[Liblas-commits] hg: return program_options as heap-allocated
liblas-commits at liblas.org
Thu Aug 26 22:23:17 EDT 2010
changeset 0f3f66a3a126 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0f3f66a3a126
summary: return program_options as heap-allocated
diffstat:
apps/las2las2.cpp | 9 ++++++---
apps/las2oci.cpp | 33 +++++++++++++++++----------------
apps/laskernel.cpp | 12 ++++++------
apps/laskernel.hpp | 4 ++--
4 files changed, 31 insertions(+), 27 deletions(-)
diffs (171 lines):
diff -r 899f8743a42b -r 0f3f66a3a126 apps/las2las2.cpp
--- a/apps/las2las2.cpp Thu Aug 26 21:11:08 2010 -0500
+++ b/apps/las2las2.cpp Thu Aug 26 21:23:10 2010 -0500
@@ -217,8 +217,8 @@
try {
po::options_description file_options("las2las2 options");
- po::options_description filtering_options = GetFilteringOptions();
- po::options_description transform_options = GetTransformationOptions() ;
+ po::options_description* filtering_options = GetFilteringOptions();
+ po::options_description* transform_options = GetTransformationOptions() ;
po::positional_options_description p;
p.add("input", 1);
@@ -237,7 +237,7 @@
po::variables_map vm;
po::options_description options;
- options.add(file_options).add(transform_options).add(filtering_options);
+ options.add(file_options).add(*transform_options).add(*filtering_options);
po::store(po::command_line_parser(argc, argv).
options(options).positional(p).run(), vm);
@@ -289,6 +289,9 @@
if (!op) {
return (1);
+ delete filtering_options;
+ delete transform_options;
catch(std::exception& e) {
std::cerr << "error: " << e.what() << "\n";
diff -r 899f8743a42b -r 0f3f66a3a126 apps/las2oci.cpp
--- a/apps/las2oci.cpp Thu Aug 26 21:11:08 2010 -0500
+++ b/apps/las2oci.cpp Thu Aug 26 21:23:10 2010 -0500
@@ -611,13 +611,13 @@
return data;
-po::options_description GetFileOptions()
+po::options_description* GetFileOptions()
-po::options_description file_options("las2oci options");
+po::options_description* file_options = new po::options_description("las2oci options");
-file_options.add_options()
+file_options->add_options()
("help,h", "produce help message")
("input,i", po::value< string >(), "input LAS file")
("connection,c", po::value< string >(), "OCI connection string")
@@ -647,10 +647,10 @@
return file_options;
-po::options_description GetHiddenOptions()
+po::options_description* GetHiddenOptions()
- po::options_description hidden_options("hidden options");
-hidden_options.add_options()
+ po::options_description* hidden_options = new po::options_description("hidden options");
+hidden_options->add_options()
("xmin", po::value< double >(), "global-extent minx value")
("ymin", po::value< double >(), "global-extent miny value")
("zmin", po::value< double >(), "global-extent minz value")
@@ -699,10 +699,7 @@
liblas::Bounds<double> global_extent;
- bool bSetExtents = false;
- int nCommitInterval = 100;
+ bool bSetExtents = false;
bool verbose = false;
bool debug = false;
@@ -714,10 +711,10 @@
try {
- po::options_description file_options = GetFileOptions();
- po::options_description hidden_options = GetHiddenOptions();
+ po::options_description* file_options = GetFileOptions();
+ po::options_description* hidden_options = GetHiddenOptions();
p.add("input", 1);
p.add("connection", 1);
@@ -727,7 +724,7 @@
- options.add(file_options).add(transform_options).add(filtering_options).add(hidden_options);
+ options.add(*file_options).add(*transform_options).add(*filtering_options).add(*hidden_options);
@@ -735,7 +732,7 @@
if (vm.count("help"))
- std::cout << GetInvocationHeader()<<file_options<<"\n"<<transform_options<<"\n"<<filtering_options<<"\n";
+ std::cout << GetInvocationHeader()<<*file_options<<"\n"<<*transform_options<<"\n"<<*filtering_options<<"\n";
std::cout <<"\nFor more information, see the full documentation for las2oci at:\n";
std::cout << " http://liblas.org/utilities/las2oci.html\n";
@@ -1256,6 +1253,10 @@
delete reader2;
delete istrm2;
delete con;
+ delete file_options;
+ delete hidden_options;
diff -r 899f8743a42b -r 0f3f66a3a126 apps/laskernel.cpp
--- a/apps/laskernel.cpp Thu Aug 26 21:11:08 2010 -0500
+++ b/apps/laskernel.cpp Thu Aug 26 21:23:10 2010 -0500
@@ -108,12 +108,12 @@
return filter;
-po::options_description GetFilteringOptions()
+po::options_description* GetFilteringOptions()
-po::options_description filtering_options("Filtering options");
+po::options_description* filtering_options = new po::options_description("Filtering options");
-filtering_options.add_options()
+filtering_options->add_options()
("extent,e", po::value< string >(), "Extent window that points must fall within to keep.\nUse a comma-separated list, for example, \n -e minx, miny, maxx, maxy\n or \n -e minx, miny, minz, maxx, maxy, maxz")
("thin,t", po::value<boost::uint32_t>()->default_value(0), "Simple decimation-style thinning.\nThin the file by removing every t'th point from the file.")
("last_return_only", po::value<bool>()->zero_tokens(), "Keep last returns (cannot be used with --first_return_only)")
@@ -135,11 +135,11 @@
return filtering_options;
-po::options_description GetTransformationOptions()
+po::options_description* GetTransformationOptions()
- po::options_description transform_options("Transformation options");
+ po::options_description* transform_options= new po::options_description("Transformation options");
- transform_options.add_options()
+ transform_options->add_options()
("a_srs", po::value< string >(), "Coordinate system to assign to input LAS file")
("t_srs", po::value< string >(), "Coordinate system to reproject output LAS file to. Use --a_srs or verify that your input LAS file has a coordinate system according to lasinfo")
("offset", po::value< string >(), "A comma-separated list of offsets to set on the output file: \n--offset 0,0,0 \n--offset min,min,min")
diff -r 899f8743a42b -r 0f3f66a3a126 apps/laskernel.hpp
--- a/apps/laskernel.hpp Thu Aug 26 21:11:08 2010 -0500
+++ b/apps/laskernel.hpp Thu Aug 26 21:23:10 2010 -0500
@@ -78,8 +78,8 @@
liblas::FilterI* MakeColorFilter(liblas::Color const& low, liblas::Color const& high, liblas::FilterI::FilterType ftype);
-po::options_description GetFilteringOptions();
-po::options_description GetTransformationOptions();
+po::options_description* GetFilteringOptions();
+po::options_description* GetTransformationOptions();
std::vector<liblas::FilterI*> GetFilters(po::variables_map vm, bool verbose);
std::vector<liblas::TransformI*> GetTransforms(po::variables_map vm, bool verbose, liblas::Header& header);
More information about the Liblas-commits
