[Liblas-commits] hg: rename Reader::seek to Reader::Seek to bring
name in line wi...
liblas-commits at liblas.org
Tue Dec 7 09:29:12 EST 2010
changeset 34d5d9cb5d36 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=34d5d9cb5d36
summary: rename Reader::seek to Reader::Seek to bring name in line with other method names
diffstat:
include/liblas/lasreader.hpp | 2 +-
src/las_c_api.cpp | 2 +-
src/lasindex.cpp | 36 ++++++++++++++++++------------------
src/lasreader.cpp | 2 +-
test/unit/lasreader_test.cpp | 10 ++++------
5 files changed, 25 insertions(+), 27 deletions(-)
diffs (156 lines):
diff -r 2a87e6c492ac -r 34d5d9cb5d36 include/liblas/lasreader.hpp
--- a/include/liblas/lasreader.hpp Mon Dec 06 16:28:23 2010 -0600
+++ b/include/liblas/lasreader.hpp Tue Dec 07 08:29:07 2010 -0600
@@ -112,7 +112,7 @@
/// Move to the specified point to start
/// ReadNextPoint operations
/// @exception may throw std::exception
- bool seek(std::size_t n);
+ bool Seek(std::size_t n);
/// Provides index-based access to point records.
/// The operator is implemented in terms of ReadPointAt method
diff -r 2a87e6c492ac -r 34d5d9cb5d36 src/las_c_api.cpp
--- a/src/las_c_api.cpp Mon Dec 06 16:28:23 2010 -0600
+++ b/src/las_c_api.cpp Tue Dec 07 08:29:07 2010 -0600
@@ -349,7 +349,7 @@
try {
liblas::Reader *reader = ((liblas::Reader*) hReader);
- if (reader->seek((std::size_t) position))
+ if (reader->Seek((std::size_t) position))
return LE_None;
else
return LE_Failure;
diff -r 2a87e6c492ac -r 34d5d9cb5d36 src/lasindex.cpp
--- a/src/lasindex.cpp Mon Dec 06 16:28:23 2010 -0600
+++ b/src/lasindex.cpp Tue Dec 07 08:29:07 2010 -0600
@@ -689,17 +689,17 @@
if (ParamSrc.m_iterator && (m_filterResult.size() >= ParamSrc.m_iterator->m_chunkSize))
break;
} // while
- if (PointsScannedThisTime >= PointsToIgnore)
- PointsScannedCurVLR += PointsScannedThisTime - PointsToIgnore;
- if (PointsScannedCurVLR >= PointsThisRecord)
- VLRDone = true;
- if (ParamSrc.m_iterator)
- ParamSrc.m_iterator->m_totalPointsScanned += PointsScannedThisTime - PointsToIgnore;
- ParamSrc.m_iterator->m_ptsScannedCurVLR = PointsScannedCurVLR;
- } // if
- } // if
+ if (PointsScannedThisTime >= PointsToIgnore)
+ PointsScannedCurVLR += PointsScannedThisTime - PointsToIgnore;
+ if (PointsScannedCurVLR >= PointsThisRecord)
+ VLRDone = true;
+ if (ParamSrc.m_iterator)
+ ParamSrc.m_iterator->m_totalPointsScanned += PointsScannedThisTime - PointsToIgnore;
+ ParamSrc.m_iterator->m_ptsScannedCurVLR = PointsScannedCurVLR;
+ } // if
+ } // if
} // if
else if (ParamSrc.m_iterator)
@@ -923,7 +923,7 @@
// seek and read
assert(static_cast<boost::uint32_t>(PointID) < m_pointRecordsCount);
- PtRead = (m_reader->seek(PointID) && m_reader->ReadNextPoint());
+ PtRead = (m_reader->Seek(PointID) && m_reader->ReadNextPoint());
} // if
if (PtRead)
@@ -966,7 +966,7 @@
// seek and read
} // if
if (PtRead)
@@ -1010,7 +1010,7 @@
// seek and read
} // if
if (PtRead)
@@ -1035,7 +1035,7 @@
m_versionMinor = LIBLAS_INDEX_VERSIONMINOR;
// reset to beginning of point data records in case points had been examined before index is built
- m_reader->seek(0);
+ m_reader->Seek(0);
// need the header to get number of point records
m_pointRecordsCount = m_pointheader.GetPointRecordsCount();
// get the bounds of the data and scale factors in case they are needed for point translation
@@ -1199,7 +1199,7 @@
// get the actual point from the las file
assert(MapIt->first < m_pointRecordsCount);
- if (m_reader->seek(MapIt->first) && m_reader->ReadNextPoint())
+ if (m_reader->Seek(MapIt->first) && m_reader->ReadNextPoint())
boost::uint32_t FirstPt = 0, LastCellZ = static_cast<boost::uint32_t>(~0);
boost::uint32_t LastSubCell = static_cast<boost::uint32_t>(~0);
@@ -1562,7 +1562,7 @@
try {
Writer writer(*m_ofs, m_idxheader);
while (m_reader->ReadNextPoint())
Point CurPt = m_reader->GetPoint();
@@ -1581,7 +1581,7 @@
try {
/* test block - uncommenting this makes it just like above version with included points
diff -r 2a87e6c492ac -r 34d5d9cb5d36 src/lasreader.cpp
--- a/src/lasreader.cpp Mon Dec 06 16:28:23 2010 -0600
+++ b/src/lasreader.cpp Tue Dec 07 08:29:07 2010 -0600
@@ -193,7 +193,7 @@
return false;
-bool Reader::seek(std::size_t n)
+bool Reader::Seek(std::size_t n)
try
diff -r 2a87e6c492ac -r 34d5d9cb5d36 test/unit/lasreader_test.cpp
--- a/test/unit/lasreader_test.cpp Mon Dec 06 16:28:23 2010 -0600
+++ b/test/unit/lasreader_test.cpp Tue Dec 07 08:29:07 2010 -0600
@@ -154,17 +154,15 @@
liblas::Reader reader(ifs);
// read 1st point
- reader.ReadNextPoint();
+ reader.ReadNextPoint();
test_file10_point1(reader.GetPoint());
- // seek to 4th point
- reader.seek(4);
+ // seek to 4th point
+ reader.Seek(4);
- // read 4th point
+ // read 4th point
test_file10_point4(reader[3]);
- // Test GetStream method
More information about the Liblas-commits
