[Liblas-commits] hg: 2 new changesets
    liblas-commits at liblas.org
    Fri Dec 17 12:14:44 EST 2010
changeset e14aba667e5a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=e14aba667e5a
summary: typos
changeset bc1a553d5a88 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=bc1a553d5a88
summary: add the ability for lasblock to write out blocked LAS files with the --write-points switch
diffstat:
 apps/CMakeLists.txt |    2 +-
 apps/las2las.cpp    |    8 +-
 apps/lasblock.cpp   |  288 ++++++++++++++++++++++++++++++++++-----------------
 3 files changed, 197 insertions(+), 101 deletions(-)
diffs (truncated from 376 to 300 lines):
diff -r 701bdd07631d -r bc1a553d5a88 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Fri Dec 17 10:10:47 2010 -0600
+++ b/apps/CMakeLists.txt	Fri Dec 17 11:14:33 2010 -0600
@@ -144,7 +144,7 @@
 # Build lasblock
 if(LASBLOCK)
-    set(LASBLOCK_SRC lasblock.cpp )
+    set(LASBLOCK_SRC lasblock.cpp laskernel.cpp)
     add_executable(${LASBLOCK} ${LASBLOCK_SRC})
     target_link_libraries(${LASBLOCK} ${APPS_CPP_DEPENDENCIES} )
 endif()
diff -r 701bdd07631d -r bc1a553d5a88 apps/las2las.cpp
--- a/apps/las2las.cpp	Fri Dec 17 10:10:47 2010 -0600
+++ b/apps/las2las.cpp	Fri Dec 17 11:14:33 2010 -0600
@@ -222,9 +222,9 @@
     oss << options;
-    oss <<"\nFor more information, see the full documentation for las2las2 at:\n";
+    oss <<"\nFor more information, see the full documentation for las2las at:\n";
-    oss << " http://liblas.org/utilities/las2las2.html\n";
+    oss << " http://liblas.org/utilities/las2las.html\n";
     oss << "----------------------------------------------------------\n";
@@ -247,7 +247,7 @@
     try {
-        po::options_description file_options("las2las2 options");
+        po::options_description file_options("las2las options");
         po::options_description filtering_options = GetFilteringOptions();
         po::options_description header_options = GetHeaderOptions();
         po::options_description transform_options = GetTransformationOptions() ;
@@ -352,4 +352,4 @@
-//las2las2 -i lt_srs_rt.las  -o foo.las -c 1,2 -b 2483590,366208,2484000,366612
+//las2las -i lt_srs_rt.las  -o foo.las -c 1,2 -b 2483590,366208,2484000,366612
diff -r 701bdd07631d -r bc1a553d5a88 apps/lasblock.cpp
--- a/apps/lasblock.cpp	Fri Dec 17 10:10:47 2010 -0600
+++ b/apps/lasblock.cpp	Fri Dec 17 11:14:33 2010 -0600
@@ -11,6 +11,7 @@
 #include <liblas/liblas.hpp>
 #include <liblas/chipper.hpp>
+#include "laskernel.hpp"
 // std
 #include <fstream>
@@ -36,127 +37,127 @@
 #define compare_no_case(a,b,n)  strncasecmp( (a), (b), (n) )
 #endif
-bool term_progress(std::ostream& os, double complete)
+typedef boost::shared_ptr<liblas::Writer> WriterPtr;
+typedef boost::shared_ptr<liblas::Summary> SummaryPtr;
+typedef boost::shared_ptr<std::ofstream> OStreamPtr;
+WriterPtr start_writer(   OStreamPtr strm,
+                          std::string const& output,
+                          liblas::Header const& header)
-    static int lastTick = -1;
-    int tick = static_cast<int>(complete * 40.0);
-    tick = std::min(40, std::max(0, tick));
-    // Have we started a new progress run?
-    if (tick < lastTick && lastTick >= 39)
-        lastTick = -1;
-    if (tick <= lastTick)
-        return true;
-    while (tick > lastTick)
+    if (!liblas::Create(*strm, output.c_str()))
-        lastTick++;
-        if (lastTick % 4 == 0)
-            os << (lastTick / 4) * 10;
-        else
-            os << ".";
+        std::ostringstream oss;
+        oss << "Cannot create " << output << "for write.  Exiting...";
+        throw std::runtime_error(oss.str());
-    if( tick == 40 )
-        os << " - done.\n";
-    else
-        os.flush();
-    return true;
+    WriterPtr writer( new liblas::Writer(*strm, header));
+    return writer;
 using namespace liblas;
+void OutputHelp( std::ostream & oss, po::options_description const& options)
+    oss << "--------------------------------------------------------------------\n";
+    oss << "    lasblock (" << GetFullVersion() << ")\n";
-int main(int argc, char* argv[])
+    oss << options;
+    oss <<"\nFor more information, see the full documentation for lasblock at:\n";
+    oss << " http://liblas.org/utilities/block.html\n";
+    oss << "----------------------------------------------------------\n";
+void write_tiles(std::string& output,
+                 liblas::chipper::Chipper& c,
+                 liblas::Reader& reader,
+                 bool verbose)
-    std::string input;
-    std::string output;
-    long capacity = 3000;
-    long precision = 8;
-    bool verbose = false;
-    po::options_description desc("Allowed lasblock options");
-    po::positional_options_description p;
-    p.add("input", 1);
-    p.add("output", 1);
-    desc.add_options()
-        ("help,h", "Produce this help message")
-        ("capacity,c", po::value<long>(&capacity)->default_value(3000), "Number of points to nominally put into each block (note that this number will not be exact)")
-        ("precision,p", po::value<long>(&precision)->default_value(8), "Number of decimal points to write for each bbox")
-        ("input,i", po::value< std::string >(), "input LAS file")
-        ("output,o", po::value< std::string >(&output)->default_value(""), "The output .kdx file (defaults to input filename + .kdx)")
-        ("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Verbose message output")
-    po::variables_map vm;
-    po::store(po::command_line_parser(argc, argv).
-      options(desc).positional(p).run(), vm);
-    po::notify(vm);
-    if (vm.count("help"))
-        std::cout << desc << "\n";
-            std::cout <<"\nFor more information, see the full documentation for lasblock at:\n";
-            std::cout << " http://liblas.org/utilities/block.html\n";
-            std::cout << "----------------------------------------------------------\n";
-        return 1;
-    if (vm.count("input"))
-        input = vm["input"].as< std::string >();
-        std::ifstream ifs;
-        if (!liblas::Open(ifs, input.c_str()))
-            std::cerr << "Cannot open file '" << input << "'for read.  Exiting...";
-            return 1;
+    std::string out = output;
-    if (output.empty())
+    liblas::Header header = reader.GetHeader();
+    std::string::size_type dot_pos = output.find_first_of(".");
+    out = output.substr(0, dot_pos);
+    if (verbose)
+        std::cout << "Writing " << c.GetBlockCount() << " blocks to " << output << std::endl;
+    boost::uint32_t prog = 0;
+    for ( boost::uint32_t i = 0; i < c.GetBlockCount(); ++i )
-        output = std::string(input) + ".kdx";
+        OStreamPtr ofs(new std::ofstream);
+        SummaryPtr summary(new::liblas::Summary);
+        std::ostringstream name;
+        name << out << "-" << i <<".las";
+        const liblas::chipper::Block& b = c.GetBlock(i);
+        header.SetExtent(b.GetBounds());
+        WriterPtr writer = start_writer(ofs, name.str(), header);
+        std::vector<boost::uint32_t> ids = b.GetIDs();
+        for ( boost::uint32_t pi = 0; pi < ids.size(); ++pi )
+            bool read = reader.ReadPointAt(pi);
+            if (read) {
+                liblas::Point const& p = reader.GetPoint();
+                summary->AddPoint(p);
+                writer->WritePoint(p);
+        writer = WriterPtr();
+        ofs = OStreamPtr();
+        liblas::Header hnew = FetchHeader(name.str());
+        RepairHeader(*summary, hnew);
+        RewriteHeader(hnew, name.str());
+        if (verbose)
+            term_progress(std::cout, (prog + 1) / static_cast<double>(c.GetBlockCount()));
+        prog++;
-    std::ifstream in;
-    if (!liblas::Open(in, input.c_str()))
-        std::cerr << "Cannot open " << input << "for read.  Exiting...";
-        return 1;
+void write_index(std::string& output,
+                 long precision,
+                 bool verbose)
     std::ofstream out(output.c_str());
-    liblas::Reader reader( in );
-    liblas::chipper::Chipper c(&reader, capacity);
-    if (verbose)
-        std::cout << "Blocking " << input<< " to " << output <<std::endl;
-    c.Chip();
     boost::uint32_t num_blocks = c.GetBlockCount();
     if (verbose)
-        std::cout << "Writing " << num_blocks << " blocks to " << output << std::endl;
-    for ( boost::uint32_t i = 0; i < num_blocks; ++i )
@@ -183,3 +184,98 @@
         prog++;
+int main(int argc, char* argv[])
+    std::string input;
+    std::string output;
+    long capacity = 3000;
+    long precision = 8;
+    bool verbose = false;
+    bool tiling = false;
+    po::options_description desc("Allowed lasblock options");
+    po::positional_options_description p;
+    p.add("input", 1);
+    p.add("output", 1);
+    desc.add_options()
+        ("help,h", "Produce this help message")
+        ("capacity,c", po::value<long>(&capacity)->default_value(3000), "Number of points to nominally put into each block (note that this number will not be exact)")
More information about the Liblas-commits
