[Liblas-commits] laszip: 4 new changesets
liblas-commits at liblas.org
Wed Dec 15 11:28:00 EST 2010
changeset 6fc09696ca40 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=6fc09696ca40
summary: eof instead of bad
changeset e7dea1f25db5 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=e7dea1f25db5
summary: added check for input & output bytes
changeset eafa0e1730af in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=eafa0e1730af
summary: merging with my code
changeset e4af65b349e7 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=e4af65b349e7
diffstat:
include/laszip/lasunzipper.hpp | 75 +++++++++++++++++---------------
include/laszip/laszipper.hpp | 81 +++++++++++++++++------------------
src/bytestreamin.hpp | 4 +
src/bytestreamin_file.hpp | 25 +++++++++-
src/bytestreamin_istream.hpp | 95 +++++++++++++++++++++--------------------
src/bytestreamout_ostream.hpp | 87 ++++++++++++++++++++-----------------
src/lasunzipper.cpp | 82 ++++++++++++++++++------------------
src/laszipper.cpp | 84 ++++++++++++++++++------------------
tools/laszippertest.cpp | 51 +++++++++++-----------
9 files changed, 308 insertions(+), 276 deletions(-)
diffs (truncated from 968 to 300 lines):
diff -r f9bbc9504f92 -r e4af65b349e7 include/laszip/lasunzipper.hpp
--- a/include/laszip/lasunzipper.hpp Wed Dec 15 08:02:55 2010 -0800
+++ b/include/laszip/lasunzipper.hpp Wed Dec 15 08:27:40 2010 -0800
@@ -1,21 +1,21 @@
- * Project: integrating laszip into liblas - http://liblas.org -
- * Purpose:
- * Author: Martin Isenburg
- * isenburg at cs.unc.edu
- * Copyright (c) 2010, Martin Isenburg
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
+ * Project: integrating laszip into liblas - http://liblas.org -
+ * Purpose:
+ * Author: Martin Isenburg
+ * isenburg at cs.unc.edu
+ * Copyright (c) 2010, Martin Isenburg
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
@@ -39,40 +39,43 @@
CHANGE HISTORY:
- 12 December 2010 -- created from LASwriter/LASreader after Howard got pushy (-;
+ 12 December 2010 -- created from LASwriter/LASreader after Howard got pushy (-;
#ifndef LAS_UNZIPPER_H
#define LAS_UNZIPPER_H
-#include <stdio.h>
+#include <stdio.h>
+#if _MSC_VER < 1300
+#include <fstream.h>
+#else
+#include <fstream>
+using namespace std;
+#endif
+#include "laszip.hpp"
-#include <fstream>
-#include "laszip.hpp"
-using namespace std;
-class ByteStreamIn;
-class LASreadPoint;
+class ByteStreamIn;
+class LASreadPoint;
class LASunzipper
public:
- bool open(FILE* file, unsigned int num_items, const LASitem* items, unsigned int compression=0);
- bool open(istream* stream, unsigned int num_items, const LASitem* items, unsigned int compression=0);
- bool read(unsigned char** point);
- bool close();
+ bool open(FILE* file, unsigned int num_items, const LASitem* items, unsigned int compression=0);
+ bool open(istream* stream, unsigned int num_items, const LASitem* items, unsigned int compression=0);
+ bool read(unsigned char** point);
+ unsigned int close();
LASunzipper();
~LASunzipper();
-private:
+private:
int count;
- ByteStreamIn* stream;
- LASreadPoint* reader;
+ ByteStreamIn* stream;
+ LASreadPoint* reader;
#endif
diff -r f9bbc9504f92 -r e4af65b349e7 include/laszip/laszipper.hpp
--- a/include/laszip/laszipper.hpp Wed Dec 15 08:02:55 2010 -0800
+++ b/include/laszip/laszipper.hpp Wed Dec 15 08:27:40 2010 -0800
@@ -1,21 +1,21 @@
- * Purpose:
+ * Purpose:
@@ -39,45 +39,44 @@
CHANGE HISTORY:
#ifndef LAS_ZIPPER_H
#define LAS_ZIPPER_H
-#include <stdio.h>
+#include <stdio.h>
+#else
+#include <fstream>
+#endif
-#if _MSC_VER < 1300
-#include <ostream.h>
-#else
-#include <fstream>
-#endif
-class ByteStreamOut;
-class LASwritePoint;
+class ByteStreamOut;
+class LASwritePoint;
class LASzipper
public:
- bool open(FILE* outfile, unsigned int num_items, LASitem* items, unsigned int compression=0);
- bool open(ostream* outstream, unsigned int num_items, LASitem* items, unsigned int compression=0);
- bool write(unsigned char** point);
- bool chunk(LASchunk* chunk);
- bool close(LASchunk* chunk=0);
+ bool open(FILE* outfile, unsigned int num_items, LASitem* items, unsigned int compression=0);
+ bool open(ostream* outstream, unsigned int num_items, LASitem* items, unsigned int compression=0);
+ bool write(unsigned char** point);
+ bool chunk(LASchunk* chunk);
+ unsigned int close(LASchunk* chunk=0);
LASzipper();
~LASzipper();
-private:
+private:
int count;
- ByteStreamOut* stream;
- LASwritePoint* writer;
+ ByteStreamOut* stream;
+ LASwritePoint* writer;
#endif
diff -r f9bbc9504f92 -r e4af65b349e7 src/bytestreamin.hpp
--- a/src/bytestreamin.hpp Wed Dec 15 08:02:55 2010 -0800
+++ b/src/bytestreamin.hpp Wed Dec 15 08:27:40 2010 -0800
@@ -51,6 +51,10 @@
virtual unsigned int getByte() = 0;
/* read an array of bytes */
virtual bool getBytes(unsigned char* bytes, unsigned int num_bytes) = 0;
+/* returns how many bytes were read since last reset */
+ virtual unsigned int byteCount() const = 0;
+/* reset byte counter */
+ virtual void resetCount() = 0;
/* destructor */
virtual ~ByteStreamIn() {};
diff -r f9bbc9504f92 -r e4af65b349e7 src/bytestreamin_file.hpp
--- a/src/bytestreamin_file.hpp Wed Dec 15 08:02:55 2010 -0800
+++ b/src/bytestreamin_file.hpp Wed Dec 15 08:27:40 2010 -0800
@@ -56,22 +56,29 @@
unsigned int getByte();
bool getBytes(unsigned char* bytes, unsigned int num_bytes);
+ unsigned int byteCount() const;
+ void resetCount();
/* destructor */
~ByteStreamInFile(){};
private:
- FILE* fp;
+ FILE* file;
+ long start;
ByteStreamInFile::ByteStreamInFile(FILE* file)
- fp = file;
+ this->file = file;
+ resetCount();
unsigned int ByteStreamInFile::getByte()
- int byte = getc(fp);
+ int byte = getc(file);
if (byte == EOF)
+ fprintf(stderr, "reading EOF\n");
byte = 0;
return (unsigned int)byte;
@@ -79,7 +86,17 @@
bool ByteStreamInFile::getBytes(unsigned char* bytes, unsigned int num_bytes)
- return (fread(bytes, 1, num_bytes, fp) != num_bytes);
+ return (fread(bytes, 1, num_bytes, file) != num_bytes);
+unsigned int ByteStreamInFile::byteCount() const
+ return ftell(file)-start;
+void ByteStreamInFile::resetCount()
+ start = ftell(file);
#endif
diff -r f9bbc9504f92 -r e4af65b349e7 src/bytestreamin_istream.hpp
--- a/src/bytestreamin_istream.hpp Wed Dec 15 08:02:55 2010 -0800
+++ b/src/bytestreamin_istream.hpp Wed Dec 15 08:27:40 2010 -0800
@@ -16,50 +16,49 @@
- FILE: bytestreamin_istream.hpp
- CONTENTS:
- PROGRAMMERS:
More information about the Liblas-commits
