[Liblas-commits] laszip: 2 new changesets
liblas-commits at liblas.org
Tue Dec 14 21:22:23 EST 2010
changeset 8df920c36a44 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=8df920c36a44
summary: it was not using streams but FILE* ... try again. i get a bug.
changeset a2f165041d2a in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=a2f165041d2a
summary: handling of raw point writing on big endian platforms
diffstat:
src/lasreadpoint.cpp | 16 +++++++++--
src/laswritepoint.cpp | 16 +++++++++--
src/mydefs.hpp | 70 +++++++++++++++++++++++++++++++++++++++++++++++++
tools/laszippertest.cpp | 18 +++++++-----
4 files changed, 106 insertions(+), 14 deletions(-)
diffs (220 lines):
diff -r 487fafda44f2 -r a2f165041d2a src/lasreadpoint.cpp
--- a/src/lasreadpoint.cpp Tue Dec 14 10:35:09 2010 -0600
+++ b/src/lasreadpoint.cpp Tue Dec 14 18:21:57 2010 -0800
@@ -48,6 +48,7 @@
#include "arithmeticdecoder.hpp"
#include "lasreaditemraw.hpp"
+#include "lasreaditemrawendianswapped.hpp"
#include "lasreaditemcompressed_v1.hpp"
#include <string.h>
@@ -151,13 +152,22 @@
switch (items[i].type)
case LASitem::POINT10:
- readers_raw[i] = new LASreadItemRaw_POINT10();
+ if (IS_LITTLE_ENDIAN())
+ readers_raw[i] = new LASreadItemRaw_POINT10();
+ else
+ readers_raw[i] = new LASreadItemRawEndianSwapped_POINT10();
break;
case LASitem::GPSTIME:
- readers_raw[i] = new LASreadItemRaw_GPSTIME();
+ readers_raw[i] = new LASreadItemRaw_GPSTIME();
+ else
+ readers_raw[i] = new LASreadItemRawEndianSwapped_GPSTIME();
break;
case LASitem::RGB:
- readers_raw[i] = new LASreadItemRaw_RGB();
+ readers_raw[i] = new LASreadItemRaw_RGB();
+ else
+ readers_raw[i] = new LASreadItemRawEndianSwapped_RGB();
break;
case LASitem::BYTE:
readers_raw[i] = new LASreadItemRaw_BYTE(items[i].size);
diff -r 487fafda44f2 -r a2f165041d2a src/laswritepoint.cpp
--- a/src/laswritepoint.cpp Tue Dec 14 10:35:09 2010 -0600
+++ b/src/laswritepoint.cpp Tue Dec 14 18:21:57 2010 -0800
@@ -48,6 +48,7 @@
#include "arithmeticencoder.hpp"
#include "laswriteitemraw.hpp"
+#include "laswriteitemrawendianswapped.hpp"
#include "laswriteitemcompressed_v1.hpp"
#include <string.h>
@@ -115,13 +116,22 @@
- writers_raw[i] = new LASwriteItemRaw_POINT10();
+ writers_raw[i] = new LASwriteItemRaw_POINT10();
+ else
+ writers_raw[i] = new LASwriteItemRawEndianSwapped_POINT10();
break;
- writers_raw[i] = new LASwriteItemRaw_GPSTIME();
+ writers_raw[i] = new LASwriteItemRaw_GPSTIME();
+ else
+ writers_raw[i] = new LASwriteItemRawEndianSwapped_GPSTIME();
break;
case LASitem::RGB:
- writers_raw[i] = new LASwriteItemRaw_RGB();
+ writers_raw[i] = new LASwriteItemRaw_RGB();
+ else
+ writers_raw[i] = new LASwriteItemRawEndianSwapped_RGB();
break;
case LASitem::BYTE:
writers_raw[i] = new LASwriteItemRaw_BYTE(items[i].size);
diff -r 487fafda44f2 -r a2f165041d2a src/mydefs.hpp
--- a/src/mydefs.hpp Tue Dec 14 10:35:09 2010 -0600
+++ b/src/mydefs.hpp Tue Dec 14 18:21:57 2010 -0800
@@ -81,5 +81,75 @@
#ifndef NULL
#define NULL 0
#endif
+inline BOOL IS_LITTLE_ENDIAN()
+ U32 i = 1;
+ if (*((U8*)&i) == 1)
+ return TRUE;
+ else
+ return FALSE;
+inline void ENDIAN_SWAP_16(U8* field)
+ U8 help = field[0];
+ field[0] = field[1];
+ field[1] = help;
+inline void ENDIAN_SWAP_32(U8* field)
+ U8 help;
+ help = field[0];
+ field[0] = field[3];
+ field[3] = help;
+ help = field[1];
+ field[1] = field[2];
+ field[2] = help;
+inline void ENDIAN_SWAP_64(U8* field)
+ U8 help;
+ help = field[0];
+ field[0] = field[7];
+ field[7] = help;
+ help = field[1];
+ field[1] = field[6];
+ field[6] = help;
+ help = field[2];
+ field[2] = field[5];
+ field[5] = help;
+ help = field[3];
+ field[3] = field[4];
+ field[4] = help;
+inline void ENDIAN_SWAP_16(U8* from, U8* to)
+ to[0] = from[1];
+ to[1] = from[0];
+inline void ENDIAN_SWAP_32(U8* from, U8* to)
+ to[0] = from[3];
+ to[1] = from[2];
+ to[2] = from[1];
+ to[3] = from[0];
+inline void ENDIAN_SWAP_64(U8* from, U8* to)
+ to[0] = from[7];
+ to[1] = from[6];
+ to[2] = from[5];
+ to[3] = from[4];
+ to[4] = from[3];
+ to[5] = from[2];
+ to[6] = from[1];
+ to[7] = from[0];
#endif
diff -r 487fafda44f2 -r a2f165041d2a tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Tue Dec 14 10:35:09 2010 -0600
+++ b/tools/laszippertest.cpp Tue Dec 14 18:21:57 2010 -0800
@@ -64,7 +64,7 @@
unsigned char c;
unsigned int i, j;
- unsigned int num_points = 10000000;
+ unsigned int num_points = 100000;
unsigned int num_errors = 0;
std::filebuf ofb1;
std::filebuf ofb2;
@@ -80,7 +80,7 @@
FILE* ifile2 = 0;
bool range = false;
- bool use_iostream = false;
+ bool use_iostream = true;
// describe the point structure
@@ -123,7 +123,7 @@
if (use_iostream)
ofb1.open("test1.lax", std::ios::out);
- std::ostream* ostream1 = new std::ostream(&ofb1);
+ ostream1 = new std::ostream(&ofb1);
if (!laszipper1->open(ostream1, num_items, items, LASZIP_COMPRESSION_NONE))
fprintf(stderr, "ERROR: could not open laszipper1\n");
@@ -131,7 +131,7 @@
ofb2.open("test2.lax", std::ios::out);
- std::ostream* ostream2 = new std::ostream(&ofb2);
+ ostream2 = new std::ostream(&ofb2);
if (!laszipper2->open(ostream2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC))
fprintf(stderr, "ERROR: could not open laszipper2\n");
@@ -177,10 +177,12 @@
if (use_iostream)
+ ostream1.flush();
+ ostream2.flush();
+ delete ostream1;
+ delete ostream2;
ofb1.close();
ofb2.close();
- delete ostream1;
- delete ostream2;
else
@@ -269,10 +271,10 @@
if (use_iostream)
+ delete istream1;
+ delete istream2;
ifb1.close();
ifb2.close();
- delete istream1;
- delete istream2;
else
More information about the Liblas-commits
