[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Mon Dec 20 12:58:56 EST 2010
changeset c0cb2660a84b in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c0cb2660a84b
summary: don't reset the header if it doesn't need to be reset. I'm so stupid
changeset 48542695b493 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=48542695b493
summary: add a CoordinateSummary utility that only touches GetX, GetY, and GetZ for doing things like summarizing the info needed for header writing in las2las, etc
diffstat:
apps/las2las.cpp | 8 +-
apps/lasblock.cpp | 4 +-
apps/laskernel.cpp | 2 +-
apps/laskernel.hpp | 2 +-
include/liblas/utility.hpp | 24 +++++++
src/detail/reader/point.cpp | 3 +-
src/utility.cpp | 145 ++++++++++++++++++++++++++++++++++++++++++++
7 files changed, 179 insertions(+), 9 deletions(-)
diffs (286 lines):
diff -r c430311ecc55 -r 48542695b493 apps/las2las.cpp
--- a/apps/las2las.cpp Mon Dec 20 09:48:35 2010 -0600
+++ b/apps/las2las.cpp Mon Dec 20 11:58:46 2010 -0600
@@ -22,7 +22,7 @@
using namespace std;
typedef boost::shared_ptr<liblas::Writer> WriterPtr;
-typedef boost::shared_ptr<liblas::Summary> SummaryPtr;
+typedef boost::shared_ptr<liblas::CoordinateSummary> SummaryPtr;
typedef boost::shared_ptr<std::ofstream> OStreamPtr;
WriterPtr start_writer( OStreamPtr strm,
@@ -62,7 +62,7 @@
liblas::ReaderFactory f;
liblas::Reader reader = f.CreateWithStream(ifs);
- SummaryPtr summary(new::liblas::Summary);
+ SummaryPtr summary(new::liblas::CoordinateSummary);
reader.SetFilters(filters);
reader.SetTransforms(transforms);
@@ -162,7 +162,7 @@
RepairHeader(*summary, hnew);
RewriteHeader(hnew, old_filename.str());
- summary = SummaryPtr(new liblas::Summary);
+ summary = SummaryPtr(new liblas::CoordinateSummary);
fileno++;
split_bytes_count = 1024*1024*split_mb;
@@ -190,7 +190,7 @@
fileno++;
split_points_count = 0;
diff -r c430311ecc55 -r 48542695b493 apps/lasblock.cpp
--- a/apps/lasblock.cpp Mon Dec 20 09:48:35 2010 -0600
+++ b/apps/lasblock.cpp Mon Dec 20 11:58:46 2010 -0600
@@ -38,7 +38,7 @@
#endif
@@ -103,7 +103,7 @@
for ( boost::uint32_t i = 0; i < c.GetBlockCount(); ++i )
OStreamPtr ofs(new std::ofstream);
std::ostringstream name;
name << out << "-" << i <<".las";
diff -r c430311ecc55 -r 48542695b493 apps/laskernel.cpp
--- a/apps/laskernel.cpp Mon Dec 20 09:48:35 2010 -0600
+++ b/apps/laskernel.cpp Mon Dec 20 11:58:46 2010 -0600
@@ -136,7 +136,7 @@
-void RepairHeader(liblas::Summary const& summary, liblas::Header& header)
+void RepairHeader(liblas::CoordinateSummary const& summary, liblas::Header& header)
for (boost::uint32_t i = 0; i < 5; i++)
diff -r c430311ecc55 -r 48542695b493 apps/laskernel.hpp
--- a/apps/laskernel.hpp Mon Dec 20 09:48:35 2010 -0600
+++ b/apps/laskernel.hpp Mon Dec 20 11:58:46 2010 -0600
@@ -101,7 +101,7 @@
LAS_DLL liblas::Header FetchHeader(std::string const& filename);
LAS_DLL void RewriteHeader(liblas::Header const& header, std::string const& filename);
-LAS_DLL void RepairHeader(liblas::Summary const& summary, liblas::Header& header);
+LAS_DLL void RepairHeader(liblas::CoordinateSummary const& summary, liblas::Header& header);
LAS_DLL liblas::property_tree::ptree SummarizeReader(liblas::Reader& reader) ;
#endif // LIBLAS_ITERATOR_HPP_INCLUDED
diff -r c430311ecc55 -r 48542695b493 include/liblas/utility.hpp
--- a/include/liblas/utility.hpp Mon Dec 20 09:48:35 2010 -0600
+++ b/include/liblas/utility.hpp Mon Dec 20 11:58:46 2010 -0600
@@ -89,6 +89,30 @@
bool bHaveHeader;
+class LAS_DLL CoordinateSummary
+public:
+ CoordinateSummary();
+ CoordinateSummary(CoordinateSummary const& other);
+ CoordinateSummary& operator=(CoordinateSummary const& rhs);
+ void AddPoint(liblas::Point const& p);
+ ptree GetPTree() const;
+ void SetHeader(liblas::Header const& h);
+private:
+ boost::uint32_t count;
+ boost::array<boost::uint32_t, 8> points_by_return;
+ boost::array<boost::uint32_t, 8> returns_of_given_pulse;
+ bool first;
+ liblas::Point min;
+ liblas::Point max;
+ liblas::Header m_header;
+ bool bHaveHeader;
LAS_DLL std::ostream& operator<<(std::ostream& os, liblas::Summary const& s);
LAS_DLL boost::uint32_t GetStreamPrecision(double scale);
diff -r c430311ecc55 -r 48542695b493 src/detail/reader/point.cpp
--- a/src/detail/reader/point.cpp Mon Dec 20 09:48:35 2010 -0600
+++ b/src/detail/reader/point.cpp Mon Dec 20 11:58:46 2010 -0600
@@ -73,7 +73,8 @@
assert(m_point.GetHeaderPtr());
assert(m_record_size > 0);
- m_point.SetHeaderPtr(m_header);
+ if (m_point.GetHeaderPtr().get() != m_header.get())
+ m_point.SetHeaderPtr(m_header);
detail::read_n(m_point.GetData().front(), m_ifs, m_record_size);
diff -r c430311ecc55 -r 48542695b493 src/utility.cpp
--- a/src/utility.cpp Mon Dec 20 09:48:35 2010 -0600
+++ b/src/utility.cpp Mon Dec 20 11:58:46 2010 -0600
@@ -456,6 +456,151 @@
+CoordinateSummary::CoordinateSummary() :
+ count(0)
+ , first(true)
+ , bHaveHeader(false)
+ points_by_return.assign(0);
+ returns_of_given_pulse.assign(0);
+CoordinateSummary::CoordinateSummary(CoordinateSummary const& other)
+ count(other.count)
+ , points_by_return(other.points_by_return)
+ , returns_of_given_pulse(other.returns_of_given_pulse)
+ , first(other.first)
+ , min(other.min)
+ , max(other.max)
+ , m_header(other.m_header)
+ , bHaveHeader(other.bHaveHeader)
+CoordinateSummary& CoordinateSummary::operator=(CoordinateSummary const& rhs)
+ if (&rhs != this)
+ count = rhs.count;
+ first = rhs.first;
+ points_by_return = rhs.points_by_return;
+ returns_of_given_pulse = rhs.returns_of_given_pulse;
+ min = rhs.min;
+ max = rhs.max;
+ m_header = rhs.m_header;
+ bHaveHeader = rhs.bHaveHeader;
+ return *this;
+void CoordinateSummary::AddPoint(liblas::Point const& p)
+ count++;
+ if (first) {
+ min = p;
+ max = p;
+ // We only summarize the base dimensions
+ // but we want to be able to read/set them all. The
+ // point copy here would set the header ptr of min/max
+ // to be whatever might have come off of the file,
+ // and this may/may not have space for time/color
+ // If we do have scale/offset values, we do want to keep those,
+ // however.
+ liblas::HeaderPtr hdr = p.GetHeaderPtr();
+ if (hdr.get())
+ // Keep scale/offset values around because we need these
+ liblas::Header header;
+ header.SetScale(hdr->GetScaleX(), hdr->GetScaleY(), hdr->GetScaleZ());
+ header.SetOffset(hdr->GetOffsetX(), hdr->GetOffsetY(), hdr->GetOffsetZ());
+ liblas::HeaderPtr h(new liblas::Header(header));
+ min.SetHeaderPtr(h);
+ max.SetHeaderPtr(h);
+ } else
+ min.SetHeaderPtr(HeaderPtr());
+ max.SetHeaderPtr(HeaderPtr());
+ first = false;
+ min.SetX(std::min(p.GetX(), min.GetX()));
+ max.SetX(std::max(p.GetX(), max.GetX()));
+ min.SetY(std::min(p.GetY(), min.GetY()));
+ max.SetY(std::max(p.GetY(), max.GetY()));
+ min.SetZ(std::min(p.GetZ(), min.GetZ()));
+ max.SetZ(std::max(p.GetZ(), max.GetZ()));
+ points_by_return[p.GetReturnNumber()]++;
+ returns_of_given_pulse[p.GetNumberOfReturns()]++;
+void CoordinateSummary::SetHeader(liblas::Header const& h)
+ m_header = h;
+ bHaveHeader = true;
+ptree CoordinateSummary::GetPTree() const
+ ptree pt;
+ ptree pmin = min.GetPTree();
+ ptree pmax = max.GetPTree();
+ pt.add_child("minimum", pmin);
+ pt.add_child("maximum", pmax);
+ ptree returns;
+ bool have_returns = false;
+ for (boost::array<boost::uint32_t,8>::size_type i=0; i < points_by_return.size(); i++) {
+ if (i == 0) continue;
+ if (points_by_return[i] != 0)
+ have_returns = true;
+ returns.put("id", i);
+ returns.put("count", points_by_return[i]);
+ pt.add_child("points_by_return.return", returns);
+ if (! have_returns) {
+ // Assume all points are first return
+ returns.put("id", 1);
+ returns.put("count", count);
+ ptree pulses;
+ for (boost::array<boost::uint32_t,8>::size_type i=0; i < returns_of_given_pulse.size(); i++) {
+ if (returns_of_given_pulse[i] != 0) {
+ pulses.put("id",i);
+ pulses.put("count", returns_of_given_pulse[i]);
+ pt.add_child("returns_of_given_pulse.pulse", pulses);
+ pt.put("count", count);
+ liblas::property_tree::ptree top;
+ if (bHaveHeader)
+ top.add_child("summary.header",m_header.GetPTree());
+ top.add_child("summary.points",pt);
+ return top;
More information about the Liblas-commits
