("pre-sql", po::value< string >(), "Quoted SQL or filename location of PL/SQL to run before executing the point cloud creation process.")
("pre-block-sql", po::value< string >(), "Quoted SQL or filename location of PL/SQL to run before executing the insertion of block data.")
("post-sql", po::value< string >(), "Quoted SQL or filename location of PL/SQL to run after inserting block data.")
@@ -700,7 +700,7 @@
bool bInsertHeaderBlob = false;
bool bCachedReader = false;
- uint32_t nCapacity = 10000;
+ boost::uint32_t nCapacity = 10000;
int srid = 0;
long precision = 8;
@@ -864,14 +864,14 @@
if (vm.count("block-capacity"))
- nCapacity = vm["block-capacity"].as< uint32_t >();
+ nCapacity = vm["block-capacity"].as< boost::uint32_t >();
if (verbose)
std::cout << "Setting block capacity to: " << nCapacity << std::endl;
if (vm.count("precision"))
- precision = vm["precision"].as< uint32_t >();
+ precision = vm["precision"].as< boost::uint32_t >();
if (verbose)
std::cout << "Setting precision to: " << precision << std::endl;
@@ -879,7 +879,7 @@
if (vm.count("srid"))
- srid = vm["srid"].as< uint32_t >();
+ srid = vm["srid"].as< boost::uint32_t >();
if (verbose)
std::cout << "Setting output Oracle SRID to: " << srid << std::endl;
@@ -1135,7 +1135,7 @@
reader2->SetFilters(filters);
reader2->SetTransforms(transforms);
- std::vector<uint8_t> header_data = GetHeaderData(input, reader2->GetHeader().GetDataOffset());
+ std::vector<boost::uint8_t> header_data = GetHeaderData(input, reader2->GetHeader().GetDataOffset());
KDXIndexSummary* query = 0;
if (!KDTreeIndexExists(input)) {
diff -r ebaaaf3dc720 -r d9076e050572 apps/las2oci.hpp
--- a/apps/las2oci.hpp Thu Aug 26 14:28:05 2010 -0600
+++ b/apps/las2oci.hpp Thu Aug 26 14:37:47 2010 -0600
@@ -11,6 +11,7 @@
#include <liblas/liblas.hpp>
+#include <boost/cstdint.hpp>
#include <string>
#include <sstream>
@@ -39,7 +40,7 @@
#include <boost/array.hpp>
#include <boost/shared_ptr.hpp>
More information about the Liblas-commits
