[Liblas-commits] laszip: handling big endian writes and reads
liblas-commits at liblas.org
Wed Dec 15 08:13:37 EST 2010
changeset 70aa87413dcb in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=70aa87413dcb
summary: handling big endian writes and reads
diffstat:
src/lasreaditemrawendianswapped.hpp | 102 +++++++++++++++++++++++++++++++++++
src/laswriteitemrawendianswapped.hpp | 99 +++++++++++++++++++++++++++++++++
2 files changed, 201 insertions(+), 0 deletions(-)
diffs (209 lines):
diff -r a2f165041d2a -r 70aa87413dcb src/lasreaditemrawendianswapped.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/src/lasreaditemrawendianswapped.hpp Wed Dec 15 05:11:54 2010 -0800
@@ -0,0 +1,102 @@
+ * Project: integrating laszip into liblas - http://liblas.org -
+ * Purpose:
+ * Author: Martin Isenburg
+ * isenburg at cs.unc.edu
+ * Copyright (c) 2010, Martin Isenburg
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ FILE: LASitemreadrawendianswapped.hpp
+ CONTENTS:
+ Implementation of LASitemReadRaw for *all* items that compose a point.
+ PROGRAMMERS:
+ martin isenburg at cs.unc.edu
+ COPYRIGHT:
+ copyright (C) 2007-2010 martin isenburg at cs.unc.edu
+ This software is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+ CHANGE HISTORY:
+ 14 December 2010 -- at Starbucks in Offenbach before watching "Fair Game"
+#ifndef LAS_READ_ITEM_RAW_ENDIAN_SWAPPED_H
+#define LAS_READ_ITEM_RAW_ENDIAN_SWAPPED_H
+#include "lasreaditem.hpp"
+#include <assert.h>
+class LASreadItemRawEndianSwapped_POINT10 : public LASreadItemRaw
+public:
+ LASreadItemRawEndianSwapped_POINT10(){};
+ BOOL read(U8* item)
+ U8 copy[20];
+ BOOL flag = instream->getBytes(copy, 20);
+ ENDIAN_SWAP_32(&(copy[ 0]), &(item[ 0])); // x
+ ENDIAN_SWAP_32(&(copy[ 4]), &(item[ 4])); // y
+ ENDIAN_SWAP_32(&(copy[ 8]), &(item[ 8])); // z
+ ENDIAN_SWAP_16(&(copy[12]), &(item[12])); // intensity
+ item[14] = copy[14]; // bitfield
+ item[15] = copy[15]; // classification
+ item[16] = copy[16]; // scan_angle_rank
+ item[17] = copy[17]; // user_data
+ ENDIAN_SWAP_16(&(copy[18]), &(item[18])); // point_source_ID
+ return flag;
+class LASreadItemRawEndianSwapped_GPSTIME : public LASreadItemRaw
+public:
+ LASreadItemRawEndianSwapped_GPSTIME(){};
+ U8 copy[8];
+ BOOL flag = instream->getBytes(copy, 8);
+ ENDIAN_SWAP_64(copy, item);
+ return flag;
+class LASreadItemRawEndianSwapped_RGB : public LASreadItemRaw
+public:
+ LASreadItemRawEndianSwapped_RGB(){};
+ U8 copy[6];
+ BOOL flag = instream->getBytes(copy, 6);
+ ENDIAN_SWAP_16(&(copy[0]), &(item[0]));
+ ENDIAN_SWAP_16(&(copy[2]), &(item[2]));
+ ENDIAN_SWAP_16(&(copy[4]), &(item[4]));
+ return flag;
+#endif
diff -r a2f165041d2a -r 70aa87413dcb src/laswriteitemrawendianswapped.hpp
+++ b/src/laswriteitemrawendianswapped.hpp Wed Dec 15 05:11:54 2010 -0800
@@ -0,0 +1,99 @@
+ * Purpose:
+ FILE: LASwriteitemrawendianswapped.hpp
+ CONTENTS:
+ Implementation of LASwriteItemRaw for *all* items that compose a point.
+ PROGRAMMERS:
+ COPYRIGHT:
+ CHANGE HISTORY:
+#ifndef LAS_WRITE_ITEM_RAW_WITH_ENDIAN_SWAPPED_H
+#define LAS_WRITE_ITEM_RAW_WITH_ENDIAN_SWAPPED_H
+#include "laswriteitem.hpp"
+class LASwriteItemRawEndianSwapped_POINT10 : public LASwriteItemRaw
+public:
+ LASwriteItemRawEndianSwapped_POINT10(){};
+ BOOL write(U8* item)
+ U8 copy[20];
+ ENDIAN_SWAP_32(&(item[ 0]), &(copy[ 0])); // x
+ ENDIAN_SWAP_32(&(item[ 4]), &(copy[ 4])); // y
+ ENDIAN_SWAP_32(&(item[ 8]), &(copy[ 8])); // z
+ ENDIAN_SWAP_16(&(item[12]), &(copy[12])); // intensity
+ copy[14] = item[14]; // bitfield
+ copy[15] = item[15]; // classification
+ copy[16] = item[16]; // scan_angle_rank
+ copy[17] = item[17]; // user_data
+ ENDIAN_SWAP_16(&(item[18]), &(copy[18])); // point_source_ID
+ return outstream->putBytes(copy, 20);
+class LASwriteItemRawEndianSwapped_GPSTIME : public LASwriteItemRaw
+public:
+ LASwriteItemRawEndianSwapped_GPSTIME() {};
+ U8 copy[8];
+ ENDIAN_SWAP_64(item, copy);
+ return outstream->putBytes(copy, 8);
+class LASwriteItemRawEndianSwapped_RGB : public LASwriteItemRaw
+public:
+ LASwriteItemRawEndianSwapped_RGB(){}
+ U8 copy[6];
+ ENDIAN_SWAP_16(&(item[0]), &(copy[0]));
+ ENDIAN_SWAP_16(&(item[2]), &(copy[2]));
+ ENDIAN_SWAP_16(&(item[4]), &(copy[4]));
+ return outstream->putBytes(copy, 6);
+#endif
More information about the Liblas-commits
