[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Thu Dec 16 10:18:43 EST 2010
changeset e47cf270ecbc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=e47cf270ecbc
summary: bad target
changeset 52bd79c0994c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=52bd79c0994c
summary: update to reflect current implementation
diffstat:
doc/development/rfc/rfc_1_verticalcs.txt | 4 +-
doc/development/rfc/rfc_2_spatialreference.txt | 70 +++++++++++++++----------
doc/download.txt | 2 +-
3 files changed, 44 insertions(+), 32 deletions(-)
diffs (193 lines):
diff -r 92d5b4500014 -r 52bd79c0994c doc/development/rfc/rfc_1_verticalcs.txt
--- a/doc/development/rfc/rfc_1_verticalcs.txt Wed Dec 15 14:36:42 2010 -0600
+++ b/doc/development/rfc/rfc_1_verticalcs.txt Thu Dec 16 09:18:34 2010 -0600
@@ -5,14 +5,12 @@
:Author: Frank Warmerdam
:Contact: warmerdam at pobox.com
:Date: 1/6/10
-:Status: Proposed
+:Status: Implemented
:Version: libLAS 1.3
.. contents::
:depth: 2
-.. sectnum::
This page holds resources to handling of vertical coordinate systems (datums
and units) in LAS files. Traditionally LAS files have not been rigorous with
regard to recording the vertical datum and vertical units. In actual use I
diff -r 92d5b4500014 -r 52bd79c0994c doc/development/rfc/rfc_2_spatialreference.txt
--- a/doc/development/rfc/rfc_2_spatialreference.txt Wed Dec 15 14:36:42 2010 -0600
+++ b/doc/development/rfc/rfc_2_spatialreference.txt Thu Dec 16 09:18:34 2010 -0600
@@ -5,20 +5,18 @@
:Date: 11/19/10
-:Status: Proposed
:Version: libLAS 1.6
.. contents::
:depth: 1
-.. sectnum::
This RFC addresses several areas of change to the liblas::SpatialReference
class and associated services. The objectives are:
- * Minimize the default exposure of liblas applications to definitions
+ * Minimize the default exposure of libLAS applications to definitions
from the GeoTIFF library.
from the GDAL library.
* Provide a mechanism to capture coordinate system definitions in a LAS
file that cannot be represented via GeoTIFF tags via a liblas
@@ -36,12 +34,12 @@
This introduces a lot of cruft into the global namespace. Also due to the
"C" style includes of these sublibraries, it introduces a lot of junk that
-might interfere in suprising ways and in contrast to how the rest of
-liblas in very careful to put things into namespaces and otherwise be
+might interfere in surprising ways and in contrast to how the rest of
+libLAS in very careful to put things into namespaces and otherwise be
somewhat sparing of includes.
The cleanup should help avoid conflicts and namespace pollution for
-applications primariliy linking against liblas and not wanting to use
+applications primarily linking against libLAS and not wanting to use
libgeotiff or GDAL services directly. It should also make building somewhat
less fragile in some cases.
@@ -52,20 +50,20 @@
There are a significant number of coordinate systems, and options that
cannot be represented in GeoTIFF tags. This includes TOWGS84 parameters,
options to use particular horizontal and vertical grid shift files, and
-support for projection methods that don't have CT_ definitions for
+support for projection methods that don't have CT\_ definitions for
GeoTIFF.
Currently the liblas::SpatialReference class converts passed in WKT
coordinate system definitions into a GeoTIFF VLR and future requests for
the WKT are created by converting the GeoTIFF VLR back into WKT. This
-makes it essentially impossible currently for las2las to perform
+makes it essentially impossible currently for :ref:`las2las <las2las>` to perform
transformations between coordinate systems not representable in GeoTIFF
-terms even if the source and destination are provided on the commandline in
+terms even if the source and destination are provided on the command-line in
WKT format.
Also, it seems with future versions of LAS format some variation of OGC
WKT in a VLR will become a supported, or even the preferred way of
-repesenting coordinate systems.
+representing coordinate systems.
Given these points it seems reasonable to make liblas::SpatialReference
less GeoTIFF VLR oriented now.
@@ -89,7 +87,7 @@
typedef struct ST_TIFFS *ST_TIFF;
#endif
-Thus liblas library code, and application code that wants "proper"
+Thus libLAS library code, and application code that wants "proper"
GTIF and ST_TIFF types will need to include the corresponding libgeotiff
include files *before* including lasspatialreference.hpp. Any attempt to
include these libgeotiff include files *after* including lasspatialreference.hpp
@@ -97,15 +95,15 @@
unobvious requirement to new folks. Some existing application code will
likely need a bit of include reordering before it will work.
-It is intended that similar approach might be used for GDAL and OGR
+It is intended that similar approach might be used for GDAL and OGR
dependencies. The primary place where this is a concern seems to be
lastransform.hpp.
It is also planned to move the lasversion.hpp function implementations into a
.cpp file to avoid having to include libgeotiff and GDAL include files right
in lasversion.hpp. This should have the added benefit of not making what
-lasversion.hpp returns depend on what extra macros (like HAVE_GDAL) are defined
-when it is included vs. when liblas itself is compiled and linked.
+lasversion.hpp returns depend on what extra macros (like `HAVE_GDAL`) are defined
+when it is included vs. when libLAS itself is compiled and linked.
SpatialReference WKT Updates
@@ -123,7 +121,7 @@
void ClearVLRs( GeoVLRType eType );
private:
- mutable std::string m_wkt;
+ std::string m_wkt;
The GeoVLRType enumeration is currently used just to define what information
should be wiped in a call to ClearVLRs() but in the future it might also
@@ -145,10 +143,23 @@
* SetWKT() now caches the WKT as well as creating the GeoTIFF definition
from it. Then the WKT and GeoTIFF VLRs are generated.
-Now, if you want *only* GeoTIFF VLRs you should normally generate the
-SpatialReference and then call "ClearVLRs(eOGRWKT);" before setting the
-SpatialReference on the header being written. If you want *only* a WKT
-VLR then you should call "ClearVLRs(eGeotIFF);" at the same point.
+.. note::
+ A liblas::SpatialReference instance that was read/generated from VLRs containing
+ only GeoTIFF keys will continue to only have GeoTIFF keys until you
+ issue a call to SetWKT(). You can simply do the following to WKT-enable
+ a liblas::SpatialReference in that case:
+ reference.SetWKT(reference.GetWKT());
+.. warning::
+ If you want *only* GeoTIFF VLRs you should normally generate the
+ SpatialReference and then call "ClearVLRs(eOGRWKT);" before setting the
+ SpatialReference on the header being written. If you want *only* a WKT VLR
+ then you should call "ClearVLRs(eGeotIFF);" at the same point.
@@ -157,18 +168,21 @@
Currently the OGR WKT VLR is currently being written with a UserId of
-"LASF_Projection" like the GeoTIFF VLRs, and with a RecordId of 2112 to
-distingish it from the GeoTIFF VLRs.
+"liblas" and with a RecordId of 2112 to
+distinguish it from the GeoTIFF VLRs.
-The data is the OGR WKT string with a terminating zero byte.
+The data is the OGR WKT string with a terminating zero byte. An exception
+is thrown if the size of the WKT is larger than a VLR record can hold.
Is there any scheme to assign RecordIds? Perhaps we should pick a value
outside the normal legal range for TIFF tags? Or perhaps we should be
using a different UserId?
-Note that it is anticipated at some point in the future there will be a
-WKT VLR definition as part of the LAS specification and that it's contents
-may be more accurately defined as OGC WKT rather than OGR WKT which can
-contain a variety of extensions to the specification.
+.. note::
+ It is anticipated at some point in the future there will be a
+ WKT VLR definition as part of the LAS specification and that it's contents
+ may be more accurately defined as OGC WKT rather than OGR WKT which can
+ contain a variety of extensions to the specification.
diff -r 92d5b4500014 -r 52bd79c0994c doc/download.txt
--- a/doc/download.txt Wed Dec 15 14:36:42 2010 -0600
+++ b/doc/download.txt Thu Dec 16 09:18:34 2010 -0600
@@ -13,7 +13,7 @@
- `libLAS-1.6.0b3-src.tar.gz`_
`(md5) <http://download.osgeo.org/liblas/libLAS-1.6.0b3.tar.gz.md5>`__
- - `libLAS-1.6.0b2-src.zip <http://download.osgeo.org/liblas/libLAS-1.6.0b3.zip>`_
+ - `libLAS-1.6.0b3-src.zip <http://download.osgeo.org/liblas/libLAS-1.6.0b3.zip>`_
`(md5) <http://download.osgeo.org/liblas/libLAS-1.6.0b3.zip.md5>`__
- See `OSGeo4W <http://trac.osgeo.org/osgeo4w>`__ for Windows release.
More information about the Liblas-commits
