[Liblas-commits] hg: 10 new changesets
liblas-commits at liblas.org
Wed Dec 1 13:05:28 EST 2010
changeset 611a00ee45ec in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=611a00ee45ec
summary: remove bogus method
changeset 7c95c0caf31e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7c95c0caf31e
summary: remove liblas::Reader::Summarize, which doesn't really belong
changeset 9224cafdf164 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9224cafdf164
summary: Cache a reference to the ostream so we aren't going through function calls for each fetch of it
changeset 24a2aa4eb165 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=24a2aa4eb165
summary: remove commented cruft
changeset ad9d6c1cb963 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ad9d6c1cb963
summary: remove stream fetching altogether and use protected data member of parent to find it
changeset a029d9316277 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a029d9316277
changeset 2e69d3811b87 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2e69d3811b87
summary: remove GetPointCount public method -- use protected data member
changeset 3cb664ce759d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=3cb664ce759d
summary: Make liblas::Reader and liblas::Writer return pointers instead of references for GetStream()
changeset 0459a7c9645f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0459a7c9645f
summary: remove bogus, unused IsEOF method
changeset db809fe8d680 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=db809fe8d680
summary: thin down liblas::Reader and liblas::Writer by removing SRS-related stuff. Use a TransformationI
diffstat:
apps/las2las.cpp | 3 +-
apps/laskernel.cpp | 22 ++++++
apps/laskernel.hpp | 1 +
include/liblas/detail/writer/base.hpp | 10 +-
include/liblas/lasreader.hpp | 29 +--------
include/liblas/laswriter.hpp | 14 +---
src/detail/writer/base.cpp | 4 +-
src/detail/writer/header.cpp | 113 ++++++++++++++++-----------------
src/detail/writer/point.cpp | 22 +------
src/las_c_api.cpp | 16 ++--
src/lasreader.cpp | 113 +---------------------------------
src/laswriter.cpp | 69 +-------------------
test/unit/lasreader_test.cpp | 4 +-
test/unit/laswriter_test.cpp | 4 +-
14 files changed, 110 insertions(+), 314 deletions(-)
diffs (truncated from 837 to 300 lines):
diff -r 4886121d806e -r db809fe8d680 apps/las2las.cpp
--- a/apps/las2las.cpp Mon Nov 29 11:02:49 2010 -0600
+++ b/apps/las2las.cpp Wed Dec 01 12:05:05 2010 -0600
@@ -68,7 +68,8 @@
if (min_offset)
- liblas::property_tree::ptree tree = reader.Summarize();
+ liblas::property_tree::ptree tree = SummarizeReader(reader);
try
header.SetOffset(tree.get<double>("summary.points.minimum.x"),
diff -r 4886121d806e -r db809fe8d680 apps/laskernel.cpp
--- a/apps/laskernel.cpp Mon Nov 29 11:02:49 2010 -0600
+++ b/apps/laskernel.cpp Wed Dec 01 12:05:05 2010 -0600
@@ -1336,4 +1336,26 @@
return transforms;
+liblas::property_tree::ptree SummarizeReader(liblas::Reader& reader)
+ liblas::Summary s;
+ reader.Reset();
+ bool read = reader.ReadNextPoint();
+ if (!read)
+ throw std::runtime_error("Unable to read any points from file.");
+ while (read)
+ liblas::Point const& p = reader.GetPoint();
+ s.AddPoint(p);
+ read = reader.ReadNextPoint();
+ return s.GetPTree();
diff -r 4886121d806e -r db809fe8d680 apps/laskernel.hpp
--- a/apps/laskernel.hpp Mon Nov 29 11:02:49 2010 -0600
+++ b/apps/laskernel.hpp Wed Dec 01 12:05:05 2010 -0600
@@ -102,5 +102,6 @@
LAS_DLL liblas::Header FetchHeader(std::string const& filename);
LAS_DLL void RewriteHeader(liblas::Header const& header, std::string const& filename);
LAS_DLL void RepairHeader(liblas::Summary const& summary, liblas::Header& header);
+LAS_DLL liblas::property_tree::ptree SummarizeReader(liblas::Reader& reader) ;
#endif // LIBLAS_ITERATOR_HPP_INCLUDED
diff -r 4886121d806e -r db809fe8d680 include/liblas/detail/writer/base.hpp
--- a/include/liblas/detail/writer/base.hpp Mon Nov 29 11:02:49 2010 -0600
+++ b/include/liblas/detail/writer/base.hpp Wed Dec 01 12:05:05 2010 -0600
@@ -58,10 +58,10 @@
WriterBase(std::ostream& ofs, boost::uint32_t& count);
~WriterBase();
- std::ostream& GetStream() const { return m_ofs; }
- boost::uint32_t& GetPointCount() const { return m_pointCount; }
- void SetPointCount(boost::uint32_t& count) { m_pointCount = count; }
+protected:
+ std::ostream& m_ofs;
+ boost::uint32_t& m_pointCount;
private:
@@ -69,8 +69,6 @@
WriterBase(WriterBase const& other);
WriterBase& operator=(WriterBase const& rhs);
- boost::uint32_t& m_pointCount;
- std::ostream& m_ofs;
}} // namespace liblas::detail
diff -r 4886121d806e -r db809fe8d680 include/liblas/lasreader.hpp
--- a/include/liblas/lasreader.hpp Mon Nov 29 11:02:49 2010 -0600
+++ b/include/liblas/lasreader.hpp Wed Dec 01 12:05:05 2010 -0600
@@ -49,7 +49,6 @@
#include <liblas/lasspatialreference.hpp>
#include <liblas/lastransform.hpp>
#include <liblas/lasfilter.hpp>
-#include <liblas/external/property_tree/ptree.hpp>
#include <liblas/export.hpp>
// boost
#include <boost/cstdint.hpp>
@@ -100,10 +99,7 @@
/// Allow fetching of the stream attached to the reader.
/// @exception nothrow
- std::istream& GetStream() const;
- /// Checks if end-of-file has been reached.
- bool IsEOF() const;
+ std::istream* GetStream() const;
/// Fetches next point record in file.
/// @exception may throw std::exception
@@ -121,21 +117,6 @@
/// ReadNextPoint operations
bool seek(std::size_t n);
- /// Reproject data as they are written if the Reader's reference is
- /// different than the Header's.
- /// @exception may throw std::exception
- bool SetSRS(const SpatialReference& ref);
- /// Override the spatial reference of the Reader's Header for
- /// writing purposes.
- bool SetInputSRS(const SpatialReference& ref);
- bool SetOutputSRS(const SpatialReference& ref);
/// Provides index-based access to point records.
/// The operator is implemented in terms of ReadPointAt method
@@ -160,9 +141,7 @@
/// the internal transform creation
void SetTransforms(std::vector<liblas::TransformPtr> const& transforms) {m_transforms = transforms;}
- /// Summarize the file represented by the reader in the form of a
- /// property_tree.
- liblas::property_tree::ptree Summarize();
private:
// Blocked copying operations, declared but not defined.
@@ -186,10 +165,6 @@
std::vector<liblas::FilterPtr> m_filters;
std::vector<liblas::TransformPtr> m_transforms;
- TransformPtr m_reprojection_transform;
- SpatialReference m_out_srs;
- SpatialReference m_in_srs;
diff -r 4886121d806e -r db809fe8d680 include/liblas/laswriter.hpp
--- a/include/liblas/laswriter.hpp Mon Nov 29 11:02:49 2010 -0600
+++ b/include/liblas/laswriter.hpp Wed Dec 01 12:05:05 2010 -0600
@@ -83,17 +83,11 @@
bool WritePoint(Point const& point);
- std::ostream& GetStream() const;
+ std::ostream* GetStream() const;
/// Allow in-place writing of header
void WriteHeader(Header& header);
- /// Reproject data as they are written if the Writer's reference is
/// Sets filters that are used to determine wither or not to
/// keep a point that before we write it
/// Filters are applied *before* transforms.
@@ -122,11 +116,7 @@
std::vector<liblas::FilterI*>* m_filters;
std::vector<liblas::TransformI*>* m_transforms;
diff -r 4886121d806e -r db809fe8d680 src/detail/writer/base.cpp
--- a/src/detail/writer/base.cpp Mon Nov 29 11:02:49 2010 -0600
+++ b/src/detail/writer/base.cpp Wed Dec 01 12:05:05 2010 -0600
@@ -48,8 +48,8 @@
namespace liblas { namespace detail {
WriterBase::WriterBase(std::ostream& ofs, boost::uint32_t& count)
- : m_pointCount(count)
- , m_ofs(ofs)
+ : m_ofs(ofs)
+ , m_pointCount(count)
diff -r 4886121d806e -r db809fe8d680 src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp Mon Nov 29 11:02:49 2010 -0600
+++ b/src/detail/writer/header.cpp Wed Dec 01 12:05:05 2010 -0600
@@ -75,8 +75,7 @@
uint8_t n1 = 0;
uint16_t n2 = 0;
uint32_t n4 = 0;
// Figure out how many points we already have.
// Figure out if we're in append mode. If we are, we can't rewrite
// any of the VLRs including the Schema and SpatialReference ones.
@@ -86,12 +85,12 @@
// std::ios::in *and* std::ios::out
// Seek to the beginning
- GetStream().seekp(0, ios::beg);
- ios::pos_type begin = GetStream().tellp();
+ m_ofs.seekp(0, ios::beg);
+ ios::pos_type begin = m_ofs.tellp();
// Seek to the end
- GetStream().seekp(0, ios::end);
- ios::pos_type end = GetStream().tellp();
+ m_ofs.seekp(0, ios::end);
+ ios::pos_type end = m_ofs.tellp();
if ((begin != end) && (end != static_cast<ios::pos_type>(0))) {
bAppendMode = true;
@@ -113,12 +112,10 @@
throw std::runtime_error(oss.str());
- uint32_t& cnt = GetPointCount();
- cnt = static_cast<uint32_t>(count);
- SetPointCount(cnt);
+ m_pointCount = static_cast<uint32_t>(count);
// Position to the beginning of the file to start writing the header
else
@@ -157,18 +154,18 @@
// 1. File Signature
std::string const filesig(m_header.GetFileSignature());
assert(filesig.size() == 4);
- detail::write_n(GetStream(), filesig, 4);
+ detail::write_n(m_ofs, filesig, 4);
// 2. File SourceId / Reserved
if (m_header.GetVersionMinor() == 0) {
n4 = m_header.GetReserved();
- detail::write_n(GetStream(), n4, sizeof(n4));
+ detail::write_n(m_ofs, n4, sizeof(n4));
} else if (m_header.GetVersionMinor() > 0) {
n2 = m_header.GetFileSourceId();
- detail::write_n(GetStream(), n2, sizeof(n2));
+ detail::write_n(m_ofs, n2, sizeof(n2));
n2 = m_header.GetReserved();
// 3-6. GUID data
@@ -178,63 +175,63 @@
uint8_t d4[8] = { 0 };
liblas::guid g = m_header.GetProjectId();
g.output_data(d1, d2, d3, d4);
- detail::write_n(GetStream(), d1, sizeof(d1));
- detail::write_n(GetStream(), d2, sizeof(d2));
- detail::write_n(GetStream(), d3, sizeof(d3));
- detail::write_n(GetStream(), d4, sizeof(d4));
+ detail::write_n(m_ofs, d1, sizeof(d1));
+ detail::write_n(m_ofs, d2, sizeof(d2));
+ detail::write_n(m_ofs, d3, sizeof(d3));
+ detail::write_n(m_ofs, d4, sizeof(d4));
// 7. Version major
n1 = m_header.GetVersionMajor();
assert(1 == n1);
- detail::write_n(GetStream(), n1, sizeof(n1));
+ detail::write_n(m_ofs, n1, sizeof(n1));
// 8. Version minor
n1 = m_header.GetVersionMinor();
// 9. System ID
std::string sysid(m_header.GetSystemId(true));
assert(sysid.size() == 32);
- detail::write_n(GetStream(), sysid, 32);
+ detail::write_n(m_ofs, sysid, 32);
// 10. Generating Software ID
std::string softid(m_header.GetSoftwareId(true));
assert(softid.size() == 32);
- detail::write_n(GetStream(), softid, 32);
+ detail::write_n(m_ofs, softid, 32);
More information about the Liblas-commits
