[Liblas-commits] hg: Remove GetStream methods of ReaderI and
WriterI altogether. ...
liblas-commits at liblas.org
Mon Dec 6 11:36:24 EST 2010
changeset 25add9edaaf1 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=25add9edaaf1
summary: Remove GetStream methods of ReaderI and WriterI altogether. These don't belong
diffstat:
include/liblas/detail/reader/reader.hpp | 2 -
include/liblas/detail/writer/writer.hpp | 2 -
include/liblas/lasreader.hpp | 4 --
include/liblas/laswriter.hpp | 3 -
include/liblas/liblas.hpp | 6 +---
src/detail/reader/reader.cpp | 5 ---
src/detail/writer/writer.cpp | 6 ---
src/las_c_api.cpp | 55 ++++++++++++++++++++++++++------
src/lasreader.cpp | 4 --
src/laswriter.cpp | 5 ---
test/unit/lasreader_test.cpp | 17 +---------
test/unit/laswriter_test.cpp | 40 +++++++----------------
12 files changed, 58 insertions(+), 91 deletions(-)
diffs (truncated from 354 to 300 lines):
diff -r 16c33aa5bf9d -r 25add9edaaf1 include/liblas/detail/reader/reader.hpp
--- a/include/liblas/detail/reader/reader.hpp Thu Dec 02 15:22:53 2010 -0600
+++ b/include/liblas/detail/reader/reader.hpp Mon Dec 06 10:36:17 2010 -0600
@@ -69,8 +69,6 @@
liblas::Point const& ReadPointAt(std::size_t n, HeaderPtr header);
void Seek(std::size_t n, HeaderPtr header);
- std::istream& GetStream() const;
void Reset(HeaderPtr header);
protected:
diff -r 16c33aa5bf9d -r 25add9edaaf1 include/liblas/detail/writer/writer.hpp
--- a/include/liblas/detail/writer/writer.hpp Thu Dec 02 15:22:53 2010 -0600
+++ b/include/liblas/detail/writer/writer.hpp Mon Dec 06 10:36:17 2010 -0600
@@ -66,8 +66,6 @@
void UpdateHeader(liblas::Header const& header);
void WritePoint(liblas::Point const& record, HeaderPtr header);
- std::ostream& GetStream() const;
protected:
PointRecord m_record;
std::ostream& m_ofs;
diff -r 16c33aa5bf9d -r 25add9edaaf1 include/liblas/lasreader.hpp
--- a/include/liblas/lasreader.hpp Thu Dec 02 15:22:53 2010 -0600
+++ b/include/liblas/lasreader.hpp Mon Dec 06 10:36:17 2010 -0600
@@ -97,10 +97,6 @@
/// @exception nothrow
std::vector<VariableRecord> const& GetVLRs() const;
- /// Allow fetching of the stream attached to the reader.
- /// @exception nothrow
- std::istream* GetStream() const;
/// Fetches next point record in file.
/// @exception may throw std::exception
bool ReadNextPoint();
diff -r 16c33aa5bf9d -r 25add9edaaf1 include/liblas/laswriter.hpp
--- a/include/liblas/laswriter.hpp Thu Dec 02 15:22:53 2010 -0600
+++ b/include/liblas/laswriter.hpp Mon Dec 06 10:36:17 2010 -0600
@@ -82,9 +82,6 @@
/// \todo TODO: How to handle point_source_id in portable way, for LAS 1.0 and 1.1
bool WritePoint(Point const& point);
- std::ostream* GetStream() const;
/// Allow in-place writing of header
void WriteHeader(Header& header);
diff -r 16c33aa5bf9d -r 25add9edaaf1 include/liblas/liblas.hpp
--- a/include/liblas/liblas.hpp Thu Dec 02 15:22:53 2010 -0600
+++ b/include/liblas/liblas.hpp Mon Dec 06 10:36:17 2010 -0600
@@ -128,9 +128,7 @@
virtual void Seek(std::size_t n, HeaderPtr header) = 0;
virtual void Reset(HeaderPtr header) = 0;
- virtual std::istream& GetStream() const = 0;
virtual ~ReaderI() {}
@@ -142,8 +140,6 @@
virtual void UpdateHeader(Header const& header) = 0;
virtual void WritePoint(const Point& point, HeaderPtr header) = 0;
- virtual std::ostream& GetStream() const = 0;
virtual ~WriterI() {}
diff -r 16c33aa5bf9d -r 25add9edaaf1 src/detail/reader/reader.cpp
--- a/src/detail/reader/reader.cpp Thu Dec 02 15:22:53 2010 -0600
+++ b/src/detail/reader/reader.cpp Mon Dec 06 10:36:17 2010 -0600
@@ -72,11 +72,6 @@
-std::istream& ReaderImpl::GetStream() const
- return m_ifs;
void ReaderImpl::Reset(HeaderPtr header)
m_ifs.clear();
diff -r 16c33aa5bf9d -r 25add9edaaf1 src/detail/writer/writer.cpp
--- a/src/detail/writer/writer.cpp Thu Dec 02 15:22:53 2010 -0600
+++ b/src/detail/writer/writer.cpp Mon Dec 06 10:36:17 2010 -0600
@@ -97,12 +97,6 @@
-std::ostream& WriterImpl::GetStream() const
- return m_ofs;
WriterImpl* WriterFactory::Create(std::ostream& ofs)
if (!ofs)
diff -r 16c33aa5bf9d -r 25add9edaaf1 src/las_c_api.cpp
--- a/src/las_c_api.cpp Thu Dec 02 15:22:53 2010 -0600
+++ b/src/las_c_api.cpp Mon Dec 06 10:36:17 2010 -0600
@@ -130,6 +130,8 @@
static std::stack<liblas::Error > errors;
+static std::map<liblas::Reader*, std::istream*> readers;
+static std::map<liblas::Writer*, std::ostream*> writers;
#ifdef _MSC_VER
# pragma warning(disable: 4127) // warning C4127: conditional expression is constant
@@ -219,8 +221,9 @@
try {
std::istream* istrm = OpenInput(std::string(filename));
- return (LASReaderH) new liblas::Reader(*istrm);
+ liblas::Reader* reader = new liblas::Reader(*istrm);
+ readers.insert(std::pair<liblas::Reader*, std::istream*>(reader, istrm));
+ return (LASReaderH) reader;
} catch (std::exception const& e)
@@ -242,8 +245,9 @@
liblas::Header* header = ((liblas::Header*) hHeader);
- return (LASReaderH) new liblas::Reader(*istrm, *header);
+ liblas::Reader* reader = new liblas::Reader(*istrm, *header);
@@ -259,13 +263,28 @@
try {
liblas::Reader* reader = (liblas::Reader*)hReader;
- std::istream* istrm = reader->GetStream();
+ std::map<liblas::Reader*, std::istream*>::iterator it = readers.find(reader);
+ if (it == readers.end())
+ LASError_PushError(LE_Failure, "Unable to find reader stream", "LASReader_Destroy");
+ return;
+ std::istream* istrm = it->second;
delete reader;
hReader = NULL;
+ if ( istrm == NULL )
+ LASError_PushError(LE_Failure, "Got 99 problems, but the stream ain't one", "LASReader_Destroy");
+ return;
if (static_cast<std::ifstream&>(*istrm))
static_cast<std::ifstream&>(*istrm).close();
+ readers.erase(reader);
delete istrm;
istrm = NULL;
@@ -1360,7 +1379,10 @@
liblas::Writer* writer = new liblas::Writer(*ostrm, *header);
+ writers.insert(std::pair<liblas::Writer*, std::ostream*>(writer, ostrm));
return (LASWriterH) writer;
@@ -1412,23 +1434,34 @@
VALIDATE_LAS_POINTER0(hWriter, "LASWriter_Destroy");
try {
liblas::Writer* writer = (liblas::Writer*)hWriter;
- std::ostream* ostrm = writer->GetStream();
+ std::map<liblas::Writer*, std::ostream*>::iterator it = writers.find(writer);
+ if (it == writers.end())
+ LASError_PushError(LE_Failure, "Unable to find writer stream", "LASWriter_Destroy");
+ return;
+ std::ostream* ostrm = it->second;
delete writer;
hWriter = NULL;
+ if ( ostrm == NULL )
+ LASError_PushError(LE_Failure, "Got 99 problems, but the stream ain't one", "LASWriter_Destroy");
+ return;
if (static_cast<std::ofstream&>(*ostrm))
static_cast<std::ofstream&>(*ostrm).close();
if (ostrm != NULL)
delete ostrm;
+ writers.erase(writer);
ostrm = NULL;
} catch (std::runtime_error const& e/* e */)
diff -r 16c33aa5bf9d -r 25add9edaaf1 src/lasreader.cpp
--- a/src/lasreader.cpp Thu Dec 02 15:22:53 2010 -0600
+++ b/src/lasreader.cpp Mon Dec 06 10:36:17 2010 -0600
@@ -298,10 +298,6 @@
-std::istream* Reader::GetStream() const
- return &(m_pimpl->GetStream());
void Reader::Reset()
diff -r 16c33aa5bf9d -r 25add9edaaf1 src/laswriter.cpp
--- a/src/laswriter.cpp Thu Dec 02 15:22:53 2010 -0600
+++ b/src/laswriter.cpp Mon Dec 06 10:36:17 2010 -0600
@@ -132,11 +132,6 @@
return true;
-std::ostream* Writer::GetStream() const
void Writer::WriteHeader(Header& header)
// The writer may update our header as part of its
diff -r 16c33aa5bf9d -r 25add9edaaf1 test/unit/lasreader_test.cpp
--- a/test/unit/lasreader_test.cpp Thu Dec 02 15:22:53 2010 -0600
+++ b/test/unit/lasreader_test.cpp Mon Dec 06 10:36:17 2010 -0600
@@ -144,7 +144,7 @@
test_file10_point2(reader[1]);
- // Test GetStream method
+ // Test seek nd GetPoint pair
template<>
template<>
void to::test<7>()
@@ -153,21 +153,6 @@
ifs.open(file10_.c_str(), std::ios::in | std::ios::binary);
liblas::Reader reader(ifs);
- std::istream* is = reader.GetStream();
- ensure_equals(ifs, *is);
- // Test seek nd GetPoint pair
- template<>
- template<>
- void to::test<8>()
- std::ifstream ifs;
- ifs.open(file10_.c_str(), std::ios::in | std::ios::binary);
- liblas::Reader reader(ifs);
// read 1st point
reader.ReadNextPoint();
test_file10_point1(reader.GetPoint());
diff -r 16c33aa5bf9d -r 25add9edaaf1 test/unit/laswriter_test.cpp
--- a/test/unit/laswriter_test.cpp Thu Dec 02 15:22:53 2010 -0600
+++ b/test/unit/laswriter_test.cpp Mon Dec 06 10:36:17 2010 -0600
@@ -238,7 +238,7 @@
+ // Test appending to an existing file
template<>
template<>
void to::test<4>()
@@ -247,44 +247,28 @@
ofs.open(tmpfile_.c_str(), std::ios::out | std::ios::binary);
More information about the Liblas-commits
